[General] Latest Real DP-300 Exam | Test DP-300 King
【General】 Latest Real DP-300 Exam | Test DP-300 King
Posted at 2/19/2026 20:00:50      View:96 | Replies:0        Print      Only Author   [Copy Link] 1#
What's more, part of that Actualtests4sure DP-300 dumps now are free: https://drive.google.com/open?id=1pwCJpxZ-Dxgf6qyju4yJdf7_xGfO4qZE
The Microsoft job market has become so competitive and challenging. To stay competitive in the market as an experienced IT professional you have to upgrade your skills and knowledge with the Administering Relational Databases on Microsoft Azure (DP-300) certification exam. With the DP-300 exam dumps you can easily prove your skills and upgrade your knowledge. To do this you just need to enroll in the Administering Relational Databases on Microsoft Azure (DP-300) certification exam and put all your efforts to pass this challenging Microsoft DP-300 exam with good scores.
Microsoft DP-300: Great Career ProspectsThe positions that the professionals holding the Microsoft Certified: Azure Database Administrator Associate certification can explore include a SQL Database Administrator, a Data Engineer, a Systems Administrator, a Database Administrator, a Data Analyst, an Azure Data Engineer, and a Data Scientist. The salary outlook for these job titles is an average of $84,000 per annum.
Free PDF DP-300 - Administering Relational Databases on Microsoft Azure Perfect Latest Real ExamActualtests4sure provides accurate and up-to-date Microsoft DP-300 Exam Questions that ensure exam success. With these Microsoft DP-300 practice questions, you can pass the DP-300 exam on the first try. Actualtests4sure understands the stress and anxiety that exam candidates experience while studying. As a result, they provide personalized Microsoft DP-300 Practice Exam material to assist you in efficiently preparing for the exam.
The DP-300 Certification Exam covers a wide range of topics related to database administration, including designing and implementing database solutions on Azure, managing and monitoring databases, ensuring database security, and performing backups and restores. It also covers advanced topics such as designing for high availability and disaster recovery, implementing Azure SQL Database features, and managing Azure Synapse Analytics.
Microsoft Administering Relational Databases on Microsoft Azure Sample Questions (Q171-Q176):NEW QUESTION # 171
You configure backups for an Azure SQL database as shown in the following exhibit.
NEW QUESTION # 172
HOTSPOT
You need to recommend a configuration for ManufacturingSQLDb1 after the migration to Azure. The solution must meet the business requirements.
What should you include in the recommendation? To answer, select the appropriate options in the answer area.
Hot Area:
Section: [none]
Box 1: Node majority with witness
As a general rule when you configure a quorum, the voting elements in the cluster should be an odd number.
Therefore, if the cluster contains an even number of voting nodes, you should configure a disk witness or a file share witness.
Note: Mode: Node majority with witness (disk or file share)
Nodes have votes. In addition, a quorum witness has a vote. The cluster quorum is the majority of voting nodes in the active cluster membership plus a witness vote. A quorum witness can be a designated disk witness or a designated file share witness.
Box 2: Azure Standard Load Balancer
Microsoft guarantees that a Load Balanced Endpoint using Azure Standard Load Balancer, serving two or more Healthy Virtual Machine Instances, will be available 99.99% of the time.
Scenario: Business Requirements
Litware identifies business requirements include: meet an SLA of 99.99% availability for all Azure deployments.
Incorrect Aswers:
Basic Balancer: No SLA is provided for Basic Load Balancer.
Note: There are two main options for setting up your listener: external (public) or internal. The external (public) listener uses an internet facing load balancer and is associated with a public Virtual IP (VIP) that is accessible over the internet. An internal listener uses an internal load balancer and only supports clients within the same Virtual Network.
https://technet.microsoft.com/wi ... eploy-cloud-witness
https://azure.microsoft.com/en-u ... load-balancer/v1_0/
NEW QUESTION # 173
You have an Azure SQL managed instance.
You need to restore a database named DB1 by using Transact-SQL.
Which command should you run? To answer, select the appropriate options in the answer area.
NOTE:Each correct selection is worth one point.
Text Description automatically generated
NEW QUESTION # 174
You need to implement statistics maintenance for SalesSQLDb1. The solution must meet the technical requirements.
1 - Create Azure automation account
2 - Import SQLServer module
3 - Create a runbook that runs a PowerShell script.
4 - Create and configure a schedule.
https://techcommunity.microsoft. ... e-using/ba-p/368974
NEW QUESTION # 175
You are designing an enterprise data warehouse in Azure Synapse Analytics that will store website traffic analytics in a star schema.
You plan to have a fact table for website visits. The table will be approximately 5 GB.
You need to recommend which distribution type and index type to use for the table. The solution must provide the fastest query performance.
What should you recommend? To answer, select the appropriate options in the answer area.
Graphical user interface, text, application, table, chat or text message Description automatically generated
Box 1: Hash
Consider using a hash-distributed table when:
The table size on disk is more than 2 GB.
The table has frequent insert, update, and delete operations.
Box 2: Clustered columnstore
Clustered columnstore tables offer both the highest level of data compression and the best overall query performance.
https://docs.microsoft.com/en-us ... use-tables-distribu
https://docs.microsoft.com/en-us ... ehouse-tables-index
NEW QUESTION # 176
Test DP-300 King: https://www.actualtests4sure.com/DP-300-test-questions.html
P.S. Free 2026 Microsoft DP-300 dumps are available on Google Drive shared by Actualtests4sure: https://drive.google.com/open?id=1pwCJpxZ-Dxgf6qyju4yJdf7_xGfO4qZE
