[General] New CompTIA CAS-004 Test Duration, CAS-004 Exam Questions Answers
100
【General】 New CompTIA CAS-004 Test Duration, CAS-004 Exam Questions Answers
Posted at 2/19/2026 06:10:33      View:89 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New CAS-004 dumps are available on Google Drive shared by Lead2PassExam: https://drive.google.com/open?id=1wZWH6oVI67ynZHd2kuLgGlRI0gBp2B6w
In today's society, many people are busy every day and they think about changing their status of profession. They want to improve their competitiveness in the labor market, but they are worried that it is not easy to obtain the certification of CAS-004. Our study tool can meet your needs. Once you use our CAS-004 exam materials, you don't have to worry about consuming too much time, because high efficiency is our great advantage. You only need to spend 20 to 30 hours on practicing and consolidating of our CAS-004 learning material, you will have a good result. After years of development practice, our CAS-004 test torrent is absolutely the best. You will embrace a better future if you choose our CAS-004 exam materials.
CompTIA CAS-004 exam is a challenging and rigorous exam that requires a comprehensive understanding of security concepts and principles. CAS-004 exam covers a wide range of security topics, including risk management, enterprise security architecture, research and collaboration, and integration of computing, communications, and business disciplines. CAS-004 Exam consists of 90 multiple-choice and performance-based questions that must be completed within 165 minutes. CAS-004 exam is available in English, Japanese, Portuguese, and Simplified Chinese.
Top New CAS-004 Test Duration 100% Pass | Efficient CAS-004: CompTIA Advanced Security Practitioner (CASP+) Exam 100% PassLead2PassExam is proud to announce that our CompTIA CAS-004 exam dumps help the desiring candidates of CompTIA CAS-004 certification to climb the ladder of success by grabbing the CompTIA Exam Questions. Lead2PassExam trained experts have made sure to help the potential applicants of CompTIA Advanced Security Practitioner (CASP+) Exam (CAS-004) certification to pass their CompTIA Advanced Security Practitioner (CASP+) Exam (CAS-004) exam on the first try. Our PDF format carries real CompTIA Advanced Security Practitioner (CASP+) Exam (CAS-004) exam dumps.
CompTIA CAS-004, also known as the CompTIA Advanced Security Practitioner (CASP+) exam, is a certification exam designed for experienced IT professionals who are looking to advance their careers in cybersecurity. CompTIA Advanced Security Practitioner (CASP+) Exam certification validates the knowledge and skills required to conceptualize, design, and implement complex security solutions across a variety of environments. CAS-004 Exam covers a range of topics, including risk management, enterprise security architecture, research and collaboration, and integration of computing, communications, and business disciplines.
CompTIA Advanced Security Practitioner (CASP+) Exam Sample Questions (Q443-Q448):NEW QUESTION # 443
The Chief information Officer (CIO) wants to implement enterprise mobility throughout the organization. The goal is to allow employees access to company resources. However the CIO wants the ability to enforce configuration settings, manage data, and manage both company-owned and personal devices. Which of the following should the CIO implement to achieve this goal?
  • A. CYOD
  • B. BYOO
  • C. MDM
  • D. COPE
NEW QUESTION # 444
A company's software developers have indicated that the security team takes too long to perform application security tasks. A security analyst plans to improve the situation by implementing security into the SDLC. The developers have the following requirements:
1. The solution must be able to initiate SQL injection and reflected XSS attacks.
2. The solution must ensure the application is not susceptible to memory leaks.
Which of the following should be implemented to meet these requirements? (Choose two.)
  • A. Protocol scanner
  • B. SAST
  • C. Side-channel analysis
  • D. DAST
  • E. HTTP interceptor
  • F. Fuzz testing
  • G. SCAP
The combination of DAST (Dynamic Application Security Testing) and SAST (Static Application Security Testing) would meet the developers' requirements. DAST is used for runtime testing, capable of simulating attacks like SQL injection and reflected XSS, which fulfills the first requirement. SAST analyzes the code statically to ensure that the application is not vulnerable to issues like memory leaks, fulfilling the second requirement. Implementing both will integrate security testing into the SDLC, addressing the security concerns earlier in the development cycle, as recommended in CASP+.
NEW QUESTION # 445
An organization's existing infrastructure includes site-to-site VPNs between datacenters. In the past year, a sophisticated attacker exploited a zero-day vulnerability on the VPN concentrator. Consequently, the Chief Information Security Officer (CISO) is making infrastructure changes to mitigate the risk of service loss should another zero-day exploit be used against the VPN solution.
Which of the following designs would be BEST for the CISO to use?
  • A. Using Base64 encoding within the existing site-to-site VPN connections
  • B. Implementing IDS services with each VPN concentrator
  • C. Adding a second redundant layer of alternate vendor VPN concentrators
  • D. Distributing security resources across VPN sites
  • E. Transitioning to a container-based architecture for site-based services
NEW QUESTION # 446
A new web server must comply with new secure-by-design principles and PCI DSS. This includes mitigating the risk of an on-path attack. A security analyst is reviewing the following web server configuration:
Which of the following ciphers should the security analyst remove to support the business requirements?
  • A. TLS_DHE_DSS_WITH_RC4_128_SHA
  • B. TLS_AES_128_GCM_SHA256
  • C. TLS_CHACHA20_POLY1305_SHA256
  • D. TLS_AES_128_CCM_8_SHA256
The security analyst should remove the cipher TLS_DHE_DSS_WITH_RC4_128_SHA to support the business requirements, as it is considered weak and vulnerable to on-path attacks. RC4 is an outdated stream cipher that has been deprecated by major browsers and protocols due to its flaws and weaknesses. The other ciphers are more secure and compliant with secure-by-design principles and PCI DSS. Verified References:
https://www.comptia.org/blog/what-is-a-cipher https://partners.comptia.org/docs/default-source/resources
/casp-content-guide
NEW QUESTION # 447
A company contracts a security consultant to perform a remote white-box penetration test.
The company wants the consultant to focus on Internet-facing services without negatively impacting production services.
Which of the following is the consultant MOST likely to use to identify the company's attack surface? (Choose two)
  • A. Directory service queries
  • B. Web crawler
  • C. Company's firewall ACL
  • D. Internal routing tables
  • E. DNS records
  • F. WHOIS registry
Answer: D,F
NEW QUESTION # 448
CAS-004 Exam Questions Answers: https://www.lead2passexam.com/CompTIA/valid-CAS-004-exam-dumps.html
BTW, DOWNLOAD part of Lead2PassExam CAS-004 dumps from Cloud Storage: https://drive.google.com/open?id=1wZWH6oVI67ynZHd2kuLgGlRI0gBp2B6w
