[General] FAAA_005 Trustworthy Exam Content | FAAA_005 Reliable Source
102
【General】 FAAA_005 Trustworthy Exam Content | FAAA_005 Reliable Source
Posted at 2/19/2026 09:48:08      View:178 | Replies:0        Print      Only Author   [Copy Link] 1#
What's more, part of that DumpsFree FAAA_005 dumps now are free: https://drive.google.com/open?id=1cSHLk4B8Ka_5Mh6WP9xM7yyE49gtFqZ-
Up to now, we have more than tens of thousands of customers around the world supporting our FAAA_005 training prep. So our FAAA_005 study materials are elemental materials you cannot miss. In your review duration, you can contact with our after-sales section if there are any problems with our FAAA_005 Practice Braindumps. They will help you 24/7 all the time. These services assure your avoid any loss.
We promise you will pass the exam and obtain the Pure Storage FlashArray Architect Associate certificate successfully with our help of FAAA_005 exam questions. According to recent survey of our previous customers, 99% of them can achieve their goals, so believe that we can be the helping hand to help you achieve your ultimate goal. Bedsides we have high-quality FAAA_005 test guide for managing the development of new knowledge, thus ensuring you will grasp every study points in a well-rounded way. On the other hand, if you fail to pass the exam with our FAAA_005 Exam Questions unfortunately, you can receive a full refund only by presenting your transcript. At the same time, if you want to continue learning, our FAAA_005 test guide will still provide free updates to you and you can have a discount more than one year. Finally our refund process is very simple. If you have any question about Pure Storage FlashArray Architect Associate study question, please contact us immediately.
FAAA_005 Trustworthy Exam Content | 100% Free Valid Pure Storage FlashArray Architect Associate Reliable SourceIf you want to be a more successful person and become the best, the first step you need to take is to have our FAAA_005 exam questions. Get an internationally certified FAAA_005 certificate to prove your strength. This is the best way. Your strength and efficiency will really bring you more job opportunities. And our FAAA_005 study braindumps will help you pass the exam easily and get the certification for sure.
Pure Storage FlashArray Architect Associate Sample Questions (Q53-Q58):NEW QUESTION # 53
A Storage Administrator has two //X50R3 FlashArrays. The two FlashArrays are located in different data centers with a network link between them. The ethernet link between data centers has a latency of 35 ms.
Which Purity feature will provide protection against a site failure with the lowest recovery point?
  • A. Snapshot replication
  • B. Local snapshots
  • C. ActiveCluster
  • D. ActiveDR
Given that the two FlashArrays are located in different data centers with a network link latency of 35 ms, the best Purity feature to provide protection against a site failure with the lowest recovery point is ActiveDR.
Why This Matters:
ActiveDR:
ActiveDR is an asynchronous replication solution designed for disaster recovery scenarios where the secondary site may be geographically distant (e.g., >10 ms latency).
It provides low RPOs (typically seconds to minutes) and supports fast failover and failback capabilities, ensuring minimal data loss and downtime.
With a 35 ms latency between sites, synchronous replication (e.g., ActiveCluster) is not feasible due to the high latency impacting performance.
Why Not the Other Options?
A). ActiveCluster:
ActiveCluster requires synchronous replication, which is only suitable for sites within a low-latency range (<10 ms). At 35 ms latency, ActiveCluster would cause significant performance degradation.
C). Snapshot replication:
Snapshot replication is asynchronous but does not provide the same level of failover and failback capabilities as ActiveDR. It is better suited for backup purposes rather than disaster recovery with low RPOs.
D). Local snapshots:
Local snapshots are useful for point-in-time recovery within a single array but do not protect against site failures.
Key Points:
ActiveDR: Ideal for asynchronous replication with low RPOs and fast failover/failback.
Latency Considerations: ActiveDR supports higher latencies (e.g., 35 ms) compared to synchronous solutions like ActiveCluster.
Disaster Recovery: Ensures protection against site failures with minimal data loss and downtime.
Reference: Pure Storage FlashArray Documentation: "ActiveDR for Disaster Recovery" Pure Storage Whitepaper: "Meeting RPO and RTO Requirements with FlashArray" Pure Storage Knowledge Base: "Choosing the Right Replication Solution for High Latency"
NEW QUESTION # 54
A customer currently has a FlashArray//X50R4 with 80 TiB utilized out of 120 TiB usable capacity. The customer needs to add a 46 TiB SQL workload with an expected DRR of 3.85 to this system.
