[General] Valid NSE5_SSE_AD-7.6 Test Vce | Certification NSE5_SSE_AD-7.6 Exam Dumps
84
General Valid NSE5_SSE_AD-7.6 Test Vce | Certification NSE5_SSE_AD-7.6 Exam Dumps
Posted at 2/20/2026 03:21:09      View101 | Replies0        Print      Only Author   [Copy Link] 1#
Our company made these NSE5_SSE_AD-7.6 practice materials with accountability. We understand you can have more chances being accepted by other places and getting higher salary or acceptance. Our Fortinet NSE 5 - FortiSASE and SD-WAN 7.6 Core Administrator training materials are made by our responsible company which means you can gain many other benefits as well. We offer NSE5_SSE_AD-7.6 free demos for your reference, and send you the new updates if our experts make them freely. If you fail the exam after using our NSE5_SSE_AD-7.6 exam prep unfortunately, we will switch other versions for you or return full refund.
Fortinet NSE5_SSE_AD-7.6 Exam Syllabus Topics:
  • SASE Deployment: This domain covers FortiSASE administration settings, user onboarding methods, and integration with SD-WAN infrastructure.
  • Decentralized SD-WAN: This domain covers basic SD-WAN implementation including configuring members, zones, and performance SLAs to monitor network quality.
  • Rules and Routing: This section addresses configuring SD-WAN rules and routing policies to control and direct traffic flow across different links.
  • Analytics: This domain covers analyzing SD-WAN and FortiSASE logs to monitor traffic behavior, identify security threats, and generate reports.
Topic 5
  • Secure Internet Access (SIA) and Secure SaaS Access (SSA): This section focuses on implementing security profiles for content inspection and deploying compliance rules to managed endpoints.
Fortinet NSE 5 - FortiSASE and SD-WAN 7.6 Core Administrator actual exam questions & NSE5_SSE_AD-7.6 valid study dumps & Fortinet NSE 5 - FortiSASE and SD-WAN 7.6 Core Administrator test practice torrentThe Fortinet NSE 5 - FortiSASE and SD-WAN 7.6 Core Administrator certification provides beginners and professionals with multiple great career opportunities. The Fortinet Exam NSE5_SSE_AD-7.6 examination is one of the most demanding Fortinet tests. There are multiple benefits you can get after cracking the NSE5_SSE_AD-7.6 test. The top-listed benefits include skill verification, high-paying jobs, bonuses, and promotions in your current organizations. All these benefits of earning the NSE5_SSE_AD-7.6 certificate help you level up your career in the tech sector.
Fortinet NSE 5 - FortiSASE and SD-WAN 7.6 Core Administrator Sample Questions (Q25-Q30):NEW QUESTION # 25
An administrator is configuring SD-WAN to load balance their network traffic. Which two things should they consider when setting up SD-WAN? (Choose two.)
  • A. SD-WAN load balancing is possible only when using the manual and the best quality strategies.
  • B. You can select the outbandwidth hash mode with all strategies that allow load balancing.
  • C. When applicable, FortiGate load balances traffic through all members that meet the SLA target.
  • D. Only the manual and lowest cost (SLA) strategies allow SD-WAN load balancing.
FortiGate load balances traffic across all members that meet the SLA targets, depending on the strategy used.
The outbandwidth hash mode can be selected with load-balancing strategies to distribute traffic based on flow characteristics.
NEW QUESTION # 26
In which order does a FortiGate device consider the following elements shown in the left column during the route lookup process?
Select the element in the left column, hold and drag it to a blank position in the column on the right. Place the four correct elements in order, placing the first element in the first position at the top of the column. Once you place an element, you can move it again if you want to change your answer before moving to the next question. You need to drop four elements in the work area.
Select and drag the screen divider to change the viewable area of the source and work areas.
NEW QUESTION # 27
You have configured the performance SLA with the probe mode as Prefer Passive.
What are two observable impacts of this configuration? (Choose two.)
  • A. FortiGate can offload the traffic that is subject to passive monitoring to hardware.
  • B. After FortiGate switches to active mode, the SLA performance rule falls back to passive monitoring after 3 minutes.
  • C. FortiGate passively monitors the member if ICMP traffic is passing through the member.
  • D. FortiGate passively monitors the member if TCP traffic is passing through the member.
  • E. During passive monitoring, the SLA performance rule cannot detect dead members.
