Posted at 2/19/2026 07:02:34
BONUS!!! 免費下載VCESoft AP-219考試題庫的完整版:https://drive.google.com/open?id=1HZsdL5QrB6f8_FgYbZV-zoZuMIaQOZiV
一般考 Salesforce AP-219 認證兩個目的:一來是學習產品知識;二來通過認證,得到一個可以證明自己能力的東西。如何讓自己一次性通過考試呢?下面向您推薦 VCESoft 考古題。如果你正在準備 Salesforce 的 AP-219 考試,為認證做最後衝刺,又苦於沒有絕對權威的考試真題模擬,AP-219 題庫能助你成功通過考試,獲取認證!
Salesforce AP-219 考試大綱:| 主題 | 簡介 | | 主題 1 | - Process Automation and Integrations: Configuring end-to-end Order Management processes and external system integrations using declarative tools and clicks-based configuration.
| | 主題 2 | - Advanced Topics: Troubleshooting configuration issues, diagnosing system integration problems, and resolving deployment obstacles.
| | 主題 3 | - Data Model: Core objects (Order, Order Summary, Fulfillment Orders, Return Orders), B2C Commerce integrations, and tracing data flow including custom attributes.
| | 主題 4 | - Order Management Basics: Foundation of Order Management within Salesforce ecosystem, platform architecture, integration capabilities with third-party systems, and native Salesforce functionality.
最新的Salesforce AP-219證照考試是行業領先材料&完整的AP-219題庫資訊期待成為擁有AP-219認證的專業人士嗎?想減少您的認證成本嗎?想通過AP-219考試嗎?如果你回答“是”,那趕緊來參加考試吧,我們為您提供涵蓋真實測試的題目和答案的試題。Salesforce的AP-219考古題覆蓋率高,可以順利通過認證考試,從而獲得證書。經過考試認證數據中心顯示,VCESoft提供最準確和最新的IT考試資料,幾乎包括所有的知識點,是最好的自學練習題,幫助您快速通過AP-219考試。
最新的 Salesforce Accredited Professional AP-219 免費考試真題 (Q112-Q117):問題 #112
What two steps are required to add an item to the Actions & Recommendations panel on the Order Summary record page?
- A. Create a New Deployment
- B. Make a new Lightning Record Page
- C. Drag the Actions & Recommendations component on the page
- D. Create a new sub-flow
答案:C,D
解題說明:
Two steps that are required to add an item to the Actions & Recommendations panel on the Order Summary record page are:
Drag the Actions & Recommendations component on the page. The Actions & Recommendations component is a standard component that displays actions and recommendations based on business logic for records in Lightning Experience orSalesforce mobile app. The administrator can use the Lightning App Builder to drag and drop the Actions & Recommendations component onto the Order Summary record page layout.
Create a new sub-flow. A sub-flow is a type of flow that can be invoked by another flow as an element. A sub-flow can contain logic and actions that are specific to a certain scenario or use case, such as order fulfillment or payment processing. The administrator can use Flow Builder to create a new sub-flow that defines the actions and recommendations for Order Summaries, and then add it to the Actions & Recommendations component on the record page.
Verified Reference: https://help.salesforce.com/s/ar ... ions.htm&type=5 https://help.salesforce.com/s/ar ... flow.htm&type=5
問題 #113
An administrator is creating a flow to manage order fulfillment The administrator creates a fault path to handle a possible error. What object record should the administrator create in the fault path to notify users of an error?
- A. Order Summary Exception
- B. OrderError
- C. Process Exception
- D. Fulfillment Error
答案:C
解題說明:
The object record that the administrator should create in the fault path to notify users of an error is Process Exception. A Process Exception is a record thatrepresents an error or exception that occurred during the order lifecycle, such as payment authorization failure, inventory allocation failure, fulfillment location assignment failure, etc. A Process Exception has a lookup relationship to the Order object,and it contains information such as the exception type, status, message, etc. Verified Reference:https://help.salesforce.com/s/ar ... tion.htm&type=5
問題 #114
A customer orders 10 products. The products must be shipped to three different locations. Two of the orders are fulfilled at the same location. How many Fulfillment Orders would be created for this order?
- A. One Fulfillment Order pet destination, totaling 3
- B. One Fulfillment Order per Fulfillment Location, totaling 2
- C. One Fulfillment Order
- D. One Fulfilment Order per item in the order, totaling 10
答案:A
解題說明:
The number of Fulfillment Orders that would be created for this order is one per destination, totaling 3. A Fulfillment Order is a record that represents a group of products in an order that are fulfilled together from the same location. A Fulfillment Order has a lookup relationship to the Order Summary object, and it contains information such as the fulfillment location, delivery method, status, etc. The number of Fulfillment Orders created depends on three factors: Fulfillment Location, Delivery Method and Recipient Address. These factors determine how the Order Items are grouped and allocated to Fulfillment Orders based on routing rules and inventory availability. In this case, since the products must be shippedto three different locations, three Fulfillment Orders are created for each destination. Verified Reference:https://help.salesforce.com/s/ar ... rder.htm&type=5
問題 #115
Universal Containers (UC) has a flow which performs some custom logic in order todetermine a least-cost shipping location. Some of the variables should be reset at the beginning of each loop iteration. Which design element in Flow allows the Admin to do this?
