[General] 3V0-24.25 Reliable Test Forum | Latest 3V0-24.25 Exam Pass4sure
138
【General】 3V0-24.25 Reliable Test Forum | Latest 3V0-24.25 Exam Pass4sure
Posted at 2/20/2026 02:49:45      View:76 | Replies:0        Print      Only Author   [Copy Link] 1#
It can be said that all the content of the 3V0-24.25 prepare questions are from the experts in the field of masterpieces, and these are understandable and easy to remember, so users do not have to spend a lot of time to remember and learn our 3V0-24.25 exam questions. It takes only a little practice on a daily basis to get the desired results. Especially in the face of some difficult problems, the user does not need to worry too much, just learn the 3V0-24.25 Practice Guide provide questions and answers, you can simply pass the 3V0-24.25 exam.
Each format specializes in a specific study style and offers unique benefits, each of which is crucial to good Advanced VMware Cloud Foundation 9.0 vSphere Kubernetes Service (3V0-24.25) exam preparation. The specs of each VMware 3V0-24.25 Exam Questions format are listed below, you may select any of them as per your requirements.
Latest 3V0-24.25 Exam Pass4sure - Reliable 3V0-24.25 Test PreparationIn order to save a lot of unnecessary trouble to users, we have completed our Advanced VMware Cloud Foundation 9.0 vSphere Kubernetes Service study questions research and development of online learning platform, users do not need to download and install, only need your digital devices have a browser, can be done online operation of the 3V0-24.25 test guide. This kind of learning method is very convenient for the user, especially in the time of our fast pace to get VMware certification. In addition, our test data is completely free of user's computer memory, will only consume a small amount of running memory when the user is using our product. At the same time, as long as the user ensures that the network is stable when using our 3V0-24.25 Training Materials, all the operations of the learning material of can be applied perfectly.
VMware Advanced VMware Cloud Foundation 9.0 vSphere Kubernetes Service Sample Questions (Q67-Q72):NEW QUESTION # 67
A VKS Administrator needs to scale out a production Tanzu Kubernetes Grid (TKG) cluster named prod-cluster-01 to handle increased load. The goal is to increase the number of worker nodes from 3 to
5.
Review the following YAML snippet of the cluster definition:
apiVersion: run.tanzu.vmware.com/v1alpha3
kind: TanzuKubernetesCluster
metadata:
namespace: production
spec:
topology:
controlPlane:
replicas: 3
vmClass: guaranteed-medium
storageClass: gold-policy
workers:
replicas: 3
vmClass: best-effort-large
storageClass: silver-policy
Which specific modification to the YAML file or kubectl command will achieve the scaling requirement?
  • A. Delete the cluster and recreate it with the new worker count.
  • B. Run the command kubectl scale --replicas=5 tanzukubernetescluster/prod-cluster-01.
  • C. Edit the YAML to set spec.topology.controlPlane.replicas: 5 and apply the change.
  • D. Edit the YAML to set spec.topology.workers.replicas: 5 and apply the change using kubectl apply -f cluster.yaml.
NEW QUESTION # 68
A remote site has a requirement for VMware vSphere Kubernetes Service (VKS). The environment has minimal storage available. Which action ensures the Content Library does not consume all available space on the datastore?
  • A. Select theDownload contentoption and chooseWhen needed.
  • B. Use a local datastore on one of the ESXi hosts.
  • C. Select theDownload contentoption and chooseImmediately.
  • D. Create a scheduled task to download the images that are needed.
VCF 9.0 explains that VKS releases are distributed throughcontent libraries, and that when you configure asubscribed content libraryyou can choose how content is downloaded and synchronized. Critically for constrained storage sites, the documentation states you can selecton-demand ("when needed")download so thatonly the metadatais synchronized, and theactual image content is not downloadeduntil you explicitly need it-"as a result storage space is saved." This directly addresses the problem of a remote site with minimal datastore capacity: choosingWhen neededprevents the subscribed library from immediately caching all published VKS images locally. The vSphere content library guidance reinforces this behavior: with "download contents only when needed," the system synchronizesmetadata only, which "saves storage space," and you download a specific item's content only when you synchronize that item for use.
Therefore, selectingDownload content # When neededis the correct action to avoid consuming all available datastore space.
NEW QUESTION # 69
What is the purpose of a ReplicaSet in the VMware vSphere Kubernetes Service (VKS)?
  • A. To provide a stable network identity and persistent storage for stateful applications.
  • B. To ensure that a specified number of identical pods are running at all times.
  • C. To run a single instance of a pod on every node in a cluster.
  • D. To expose a set of pods as a network service with a single, stable IP address.
A ReplicaSet is a core Kubernetes workload controller used in VKS clusters to maintainavailability and steady-state capacityfor stateless applications. Its primary purpose is to ensure that adesired number of identical pod replicasare running continuously. If a pod is deleted, crashes, or is evicted because a node fails, the ReplicaSet detects that the current number of matching pods has dropped below the target and immediately creates replacement pods to restore the requested replica count. Conversely, if too many matching pods exist (for example, due to manual creation or a transient surge), it scales down by deleting excess pods to return to the desired state.
