312-97 Exam Materials: EC-Council Certified DevSecOps Engineer (ECDE) & 312-
Posted at 2/19/2026 20:53:20
For one thing, the most advanced operation system in our company which can assure you the fastest delivery speed on our 312-97 exam questions, and your personal information will be encrypted automatically by our operation system. For another thing, with our 312-97 actual exam, you can just feel free to practice the questions in our training materials on all kinds of electronic devices. In addition, under the help of our 312-97 Exam Questions, the pass rate among our customers has reached as high as 98% to 100%. We are look forward to become your learning partner in the near future.
Our DumpsKing can help you realize your dream to pass 312-97 certification exam by providing 312-97 test training materials. Because it concludes all training materials you need to Pass 312-97 Exam. Choosing our DumpsKing can absolutely help you pass 312-97 test easily, and make you become a member of elite in IT. What are you waiting for? Hurry up!
312-97 Free Download & 312-97 Sure PassBefore you place orders, you can download the free demos of 312-97 practice test as experimental acquaintance. Once you decide to buy, you will have many benefits like free update lasting one-year and convenient payment mode. We will inform you immediately once there are latest versions of 312-97 Test Question released. And if you get any questions, please get contact with us, our staff will be online 24/7 to solve your problems all the way.
ECCouncil EC-Council Certified DevSecOps Engineer (ECDE) Sample Questions (Q52-Q57):NEW QUESTION # 52
(Cindy Williams has recently joined an IT company as a DevSecOps engineer. She configured Bundle-Audit in Travis CI. Cindy detected vulnerability in Gemfile dependencies and resolved it by adding some line of codes. How does Bundler scan Gemfile.lock for insecure versions of gems?)
- A. By taking the information from the Gemfile and comparing it with the unknown vulnerabilities.
- B. By taking the information from the travis.yml and comparing it with the unknown vulnerabilities.
- C. By taking the information from the travis.yml file and comparing it with the known vulnerabilities.
- D. By taking the information from the Gemfile and comparing it with the known vulnerabilities.
Bundler-Audit is a Software Composition Analysis (SCA) tool designed specifically for Ruby applications. It scans theGemfile and Gemfile.lockto identify all declared dependencies and their resolved versions. The Gemfile specifies which gems the application depends on, while the Gemfile.lock ensures consistent dependency versions across environments. Bundler-Audit compares this dependency information against a database ofknown vulnerabilitiesto identify insecure or outdated gems. It does not rely on the Travis CI configuration file for vulnerability detection, nor does it compare against unknown vulnerabilities. Integrating Bundler-Audit into the Build and Test stage ensures that vulnerable third-party libraries are detected early, allowing developers to remediate issues before the application progresses further in the pipeline. This practice supports shift-left security and reduces the risk of introducing known vulnerabilities into production systems.
NEW QUESTION # 53
(Terry Diab has been working as a DevSecOps engineer in an IT company that develops software products and web applications for a call center. She would like to integrate Snyk with AWS CodeCommit to monitor and remediate vulnerabilities in the code repository. Terry pushed code to AWS CodeCommit; this triggered Amazon EventBridge Rule, which then triggered AWS CodePipeline. AWS CodePipeline passed code to Snyk CLI run. Who among the following interacts with Snyk CLI and sends the results to Snyk UI?)
- A. AWS CodeCommit.
- B. AWS CodeBuild.
- C. AWS Pipeline.
- D. AWS CodeDeploy.
In an AWS CI/CD architecture, AWS CodePipeline acts as an orchestration service that coordinates different stages but does not execute build or scan commands itself. AWS CodeBuild is the service responsible for running commands such as compiling code, executing tests, and running third-party security tools like the Snyk CLI. In Terry's workflow, CodeCommit stores the source code, EventBridge triggers the pipeline, and CodePipeline passes the source to CodeBuild. CodeBuild then executes the Snyk CLI, performs vulnerability scanning, and sends the scan results to the Snyk UI using the configured authentication token. AWS CodeDeploy is focused on application deployment and does not interact with Snyk CLI. Therefore, AWS CodeBuild is the component that interacts with Snyk CLI and communicates results back to the Snyk platform. This integration ensures that dependency vulnerabilities are detected early in the Build and Test stage.
