Using both "mainline" and "stock" linux kernels
638
Posted at 6/3/2015 00:52:17      View4912 | Replies6        Print      Only Author   [Copy Link] 1#
I'd like to make some tests with both "stock" and "mainline" linux kernels. But I'm a real rookie for that matter and I don't want to 'brick' my firefly board...
I don't know if it is possible to define a dual-boot configuration for both kernels residing on the eMMC. Maybe a simpler way to live with both kernels could be to install everything needed for the "mainline" kernel on an SDCARD leaving the eMMC untouched. In the tutorials I've seen at some places on this forum I don't see how I can tell that I want everything written to an SDCARD instead of the eMMC.
What I've done so far is to flash the last u-boot (RK3288UbootLoader_V2.19.01.bin) using upgrade_tool without changing anything else. The stock kernel is still booting. I've also compiled the "mainline" kernel (following the Wiki instructions) but I see that cmdline parameters (tty name, partitions name and size) for the "stock" firefly (dual boot android/linux) are really different than those required for the "mainline" linux kernel.  How are these parameters used? Are they used to create the partitions, or set the size of those partitions? Or are they just a "copy" of sizes determined somewhere else?
I suppose that if I flash the parameters needed by the "mainline" kernel then I won't be able anymore to boot on the "stock" kernel. Right?
Thx
Posted at 1/13/2026 11:47:08        Only Author  2#
Thank you for sharing this inspiring piece, it's really uplifting! Free Valid NCA-GENL test simulator available for boosting your IT skills. Wishing you success!
Posted at 1/16/2026 07:17:12        Only Author  3#
This article is truly magnificent, thank you for sharing your knowledge. Heading into the Related 350-701 Certifications exam soon. Pray for me!
Posted at 1/17/2026 15:23:59        Only Author  4#
Thank you for sharing this incredible article, its truly breathtaking! Level up your IT abilities with free AP-214 reliable study guide pdf. Best of luck to everyone!
restricted members
Posted at 1/25/2026 22:10:09        Only Author  5#
Just had to hit likethis content is so good. Free C_BCSBN_2502 Exam Tests materials availablewishing you all success in your exams!
Posted at 2/3/2026 16:47:29        Only Author  6#
Thank you for your article, it really captured my attention. Free NCP-AIO exam testking resources for exam success. Wishing you the best!
