[Hardware] CNX-001認證考試問題與答案
91
【Hardware】 CNX-001認證考試問題與答案
Posted at 2/19/2026 21:28:11      View:75 | Replies:0        Print      Only Author   [Copy Link] 1#
從Google Drive中免費下載最新的PDFExamDumps CNX-001 PDF版考試題庫:https://drive.google.com/open?id=19u59E8myCTLNG5TCT--dypjpzW5gBxpT
大多數人在選擇CompTIA的CNX-001的考試,由於它的普及,你完全可以使用PDFExamDumps CompTIA的CNX-001考試的試題及答案來檢驗,可以通過考試,還會給你帶來極大的方便和舒適,這個被實踐檢驗過無數次的網站在互聯網上提供了考試題及答案,眾所周知,我們PDFExamDumps是提供 CompTIA的CNX-001考試試題及答案的專業網站。
CompTIA CNX-001 考試大綱:
主題簡介
主題 1
  • Network Operations, Monitoring, and Performance: This section of the exam measures skills of Network Operations Specialists and covers day-to-day operational management of network environments. It involves configuring monitoring tools, analyzing performance data, and responding to alerts. Candidates are evaluated on their ability to maintain network health, optimize throughput, and ensure consistent uptime by applying best practices for proactive performance tuning and operations management.
主題 2
  • Network Architecture Design: This section of the exam measures the skills of Network Architects and covers the ability to design scalable, secure, and efficient network architectures. It focuses on understanding design principles, selecting appropriate network components, and aligning architecture decisions with organizational needs. Candidates are expected to demonstrate a solid grasp of topology planning, high-availability configurations, and integration of cloud and on-premise systems to ensure reliability and performance.
主題 3
  • Network Security: This section of the exam measures the skills of Security Engineers and covers core practices for protecting network infrastructure. It includes applying firewall rules, implementing access control measures, and designing secure segmentation strategies. The content emphasizes threat mitigation techniques, secure configuration of networking devices, and adherence to compliance frameworks, preparing professionals to safeguard both internal and external network assets effectively.
主題 4
  • Network Troubleshooting: This section of the exam measures the skills of Network Support Engineers and covers diagnosing and resolving connectivity and performance issues across various network layers. It focuses on identifying root causes, using diagnostic tools, and applying systematic troubleshooting methodologies. The goal is to ensure that professionals can minimize downtime, restore service quickly, and prevent recurring problems by maintaining a resilient and stable network environment.
CompTIA CNX-001通過考試 & CNX-001認證考試解析目前,全球500強中的90%企業都在使用 CompTIA 公司的產品。CNX-001 認證是全球專業認證各領域中的權威認證。在IT世界裡,擁有 CompTIA CNX-001 認證已成為最合適的加更簡單的方法來達到成功。這意味著,考生應努力通過考試才能獲得認證。而 PDFExamDumps 考題大師致力與為客戶提供 CNX-001 認證的全真考題及認證學習資料,能夠幫助妳一次通過 CNX-001 認證考試。
最新的 CloudNetX CNX-001 免費考試真題 (Q82-Q87):問題 #82
A network engineer is establishing a wireless network for handheld inventory scanners in a manufacturing company's warehouse. The engineer needs an authentication mechanism for these scanners that uses the Wi-Fi network and works with the company's Active Directory. The business requires that the solution authenticate the users and authorize the scanners. Which of the following provides the best solution for authentication and authorization?
  • A. LDAP
  • B. TACACS+
  • C. PKI
  • D. RADIUS
答案:D
解題說明:
RADIUS (Remote Authentication Dial-In User Service) is the best-fit protocol for this requirement. It supports both authentication and authorization and is widely used in Wi-Fi network environments for client device authentication using credentials stored in centralized directories such as Active Directory.
RADIUS integrates seamlessly with enterprise authentication sources and supports EAP (Extensible Authentication Protocol), making it compatible with Wi-Fi-based client devices. It also allows for role-based access control, enabling policy enforcement specific to device types (e.g., inventory scanners).
Relevant Extract from CompTIA CloudNetX CNX-001 Study Guide - "Authentication and Authorization Technologies":
"RADIUS provides centralized authentication, authorization, and accounting (AAA) services and is commonly used for securing wireless access in conjunction with Active Directory."
"Organizations use RADIUS to manage Wi-Fi authentication for user devices and enforce security policies during access attempts." Using a RADIUS server with 802.1X on the Wi-Fi infrastructure allows the scanners (and their users) to be authenticated against Active Directory and mapped to the correct authorization policies. TACACS+ is geared toward device management, LDAP alone doesn't handle the Wi-Fi 802.1X handshake, and PKI by itself wouldn't provide the user-to-device authorization flow needed. RADIUS gives you both authentication and authorization tied into AD.