- A. Reset
- B. Reassignment
- C. Assignment
- D. Preset
答案:C
解題說明:
The designelement in Flow that allows the admin to reset some variables at the beginning of each loop iteration is Assignment. An Assignment element lets the admin assign new values to one or more variables or sObject fields in a flow. The admin can use an Assignment element before a Loop element to initialize the variables that are used in the loop, and then use another Assignment element inside the loop to reset the variables for each iteration. Verified Reference: https://help.salesforce.com/s/ar ... ment.htm&type=5[/url]
問題 #116
A developer is creating a flow to generate Fulfillment Orders for Order Summaries. What object is used to generate the Fulfillment Groups?
- A. Fulfillment Summaries
- B. Order Product Summaries
- C. Products
- D. Order Fulfillment Summaries
答案:B
問題 #117
所有購買 VCESoft 題庫學習資料網“Salesforce AP-219 題庫學習資料”的考生,都將獲半年免費升級的售后服務,確保考生一次通過。我们網站的學習資料覆蓋了當前最新的知識點。如果你發現我們的題庫學習資料,存在重大的質量問題,一經核實,我們會無條件退換你的購買費用。事實證明,大多數考生對 Salesforce 的 AP-219 權威考試題庫學習資料充滿信任,如果你不確定,可以免費下載 AP-219 考題學習資料試用版本,這樣方便你了解真實考試軟件界面,熟悉操作流程,讓 AP-219 試題的質量得到保證。
AP-219題庫資訊: https://www.vcesoft.com/AP-219-pdf.html
- AP-219題庫最新資訊 🚖 AP-219考試心得 🚕 AP-219學習指南 🏨 在“ [url]www.kaoguti.com ”搜索最新的➡ AP-219 ️⬅️題庫AP-219熱門考題[/url]
- 100%權威的AP-219證照考試,最好的考試指南幫助妳快速通過AP-219考試 😤 複製網址[ [url]www.newdumpspdf.com ]打開並搜索▶ AP-219 ◀免費下載AP-219熱門考題[/url]
- AP-219考題資訊 🕒 AP-219在線考題 📇 AP-219通過考試 🦨 免費下載⏩ AP-219 ⏪只需進入[ [url]www.vcesoft.com ]網站AP-219題庫最新資訊[/url]
- 選擇我們的高質量的AP-219證照考試:Salesforce Order Management Administrator Accredited Professional,Salesforce AP-219一定會很簡單 🌰 在【 [url]www.newdumpspdf.com 】網站下載免費☀ AP-219 ️☀️題庫收集AP-219熱門考古題[/url]
- 選擇我們的高質量的AP-219證照考試:Salesforce Order Management Administrator Accredited Professional,Salesforce AP-219一定會很簡單 😿 免費下載▷ AP-219 ◁只需進入☀ [url]www.newdumpspdf.com ️☀️網站AP-219最新試題[/url]
- 最熱鬧的Salesforce AP-219證照考試助您輕松通過Salesforce AP-219認證考試 📝 透過“ [url]www.newdumpspdf.com ”輕鬆獲取【 AP-219 】免費下載AP-219認證資料[/url]
- 最新AP-219考題 🐂 AP-219學習指南 😚 AP-219 PDF題庫 🧹 ▷ [url]www.newdumpspdf.com ◁上的免費下載✔ AP-219 ️✔️頁面立即打開AP-219認證資料[/url]
- 準確的AP-219證照考試 |高通過率的考試材料|免費下載AP-219:Salesforce Order Management Administrator Accredited Professional ⏮ 請在《 [url]www.newdumpspdf.com 》網站上免費下載➡ AP-219 ️⬅️題庫AP-219認證資料[/url]
- 選擇我們的高質量的AP-219證照考試:Salesforce Order Management Administrator Accredited Professional,Salesforce AP-219一定會很簡單 😉 ➽ [url]www.pdfexamdumps.com 🢪網站搜索“ AP-219 ”並免費下載AP-219熱門考古題[/url]
- AP-219題庫資訊 💮 AP-219考試備考經驗 🍸 AP-219真題材料 🛺 打開網站➡ [url]www.newdumpspdf.com ️⬅️搜索▶ AP-219 ◀免費下載AP-219最新試題[/url]
- AP-219學習指南 🤒 AP-219認證資料 ✒ AP-219真題材料 🦛 在⮆ [url]www.newdumpspdf.com ⮄上搜索☀ AP-219 ️☀️並獲取免費下載AP-219認證資料[/url]
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.dmb-pla.com, tattoo-workshop25.com, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, lms.blogdu.de, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
順便提一下,可以從雲存儲中下載VCESoft AP-219考試題庫的完整版:https://drive.google.com/open?id=1HZsdL5QrB6f8_FgYbZV-zoZuMIaQOZiV