Answer: D,E
When "Prefer Passive" is set, FortiGate attempts to passively monitor the health of SD-WAN members using real application traffic like TCP sessions, collecting statistics such as latency, jitter, and packet loss from actual observed flows.
Passive monitoring does not generate probe packets; it relies entirely on existing traffic. If there is no matching traffic, health check data is unavailable, meaning dead members may go undetected when only passive monitoring is active.
NEW QUESTION # 28
Refer to the exhibit, which shows the SD-WAN rule status and configuration.
Based on the exhibit, which change in the measured packet loss will make HUB1-VPN3 the new preferred member? (Choose one answer)
  • A. When HUB1-VPN3 has 4% packet loss
  • B. When HUB1-VPN1 has 12% packet loss
  • C. When all three members have the same packet loss
  • D. When HUB1-VPN1 has 4% packet loss
According to theSD-WAN 7.6 Core Administratorstudy guide and theFortiOS 7.6 Administration Guide, the selection process for theBest Quality (priority)strategy depends on two primary factors: the measured link quality metric and the configured member priority order.
Based on the provided exhibit (image_b40dfc.png), we can determine the following:
* Strategy and Metric: The rule is in Mode(priority) (Best Quality) using link-cost-factor(packet loss).
* Strict Comparison: The link-cost-threshold is set to0. This means there is no "advantage" given to the current preferred link; the FortiGate performs a strict comparison where the link with the objectively best metric is chosen.
* Tie-Breaker Logic: When multiple links have thesamepacket loss, the FortiGate uses theMember Priority Orderdefined in the rule (set priority-members 6 4 5) as the tie-breaker.
* Member 6 (HUB1-VPN3)is the highest priority.
* Member 4 (HUB1-VPN1)is the second priority.
* Member 5 (HUB1-VPN2)is the lowest priority.
* Current State: HUB1-VPN1 is currently selected because its packet loss (2.000%) is lower than HUB1-VPN2 (4.000%) and HUB1-VPN3 (12.000%). Even though HUB1-VPN3 has a higher configuration priority, its significantly higher packet loss prevents it from being chosen.
Evaluation of Options:
* Option A (Verified): If all three members have thesame packet loss(e.g., they all show 2%), the quality metrics are equal. The SD-WAN engine then refers to the priority-members list. Since HUB1- VPN3 (Seq 6) is the first member in that list, it will immediately become the new preferred member.
* Option B: If HUB1-VPN1 reaches 4%, it matches HUB1-VPN2 (4%). HUB1-VPN3 remains at 12%.
The system will choose between VPN1 and VPN2. Since VPN1 (Seq 4) is higher in the priority list than VPN2 (Seq 5), HUB1-VPN1 stays preferred.
* Option C: If HUB1-VPN1 reaches 12%, it matches HUB1-VPN3. However, HUB1-VPN2 is still better at4.000%. Therefore, HUB1-VPN2 would become the new preferred member, not HUB1-VPN3.
* Option D: If HUB1-VPN3 drops to 4%, it matches HUB1-VPN2. However, HUB1-VPN1 is still the best link at2.000%, so it remains selected.
NEW QUESTION # 29
Which statement about security posture tags in FortiSASE is correct?
  • A. Tags are static and do not change with endpoint status.
  • B. Only one tag can be assigned to an endpoint.
  • C. Multiple tags can be assigned to an endpoint, but only one is used for evaluation.
  • D. Multiple tags can be assigned to an endpoint and used for evaluation.
Security posture tags in FortiSASE dynamically assess endpoint compliance based on rules like OS version, antivirus status, and FortiClient connectivity. Endpoints receive multiple tags simultaneously (e.g., for Windows 11, active AV, and SASE connection), which firewalls then evaluate in policies for ZTNA access control.
NEW QUESTION # 30
At the moment you come into contact with our NSE5_SSE_AD-7.6 learning guide you can enjoy our excellent service. You can ask our staff about what you want to know. After full understanding, you can choose to buy our NSE5_SSE_AD-7.6 exam questions. If you use the NSE5_SSE_AD-7.6 study materials, you have problems that you cannot solve. Just contact with us via email or online, we will deal with you right away. And we offer 24/7 online service. So if you have any problem, you can always contact with us no matter any time it is.
Certification NSE5_SSE_AD-7.6 Exam Dumps: https://www.test4cram.com/NSE5_SSE_AD-7.6_real-exam-dumps.html
