[General] Pass Guaranteed Quiz 2026 Ping Identity Accurate PAP-001 Practice Test
96
【General】 Pass Guaranteed Quiz 2026 Ping Identity Accurate PAP-001 Practice Test
Posted at 2/20/2026 01:34:46      View:110 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of CertkingdomPDF PAP-001 dumps from Cloud Storage: https://drive.google.com/open?id=1DwuXgclXaZ7uLFfzMYPWlgZBzsKUegZP
You can download a free demo of Ping Identity - PAP-001 exam study material at CertkingdomPDF The free demo of PAP-001 exam product will eliminate doubts about our Certified Professional - PingAccess PDF and practice exams. You should avail this opportunity of PAP-001 exam dumps free demo. It will help you pay money without any doubt in mind. We ensure that our Certified Professional - PingAccess exam questions will meet your Certified Professional - PingAccess test preparation needs. If you remain unsuccessful in the PAP-001 test after using our PAP-001 product, you can ask for a full refund. CertkingdomPDF will refund you as per the terms and conditions.
Ping Identity PAP-001 Exam Syllabus Topics:
  • Installation and Initial Configuration: This section of the exam measures skills of System Engineers and reviews installation prerequisites, methods of installing or removing PingAccess, and securing configuration database passwords. It explains the role of run.properties entries and outlines how to set up a basic on-premise PingAccess cluster.
  • General Configuration: This section of the exam measures skills of Security Administrators and introduces the different object types within PingAccess such as applications, virtual hosts, and web sessions. It explains managing application resource properties, creating web sessions, configuring identity mappings, and navigating the administrative console effectively.
  • Product Overview: This section of the exam measures skills of Security Administrators and focuses on understanding PingAccess features, functionality, and its primary use cases. It also covers how PingAccess integrates with other Ping products to support secure access management solutions.
  • Policies and Rules: This section of the exam measures the skills of Security Administrators and focuses on how PingAccess evaluates paths for applying policies and resources. It covers the role of different rule types, their configuration, and the implementation of rule sets and rule set groups for consistent policy enforcement.
Topic 5
  • Integrations: This section of the exam measures skills of System Engineers and explains how PingAccess integrates with token providers, OAuth and OpenID Connect configurations, and site authenticators. It also includes the use of agents and securing web, API, and combined applications through appropriate integration settings.
Topic 6
  • Security: This section of the exam measures skills of Security Administrators and highlights how to manage certificates and certificate groups. It covers the association of certificates with virtual hosts or listeners and the use of administrator roles for authentication management.
Sample PAP-001 Exam | New PAP-001 Test Vce FreeCertkingdomPDF allows all visitors to try a free demo of PAP-001 pdf questions and practice tests to assess the quality of our PAP-001 study material. Your money is 100% secure as we will ensure that you crack the Ping Identity PAP-001 test on the first attempt. You will also enjoy 24/7 efficient support from our customer support team before and after the purchase of Ping Identity PAP-001 Exam Dumps. If you face any issues while using our PAP-001 PDF dumps or PAP-001 practice exam software (desktop and web-based), contact CertkingdomPDF customer service for guidance.
Ping Identity Certified Professional - PingAccess Sample Questions (Q63-Q68):NEW QUESTION # 63
An administrator needs to use attributes that are not currently available in theIdentity Mapping Attribute Namedropdown. Which action should the administrator take?
  • A. Create a Web Session Attribute rule for the additional attributes
  • B. Request that the additional attributes be added by the token provider administrator
  • C. Request that the additional attributes be added by the web developer
  • D. Create a Rewrite Content rule for the additional attributes
Identity Mapping in PingAccess relies on attributes provided by thetoken provider(e.g., PingFederate, OIDC provider). If the desired attributes are not present in the dropdown, it means they are not being provided in the token or userinfo response.
Exact Extract:
"Attributes available in identity mappings are those provided in the web session by the token provider. If attributes are missing, they must be added to the token by the identity provider."
* Option Ais correct - the token provider administrator must configure the IdP to include the additional attributes.
* Option Bis incorrect - rewrite rules modify content but do not supply new identity attributes.
* Option Cis incorrect - developers cannot directly add identity attributes; they must come from the IdP.
* Option Dis incorrect - Web Session Attribute rules only evaluate available attributes; they don't create new ones.
ReferenceingAccess Administration Guide -Identity Mapping and Attributes
NEW QUESTION # 64
An administrator needs to configure a protected web application using theAuthorization Codelogin flow.
