[General] Exam CTS-I Collection | Reliable CTS-I Test Blueprint
88
【General】 Exam CTS-I Collection | Reliable CTS-I Test Blueprint
Posted at 2/19/2026 15:36:24      View:107 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of DumpsKing CTS-I dumps from Cloud Storage: https://drive.google.com/open?id=1fLtVffk1rvuFrHEEFPDk8UikNKKZVAvk
One of the most effective strategies to prepare for the Certified Technology Specialist - Installation (CTS-I) exam successfully is to prepare with actual AVIXA CTS-I exam questions. It would be difficult for the candidates to pass the CTS-I exam on the first try if the CTS-I study materials they use are not updated. Studying with invalid CTS-I practice material results in a waste of time and money. Therefore, updated AVIXA CTS-I practice questions are essential for the preparation of the CTS-I exam.
AVIXA CTS-I Exam Certification Details:
Exam NameAVIXA Certified Technology Specialist - Installation (CTS-I)
Passing Score350 / 500
MemberExam Price$475(USD)
Number of Questions110
Duration150 mins
Quiz 2026 AVIXA CTS-I: Trustable Exam Certified Technology Specialist - Installation CollectionNowadays, online learning is very popular among students. Most candidates have chosen our CTS-I learning engine to help them pass the exam. Our company has accumulated many experiences after ten years’ development. We never stop researching and developing the new version of the CTS-I practice materials. With our CTS-I study questions, you can easily get your expected certification as well as a brighter future.
AVIXA CTS-I - Installation Exam Syllabus Topics:
TopicWeight
Duty A: Conducting Pre-Installation Activities20%
Task 1: Review Audiovisual Project Documentation4%
Task 2: Conduct Technical Site Survey4%
Task 3: Prepare for Audiovisual Installation4%
Task 4: Evaluate Overall Facility Readiness4%
Task 5: Conduct On-Site Preparations for Installation4%
Duty B: Conducting Site Rough-In/First-Fix10%
Task 1: Deinstallation of Existing Equipment and cabling2%
Task 2: Mount Substructure4%
Task 3: Pull Cable4%
Duty C: Installing Audiovisual Systems38%
Task 1: Assemble AV Rack4%
Task 2: Wire the AV Equipment Rack5%
Task 3: Distribute AV Equipment4%
Task 4: Mount AV Equipment4%
Task 5: Terminate Cables5%
Task 6: Configure Network Properties of Equipment4%
Task 7: Load Configuration and Control Programs4%
Task 8: Test the AV System4%
Task 9: Calibrate the AV System4%
Duty D: Perform Systems Close Out11%
Task 1: Demonstrate to Client or Client's Representative that System Performs to Specifications4%
AVIXA Certified Technology Specialist - Installation Sample Questions (Q397-Q402):NEW QUESTION # 397
Which one of these is an unsafe lift practice?
  • A. Perform the lift slowly; Do not make sudden movements or rotate during the lift
  • B. Do not perform the lift alone; Always have a partner or helper.
  • C. Be sure to keep a firm footing and balance the weight between your feet
  • D. Do not bend your knees and do the lifting with your back.
NEW QUESTION # 398
What type of rack would you use for a room with limited space for servicing equipment?
Response:
  • A. Portable
  • B. Fixed stand-alone
  • C. Wall-mounted
  • D. Built-in
NEW QUESTION # 399
The number of ___ in the primary and secondary sides of a transformer determines the impedance and/or voltage ratio.
  • A. Ohms
  • B. Loudspeaker taps
  • C. Coils of wire
  • D. Unused tap wires
NEW QUESTION # 400
What does 1000Base-T refer to?
Response:
  • A. Ethernet speed of 100 Mbps
  • B. IP speed of 1 Gbps
  • C. Ethernet speed of 1 Gbps
  • D. IP speed of 100 Mbps
NEW QUESTION # 401
When removing existing cabling, the AV technician should:
  • A. Check to see if cable is salvageable
  • B. Make a drawing of how the system is wired
  • C. Start at the device and go to the rack
  • D. Identify and mark what is to be re-used
NEW QUESTION # 402
Reliable CTS-I Test Blueprint: https://www.dumpsking.com/CTS-I-testking-dumps.html
P.S. Free 2026 AVIXA CTS-I dumps are available on Google Drive shared by DumpsKing: https://drive.google.com/open?id=1fLtVffk1rvuFrHEEFPDk8UikNKKZVAvk
