[General] NSE6_SDW_AD-7.6 Reliable Exam Guide, NSE6_SDW_AD-7.6 Materials
98
【General】 NSE6_SDW_AD-7.6 Reliable Exam Guide, NSE6_SDW_AD-7.6 Materials
Posted at 2/20/2026 00:57:55      View:107 | Replies:0        Print      Only Author   [Copy Link] 1#
We have professional technicians to check website at times, therefore if you buy NSE6_SDW_AD-7.6 Study Materials from us, we can ensure you that you can have a clean and safe shopping environment. Moreover NSE6_SDW_AD-7.6 exam braindumps of us is compiled by professional experts, and therefore the quality and accuracy can be guaranteed. We have online and offline chat service stuff, if you have any questions, you can contact us, we will give you reply as quickly as possible.
In Exams-boost's website you can free download study guide, some exercises and answers about Fortinet Certification NSE6_SDW_AD-7.6 Exam as an attempt.
Pass Guaranteed Quiz 2026 NSE6_SDW_AD-7.6: Efficient Fortinet NSE 6 - SD-WAN 7.6 Enterprise Administrator Reliable Exam GuideAfter a short time's studying and practicing with our NSE6_SDW_AD-7.6 exam questions, you will easily pass the examination. We can claim that if you study with our NSE6_SDW_AD-7.6 learning quiz for 20 to 30 hours, then you will be confident to attend the exam. God helps those who help themselves. If you choose our NSE6_SDW_AD-7.6 Study Materials, you will find God just by your side. The only thing you have to do is just to make your choice and study. Isn't it very easy? So know more about our NSE6_SDW_AD-7.6 practice guide right now!
Fortinet NSE 6 - SD-WAN 7.6 Enterprise Administrator Sample Questions (Q49-Q54):NEW QUESTION # 49
As an IT manager for a healthcare company, you want to delegate the installation and management of your SD-WAN deployment to a managed security service provider (MSSP). Each site must maintain direct internet access and ensure that it is secure. You expected significant traffic flow between the sites and want to delegate as much of the network administration and management as possible to the MSSP.
Which two MSSP deployment blueprints best address the customer's requirements? (Choose two.)
  • A. Use a shared hub at the MSSP premises with a dedicated VDOM for the new customer, and install the spokes at the customer premises.
  • B. Install the hub and spokes at the customer premises and enable the MSSP to manage the SD-WAN deployment using FortiManager with a dedicated ADOM.
  • C. Use a shared hub at the MSSP premises and a dedicated hub at the customer premises and install the spokes at the customer premises.
  • D. Install a dedicated hub at the MSSP premises for the new customer, and install the spokes at the customer premises.
Hosting the hub at the MSSP centralizes installation, security, and ongoing management while each site (spoke) keeps local DIA. This can be done multi-tenant with a shared hub using a dedicated VDOM or with a fully dedicated hub per customer for stricter isolation and control, both meeting the requirement to delegate administration to the MSSP and support high inter-site traffic.
NEW QUESTION # 50
An administrator is troubleshooting SD-WAN on FortiGate. A device behind branch1_fgt generates traffic to the 10.0.0.0/8 network.
The administrator expects the traffic to match SD-WAN rule ID 1 and be routed over HUB1-VPN1. However, the traffic is routed over HUB1-VPN3.
Based on the output shown in the exhibit, which two reasons, individually or together, could explain the observed behavior? (Choose two.)
  • A. HUB1-VPN3 has a higher member configuration priority than HUB1-VPN1.
  • B. HUB1-VPN1 does not have a valid route to the destination
  • C. HUB1-VPN3 has a lower route priority value (higher priority) than HUB1-VPN1.
  • D. The traffic matches a regular policy route configured with HUB1-VPN3 as the outgoing device
NEW QUESTION # 51
(In which order does FortiGate consider the following elements during the route lookup process? Choose one answer.)
  • A. Policy routes, SD-WAN rules, Internet Service Database (ISDB) routes, BGP routes
  • B. Policy routes, ISDB routes, SD-WAN rules, static routes
  • C. SD-WAN rules, ISDB routes, policy routes, BGP routes
  • D. SD-WAN rules, policy routes, static routes, ISDB routes
In FortiOS (including FortiOS 7.6), FortiGate follows a strict and well-defined route lookup order when determining how to forward traffic. This order is critical for understanding SD-WAN behavior and is explicitly referenced in the FCSS SD-WAN curriculum.
The correct lookup sequence is:
* Policy routes (Policy-Based Routing)Policy routes are evaluated first. If traffic matches a policy route, FortiGate immediately forwards the traffic according to that policy and bypasses all other routing mechanisms.
* Internet Service Database (ISDB) routesIf no policy route matches, FortiGate checks ISDB routes.
These routes match traffic based on Internet Services rather than destination IP prefixes.
* SD-WAN rulesIf neither a policy route nor an ISDB route matches, FortiGate evaluates SD-WAN rules to determine the outgoing interface based on the configured SD-WAN strategy.
* Routing table (connected, static, and dynamic routes such as BGP)If no SD-WAN rule matches, FortiGate performs a normal routing table lookup.
