[General] SAP C-ARSUM-2508考試資訊 - C-ARSUM-2508真題
120
【General】 SAP C-ARSUM-2508考試資訊 - C-ARSUM-2508真題
Posted at 2/19/2026 13:58:10      View:85 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! 免費下載NewDumps C-ARSUM-2508考試題庫的完整版:https://drive.google.com/open?id=1oPDdAwSmdhMaqHLX6g6LPZCgZLZ9Td0v
為了通過SAP C-ARSUM-2508 認證考試,請選擇我們的NewDumps來取得好的成績。你不會後悔這樣做的,花很少的錢取得如此大的成果這是值得的。我們的NewDumps不僅能給你一個好的考試準備,讓你順利通過SAP C-ARSUM-2508 認證考試,而且還會為你提供免費的一年更新服務。
SAP C-ARSUM-2508 考試大綱:
主題簡介
主題 1
  • SAP Ariba Supplier Lifecycle Management Users and Supplier Contacts: This section of the exam measures the skills of Procurement Specialists and covers managing users, supplier contacts, and access roles within Supplier Lifecycle Management. It ensures candidates understand user assignments and supplier collaboration.
主題 2
  • Supplier Lifecycle Management Components: This section of the exam measures the skills of SAP Consultants and covers the various components of Supplier Lifecycle Management. It introduces how each component contributes to onboarding, qualification, and ongoing supplier engagement processes.
主題 3
  • Workspace Template Management: This section of the exam measures the skills of SAP Consultants and covers the setup and use of workspace templates within SAP Ariba. It ensures candidates can apply templates for consistency, efficiency, and compliance across supplier management processes.
主題 4
  • SAP Ariba Supplier Performance Management Surveys and Scorecards: This section of the exam measures the skills of Procurement Specialists and covers creating, managing, and analyzing surveys and scorecards to evaluate supplier performance. It focuses on methods of capturing feedback and structuring supplier evaluations.
主題 5
  • SAP Ariba Supplier Management Portfolio Overview: This section of the exam measures the skills of Procurement Specialists and covers the foundational understanding of the SAP Ariba Supplier Management portfolio. It highlights how the portfolio supports supplier onboarding, qualification, performance tracking, and risk management within enterprise procurement.
SAP C-ARSUM-2508真題 & C-ARSUM-2508熱門考古題NewDumps有很好的的售後服務。如果你選擇購買NewDumps的產品,NewDumps將為你提供每天24小時的線上客戶服務和提供一年的免費更新服務,及時的通知顧客最新的考試資訊讓客戶有充分準備。我們可以讓你花費少量的時間和金錢就可以通過IT認證考試。選擇NewDumps的產品幫助你的第一次參加的SAP C-ARSUM-2508 認證考試是很划算的。
最新的 SAP Certified Associate C-ARSUM-2508 免費考試真題 (Q70-Q75):問題 #70
You applied an update to the Team Member Rules file in a Supplier Performance Management project template and published. However, the project you created two weeks ago does NOT reflect this updated file. Why is this the case?
  • A. The field labels in the file are incorrect.
  • B. A deactivated template was used for the project.
  • C. A user must edit the project and accept the changes.
  • D. The template upgrade option was disabled.
答案:D
問題 #71
Which template type defines assessments for control-based engagement risk projects?
  • A. Modular supplier management questionnaire project templates
  • B. Issue management template
  • C. Supplier qualification template
  • D. Supplier engagement risk project template
答案:A
問題 #72
答案:D
問題 #73
You need to invite suppliers and internal participants to the same survey but would like to restrict their views.
How do you achieve this?
  • A. Map only internal sections and questions to a scorecard.
  • B. Create internal and external surveys.
  • C. Set up access controls on the content to restrict visibility.
  • D. Invite all participants to the event and edit each section that needs to bee restricted.
答案:B
問題 #74
Which of the following is a characteristic of a simple workflow in a control-based engagement risk assessment project?
  • A. All assessments are sent to recipients at the same time.
  • B. Assessments are reviewed through a single approval task.
  • C. Issues are automatically created for all active controls.
  • D. Owners can choose the recipient for each assessment.
答案:A
問題 #75
作為SAP相關認證考試大綱的主要供應商,NewDumps的C-ARSUM-2508專家一直不斷地提供品質較高的產品,不斷為客戶提供免費線上客戶服務,並以最快的速度更新考試大綱。
C-ARSUM-2508真題: https://www.newdumpspdf.com/C-ARSUM-2508-exam-new-dumps.html
從Google Drive中免費下載最新的NewDumps C-ARSUM-2508 PDF版考試題庫:https://drive.google.com/open?id=1oPDdAwSmdhMaqHLX6g6LPZCgZLZ9Td0v
