[General] 100% Pass Quiz 2026 GitHub-Advanced-Security: GitHub Advanced Security GHAS Exam
109
General 100% Pass Quiz 2026 GitHub-Advanced-Security: GitHub Advanced Security GHAS Exam
Posted at 2/20/2026 00:38:48      View106 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free & New GitHub-Advanced-Security dumps are available on Google Drive shared by ValidVCE: https://drive.google.com/open?id=1CHndMouJzMWLqKeRkINcXvHD3K6z4-cA
You may be busy in your jobs, learning or family lives and can't get around to preparing and takes the certificate exams but on the other side you urgently need some useful GitHub-Advanced-Security certificates to improve your abilities in some areas. If you choose the test GitHub-Advanced-Security certification and then buy our GitHub-Advanced-Security prep material you will get the panacea to both get the useful GitHub-Advanced-Security certificate and spend little time. Passing the GitHub-Advanced-Security test certification can help you stand out in your colleagues and have a bright future in your career.
GitHub GitHub-Advanced-Security Exam Syllabus Topics:
  • Use code scanning with CodeQL: This section of the exam measures skills of a DevSecOps Engineer and covers working with CodeQL to write or customize queries for deeper semantic analysis. Candidates should demonstrate how to configure CodeQL workflows, understand query suites, and interpret CodeQL alerts to uncover complex code issues beyond standard static analysis.
  • Configure and use code scanning: This section of the exam measures skills of a DevSecOps Engineer and covers enabling and customizing GitHub code scanning with built?in or marketplace rulesets. Examinees must know how to interpret scan results, triage findings, and configure exclusion or override settings to reduce noise and focus on high?priority vulnerabilities.
  • Configure GitHub Advanced Security tools in GitHub Enterprise: This section of the exam measures skills of a GitHub Administrator and covers integrating GHAS features into GitHub Enterprise Server or Cloud environments. Examinees must know how to enable advanced security at the enterprise level, manage licensing, and ensure that scanning and alerting services operate correctly across multiple repositories and organizational units.
Reliable GitHub-Advanced-Security Reliable Test Testking & Leading Offer in Qualification Exams & Authorized GitHub GitHub Advanced Security GHAS ExamWhen preparing to take the GitHub GitHub-Advanced-Security exam dumps, knowing where to start can be a little frustrating, but with ValidVCE GitHub GitHub-Advanced-Security practice questions, you will feel fully prepared. Using our GitHub GitHub-Advanced-Security practice test software, you can prepare for the increased difficulty on GitHub-Advanced-Security Exam day. Plus, we have various question types and difficulty levels so that you can tailor your GitHub GitHub-Advanced-Security exam dumps preparation to your requirements.
GitHub Advanced Security GHAS Exam Sample Questions (Q17-Q22):NEW QUESTION # 17
Which CodeQL query suite provides queries of lower severity than the default query suite?
  • A. github/codeql/cpp/ql/src@main
  • B. security-extended
  • C. github/codeql-go/ql/src@main
Thesecurity-extendedquery suite includes additional CodeQL queries that detectlower severity issuesthan those in the default security-and-quality suite.
It's often used when projects want broader visibility into code hygiene and potential weak spots beyond critical vulnerabilities.
The other options listed arepaths to language packs, not query suites themselves.
NEW QUESTION # 18
If default code security settings have not been changed at the repository, organization, or enterprise level, which repositories receive Dependabot alerts?
  • A. Private repositories
  • B. None
  • C. Repositories owned by an enterprise account
  • D. Repositories owned by an organization
Bydefault,no repositoriesreceive Dependabot alerts unless configuration is explicitly enabled. GitHub does notenable Dependabot alerts automatically for any repositories unless:
* The feature is turned on manually
* It's configured at the organization or enterprise level via security policies This includes public, private, and enterprise-owned repositories -manual activation is required.
NEW QUESTION # 19
As a repository owner, you want to receive specific notifications, including security alerts, for an individual repository. Which repository notification setting should you use?
  • A. All Activity
  • B. Ignore
  • C. Participating and @mentions
  • D. Custom
Using theCustomsetting allows you to subscribe to specific event types, such as Dependabot alerts or vulnerability notifications, without being overwhelmed by all repository activity. This is essential for repository maintainers who need fine-grained control over what kinds of events trigger notifications.
This setting is configurable per repository and allows users to stay aware of critical issues while minimizing notification noise.
NEW QUESTION # 20
As a contributor, you discovered a vulnerability in a repository. Where should you look for the instructions on how to report the vulnerability?
  • A. support.md
  • B. contributing.md
  • C. security.md
  • D. readme.md
The correct place to look is the SECURITY.md file. This file provides contributors and security researchers with instructions on how to responsibly report vulnerabilities. It may include contact methods, preferred communication channels (e.g., security team email), and disclosure guidelines.
This file is considered a GitHub best practice and, when present, activates a "Report a vulnerability" button in the repository'sSecuritytab.
NEW QUESTION # 21
As a repository owner, you do not want to run a GitHub Actions workflow when changes are made to any .txt or markdown files. How would you adjust the event trigger for a pull request that targets the main branch?
(Each answer presents part of the solution. Choose three.)
* on:
* pull_request:
* branches: [main]
  • A. - 'docs/*.md'
  • B. - '/*.md'
  • C. paths:
  • D. - '/*.txt'
  • E. paths-ignore:
Answer: B,D,E
Toexclude.txt and .md files from triggering workflows on pull requests to the main branch:
* on: defines the event (e.g., pull_request)
* pull_request: is the trigger
* paths-ignore: is the key used to ignore file patterns
Example YAML:
yaml
CopyEdit
on:
pull_request:
branches:
- main
paths-ignore:
- '*.md'
- '*.txt'
Using paths: would include only specific files instead - not exclude. paths-ignore: is correct here.
NEW QUESTION # 22
You can get a sense of the actual GitHub-Advanced-Security exam by attempting our GitHub-Advanced-Security practice tests. Desktop and web-based practice exams are identical to the real GitHub-Advanced-Security exam and simulate the GitHub-Advanced-Security exam environment. Practice exams (desktop and web-based) of can be customized according to your needs. One benefit of taking GitHub-Advanced-Security Practice Tests multiple times is that it enables you to concentrate on your weak areas.
Latest GitHub-Advanced-Security Exam Vce: https://www.validvce.com/GitHub-Advanced-Security-exam-collection.html
DOWNLOAD the newest ValidVCE GitHub-Advanced-Security PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1CHndMouJzMWLqKeRkINcXvHD3K6z4-cA
