[General] Salesforce CRT-450 Web-Based Practice Program
101
【General】 Salesforce CRT-450 Web-Based Practice Program
Posted at 2/19/2026 07:54:59      View:132 | Replies:1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of FreeDumps CRT-450 dumps for free: https://drive.google.com/open?id=1vm3PmkzIsAubdWFAV1Bsped2jpfFA3Nr
FreeDumps offers you a full refund if you are not able to pass the CRT-450 certification exams after preparing with our products. The high quality of CRT-450 certification exam preparation products increases your success probability and reduces the chances of failure. The CRT-450 exam preparation products contain all the features to make you ready for embracing success in a first attempt. These CRT-450 Exam Preparation products are updated regularly for guaranteed success. Free demo is also offered to the users for checking the CRT-450 exam preparation products quality.
The Salesforce CRT-450 Exam consists of 60 multiple-choice questions that need to be answered in 105 minutes. To pass the exam, you need to score at least 68%, which means you need to answer at least 41 questions correctly out of the 60 questions.
CRT-450 Test Collection | Reliable CRT-450 Test VoucherAs you know the registration fee for the Salesforce Certified Platform Developer I (CRT-450) certification exam is itself very high, varying between $100 and $1000. And after paying the registration fee for better preparation a candidate needs budget-friendly and reliable Salesforce Certified Platform Developer I (CRT-450) pdf questions. That is why FreeDumps has compiled the most reliable updated CRT-450 Exam Questions with up to 1 year of free updates. The Salesforce CRT-450 practice test can be used right after being bought by the customer and they can avail of the benefits given in the Salesforce Certified Platform Developer I (CRT-450) pdf questions.
Salesforce Certified Platform Developer I Sample Questions (Q175-Q180):NEW QUESTION # 175
A developer must modify the following code snippet to prevent the number of SOQL queries issued from exceeding the platform governor limit. public class without sharing OpportunityService( public static List<OpportunityLineItem> getOpportunityProducts(Set<Id> opportunityIds){ List<OpportunitylineItem> oppLineItems = new List<OpportunityLineItem>(); for(Id thisOppId : opportunityIds){ oppLineItems.addAll([Select Id FROM OpportunityLineItems WHERE OpportunityId = :thisOppId)]; } return oppLineItems; } } The above method might be called during a trigger execution via a Lightning component. Which technique should be implemented to avoid reaching the governor limit?
  • A. Use the System.Limits.getQueries() method to ensure the number of queries is less than 100.
  • B. Refector the code above to perform the SOQL query only if the Set of opportunityIds contains less 100 Ids.
  • C. Refactor the code above to perform only one SOQL query, filtering by the Set of opportunityIds.
  • D. Use the System.Limits.getlimitQueries() method to ensure the number of queries is less than 100.
NEW QUESTION # 176
Which two statements are true about using the @testSetup annotation in an Apex test class? (Choose two.)
  • A. The @testSetup annotation cannot be used when the @isTest(SeeAllData=True) annotation is used.
  • B. Test data is inserted once for all test methods in a class.
  • C. The @testSetup method is automatically executed before each test method in the test class is executed.
  • D. Records created in the @testSetup method cannot be updates in individual test methods.
NEW QUESTION # 177
Which two roll-up summary field types are required to find the average of values on detail records in a Master-Detail relationship?
  • A. Roll-up summary field of type TOTAL
  • B. Roll-up summary field of type COUNT
  • C. Roll-up summary field of type SUM
  • D. Roll-up summary field of type NUM
NEW QUESTION # 178
(Full question statement)
A developer is tasked with building a custom Lightning Web Component (LWC) to collectContactinformation. The form will be shared among different types of users in the org. There are security requirements stating that only certain fields should beeditable and visibleto certain groups of users.
What should the developer use in their Lightning Web Component to support the security requirements?
  • A. force:inputField
  • B. lightning-input-field
  • C. aura:input
  • D. ui:inputField
A (Correct):lightning-input-field is part ofLightning Data Service (LDS), and itautomatically enforces field- level security (FLS)and CRUD rules. This is thebest practicefor handling sensitive data in LWC forms and ensures compliance with user-level permissions.
Incorrect options:
B:force:inputField is used inAura, not in Lightning Web Components.
C/D:These are deprecated or older framework components that donotinherently enforce FLS.
ReferenceWC Developer Guide - lightning-input-field
This topic relates toUser Interface (25%)andsecurity in LWC development, a key concept in the PD1 exam.
NEW QUESTION # 179
Which three statements are accurate about debug logs?
Choose 3 answers
  • A. Debug log levels are cumulative, where FINE log level includes all events logged at the DEBUG, INFO, WARN, and ERROR levels.
  • B. Only the 20 most recent debug logs for a user are kept.
  • C. Debug logs can be set for specific users, classes, and triggers.
  • D. The maximum size of 3 debug log is 5 MB.
  • E. A System debug logs are retained for 24 hours.
Answer: A,B,E
The accurate statements about debug logs are:
Option A: System debug logs are retained for 24 hours.
"Debug logs are retained for 24 hours. After that, they're deleted."
- Salesforce Help: View Debug Logs
Option B: Only the 20 most recent debug logs for a user are kept.
"A maximum of 20 debug logs are retained for each user. If there are already 20 logs, the oldest log is overwritten."
- Salesforce Help: Log Limits
Option C: Debug log levels are cumulative, where FINE log level includes all events logged at the DEBUG, INFO, WARN, and ERROR levels.
"Each log level includes all events with higher severities. For example, the DEBUG level includes ERROR, WARN, and INFO events."
- Salesforce Developer Guide: Trace Flags
Why Other Options Are Incorrect:
Option D: While you can set debug logs for specific users, you cannot set them directly for specific classes and triggers. Instead, you use trace flags associated with users, Apex classes, or Apex triggers.
Option E: The maximum size of a debug log is 20 MB, not 5 MB.
"When the debug log exceeds the 20 MB maximum size, Salesforce truncates the log. Truncated logs end with a message similar to '... truncated'."
- Salesforce Help: Debug Log Limits
NEW QUESTION # 180
If you have the certification the exam, you can enter a better company, and your salary will also be doubled. CRT-450 training materials can help you pass the exam and obtain corresponding certification successfully. CRT-450 exam materials are edited by experienced experts, and they possess the professional knowledge for the exam, and you can use it with ease. We have online and offline chat service, they possess the professional knowledge for the exam, and you can consult them any questions that bothers you. We offer you free update for one year for CRT-450 Exam Dumps, and our system will send the latest version to you automatically.
CRT-450 Test Collection: https://www.freedumps.top/CRT-450-real-exam.html
What's more, part of that FreeDumps CRT-450 dumps now are free: https://drive.google.com/open?id=1vm3PmkzIsAubdWFAV1Bsped2jpfFA3Nr
Posted at 2/20/2026 10:42:12        Only Author  2#
MogiExamのC-P2W43-2023問題集は多くの受験生に検証されたものですから、高い成功率を保証できます。もしこの問題集を利用してからやはり試験に不合格になってしまえば、MogiExamは全額で返金することができます。あるいは、無料で試験C-P2W43-2023問題集を更新してあげるのを選択することもできます。こんな保障がありますから、心配する必要は全然ないですよ。