Which two configuration parameters must be set? (Choose 2 answers.)
  • A. OAuth Token Introspection Endpoint
  • B. OpenID Connect Issuer
  • C. Virtual Host
  • D. OAuth Client ID
  • E. OpenID Connect Login Type
Answer: D,E
When using theAuthorization Code Flowfor authentication, PingAccess must be configured with:
* AnOAuth Client IDthat identifies the application to the IdP.
* TheOpenID Connect Login Typeset to Authorization Code.
Exact Extract:
"When configuring an OIDC web session, specify the OAuth client ID and select the OpenID Connect login type (Authorization Code, Hybrid, or Implicit)."
* Option A (OAuth Token Introspection Endpoint)is not required for Authorization Code flow - token introspection is used in other cases.
* Option B (OAuth Client ID)is correct - required for OIDC authorization requests.
* Option C (OpenID Connect Issuer)is discovered automatically via metadata when you configure the token provider.
* Option D (Virtual Host)is required for application exposure but not specific to OIDC flow.
* Option E (OpenID Connect Login Type)is correct - must be set to "Authorization Code." ReferenceingAccess Administration Guide -Configuring OIDC Web Sessions
NEW QUESTION # 65
What information must be provided when setting the PingFederate Standard Token Provider for the Runtime engines?
  • A. Host
  • B. Issuer
  • C. Client ID
  • D. Port
When configuring PingAccess to use PingFederate as theStandard Token Providerfor runtime engines, PingAccess must know how to contact PingFederate. The configuration requires theHost(PingFederate base URL).
Exact Extract:
"When configuring the Standard Token Provider, specify the PingFederate host to which PingAccess engines will connect for token validation."
* Option A (Issuer)is part of OIDC metadata but not required explicitly in this configuration.
* Option B (Client ID)is needed for OAuth clients but not when defining the token provider connection itself.
* Option C (Host)is correct - this is required to connect to PingFederate.
* Option D (Port)may be included within the host definition (host:port) but is not the required field.
ReferenceingAccess Administration Guide -Configuring PingFederate as a Token Provider
NEW QUESTION # 66
For a Web Application, theid_tokenmust be transmitted through a back channel with the OIDC standards- based approach. Which action should the administrator perform in the Web Session to meet this requirement?
  • A. Set the request preservation to None
  • B. Set the login type to code
  • C. Set the request preservation to POST
  • D. Set the login type to POST
To transmit theid_tokenvia a back channel according to OIDC best practices, the application must use the Authorization Code Flow(login type =code). This ensures tokens are retrieved securely via the back channel instead of being exposed in the browser.
Exact Extract:
"For back-channel transmission of ID tokens, configure the OIDC login type as Authorization Code."
* Option Ais correct - setting login type to code ensures back-channel delivery.
* Option Bis incorrect - request preservation concerns request method persistence, not OIDC flow.
* Option Cis incorrect - POST is not a valid login type; only Code, Implicit, or Hybrid.
* Option Dis incorrect - request preservation has no bearing on token delivery.
NEW QUESTION # 67
An application owner would like customized errors for rule violations within an application. Where is this configured?
  • A. When assigning a Rule to a Resource
  • B. When combining Rules into Rule Sets
  • C. Within the Rule definition
  • D. Within the Root Resource of the Application
PingAccess allows administrators to configurecustom error pages or messagesat theRoot Resource levelof an application. This ensures that when rule violations (e.g., authorization failures) occur, the application can display tailored error responses.
Exact Extract:
"Custom error handling for rule violations is configured within the Root Resource of an application."
* Option Ais incorrect - assigning a rule to a resource does not allow defining custom errors.
* Option Bis correct - the Root Resource is where administrators define custom error handling for the entire application.
* Option Cis incorrect - Rule Sets only combine rules; they do not handle error responses.
* Option Dis incorrect - individual rule definitions do not contain custom error configurations.
ReferenceingAccess Administration Guide -Configuring Application Resources and Error Handling
NEW QUESTION # 68
We provide three versions to let the clients choose the most suitable equipment on their hands to learn the PAP-001 study materials such as the smart phones, the laptops and the tablet computers. We provide the professional staff to reply your problems about our study materials online in the whole day and the timely and periodical update to the clients. So you will definitely feel it is your fortune to buy our PAP-001 Study Materials.
Sample PAP-001 Exam: https://www.certkingdompdf.com/PAP-001-latest-certkingdom-dumps.html
