[General] Press Brakes
15
General Press Brakes
Posted at 2/19/2026 17:02:06      View250 | Replies0        Print      Only Author   [Copy Link] 1#
A press brake is a machine tool used in metal fabrication to bend, form, and shape sheet metal and plate into precise angles and complex profiles. It works by pressing a piece of metal between a punch (upper tool) and a die (lower tool), creating controlled bends as dictated by operator settings or computer programming.
Press brakes are fundamental in industries such as automotive, aerospace, shipbuilding, construction, appliance manufacturing, and custom metal fabrication.
How a Press Brake Works
  • Material Placement: A sheet or plate of metal (steel, aluminum, stainless steel, etc.) is positioned on the press brake bed.
  • Tool Selection: The appropriate punch and die set is selected based on the desired bend type.
  • Bending Operation: The ram (upper beam) descends, pressing the punch into the metal against the die, causing it to bend at the desired angle.
  • Control Inputs: Operator sets bend angle, back gauge position, force, and speed either manually or via CNC programming.
  • Completion: After bending, the ram retracts and the finished part is removed.
Types of Press Brakes
Press brakes vary by design, power source, and control method:
1. Mechanical Press Brakes
  • Driven by a flywheel and crank
  • Traditional design
  • High tonnage capacity
  • Good for repetitive, high-force operations
2. Hydraulic Press Brakes
  • Powered by hydraulic cylinders
  • Smooth force delivery
  • Accurate and repeatable bending
  • Most common type in modern fabrication shops
3. CNC (Computer Numerical Control) Press Brakes
  • Digital control for automated bending sequences
  • Excellent precision for complex parts
  • Integrates with design software (CAD/CAM)
  • Reduces operator error and setup time
4. Electric Press Brakes
  • Servo-electric drive systems
  • Energy efficient
  • Fast positioning and repeatability
  • Ideal for medium loads and precision work
Press brake is a versatile and indispensable machine in the sheet metal fabrication industry. Whether used for small jobs in a local workshop or high-precision production in a major manufacturing facility, press brakes provide controlled bending, high repeatability, and excellent productivity. With modern CNC controls and robust tooling options, they remain central to bending operations across automotive, aerospace, construction, and industrial sectors
