[General] Fortinet FCP_FCT_AD-7.4 Exam Sims | FCP_FCT_AD-7.4 New Braindumps
140
【General】 Fortinet FCP_FCT_AD-7.4 Exam Sims | FCP_FCT_AD-7.4 New Braindumps
Posted at 2/20/2026 04:20:57      View:92 | Replies:1        Print      Only Author   [Copy Link] 1#
All these FCP_FCT_AD-7.4 exam dumps formats contain real, updated, and error-free FCP - FortiClient EMS 7.4 Administrator (FCP_FCT_AD-7.4) exam questions that prepare you for the final FCP_FCT_AD-7.4 exam. To give you an idea about the top features of FCP_FCT_AD-7.4 Exam Dumps, a free demo download facility is being offered to FCP - FortiClient EMS 7.4 Administrator candidates. This free FCP_FCT_AD-7.4 exam questions demo download facility is available in all three FCP_FCT_AD-7.4 exam dumps formats.
You can make your dream of passing the Fortinet FCP_FCT_AD-7.4 exam come true with DumpsTests updated Fortinet FCP_FCT_AD-7.4 practice test questions. DumpsTests offer Fortinet FCP_FCT_AD-7.4 the latest dumps in three formats. Fortinet FCP_FCT_AD-7.4 desktop practice test software creates a real exam environment so that you can feel like attempting the FCP - FortiClient EMS 7.4 Administrator FCP_FCT_AD-7.4 actual exam.
FCP_FCT_AD-7.4 New Braindumps | Latest FCP_FCT_AD-7.4 Dumps BookIn today's competitive IT industry, passing Fortinet certification FCP_FCT_AD-7.4 exam has a lot of benefits. Gaining Fortinet FCP_FCT_AD-7.4 certification can increase your salary. People who have got Fortinet FCP_FCT_AD-7.4 certification often have much higher salary than counterparts who don't have the certificate. But Fortinet Certification FCP_FCT_AD-7.4 Exam is not very easy, so DumpsTests is a website that can help you grow your salary.
Fortinet FCP - FortiClient EMS 7.4 Administrator Sample Questions (Q50-Q55):NEW QUESTION # 50
Refer to the exhibit, which shows the Zero Trust Tagging Rule Set configuration.
Which two statements about the rule set are true? (Choose two.)
  • A. The endpoint must satisfy that only AV software is installed and running.
  • B. The endpoint must satisfy that antivirus is installed and running and Windows 10 is running.
  • C. The endpoint must satisfy that only Windows 10 is running.
  • D. The endpoint must satisfy that only Windows Server 2012 R2 is running.
Based on the Zero Trust Tagging Rule Set configuration shown in the exhibit:
* The rule set includes two conditions:
* AV Software is installed and running
* OS Version is Windows Server 2012 R2 or Windows 10
* The Rule Logic is specified as "(1 and 3) or 2," meaning:
* The endpoint must have antivirus software installed and running and must be running Windows
10.
* Alternatively, the endpoint must be running Windows Server 2012 R2.
Therefore, the endpoint must satisfy either:
* Antivirus is installed and running and Windows 10 is running.
* Windows Server 2012 R2 is running.
References
* FortiClient EMS 7.2 Study Guide, Zero Trust Tagging Rule Set Configuration Section
* Fortinet Documentation on Configuring Zero Trust Tagging Rules and Logic
NEW QUESTION # 51
A company must integrate the FortiClient EMS with their existing identity management infrastructure for user authentication, and implement and enforce administrative access with multi-factor authentication (MFA).
Which two authentication methods can they use in this scenario? (Choose two answers)
  • A. TACACS
  • B. LDAPS
  • C. RADIUS
  • D. SAML
According to theFortiClient EMS 7.4 Administration Guide, for an organization to integrate with an identity management infrastructure while enforcing administrative access with Multi-Factor Authentication (MFA), the primary supported methods for remote administrator authentication areRADIUSandSAML.
1. RADIUS (Answer B)
* Identity Integration:FortiClient EMS allows administrators to addRADIUS serversas an authentication source under theAdministration > Authentication Serverssection.
* MFA Support:RADIUS is a standard protocol for enforcing MFA. In this scenario, FortiClient EMS acts as a RADIUS client to an external MFA provider (such as FortiAuthenticator, RSA Authentication Manager, or Duo).
* Workflow:When an administrator attempts to log in to the EMS console, EMS sends an Access- Request to the RADIUS server. If the provider requires MFA, it can challenge the user (via push notification or token code) before sending an Access-Accept back to EMS.
2. SAML (Answer D)
* Modern Identity Management:SAML (Security Assertion Markup Language) is the preferred method for integrating with modern cloud and on-premises Identity Providers (IdPs) likeMicrosoft Entra ID (formerly Azure AD),Okta,AD FS, orFortiAuthenticator.
* Native MFA Enforcement:By using SAML SSO, the authentication and MFA process are handled entirely by the IdP. The EMS server acts as the Service Provider (SP). When an admin logs in, they are redirected to the IdP, where the company's existing MFA policies (Conditional Access, etc.) are enforced before the user is granted access back to the EMS console.
