[Hardware] Juniper JN0-253 Questions - Say Goodbye To Exam Anxiety
89
【Hardware】 Juniper JN0-253 Questions - Say Goodbye To Exam Anxiety
Posted at 2/19/2026 23:15:43      View:101 | Replies:1        Print      Only Author   [Copy Link] 1#
2026 Latest TorrentVCE JN0-253 PDF Dumps and JN0-253 Exam Engine Free Share: https://drive.google.com/open?id=1i5xG11zR7DdwZc2xtAjW4Zb78Me8-Xh3
Do not postpone seeking help from our extraordinary Juniper JN0-253 dumps to get the crucial Juniper JN0-253 certification exams. This platform allows you to self-assess your progress with a performance score. You can also customize your Juniper JN0-253 mock tests according to the time and kinds of practice queries. It imitates the exact pattern of the actual Juniper JN0-253 certification exam.
Juniper JN0-253 Exam Syllabus Topics:
  • Juniper Mist Monitoring and Analytics: This domain focuses on monitoring tools including service-level expectations, packet captures, AI-driven insights, automated alerts, and audit logs for comprehensive network visibility.
  • Marvis Virtual Network Assistant AI: This domain introduces Marvis, an AI-powered assistant providing automated troubleshooting through intelligent actions, natural language queries, and specialized analytical tools for proactive issue resolution.
  • Juniper Mist Configuration Basics: This domain addresses initial setup including user accounts, device onboarding, organizational structures, subscription licensing, certificate management, and automated provisioning with labels and policies.
100% JN0-253 Exam Coverage - JN0-253 DiscountFor candidates who want to buy JN0-253 exam materials online, they may have the concern of the privacy. We respect personal information of you. If you buy JN0-253 test materials from us, your personal information such as your email address and name will be protected well. Once the order finishes, your personal information will be concealed. Moreover, JN0-253 Exam Dumps cover most of knowledge points for the exam, and it will be enough for you to pass the exam just one time. In order to strengthen your confidence for JN0-253 exam braindumps, we are pass guarantee and money back guarantee.
Juniper Mist AI, Associate (JNCIA-MistAI) Sample Questions (Q28-Q33):NEW QUESTION # 28
You are asked to configure a site in Juniper Mist.
Which statement describes completing this step?
  • A. You must configure the site within your organization.
  • B. You must first configure the country, time zone, and location at the organization level.
  • C. You must claim your site by scanning the access point's QR code.
  • D. You must define your organization within the site.
You must configure the site within your organization-this is the correct process according to Juniper Mist's official configuration guides. When setting up a deployment, first an organization is created in the Mist cloud.
Within this organization, sites are added for each physical location. The Mist documentation says: "You can create Sites in the Juniper Mist portal from the Organization > Site Configuration menu. Add or update sites as needed." The configuration requires the site name, country, and location to be set at the site level-not the organization level. Claiming APs via QR codes and organization definition are separate steps in device onboarding and initial setup.
Reference:Juniper Mist Management Guide , Mist Edge Teleworker Solution User Guide , Juniper Mist Access Points
NEW QUESTION # 29
What are three methods for requesting authentication in the Juniper Mist API? (Choose three.)
  • A. Enable basic authentication with a token.
  • B. Use an HTTPS login with a user name and password.
  • C. Use OAuth2 linked to an OAuth provider.
  • D. Use RADIUS certificates.
  • E. Enable MFA with Okta Verify.
Answer: A,B,C
The three valid methods for requesting authentication with the Juniper Mist API are:
Use an HTTPS login with a user name and password: The Mist API accepts HTTPS requests where credentials are provided directly for session/token generation and user administration.
Use OAuth2 linked to an OAuth provider: "Juniper Mist APIs offer authentication via OAuth2 with various OAuth-compatible identity providers, such as Okta, for secure and federated access." Enable basic authentication with a token: Mist APIs accept programmatic requests using tokens (API tokens or bearer tokens) for automation, scripting, and integration-each token mapping to specific scopes and user permissions.
Enabling MFA with Okta Verify enhances user portal security but is not an API authentication mechanism.
RADIUS certificates are used for infrastructure 802.1X authentication, not for API access.
Juniper Mist API Authentication Mechanisms
NEW QUESTION # 30
Which two Juniper devices are used in Juniper Mist WAN Assurance? (Choose two.)
  • A. EX Series Switches
  • B. Session Smart Routers
  • C. SRX Series Firewalls
  • D. QFX Series Switches
Juniper Mist WAN Assuranceis a cloud-based service that extends Mist AI capabilities to the WAN edge, providing visibility, automation, and AI-driven analytics for WAN devices. It focuses on ensuringend-to-end service assurancefor users and applications across distributed networks.
According to theJuniper Mist WAN Assurance and SD-WAN Deployment Guide, the supported devices include:
"Juniper SRX Series Firewalls and Session Smart Routers (SSR) are integrated with Mist WAN Assurance for telemetry collection, service-level monitoring, and AI-driven troubleshooting."
* SRX Series Firewalls (A)rovide secure WAN connectivity and send real-time telemetry (including throughput, latency, and packet loss metrics) to Mist Cloud.
* Session Smart Routers (C)ower the AI-driven SD-WAN solution with application-aware routing and session intelligence, fully integrated into Mist Cloud for advanced visibility and analytics.
EXandQFXswitches are used withWired Assurance, not WAN Assurance.
Therefore, the correct answers areA. SRX Series FirewallsandC. Session Smart Routers.
References:- Juniper Mist WAN Assurance and SD-WAN Deployment Guide- Juniper Mist Cloud Operations and Assurance Documentation- Juniper Mist AI WAN and Telemetry Overview
NEW QUESTION # 31
Which statement is correct when a subscription expires?
  • A. The devices remain operational, and all functionality remains available for a one-year grace period.
  • B. The devices remain operational, but you are not allowed to manage the devices using the Mist management GUI.
  • C. The devices become inactive and unreachable through the Mist management GUI.
  • D. The devices remain operational, but the Mist management GUI functionality related to expired subscriptions is hidden from the user.
When a Mist subscription expires, the devices associated with that subscription continue to operate normally, ensuring there is no immediate disruption to network operations. However, management capabilities through the Mist management GUI are restricted. This means that while the devices remain functional, you cannot make configuration changes, monitor, or manage them using the Mist management interface until the subscription is renewed. This restriction emphasizes the importance of maintaining active subscriptions for full access to Mist's management features.
NEW QUESTION # 32
Which protocol is used by Mist to monitor non-Juniper switches?
  • A. SNMP
  • B. LLDP
  • C. IPsec
  • D. SMTP
The Simple Network Management Protocol (SNMP) is used by Mist to monitor non-Juniper switches. SNMP is a widely adopted protocol for network management, enabling the collection and organization of information about managed devices on IP networks.
NEW QUESTION # 33
Each of us is dreaming of being the best, but only a few people take that crucial step. The key step is to work hard to make yourself better. Our JN0-253 study materials may become your right man. Perhaps you have heard of our JN0-253 Exam Braindumps. A lot of our loyal customers are very familiar with their characteristics. And our JN0-253 learning quiz have become a very famous brand in the market and praised for the best quality.
100% JN0-253 Exam Coverage: https://www.torrentvce.com/JN0-253-valid-vce-collection.html
Posted at 3/8/2026 00:07:10        Only Author  2#
This article is truly one worth keeping and referring to. Latest test DOP-C02 vce free exam materials are the secret to promotion and salary increases—available for free!