This behavior makes ReplicaSets foundational to reliable, self-healing application operation in Kubernetes and therefore in VKS. In practice, administrators and DevOps teams usually interact with ReplicaSets indirectly through higher-level controllers likeDeployments, which manage rolling updates and revisions while using ReplicaSets underneath to enforce the replica count for each version of an application. Options A, B, and D map to other Kubernetes objects (Service, StatefulSet, and DaemonSet respectively), not ReplicaSet.
NEW QUESTION # 70
A Security Architect is designing the ingress and egress traffic flow for a highly regulated PCI-DSS zone within vSphere with Tanzu.
The requirements state:
1. Ingress: All incoming HTTP/S traffic must pass through a dedicated WAF (Web Application Firewall) before reaching the Kubernetes Ingress Controller.
2. Egress: All outbound traffic from the namespace must be identifiable by a unique, persistent IP address to allow for strict firewall rules on the perimeter.
3. Isolation: The namespace must use a dedicated T1 Gateway in NSX.
Review the following design decisions.
Which configuration choices correctly support these requirements? (Select all that apply.)
  • A. Disable SNAT on the namespace to expose internal Pod IPs directly to the WAF.
  • B. Deploy a Tanzu Kubernetes Cluster with a Service of type: LoadBalancer to expose the Ingress Controller, and point the external WAF to the allocated Load Balancer VIP.
  • C. Use vDS networking with HAProxy, as it supports "Transparent Mode" for preserving client IPs better than NSX.
  • D. Define a specific Egress CIDR range for the Supervisor and ensure the namespace is assigned a specific SNAT IP (Egress IP) from this range, which is then reserved in the perimeter firewall.
  • E. Configure the Supervisor with NSX networking to ensure each namespace receives a dedicated Tier-1 Gateway and SNAT rules.
Answer: B,D,E
NEW QUESTION # 71
An administrator is tasked with making an existing vSphere Supervisor highly available by adding two additional vSphere Zones. How should the administrator perform this task?
  • A. Create a new multi-zone deployment and assign an existing vSphere cluster to it.
  • B. Select Configure, select vSphere Zones, and click Add New vSphere Zone.
  • C. You cannot add an existing Supervisor to a new vSphere Zone.
  • D. Create a new vSphere Zone and add the Supervisor to the new vSphere Zone.
In VMware Cloud Foundation 9.0 and vSphere Supervisor architectures, the decision to deploy aSingle- Zoneor aMulti-ZoneSupervisor is made at the time ofinitial enablement. A Single-Zone Supervisor is tied to a specific vSphere Cluster. A Multi-Zone Supervisor requires a minimum of three vSphere Zones (each mapped to a cluster) to be defined before the Supervisor is deployed so that the Control Plane VMs can be distributed for high availability.
Currently, there is no supported "in-place" migration path to convert a deployed Single-Zone Supervisor into a Multi-Zone Supervisor by simply adding zones later. If an organization requires the high availability provided by a three-zone architecture, the administrator must decommission the existing Single-Zone Supervisor and then re-enable the Supervisor Service using the Multi-Zone configuration wizard. This design ensures that the underlying Kubernetes Control Plane components are correctly instantiated with the necessary quorum and anti-affinity rules that can only be established during the initial "Workload Management" setup phase.
NEW QUESTION # 72
Regularly updated material content to ensure you are always practicing with the most up-to-date preparation material which covers all the changes that are made to the Advanced VMware Cloud Foundation 9.0 vSphere Kubernetes Service (3V0-24.25) exam questions from CertkingdomPDF. Our preparation material is built in such a way that it will help everyone even a beginner to reach his goal of clearing the VMware 3V0-24.25 Exam Dumps from CertkingdomPDF just in one attempt.
Latest 3V0-24.25 Exam Pass4sure: https://www.certkingdompdf.com/3V0-24.25-latest-certkingdom-dumps.html
VMware 3V0-24.25 Reliable Test Forum 1) PDF format 2) Practice Exam Software, You can find everything that you need to pass test in our 3V0-24.25 valid vce, VMware 3V0-24.25 Reliable Test Forum Now, you may wonder how to get the latest dumps after you buy, The more times you choose our 3V0-24.25 training materials, the more benefits you can get, such as free demos of our 3V0-24.25 exam dumps, three-version options, rights of updates and so on, VMware 3V0-24.25 Reliable Test Forum Why we are so popular in the market and trusted by tens of thousands of our clients all over the world?
His research involves writing programs to play, The biggest 3V0-24.25 thing Flash the runtime component) has going for it is ubiquity, 1) PDF format 2) Practice Exam Software.
You can find everything that you need to pass test in our 3V0-24.25 valid vce, Now, you may wonder how to get the latest dumps after you buy, The more times you choose our 3V0-24.25 training materials, the more benefits you can get, such as free demos of our 3V0-24.25 exam dumps, three-version options, rights of updates and so on.
2026 Reliable 100% Free 3V0-24.25 – 100% Free Reliable Test Forum | Latest Advanced VMware Cloud Foundation 9.0 vSphere Kubernetes Service Exam Pass4sureWhy we are so popular in the market Latest 3V0-24.25 Exam Pass4sure and trusted by tens of thousands of our clients all over the world?
