[General] PDII-JPN Latest Exam Pdf, Positive PDII-JPN Feedback
【General】 PDII-JPN Latest Exam Pdf, Positive PDII-JPN Feedback
Posted at 2/19/2026 12:48:32      View:62 | Replies:0        Print      Only Author   [Copy Link] 1#
With the  (PDII-JPN) web-based practice exam, you get the same features as a PDII-JPN desktop practice test software. It includes real Salesforce PDII-JPN exam questions to help you understand each topic. The web-based PDII-JPN Practice Exam is compatible with every operating system including Mac, Linux, iOS, Windows, and Android. This Salesforce PDII-JPN practice exam works fine on Chrome, Internet Explorer, Microsoft Edge, Opera, etc.
Learning at electronic devices does go against touching the actual study. Although our PDII-JPN exam dumps have been known as one of the world's leading providers of exam materials, you may be still suspicious of the content. Therefore, we especially provide several demos for future reference and we promise not to charge you of any fee for those downloading. Then you will know whether it is suitable for you to use our PDII-JPN Test Questions. There are answers and questions provided to give an explicit explanation. We are sure to be at your service if you have any downloading problems'
Free PDF 2026 PDII-JPN: High Hit-Rate  Latest Exam PdfIn the process of preparing the passing test, our PDII-JPN guide materials and service will give you the oriented assistance. We can save your time and energy to arrange time schedule, search relevant books and document, ask the authorized person. As our PDII-JPN study materials are surely valid and high-efficiency, you should select us if you really want to pass exam one-shot. With so many advantages of our PDII-JPN training engine to help you enhance your strength, you will pass the exam by your first attempt!
Salesforce  Sample Questions (Q70-Q75):NEW QUESTION # 70
Lightning コンポーネントから呼び出され、クラスにラップされたデータを返す上記のコントローラ コードを考えてみましょう。
開発者は、クエリがそれぞれ 1 つのレコードを返し、Lightning コンポーネントにエラー処理があることを確認しましたが、コントローラーの getSomeData() を呼び出すときに、コンポーネントは何も返されません。
なにが問題ですか?
  • A. メンバーの名前とオプションは public として宣言しないでください。
  • B. クラス MyDataWrapper のメンバーの名前とオプションにも @AuraEnabled のアノテーションを付ける必要があります。
  • C. メンバーの Name と Option には getter と setter があってはなりません。
  • D. MyDataWrapper などの Apex クラスのインスタンスを Lightning コンポーネントに返すことはできません。
NEW QUESTION # 71
標準コントローラー ページにカスタム機能を追加する場合、またはページ全体で再利用可能な機能が必要な場合、どのタイプのコントローラーが最適ですか?
  • A. カスタムコントローラー
  • B. 標準リスト/セット コントローラー
  • C. 標準コントローラー
  • D. コントローラ拡張
NEW QUESTION # 72
ある企業には、いくつかの異なるオブジェクトといくつかの共通オブジェクトを含むさまざまな Salesforce 組織があり、すべての異なる組織で共通のオブジェクト レコードを作成、取得、更新できる単一の Java アプリケーションを構築したいと考えています。
アプリケーションはどの統合方法を使用する必要がありますか?
  • A. メタデータ APT
  • B. Enterprise WSDL を使用した SOAP API
  • C. パートナー WSDL を使用した SOAP API
  • D. Apex REST Web サービス
The SOAP API with the Partner WSDL is ideal for building integrations that work across multiple Salesforce orgs, especially when they have varying schemas. The Partner WSDL is designed to be flexible and dynamic, catering to different metadata.
References: SOAP API Developer Guide
NEW QUESTION # 73
組織には、Apex コントローラと、ユーザが選択した選択リスト値の組み合わせで構成されるカスタムフィルタを使用してレコードを表示する Visualforce ページがあります。
一部の入力の組み合わせではページに結果が表示されるまでに時間がかかりすぎますが、他の入力の選択肢では「ビュー ステートの最大サイズ制限を超えました」という例外がスローされます。
この問題を解決するには、開発者はどのような手順を実行する必要がありますか?
  • A. ビューステート エラーを回避するために、Apex コントローラから transient キーワードのインスタンスを削除します。
  • B. Apex コントローラで StandardSetController または SOQL LIMIT を使用して、一度に表示されるレコード数を制限します。
  • C. インデックスが作成されていないため、選択リストの値によってフィルタリングするコードを調整します。
  • D. レイアウトを分割して 1 つの Visualforce ページでレコードをフィルタし、同じ Apex コントローラを使用して 2 番目のページにレコードのリストを表示します。
To resolve the issue of the Visualforce page taking too long to display results or exceeding the view state limit, the developer should use a StandardSetController or implement SOQL LIMIT in the Apex controller. This limits the number of records that are processed and displayed at one time, which can prevent view state errors and improve performance.References: Visualforce Developer Guide - StandardSetController
NEW QUESTION # 74
Universal Containers (UC) は翻訳ワークベンチを有効にし、選択リストの値を翻訳しました。UC には、Account オブジェクトにカスタムの複数選択リスト フィールド Product__c があり、営業担当者はこれを使用して、Account がすでに所有している UC の製品を指定できます。開発者は、Product_c 項目を含む取引先レコードを取得する Apex メソッドを作成する必要があります。
Products__c の値が現在のユーザーの言語であることを確認するには、開発者は何をすべきでしょうか?
  • A. SOQL クエリのフィールドリストでラベル ducts__c) を使用します。
  • B. SOQL クエリで Locale 句を使用します。
  • C. SOQL 結果リストの各レコードでtranslate メソッドを呼び出します。
  • D. SOQL 結果リストの各レコードにロケールを設定します。
NEW QUESTION # 75
The more times you choose us, the more discounts you may get. To make your whole experience more comfortable, we also provide considerate whole package services once you make decisions of our PDII-JPN test question. If you have any questions related to our PDII-JPN exam prep, pose them and our employees will help you as soon as possible. It is a mutual benefit job, that is why we put every exam candidates’ goal above ours, and it is our sincere hope to make you success by the help of PDII-JPN Guide question and elude any kind of loss of you and harvest success effortlessly.
Positive PDII-JPN Feedback: https://www.realvalidexam.com/PDII-JPN-real-exam-dumps.html
In order to keep abreast of the times, our company will continuously update our Positive PDII-JPN Feedback -  vce exam dumps, Salesforce PDII-JPN Latest Exam Pdf This format works on Windows-based devices and requires no internet connection, These Salesforce PDII-JPN practice tests are based on the real examination scenario so the students can feel the pressure and learn to deal with it, Salesforce PDII-JPN Latest Exam Pdf GetCertKey provides the most accurate and latest IT exam materials which almost contain all knowledge points.
Processes versus Threads, It's about any engagement with a stakeholder, including PDII-JPN silence, inaction, and action, In order to keep abreast of the times, our company will continuously update our  vce exam dumps.
Excellent PDII-JPN Latest Exam Pdf - Trustworthy & Valuable PDII-JPN Materials Free Download for Salesforce PDII-JPN ExamThis format works on Windows-based devices and requires no internet connection, These Salesforce PDII-JPN Practice Tests are based on the real examination scenario so the students can feel the pressure and learn to deal with it.
GetCertKey provides the most accurate and latest IT exam materials which almost contain all knowledge points, PDII-JPN exam torrent materials are edited by experienced and professional education experts so that most of our on-sale PDII-JPN guide torrent files are valid and latest.
