[Hardware] OGEA-101指南 - OGEA-101試題
102
【Hardware】 OGEA-101指南 - OGEA-101試題
Posted at 2/19/2026 11:35:44      View:106 | Replies:0        Print      Only Author   [Copy Link] 1#
此外,這些KaoGuTi OGEA-101考試題庫的部分內容現在是免費的:https://drive.google.com/open?id=1brjFYj8C2y-Tmqze8Qbde8z4SIrsgC8Y
想要通過OGEA-101認證考試並不是僅僅依靠與考試相關的書籍就可以辦到的。與其盲目地學習考試要求的相關知識,不如做一些有價值的試題。一本高效率的考古題是大家準備考試時必不可少的工具。所以,快點購買KaoGuTi的OGEA-101考古題吧。這是一本命中率很高的考古題,比其他任何學習方法都有效。这是可以保证你一次就成功的难得的资料。
The Open Group OGEA-101 考試大綱:
主題簡介
主題 1
  • Architecture Governance: This topic of The Open Group OGEA-101 exam covers the governance framework and responsibilities of architecture boards. It evaluates the skills of TOGAF practitioners in establishing governance structures.
主題 2
  • Information Systems Architecture: Focusing on data and application architectures, this topic of the OGEA-101 exam assesses ability of TOGAF practitioners to define and manage information systems. It measures their skills in identifying data entities and application components.
主題 3
  • ADM Phase Requirements: This topic of the TOGAF Enterprise Architecture Part 1 exam focuses on the specific requirements for each ADM phase, including stakeholder identification and architecture scope definition. It measures the ability of aspiring TOGAF Practitioner to apply these requirements in real-world scenarios.
主題 4
  • Business Architecture: This topic of The Open Group OGEA-101 exam emphasizes the development of business architecture, including baseline and target architectures. It measures the understanding of TOGAF practitioners about business capabilities and processes.
主題 5
  • Fundamental Concepts of Enterprise Architecture: This topic covers the definition, purpose, and benefits of enterprise architecture, emphasizing its role in aligning business objectives with IT strategies. It measures the understanding of TOGAF practitioners about foundational principles essential for effective enterprise architecture practice, crucial for passing the OGEA-101 exam.
The Open Group OGEA-101試題 - OGEA-101認證題庫通過OGEA-101 考試不是很簡單的。通過OGEA-101考試需要高度專業的知識,如果你還欠缺這方面的知識,KaoGuTi可以為你提供知識的來源。KaoGuTi的專家團隊以他們的豐富的專業知識和經驗幫助你增長知識,並且給你能提供OGEA-101認證考試的相關練習題和答案。KaoGuTi會盡全力幫助你一次性通過OGEA-101認證考試,並且還可以鞏固你的IT專業知識。選擇了KaoGuTi不僅可以保證你100%通過OGEA-101認證考試,並且還會為你提供一年的免費的練習題和答案的更新服務。如果你考試不小心失敗了,我們保證立刻地100%全額退款給您。
最新的 Enterprise Architecture OGEA-101 免費考試真題 (Q143-Q148):問題 #143
Consider the following ADM phases objectives.
Which phase does each objective match?
  • A. 1G-2E-3F-4F
  • B. 1F-2E-3F-4G
  • C. 1E-2F-3E-4F
  • D. 1E-2E-3F-4F
答案:A
問題 #144
Consider the following statement.
Projects may cycle between ADM phases, in planned cycles covering multiple phases.
What does it illustrate?
  • A. Requirements management
  • B. Enterprise Architecture
  • C. Iteration
  • D. Implementation governance
答案:C
解題說明:
The statement "Projects may cycle between ADM phases, in planned cycles covering multiple phases" illustrates the concept of iteration, which is the process of repeating the ADM phases or steps within a phase to refine the architecture outputs and address the changing requirements and stakeholder concerns. Iteration can occur at different levels of granularity and scope, such as within a single phase, across multiple phases, or across the entire ADM cycle. Iteration can also be applied to different architecture domains, such as business, data, application, and technology. Iteration is a key feature of the ADM that enables the development of architectures that are fit for purpose, adaptable, and responsive to change. References: : The TOGAF Standard, Version 9.2, Part III: ADM Guidelines and Techniques, Chapter 24: Applying Iteration to the ADM
問題 #145
Which of the following best describes the need for the ADM process to be governed?
  • A. To verify that the method is being applied correctly
  • B. To enable development of reference architectures
  • C. To enable a fast response to market changes
  • D. To permit the architecture domains to be integrated
答案:A
解題說明:
According to the TOGAF standard, the need for the ADM process to be governed is to ensure that the architecture development and implementation activities are conducted in a consistent, coherent, and compliant manner1. Governance provides the means to verify that the method is being applied correctly and effectively, and that the architecture deliverables and artifacts meet the quality and standards criteria1. Governance also enables the management of risks, issues, changes, and dependencies that may arise during the ADM process1.
Some of the benefits of governing the ADM process are2:
*Improved alignment of the architecture with the business strategy and objectives
*Enhanced stakeholder engagement and communication
*Increased reuse and integration of architecture assets and resources
*Reduced complexity and duplication of architecture efforts
*Increased agility and adaptability of the architecture to changing needs and requirements
*Improved compliance and auditability of the architecture outcomes and outputs References: 1: Architecture Governance 2: Architecture Governance Benefits
問題 #146
Consider the following statements
1 A whole corporation or a division of a corporation
2 A government agency or a single government department
3 Partnerships and alliances of businesses working together such as a consortium or supply chain What are those examples of according to the TOGAF Standard?
  • A. Organizations
  • B. Architectures Scopes
  • C. Enterprises
  • D. Business Units
答案:C
解題說明:
Enterprises are examples of the scope of an architecture according to the TOGAF Standard. An enterprise is defined as any collection of organizations that has a common set of goals and/or a single bottom line. Enterprises can be whole corporations or divisions of a corporation, government agencies or single government departments, partnerships and alliances of businesses working together, etc. Reference: The TOGAF Standard | The Open Group Website, Section 2.1 Core Concepts.
問題 #147
Which one of the following classes of information within the Architecture Repository would typically contain a list of the applications in use within the enterprise?
  • A. Architecture Landscape
  • B. Governance Log
  • C. Architecture Metamodel
  • D. Reference Library
答案:A
解題說明:
The Architecture Landscape is a class of information within the Architecture Repository that shows an architectural view of the building blocks that are in use within the organization today (the Baseline Architecture), as well as those that are planned for the future (the Target Architecture). The Architecture Landscape typically contains a list of the applications in use within the enterprise, along with their relationships and dependencies, as well as other relevant architectural information. The Architecture Landscape helps to identify opportunities for re-use, consolidation, or retirement of existing applications, as well as gaps or overlaps in the current or future architecture.
問題 #148
與 KaoGuTi考古題的超低價格相反,KaoGuTi提供的OGEA-101考試考古題擁有最好的品質。而且更重要的是,KaoGuTi為你提供優質的服務。只要你支付了你想要的考古題,那麼你馬上就可以得到它。KaoGuTi網站有你最需要的,也是最適合你的考試資料。你購買了OGEA-101考古題以後還可以得到一年的免費更新服務,一年之內,只要你想更新你擁有的資料,那麼你就可以得到最新版。KaoGuTi盡最大努力給你提供最大的方便。
OGEA-101試題: https://www.kaoguti.com/OGEA-101_exam-pdf.html
BONUS!!! 免費下載KaoGuTi OGEA-101考試題庫的完整版:https://drive.google.com/open?id=1brjFYj8C2y-Tmqze8Qbde8z4SIrsgC8Y
