[General] OGBA-101 New Cram Materials & Pdf OGBA-101 Exam Dump
108
【General】 OGBA-101 New Cram Materials & Pdf OGBA-101 Exam Dump
Posted at 2/19/2026 12:42:35      View:122 | Replies:0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest ITCertMagic OGBA-101 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1l1pc6j3i2QOXXo2M1FTIZETHp7zTxc07
At the moment you come into contact with our OGBA-101 learning guide you can enjoy our excellent service. You can ask our staff about what you want to know. After full understanding, you can choose to buy our OGBA-101 exam questions. If you use the OGBA-101 study materials, you have problems that you cannot solve. Just contact with us via email or online, we will deal with you right away. And we offer 24/7 online service. So if you have any problem, you can always contact with us no matter any time it is.
Sometime, most candidates have to attend an exam, they may feel nervious and don't know what to do. If you happen to be one of them, our OGBA-101 learning materials will greatly reduce your burden and improve your possibility of passing the exam. Our advantages of time-saving and efficient can make you no longer be afraid of the OGBA-101 Exam, and you will find more about the benefits of our OGBA-101 exam questions later on.
The Open Group OGBA-101 Guaranteed Success with Satisfied Customers and 24/7 Support SystemAs long as you are willing to buy our OGBA-101 preparation exam, coupled with your careful preparation, we can guarantee that you will get the OGBA-101 certification for sure for we have been the brand in this field and welcomed by tens of thousands of our customers. Not only save you a lot of time and energy, but also can make your mood no longer anxious on the coming OGBA-101 Exam. So, for your future development, please don't hesitate to use our OGBA-101 actual exam.
The Open Group TOGAF Business Architecture Foundation Exam Sample Questions (Q55-Q60):NEW QUESTION # 55
Which of the following best describes this diagram?
  • A. Business Capabilities Layer diagram
  • B. Business Capability Map
  • C. Business Relationships diagram
  • D. Business Capability/Value Stream Mapping
The diagram presented is best described as a Business Capability Map. Here's a detailed explanation:
Business Capability Map:
Definition: A Business Capability Map represents the various capabilities an organization requires to deliver its products and services and achieve its strategic objectives. It typically categorizes capabilities into different levels or tiers, such as strategic, core, and supporting capabilities.
Diagram Analysis:
Layers and Groupings: The diagram shows capabilities grouped into three categories: Strategic, Core, and Supporting. Each group lists specific business capabilities necessary for the organization's functioning.
Color Coding: The use of different colors (green, red, yellow, purple) may indicate various aspects such as priority, status, or different business units. However, the primary purpose is to visually represent and categorize capabilities.
TOGAF Reference:
Phase B: Business Architecture: In this phase, creating a Business Capability Map is a crucial activity. It helps in understanding the business functions and aligning them with strategic goals.
Capability-Based Planning: TOGAF promotes capability-based planning, which involves identifying, mapping, and analyzing business capabilities to ensure they support the overall strategy and objectives.
Purpose and Benefits:
Strategic Alignment: The Business Capability Map helps in aligning business capabilities with the strategic objectives of the organization. It provides a clear view of what the organization needs to do to achieve its goals.
Gap Analysis: It is useful for conducting gap analysis by comparing current capabilities with the desired state, helping to identify areas for improvement.
Resource Allocation: By understanding the different capabilities, organizations can allocate resources more effectively to areas that need development or enhancement.
In summary, the diagram is best described as a Business Capability Map because it visually represents and categorizes the various capabilities needed by the organization into strategic, core, and supporting layers, aligning them with the business strategy and objectives.
NEW QUESTION # 56
What process is used to decompose a set of business capabilities to communicate more detail?
  • A. Leveling
  • B. Sorting
  • C. Mapping
  • D. Layering
The process used to decompose a set of business capabilities to communicate more detail is leveling6. Leveling is a technique that can be used to break down a business capability into sub-capabilities at lower levels of granularity6. Leveling can help to provide more clarity and specificity about what a business capability entails and how it supports the business goals and objectives6. Leveling can also help to identify dependencies, gaps, overlaps, or redundancies among business capabilities6.
NEW QUESTION # 57
Which approach to modeling business value is designed to create and end-to-end perspective of value from the customer's perspective?
