[General] Valid F5CAB4 Exam Cost & Reliable F5CAB4 Exam Topics
89
General Valid F5CAB4 Exam Cost & Reliable F5CAB4 Exam Topics
Posted at 2/19/2026 07:36:28      View134 | Replies0        Print      Only Author   [Copy Link] 1#
The clients can consult our online customer service before and after they buy our F5CAB4 study materials. We provide considerate customer service to the clients. Before the clients buy our F5CAB4 study materials they can consult our online customer service personnel about the products version and price and then decide whether to buy them or not. After the clients buy the F5CAB4 study materials they can consult our online customer service about how to use them and the problems which occur during the process of using. If the clients fail in the test and require the refund our online customer service will reply their requests quickly and deal with the refund procedures promptly. In short, our online customer service will reply all of the clients questions about the F5CAB4 Study Materials timely and efficiently.
F5 F5CAB4 Exam Syllabus Topics:
  • List which log files could be used to find events and
  • or hardware issues: This section teaches identification of key log files (
  • var
  • log
  • ltm, secure, audit), understanding event severity levels, and interpreting log messages.
  • Apply procedural concepts required to create, manage, and restore a UCS archive: This domain covers UCS backup and restore procedures, understanding backup use cases, proper storage practices, and UCS file contents including private keys.
  • Identify and report current device status: This domain covers monitoring BIG-IP operational status through LCD panels, dashboards, Network Map, GUI
  • TMSH commands, and checking high availability states.
  • Identify management connectivity configurations: This section focuses on understanding management access configurations, including management IP addresses, port lockdown settings, remote connectivity verification, and troubleshooting access issues.
Topic 5
  • Given a scenario, determine device upgrade eligibility: This domain covers determining appropriate timing for software and platform upgrades and strategies to minimize downtime during upgrades.
Topic 6
  • Explain config sync: This section focuses on configuration synchronization procedures, identifying sync errors, determining sync necessity, checking sync status, and comparing configuration timestamps.
Topic 7
  • Explain authentication methods: This section focuses on user management including creating
  • modifying users, configuring remote authentication providers, and implementing group-based access control.
Topic 8
  • Apply procedural concepts required to manage the state of a high availability pair: This domain covers controlling and monitoring failover states in high availability pairs, including forcing standby
  • offline modes, reporting failover status, and verifying device trust.
Pass Guaranteed Quiz 2026 F5 F5CAB4 Latest Valid Exam CostThe content and design of our F5CAB4 learning quiz are all perfect and scientific, and you will know it when you use this. Of course, we don't need you to spend a lot of time on our F5CAB4 exam questions. As long as you make full use of your own piecemeal time after 20 to 30 hours of study, you can go to the exam. The users of ourF5CAB4 Study Materials have been satisfied with their results. I believe you are the next person to pass the exam!
F5 BIG-IP Administration Control Plane Administration Sample Questions (Q42-Q47):NEW QUESTION # 42
A BIG-IP Administrator needs to check the memory utilization on a BIG-IP system. Which two methods can the BIG-IP Administrator use? (Choose two.)
  • A. Go to Statistics > Module Statistics > Traffic Summary in the configuration utility
  • B. Run the tmsh show /sys traffic command
  • C. Run the tmsh show /sys memory command
  • D. Go to Statistics > Module Statistics > Memory in the configuration utility
Reporting device status includes monitoring physical resource exhaustion, such as memory. The Control Plane provides both a command-line method via TMSH (show /sys memory) and a graphical method under Statistics > Module Statistics > Memory to report on how memory is allocated across TMM and the Linux host494949494949494949. This is essential for identifying potential "Aggressive Mode" triggers or hardware performance bottlenecks50.
NEW QUESTION # 43
Administrative user accounts have been defined on the remote LDAP server and are unable to log in to the BIG-IP device.
Which log file should the BIG-IP Administrator check to find the related messages? (Choose one answer)
  • A. /var/log/user.log
  • B. /var/log/messages
  • C. /var/log/ltm
  • D. /var/log/secure
Comprehensive and Detailed Explanation From BIG-IP Administration Control Plane Administration documents:
When BIG-IP is configured to use remote authentication (such as LDAP), all authentication and authorization attempts-including successes and failures-are logged to /var/log/secure.
For LDAP-based administrative login issues, /var/log/secure contains:
LDAP authentication failures
PAM authentication errors
Authorization and access-denied messages
Details explaining why a remote user could not log in
/var/log/user.log is not a standard BIG-IP log file for authentication.
/var/log/ltm logs traffic management events, not user authentication.
/var/log/messages contains general system messages but not detailed authentication failure information.
Therefore, the correct log file to troubleshoot LDAP administrative login failures is /var/log/secure.
NEW QUESTION # 44
As an organization grows, more people have to log into the BIG-IP. Instead of adding more local users, the BIG-IP Administrator is asked to configure remote authentication against a central authentication server.
Which two types of remote server can be used here? (Choose two answers)
  • A. SAML
  • B. RADIUS
  • C. LDAP
  • D. OAUTH
BIG-IP supports remote authentication by integrating with centralized authentication services through its AAA framework. The supported and commonly used remote authentication servers include:
* LDAP (A)Used to authenticate users against directory services such as Active Directory or other LDAP-compliant directories.
* RADIUS (C)Commonly used for centralized authentication, authorization, and accounting, especially in network and security environments.
* OAUTH (B) is an authorization framework, not supported as a direct administrative authentication backend for BIG-IP management access.
* SAML (D) is primarily used for single sign-on (SSO) in application authentication scenarios, not for BIG-IP administrative login authentication.
Thus, the correct remote authentication server types are LDAP and RADIUS.
NEW QUESTION # 45
Which command will provide the BIG-IP Administrator with the current device HA status? (Choose one answer)
  • A. list /cm failover
  • B. show /cm failover-status
  • C. show /sys failover
To determine the current failover (HA) status of a BIG-IP system using tmsh, F5 documentation explicitly states that the administrator should use the following command:
This command displays:
The current failover state (active, standby, or offline)
Detailed failover status information
The operational HA condition of the device within a device group
According to F5 Knowledge Base Article K08452454, the documented procedure for checking failover status is:
Log in to the TMOS Shell (tmsh)
Run show /cm failover-status
A . list /cm failover shows configuration settings, not operational HA status.
B . show /sys failover is not the documented command for checking current failover status and does not align with F5's recommended procedure.
NEW QUESTION # 46
Comprehensive and Detailed Explanation From BIG-IP Administration Control Plane Administration documents: Reporting device status includes monitoring physical resource exhaustion, such as memory48. The Control Plane provides both a command-line method via TMSH (show /sys memory) and a graphical method under Statistics > Module Statistics > Memory to report on how memory is allocated across TMM and the Linux host494949494949494949. This is essential for identifying potential "Aggressive Mode" triggers or hardware performance bottlenecks50.
NEW QUESTION # 47
We provide 3 versions of our F5CAB4 exam torrent and they include PDF version, PC version, APP online version. Each version's functions and using method are different and you can choose the most convenient version which is suitable for your practical situation. For example, the PDF version is convenient for you to download and print our F5CAB4 Test Torrent and is suitable for browsing learning. If you use the PDF version you can print our F5CAB4 guide torrent on the papers. The PC version of our F5CAB4 exam questions can stimulate the real exam's environment.
Reliable F5CAB4 Exam Topics: https://www.exam4tests.com/F5CAB4-valid-braindumps.html