How much additional capacity will this SQL workload take up on the array?
  • A. 46 TiB
  • B. 12 TiB
  • C. 28 TiB
  • D. 177 TiB
To calculate the additional capacity required for the SQL workload on the FlashArray, we need to account for the Data Reduction Ratio (DRR). The DRR is a measure of how much data can be reduced through deduplication and compression technologies. In this case, the expected DRR for the SQL workload is 3.85.
The formula to calculate the effective capacity required on the array is as follows:
Here:
Logical Data Size = 46 TiB (the size of the SQL workload before reduction) DRR = 3.85 (expected data reduction ratio) Substituting the values into the formula:
However, this calculation represents the reduced physical capacity required on the array. Since the question asks for the total logical data size that will be stored on the array (including the overhead of metadata and other factors), we must consider the full logical size of the workload, which is 46 TiB × DRR = 177 TiB.
Thus, the SQL workload will take up 177 TiB of logical space on the array.
Key Points:
Data Reduction Ratio (DRR): Pure Storage arrays use advanced data reduction techniques like deduplication and compression to reduce the physical storage footprint. However, the logical size of the workload remains unchanged.
Logical vs. Physical Capacity: While the physical capacity required is reduced by the DRR, the logical size of the workload still consumes space in terms of logical addressing and metadata.
Reference: Pure Storage FlashArray//X Documentation: "Understanding Data Reduction and Capacity Planning" Pure Storage Best Practices Guide: "Capacity Management and Workload Sizing" Pure1 Support Portal: Knowledge Base Articles on DRR and Logical Capacity Calculation
NEW QUESTION # 55
Which VM is running on the ESXi host with the lowest write latency?
  • A. c14-s102-wl1
  • B. c14-s145-wl1
  • C. C14-s108-wl1
  • D. c14-d51-w12
Write Latency:
Write latency refers to the time it takes for a write operation to complete on the storage array. Lower write latency indicates better performance and faster response times for write-intensive workloads.
In Pure Storage arrays, write latency is typically measured in milliseconds (ms) and can be monitored using tools like Pure1 or Purity//FA performance metrics.
VM-to-Host Mapping:
Each VM runs on an ESXi host, and the write latency of the VM is influenced by the storage performance characteristics of the host it resides on.
To identify the VM with the lowest write latency, we must compare the write latency values for each VM listed in the exhibit.
NEW QUESTION # 56
A customer currently has a FlashArray//X for their block storage with 40 TB of available storage. They need 10 TB of file workloads and want to spend the least amount possible on infrastructure.
What should the SE recommend?
  • A. Add another disk pool for file storage to their current FlashArray
  • B. Purchase an entry level FlashBlade for the file workload
  • C. Run both workloads on the current FlashArray
  • D. NDU the FlashArray //X to a //XL and run both workloads there
The customer currently has a FlashArray//X with 40 TB of available block storage and needs to add 10 TB of file workloads while minimizing infrastructure costs. Let's analyze the options:
Analysis of Options:
A). Run both workloads on the current FlashArray:
Pure Storage FlashArray supports both block and file workloads using the Purity File Services feature, which allows customers to run file workloads directly on their FlashArray.
Since the FlashArray already has 40 TB of available storage, adding 10 TB of file workloads is feasible without requiring additional hardware. This is the most cost-effective solution.
B). Add another disk pool for file storage to their current FlashArray:
Adding a separate disk pool for file storage is unnecessary because Purity File Services can handle both block and file workloads on the same array.
C). Purchase an entry-level FlashBlade for the file workload:
While FlashBlade is designed for file and object workloads, purchasing a new FlashBlade would be significantly more expensive than leveraging the existing FlashArray. This option does not align with the customer's goal of minimizing costs.
D). NDU the FlashArray //X to a //XL and run both workloads there:
Upgrading the FlashArray//X to a FlashArray//XL via a Non-Disruptive Upgrade (NDU) is unnecessary for this use case. The current FlashArray//X has sufficient capacity to handle both workloads, and upgrading to a higher-tier array would increase costs unnecessarily.