NEW QUESTION # 54
(David Paymer has been working as a senior DevSecOps engineer in an IT company over the past 5 years. His organization is using Azure DevOps service to produce software products securely and quickly. David's team leader asked him to publish a NuGet package utilizing a command line. Imagine you are in David's place; which command would you use to publish NuGet package into the feed?.)
- A. nuget.exe push -Destination "< YOUR_FEED_NAME >" -ApiKey < ANY_STRING > < PACKAGE_PATH >.
- B. nuget.exe publish -Source "< YOUR_FEED_NAME >" -ApiKey < ANY_STRING > < PACKAGE_PATH >.
- C. nuget.exe publish -Destination "< YOUR_FEED_NAME >" -ApiKey < ANY_STRING > < PACKAGE_PATH >.
- D. nuget.exe push -Source "< YOUR_FEED_NAME >" -ApiKey < ANY_STRING > < PACKAGE_PATH >.
Publishing a NuGet package to a feed is done using the nuget.exe push command. The -Source parameter specifies the target feed name or URL, and the -ApiKey parameter is required even if the feed ignores its value. The publish verb is not used for NuGet package uploads, and -Destination is not a valid parameter for pushing packages. Therefore, nuget.exe push -Source "<YOUR_FEED_NAME>" -ApiKey
<ANY_STRING> < ACKAGE_PATH> is the correct command. Using command-line publishing supports automation and consistency in DevSecOps workflows, enabling secure and repeatable artifact distribution as part of continuous delivery pipelines.
NEW QUESTION # 55
(Kevin Ryan has been working as a DevSecOps engineer in an MNC company that develops various software products and web applications. For easy management of secret credentials in CI/CD pipeline, he would like to integrate Azure Key Vault with Jenkins. Therefore, he created an Azure Key Vault, noted down the credentials displayed on the screen, and created a secret in Azure Key Vault. Then, he used the secret key from the credentials obtained from creating the vault. Kevin went back to Jenkins and installed Azure Key Vault plugin. Then, he navigated to Configure System under Manage Jenkins and added the URL for Azure Key Vault. How can Kevin complete the integration of Azure Key Vault with Jenkins?.)
- A. By modifying old credentials in Global Credentials (restricted).
- B. By creating new credentials in Global Credentials (unrestricted).
- C. By modifying old credentials in Global Credentials (unrestricted).
- D. By creating new credentials in Global Credentials (restricted).
To complete Azure Key Vault integration with Jenkins, Kevin must createnew credentialsin Jenkins under Global Credentials (unrestricted). These credentials store the Azure client ID, client secret, tenant ID, and subscription details required by the Azure Key Vault plugin to authenticate securely. Modifying old credentials can lead to misconfiguration or credential reuse risks, while restricted credentials may prevent the plugin from accessing secrets across pipelines. Creating new unrestricted credentials ensures proper authentication and controlled access to secrets during the Code stage, supporting secure secret management across CI/CD workflows.
NEW QUESTION # 56
(Dustin Hoffman has been working as a DevSecOps engineer in an IT company located in San Diego, California. For detecting new security vulnerabilities at the beginning of the source code development, he would like to integrate Checkmarx SCA tool with GitLab. The Checkmarx template has all the jobs defined for pipeline. Where should Dustin incorporate the Checkmarx template file 'https://raw.githubusercontent.com
/checkmarx-ltd/cx-flow/develop/templates/gitlab/v3/Checkmarx.gitlab-ci.yml'?)
- A. gitlab-cd.yml root directory.
- B. gitlab.yml root directory.
- C. gitlab-ci/cd.yml root directory.
- D. gitlab-ci.yml root directory.
GitLab CI/CD pipelines are defined using a configuration file namedgitlab-ci.yml, which must be placed in the root directory of the repository. This file controls pipeline stages, jobs, and template inclusions. To integrate Checkmarx SCA using a predefined template, the template reference must be included in the root- level gitlab-ci.yml file so GitLab can load and execute the defined jobs automatically. The other filenames listed in the options are not recognized by GitLab as valid pipeline configuration files. Integrating SCA at the Code stage allows early detection of vulnerable open-source dependencies, reducing remediation cost and preventing insecure components from progressing further in the DevSecOps pipeline.
NEW QUESTION # 57
Now, I am glad to introduce a secret weapon for all of the candidates to pass the exam as well as get the related certification without any more ado-- our 312-97 study braindumps. You can only get the most useful and efficient 312-97 Guide materials with the most affordable price from our company, since we aim to help as many people as possible rather than earning as much money as possible. You will be much awarded with our 312-97 learning engine.
