[General] Free PDF Quiz ServiceNow - Authoritative CIS-Discovery - Certified Implementatio
91
【General】 Free PDF Quiz ServiceNow - Authoritative CIS-Discovery - Certified Implementatio
Posted at 2/19/2026 18:08:11      View:101 | Replies:0        Print      Only Author   [Copy Link] 1#
What's more, part of that Exam4Tests CIS-Discovery dumps now are free: https://drive.google.com/open?id=1FGBWDn8OK6WlOdaC5mk2VMEARAGtv2XE
If you buy our CIS-Discovery exam questions, we will offer you high quality products and perfect after service just as in the past. We believe our consummate after-sale service system will make our customers feel the most satisfactory. Our company has designed the perfect after sale service system for these people who buy our CIS-Discovery practice materials. We can always give the most professinal suggestion on our CIS-Discovery learning guide to our customers at the first time for our service are working 24/7 online.
The Certified Implementation Specialist - Discovery (CIS-Discovery) prep material is available in three versions. CIS-Discovery Practice exams and PDF questions are available at Exam4Tests so that users can meet their training needs and pass the Certified Implementation Specialist - Discovery (CIS-Discovery) exam on the first try. The philosophy of Exam4Tests behind offering Certified Implementation Specialist - Discovery (CIS-Discovery) prep material in three formats is helping students meet their unique learning needs.
Exam ServiceNow CIS-Discovery Materials & Reliable CIS-Discovery Test CampYou don't have to worry about your problems on our CIS-Discovery exam questions are too much or too simple. Our staff will give you a smile and then answer them carefully. All we do is just want you to concentrate on learning on our CIS-Discovery study guide! Let other things go to us. And as long as you focus on our CIS-Discovery Training Materials, we believe you will pass for sure for our CIS-Discovery practice braindumps are always the latest and valid for all of our customers.
ServiceNow Certified Implementation Specialist - Discovery Sample Questions (Q58-Q63):NEW QUESTION # 58
Port Probe classification priority is specified in the ______ .
Response:
  • A. IP Services module
  • B. Classifier
  • C. Scanner field
  • D. Port Probes module
NEW QUESTION # 59
Which choice represents the three best ways of extending Discovery?
  • A. Orchestration, Classifiers, Probes & Sensors
  • B. Fingerprinting, Classifiers, Discovery Patterns
  • C. Orchestration, Classifiers, Discovery Patterns
  • D. Classifiers, Fingerprinting, Probes & Sensors
  • E. Classifiers, Probes & Sensors, Discovery Patterns
NEW QUESTION # 60
Which of the below choices are benefits of Tracked Configuration Files? (Choose two.)
  • A. Files tracked as CIs
  • B. No credentials needed
  • C. Unwanted files removed from target
  • D. Content version comparison
Tracked configuration files are files that contain settings and parameters of certain applications or devices that Discovery can find and add to the CMDB. Some of the benefits of tracked configuration files are:
* Content version comparison: You can compare the content of different versions of the same configuration file and see the changes that occurred over time. This can help you troubleshoot issues, audit changes, and restore previous configurations if needed.
* Files tracked as CIs: You can view the configuration files as configuration items (CIs) in the CMDB and see their relationships with other CIs, such as the applications or devices they belong to. This can help you understand the dependencies and impact of the configuration files on your IT environment.
1: Configuration file tracking, Modify tracking changes in configuration files
NEW QUESTION # 61
In general, Discovery can provide which of the following kinds of application relationships? (Choose two.)
  • A. host to application
  • B. application to application
  • C. tcp to udp
  • D. mid server to target
Discovery can provide information about the relationships between configuration items (CIs), including applications and hosts. Application relationships are the connections between applications that run on different hosts or servers, such as web servers, databases, load balancers, etc. Host relationships are the connections between applications and the hosts or servers that they run on, such as Windows, Linux, Unix, etc. Discovery can identify these relationships using various methods, such as probes, sensors, patterns, file- based discovery, etc. Discovery can also create and update these relationships in the CMDB, using the Depends on::Used by or Runs on::Runs relationship types.
1: Discovery Relationship Creation, Application Discovery Mapping Overview, IT Discovery - Application Dependency Mapping
NEW QUESTION # 62
A discovery runs against a Windows Server returning the following attribute values for the first time:
name = WindowsSN1 serial_number = 12321
A subsequent discovery is ran against a different Windows Server returning the following attribute values:
name = WindowsSN2
With only base system CI Identifiers configured, which of the following is true?
  • A. A Windows Server CI is created, then updated with WindowsSN1 as the name.
  • B. A Windows Server CI is created, then updated with WindowsSN2 as the name.
  • C. Two Windows Sewer CIs are created, with WindowsSN1 AND WindowsSN2 for names.
  • D. Two Windows Server CIs are created, without serial_number values.
According to the ServiceNow Discovery documentation, the base system CI Identifiers for Windows Server class are name and serial_number. These are the attributes that Discovery uses to uniquely identify a Windows Server CI. If both attributes match an existing CI, Discovery updates that CI. If only one attribute matches, Discovery creates a new CI. If neither attribute matches, Discovery also creates a new CI. In this scenario, the serial_number is the same for both Windows Servers, but the name is different. Therefore, Discovery will create two separate CIs, one with WindowsSN1 as the name and one with WindowsSN2 as the name.
Create a Discovery CI classification - Product Documentation: Tokyo - Now Support Portal Identification rules - Product Documentation: Tokyo - Now Support Portal ServiceNow IRE: Identification Rules Explained - Cookdown
NEW QUESTION # 63
The ServiceNow CIS-Discovery desktop-based practice exam is compatible with Windows-based computers and only requires an internet connection for the first-time license validation. The web-based Certified Implementation Specialist - Discovery (CIS-Discovery) practice test is accessible on any browser without needing to install any separate software. Finally, the Certified Implementation Specialist - Discovery (CIS-Discovery) dumps pdf is easily portable and can be used on smart devices or printed out.
Exam CIS-Discovery Materials: https://www.exam4tests.com/CIS-Discovery-valid-braindumps.html
The passing rate of our CIS-Discovery guide materials is high as 98% to 100% and you don’t need to worry that you have spent money but can’t pass the test, ServiceNow CIS-Discovery Exam You can see an overview of our products on the Sample page, also DEMO for a few selected exams are available on product pages, The updated CIS-Discovery from Exam4Tests engine is a complete package for your CIS-Discovery certification You can use this CIS-Discovery updated lab simulation as well as CIS-Discovery exam papers online.
We are determined to be the best vendor in this career to help more and more candidates to acomplish their dream and get their desired CIS-Discovery certification, To this point, it might seem that there isn't much difference.
Real ServiceNow CIS-Discovery PDF Questions [2026] - Get Success With Best ResultsThe passing rate of our CIS-Discovery Guide materials is high as 98% to 100% and you don’t need to worry that you have spent money but can’t pass the test, You can see an overview of our products CIS-Discovery on the Sample page, also DEMO for a few selected exams are available on product pages.
However, you can't get the CIS-Discovery certification until you pass the CIS-Discovery pdf vce, which is a great challenge for the majority of workers, You can clearly get all the information about our CIS-Discovery study guide.
DOWNLOAD the newest Exam4Tests CIS-Discovery PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1FGBWDn8OK6WlOdaC5mk2VMEARAGtv2XE