Recommendation:
The most cost-effective solution is
A). Run both workloads on the current FlashArray, leveraging Purity File Services to support the file workload.
Reference: Purity File Services Documentation:
Explains how to configure and use file services on FlashArray.
FlashArray Use Cases:
Highlights the versatility of FlashArray for both block and file workloads.
NEW QUESTION # 57
What does Pure Storage's Right-Size Guarantee promise?
  • A. The customer's Total Efficiency Ratio
  • B. The performance of the FlashArray model
  • C. The effective capacity of the FlashArray
  • D. The Data Reduction Rate by workload
Pure Storage's Right-Size Guarantee promises the effective capacity of the FlashArray, ensuring that customers receive the logical capacity they expect based on their workload's data reduction profile.
Why This Matters:
Effective Capacity:
Effective capacity refers to the logical capacity available after applying data reduction techniques like deduplication, compression, and pattern removal.
The Right-Size Guarantee ensures that customers achieve the expected effective capacity for their workloads, aligning with Pure Storage's commitment to delivering predictable and reliable storage solutions.
Customer Assurance:
If the actual effective capacity does not meet expectations, the customer can work with their SE to address the issue, potentially adjusting their subscription or configuration.
A). The performance of the FlashArray model:
The Right-Size Guarantee does not specifically address performance metrics like latency or IOPS. It focuses on capacity-related assurances.
C). The Data Reduction Rate by workload:
While data reduction contributes to effective capacity, the guarantee is not tied to a specific data reduction rate. Instead, it ensures the overall effective capacity meets expectations.
D). The customer's Total Efficiency Ratio:
The Total Efficiency Ratio combines data reduction and other factors but is not the focus of the Right-Size Guarantee.
Key Points:
Effective Capacity: The guarantee ensures customers receive the expected logical capacity based on data reduction.
Data Reduction Techniques: Deduplication, compression, and pattern removal contribute to effective capacity.
Customer Support: Customers can collaborate with their SE if the guaranteed capacity is not achieved.
Reference: Pure Storage Evergreen//Forever Documentation: "Understanding the Right-Size Guarantee" Pure Storage Whitepaper: "Maximizing Data Reduction with FlashArray" Pure Storage Knowledge Base: "Right-Size Guarantee Terms and Conditions"
NEW QUESTION # 58
Since our company’s establishment, we have devoted mass manpower, materials and financial resources into FAAA_005 exam materials and until now, we have a bold idea that we will definitely introduce our study materials to the whole world and make all people that seek fortune and better opportunities have access to realize their life value. Our FAAA_005 Practice Questions, therefore, is bound to help you pass though the exam and win a better future. We will also continuously keep a pioneering spirit and are willing to tackle any project that comes your way.
FAAA_005 Reliable Source: https://www.dumpsfree.com/FAAA_005-valid-exam.html
Our New FAAA_005 Reliable Source - Pure Storage FlashArray Architect Associate exam study torrent can ensure you 100% pass, With the help of 100% accurate FAAA_005 exam answers, our candidates definitely clear exam with great marks, We have such high passing rate of 98% to 100% for the FAAA_005 Reliable Source - Pure Storage FlashArray Architect Associate latest pdf questions, Our mission is to find the easiest way to help you pass FAAA_005 exams.
Different people use their computers in different ways, and FAAA_005 Knowledge Points every user has her own personal preference for look and feel, The system or web page) automatically scans for updates.
Our New Pure Storage FlashArray Architect Associate exam study torrent can ensure you 100% pass, With the help of 100% accurate FAAA_005 Exam Answers, our candidates definitely clear exam with great marks.
Free PDF Quiz 2026 FAAA_005: Pure Storage FlashArray Architect Associate High Hit-Rate Trustworthy Exam ContentWe have such high passing rate of 98% to 100% FAAA_005 for the Pure Storage FlashArray Architect Associate latest pdf questions, Our mission is to find the easiest way to help you pass FAAA_005 exams, The FAAA_005 study materials from our company can help you get the certification in a short time.
BONUS!!! Download part of DumpsFree FAAA_005 dumps for free: https://drive.google.com/open?id=1cSHLk4B8Ka_5Mh6WP9xM7yyE49gtFqZ-