312-97 Free Download: https://www.dumpsking.com/312-97-testking-dumps.html
ECCouncil 312-97 Trustworthy Practice Our company has accumulated many experiences after ten years' development, ECCouncil 312-97 Trustworthy Practice I was preparing for this Aruba exam for last 4 months and always felt that something missing in my preparation and thus decided to consult with some of my friends who have already passed the Aruba exam, ECCouncil 312-97 Trustworthy Practice We should not let them down.
Wait a few seconds afterward to ensure that the power is completely 312-97 off, These interactions have inspired us to do better, Our company has accumulated many experiences after ten years' development.
Reliable 312-97 Trustworthy Practice | Amazing Pass Rate For 312-97: EC-Council Certified DevSecOps Engineer (ECDE) | High-quality 312-97 Free DownloadI was preparing for this Aruba exam for last 4 months and always felt 312-97 Sure Pass that something missing in my preparation and thus decided to consult with some of my friends who have already passed the Aruba exam.
We should not let them down, Many candidates think 312-97 Test Online materials are surefooted and dependable, At the same time, you will have a friendly working environment and development space.
- New 312-97 Test Review 😎 New 312-97 Test Review 🏬 312-97 Exam Tutorial 🚡 ⇛ [url]www.dumpsquestion.com ⇚ is best website to obtain ➤ 312-97 ⮘ for free download 👨Study 312-97 Plan[/url]
- Free 312-97 Sample 😞 Free 312-97 Sample 💰 New 312-97 Test Preparation 🧱 Open ➤ [url]www.pdfvce.com ⮘ and search for ( 312-97 ) to download exam materials for free ✔Valid 312-97 Exam Review[/url]
- Pass 312-97 Exam with 100% Pass Rate 312-97 Trustworthy Practice by [url]www.examcollectionpass.com 🧀 ➡ www.examcollectionpass.com ️⬅️ is best website to obtain 「 312-97 」 for free download 🍯312-97 Updated Demo[/url]
- 312-97 Lead2pass Review 🤧 Latest 312-97 Test Testking 🛺 312-97 Certification Book Torrent 📿 Open ( [url]www.pdfvce.com ) enter ➡ 312-97 ️⬅️ and obtain a free download 🔆312-97 Cost Effective Dumps[/url]
- 312-97 valid cram guide - 312-97 training prep - 312-97 sure pass 🧿 Simply search for ⏩ 312-97 ⏪ for free download on ( [url]www.prep4sures.top ) 💌Valid 312-97 Exam Review[/url]
- Study Materials 312-97 Review 🈺 312-97 Certification Book Torrent 🅱 Latest 312-97 Test Testking 🐭 Download 《 312-97 》 for free by simply searching on 「 [url]www.pdfvce.com 」 ✉Valid 312-97 Exam Review[/url]
- Latest 312-97 Test Testking 🚟 312-97 Lead2pass Review 🐫 312-97 Lead2pass Review 🤍 Download ➽ 312-97 🢪 for free by simply entering ☀ [url]www.pdfdumps.com ️☀️ website 🌛312-97 Exam Tutorial[/url]
- Updates To The ECCouncil 312-97 Exam Are Free For 1 year 🐜 Open ➤ [url]www.pdfvce.com ⮘ and search for ⇛ 312-97 ⇚ to download exam materials for free 🍏New 312-97 Test Review[/url]
- 312-97 Updated Demo 🔢 Study 312-97 Plan 🏖 Latest 312-97 Test Testking 🍑 Search for 《 312-97 》 on ➽ [url]www.exam4labs.com 🢪 immediately to obtain a free download 🧥
ass 312-97 Test[/url] - Crack the ECCouncil 312-97 Exam with Confidence ⚗ Search on ➡ [url]www.pdfvce.com ️⬅️ for ➠ 312-97 🠰 to obtain exam materials for free download 🈵312-97 Cost Effective Dumps[/url]
- Crack the ECCouncil 312-97 Exam with Confidence 🛕 Download ➥ 312-97 🡄 for free by simply entering 【 [url]www.troytecdumps.com 】 website ⏬New 312-97 Test Preparation[/url]
- www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, elearning.greatergracecollege.com.ng, Disposable vapes