  • A. Value networks
  • B. Lean value streams
  • C. Value chains
  • D. Value streams
A value stream is an approach to modeling business value that focuses on the end-to-end sequence of activities that an organization performs to deliver a product or service to the customer. This perspective is designed to help organizations understand the full lifecycle of value creation, from the initial customer demand to the final delivery of value. It provides a holistic view of the flow of value through the organization and is instrumental in identifying areas of waste and opportunities for improvement to enhance the overall customer experience.
Value streams help in visualizing and optimizing the steps necessary to effect change in the business processes and systems that create value for the customers.
NEW QUESTION # 58
Consider the following statements;
1. A whole corporation or a division of a corporation
2. A government agency or a single government department
3. Partnerships and alliances of businesses working together, such as a consortium or supply chain What are those examples of according to the TOGAF Standard?
  • A. Architectures Scopes
  • B. Organizations
  • C. Enterprises
  • D. Business Units
According to the TOGAF Standard, an enterprise is defined as any collection of organizations that has a common set of goals and/or a single bottom line1. The examples given in the question are all types of enterprises that can be the subject of enterprise architecture1.
In the context of TOGAF, the term 'enterprise' encompasses more than just a single organization. It refers to any collection of organizations that has a common set of goals. This can include, as described in the statements provided, entire corporations or their divisions, government agencies or departments, as well as business partnerships such as consortia or supply chains. TOGAF uses the term 'enterprise' to define the full scope of the entity that is the subject of planning, design, implementation, and operation of an Enterprise Architecture.
NEW QUESTION # 59
Consider the following Business Capability Example:
Which of the following are A and C?
  • A. Actors, Actions.
  • B. Roles, Information.
  • C. Organization. Data.
  • D. Who. What.
According to the TOGAF Business Capabilities Guide V2, a business capability is defined as "the expression or the articulation of the capacity, materials, and expertise an organization needs in order to perform core functions"5. A business capability can be decomposed into four elements: roles, information, processes, and technology5. In the given example, A represents roles and C represents information.
In the context provided in the image, 'A' refers to the roles involved in the recruitment management process, which in this case is the 'User: Recruiter' and the 'Stakeholders: Manager, Candidate Employee'. 'C' refers to the information or data aspects of the process, which includes 'Candidate/Applicant Details', 'Position Descriptions', 'Recruitment Agency Data', and 'Industry Standard Role Definitions'. Thus, 'A' corresponds to 'Roles' and 'C' to 'Information'.
https://pubs.opengroup.org/pocke ... de/main/chap04.html
NEW QUESTION # 60
Our OGBA-101 study materials have won many people’s strong support. And our OGBA-101 learning quiz is famous all over the world. Now, our loyal customers have gained wealth and respect with the guidance of our OGBA-101 learning materials. At the same time, the price is not so high. You totally can afford them. Do not make excuses for your laziness. Please take immediate actions. Our OGBA-101 Study Guide is extremely superior.
Pdf OGBA-101 Exam Dump: https://www.itcertmagic.com/TheOpenGroup/real-OGBA-101-exam-prep-dumps.html
And you will be bound to pass the OGBA-101 exam with them, The Open Group OGBA-101 New Cram Materials if still can’t work, please go to our live support, then we will reset your new password, NO need of second chances, Clear OGBA-101 Exam in first attempt, Users can customize the time and TOGAF Business Architecture Foundation Exam (OGBA-101) questions of The Open Group OGBA-101 practice tests according to their needs, latest TOGAF Business Architecture Foundation Exam OGBA-101 exam sample questions and exam material help you pass TOGAF Business Architecture Foundation Exam exam easily.
Minimizing Your Packing, No other book offers this much OGBA-101 practical guidance on choosing and paying for college now  and no other book will save you as much money!
And you will be bound to pass the OGBA-101 Exam with them, if still can’t work, please go to our live support, then we will reset your new password, NO need of second chances, Clear OGBA-101 Exam in first attempt.
Free PDF Quiz Latest The Open Group - OGBA-101 - TOGAF Business Architecture Foundation Exam New Cram MaterialsUsers can customize the time and TOGAF Business Architecture Foundation Exam (OGBA-101) questions of The Open Group OGBA-101 practice tests according to their needs, latest TOGAF Business Architecture Foundation Exam OGBA-101 exam sample questions and exam material help you pass TOGAF Business Architecture Foundation Exam exam easily.
BTW, DOWNLOAD part of ITCertMagic OGBA-101 dumps from Cloud Storage: https://drive.google.com/open?id=1l1pc6j3i2QOXXo2M1FTIZETHp7zTxc07