問題 #83
A company is expanding its network and needs to ensure improved stability and reliability. The proposed solution must fulfill the following requirements:
* Detection and prevention of network loops
* Automatic configuration of ports
* Standard protocol (not proprietary)
Which of the following protocols is the most appropriate?
  • A. STP
  • B. BGP
  • C. RTSP
  • D. SIP
答案:A
解題說明:
STP (Spanning Tree Protocol) is a Layer 2 standard protocol that prevents switching loops in Ethernet networks by creating a loop-free logical topology. It can automatically block and unblock redundant paths based on network changes, ensuring reliability and avoiding broadcast storms.
Relevant Extract from CompTIA CloudNetX CNX-001 Study Guide - under "Ethernet Loop Prevention and Switching Protocols":
"STP is a standard Layer 2 protocol used to detect and prevent network loops, enhancing network stability in switched topologies." Other options:
* B. SIP is a signaling protocol used in VoIP.
* C. RTSP is for media streaming control.
* D. BGP is a routing protocol, not for Layer 2 loop prevention.
問題 #84
Security policy states that all inbound traffic to the environment needs to be restricted, but all external outbound traffic is allowed within the hybrid cloud environment. A new application server was recently set up in the cloud. Which of the following would most likely need to be configured so that the server has the appropriate access set up? (Choose two.)
  • A. Network security group
  • B. Firewall
  • C. Port security
  • D. Application gateway
  • E. Screened subnet
  • F. IPS
答案:A,B
解題說明:
A perimeter firewall enforces the organization's "deny inbound by default, allow all outbound" policy at the edge of the cloud environment, while an Azure-style NSG applies the same rule set at the VM/subnet level.
Together they ensure no inbound connections slip through and that outbound traffic remains unrestricted.
問題 #85
A network load balancer is not correctly validating a client TLS certificate. The network architect needs to validate the certificate installed on the load balancer before progressing. Which of the following commands should the architect use to confirm whether the private key and certificate match?
  • A. openssl req -in certificate.csr -verify
    openssl-verify -noout -modulus -in privkey.txt | openssl md5
  • B. openssl x509 -noout -modulus -in cert.crt | openssl md5
    openssl rsa -noout -modulus -in privkey.txt | openssl md5
  • C. openssl-rsa -noout -modulus -in cert.crt | openssl md5
  • D. openssl-list -noout -modulus -in cert.crt | openssl md5
答案:B
解題說明:
If the MD5 hashes match, the certificate and private key correspond correctly.
問題 #86
A large commercial enterprise that runs a global video streaming platform recently acquired a small business that serves customers in a geographic area with limited connectivity to the global telecommunications infrastructure. The executive leadership team issued a mandate to deliver the highest possible video streaming quality to all customers around the world. Which of the following solutions should the enterprise architect suggest to meet the requirements?
  • A. Use a geographically weighted DNS solution to distribute the traffic.
  • B. Deploy multiple local load balancers in the newly added geographic area.
  • C. Serve the customers in the acquired area with a highly compressed version of content.
  • D. Utilize CDN for all customers regardless of geographic location.
答案:D
解題說明:
A Content Delivery Network (CDN) distributes content across geographically distributed edge locations to provide faster access and higher quality to users, especially in areas with suboptimal connectivity to central data centers. By caching and serving content from edge servers near users, CDNs reduce latency and improve streaming performance globally.
Relevant Extract from CompTIA CloudNetX CNX-001 Study Guide - under "CDN and Cloud Edge Services":
"CDNs provide globally distributed edge nodes for content caching and delivery, ensuring low-latency, high- bandwidth access for end users regardless of their location." Other options:
* A. Reduces quality, contrary to the stated goal.
* B. DNS-based routing helps with direction but does not solve content delivery or bandwidth issues.
* C. Load balancers help distribute traffic locally, but do not provide edge caching or bandwidth optimization.
問題 #87
CompTIA CNX-001 認證證書是很多IT人士夢寐以求的。CompTIA CNX-001 認證考試是個檢驗IT專業知識和經驗的認證考試,通過考試是需要豐富的IT知識和經驗。為了掌握這麼多知識,一般需要花費大量的時間和精力。PDFExamDumps是個能幫你節約時間和精力的網站,能快速有效地幫助你補充CompTIA CNX-001 認證考試的相關知識。如果你對PDFExamDumps感興趣,你可以先在網上免費下載PDFExamDumps提供的部分關於CompTIA CNX-001 認證考試的練習題和答案作為嘗試。
CNX-001通過考試: https://www.pdfexamdumps.com/CNX-001_valid-braindumps.html
順便提一下,可以從雲存儲中下載PDFExamDumps CNX-001考試題庫的完整版:https://drive.google.com/open?id=19u59E8myCTLNG5TCT--dypjpzW5gBxpT