* FIB (Forwarding Information Base)The FIB is used to forward the packet based on the selected route.
* DropIf no valid route exists, the packet is dropped.
Among the options provided, only Option D correctly reflects the beginning of this sequence by placing policy routes first, followed by ISDB routes, then SD-WAN rules, and finally static routes (representing the routing table).
Therefore, the correct answer is D.
NEW QUESTION # 52
The exhibit shows the health-check configuration on a FortiGate device used as a spoke. You notice that the hub FortiGate doesn't prioritize the traffic as expected.
Which two configuration elements should you check on the hub? (Choose two.)
  • A. The performance SLA has the parameter priority-out-sla configured.
  • B. The performance SLA uses the same criteria.
  • C. The performance SLA is configured with set embedded-measure accept.
  • D. This performance SLA uses the same members.
The hub must use a performance SLA with the same criteria as the spoke's health check. The spoke's health check is using ping (protocol ping) and measuring latency (link-cost-factor latency). For the hub to use the data sent by the spoke, its performance SLA must be configured to measure the same metrics. If the hub is looking for jitter or packet loss, it will not use the latency data sent by the spoke.
When a spoke sends embedded health data, the hub FortiGate must be configured to receive and use it. This is done by setting set embedded-measure accept within the performance SLA configuration on the hub. This setting explicitly tells the hub to trust and use the performance metrics received from the remote FortiGate (the spoke). Without this setting, the hub will likely ignore the embedded health data and rely on its own health checks, which could lead to incorrect traffic prioritization.
NEW QUESTION # 53
The administrator analyzed the traffic between a branch FortiGate and the server located in the data center, and noticed the behavior shown in the diagram.
When the LAN clients located behind FGT1 establish a session to a server behind DC-1, the administrator observes that, on DC-1, the reply traffic is routed overT2. even though T1 is the preferred member in the matching SD-WAN rule.
What can the administrator do to instruct DC-1 to route the reply traffic through the member with the best performance?
  • A. FortiGate route lookup for reply traffic only considers routes over the original ingress interface.
  • B. Enable snat-route-change under config system global.
  • C. Enable auxiliary-session under config system settings.
  • D. Enable reply-session under config system sdwan.
When asymmetric routing is observed (such as reply traffic not following the optimal path), the solution is:
"The auxiliary-session feature, enabled under config system settings, allows FortiGate to consider multiple egress interfaces for reply traffic, not just the original ingress interface. This is crucial for SD-WAN environments where the best path may differ between forward and return directions, especially when performance or policy rules are dynamically evaluated." Activating this ensures reply traffic is always sent on the member with the best real-time metrics.
[FCSS_SDW_AR-7.4 1-0.docx Q23]
FortiOS 7.4 CLI Reference, "auxiliary-session for SD-WAN Path Optimization"
NEW QUESTION # 54
The Fortinet NSE6_SDW_AD-7.6 certification is on trending nowadays, and many IT aspirants are trying to get it. Success in the NSE6_SDW_AD-7.6 test helps you land well-paying jobs. Additionally, the Fortinet NSE6_SDW_AD-7.6 certification exam is also beneficial to get promotions in your current company. But the main problem that every applicant faces while preparing for the NSE6_SDW_AD-7.6 Certification test is not finding updated Fortinet NSE6_SDW_AD-7.6 practice questions.
NSE6_SDW_AD-7.6 Materials: https://www.exams-boost.com/NSE6_SDW_AD-7.6-valid-materials.html
Finally, our company emphasis on the customer privacy and keep the information of customers secret who purchase our NSE6_SDW_AD-7.6 pass-for-sure material, because the operation idea of our company is what customers demand, As one of the most reliable Fortinet NSE 6 NSE6_SDW_AD-7.6 training pdf providers in the world, we will be responsible for every customer and make endless efforts to help them obtain the NSE6_SDW_AD-7.6 exam certificate, In doing so, you never worry to waste your time or money and have a free trial of our NSE6_SDW_AD-7.6 exam engine to know more and then you can choose whether buy NSE6_SDW_AD-7.6 study material or not.
For example, since type can interact with transparent objects in unexpected ways, NSE6_SDW_AD-7.6 it's common practice to create an extra layer for textual elements that is located above all the layers containing transparent objects and effects.
100% Pass Quiz 2026 Fortinet The Best NSE6_SDW_AD-7.6 Reliable Exam GuideSection I Working Foundations, Finally, our Trustworthy NSE6_SDW_AD-7.6 Pdf company emphasis on the customer privacy and keep the information of customers secret who purchase our NSE6_SDW_AD-7.6 pass-for-sure material, because the operation idea of our company is what customers demand.
As one of the most reliable Fortinet NSE 6 NSE6_SDW_AD-7.6 training pdf providers in the world, we will be responsible for every customer and make endless efforts to help them obtain the NSE6_SDW_AD-7.6 exam certificate.
Skillfully designed NSE6_SDW_AD-7.6 Dumps will definitely help you to succeed in the very first attempt, Do I need to choose between Fortinet NSE 6 - SD-WAN 7.6 Enterprise Administrator dumps PDF and Fortinet NSE 6 NSE6_SDW_AD-7.6 practice test questions software?