* EMS Configuration:The curriculum details specific SAML SSO configurations for various IdPs under theSAML SSOsection of the Administration Guide.
3. Why Other Options are Incorrect/Insufficient
* A. LDAPS:While FortiClient EMS supports importing users fromActive Directory (ADDS)via LDAP
/LDAPS for endpoint management and basic admin login, standard LDAPS does not natively support or enforce an MFA challenge-response workflow in the same integrated way that RADIUS or SAML does for administrative console access.
* C. TACACS:TACACS+ is primarily used for device administration on networking equipment (like FortiGate) and is not a listed or standard method for administrative authentication within the FortiClient EMS software documentation.
NEW QUESTION # 52
Which security fabric component sends a notification to quarantine an endpoint after IOC detection in the automation process?
  • A. FortiAnalyzer
  • B. D. Forti Gate
  • C. FortiClient
  • D. ForbClient EMS
NEW QUESTION # 53
Refer to the exhibit, which shows FortiClient EMS deployment, profiles.
When an administrator creates a deployment profile on FortiClient EMS. which statement about the deployment profile is true?
  • A. Deployment-2 will install FortiClient on both the AD group and workgroup.
  • B. Deployment-2 will upgrade FortiClient on both the AD group and workgroup.
  • C. Deployment-1 will install FortiClient on new AO group endpoints.
  • D. Deployment-1 will upgrade FortiClient only on the workgroup.
* Deployment Profiles Analysis:
* Deployment-1 has the "First-Time-Installation" package and is assigned to "All Groups" with a priority of 1 but is not enabled.
* Deployment-2 has the "To-Upgrade" package, is assigned to both "All Groups" and "trainingAD.
training.lab," with a priority of 2 and is enabled.
* Evaluating Deployment-2:
* Deployment-2 will upgrade FortiClient on both "All Groups" and "trainingAD.training.lab" since it is enabled and assigned to these groups. This includes both AD (Active Directory) groups and workgroups.
* Conclusion:
* Since Deployment-2 is set to upgrade FortiClient on all the assigned groups and workgroups, the correct answer is A.
FortiClient EMS deployment and profile documentation from the study guides.
NEW QUESTION # 54
An administrator installs FortiClient on Windows Server.
What is the default behavior of real-time protection control?
  • A. Real-time protection must update AV signature database
  • B. Real-time protection is disabled
  • C. Real-time protection sends malicious files to FortiSandbox when the file is not detected locally
  • D. Real-time protection must update the signature database from FortiSandbox
When FortiClient is installed on a Windows Server, the default behavior for real-time protection control is:
* Real-time protection is disabled:By default, FortiClient does not enable real-time protection on server installations to avoid potential performance impacts and because servers typically have different security requirements compared to client endpoints.
Thus, real-time protection is disabled by default on Windows Server installations.
References
* FortiClient EMS 7.2 Study Guide, Real-time Protection Section
* Fortinet Documentation on FortiClient Default Settings for Server Installations
NEW QUESTION # 55
DumpsTests FCP_FCT_AD-7.4 Questions have helped thousands of candidates to achieve their professional dreams. Our FCP - FortiClient EMS 7.4 Administrator (FCP_FCT_AD-7.4) exam dumps are useful for preparation and a complete source of knowledge. If you are a full-time job holder and facing problems finding time to prepare for the FCP - FortiClient EMS 7.4 Administrator (FCP_FCT_AD-7.4) exam questions, you shouldn't worry more about it.
FCP_FCT_AD-7.4 New Braindumps: https://www.dumpstests.com/FCP_FCT_AD-7.4-latest-test-dumps.html
They would choose this difficult Fortinet certification FCP_FCT_AD-7.4 exam to get certification and gain recognition in IT area, Fortinet FCP_FCT_AD-7.4 Exam Sims Besides, the software version can simulate the real test environment, which is favorable for people to better adapt to the examination atmosphere, It is a well-researched booklet for all those professionals who are looking to pass the FCP_FCT_AD-7.4 New Braindumps - FCP - FortiClient EMS 7.4 Administrator exam through selective study.
Throughput Accounting is appropriate for managing general systems Latest FCP_FCT_AD-7.4 Dumps Book because it focuses on Throughput, which is the desired adaptive behavior of the system, Stephen: It would help.
They would choose this difficult Fortinet Certification FCP_FCT_AD-7.4 Exam to get certification and gain recognition in IT area, Besides, the software version can simulate the real test FCP_FCT_AD-7.4 Exam Tutorials environment, which is favorable for people to better adapt to the examination atmosphere.
FCP_FCT_AD-7.4 exam materials & FCP_FCT_AD-7.4 practice questions & FCP_FCT_AD-7.4 study guideIt is a well-researched booklet for all those FCP_FCT_AD-7.4 professionals who are looking to pass the FCP - FortiClient EMS 7.4 Administrator exam through selective study, Because we endorse customers' opinions and drive of passing the FCP_FCT_AD-7.4 certificate, so we are willing to offer help with full-strength.
For candidates who preparing for the FCP_FCT_AD-7.4 New Braindumps exam, knowing the latest information for the exam is quite necessary.
Posted at 2/22/2026 01:58:03        Only Author  2#
Your article is superb, I’m so grateful for your generosity in sharing! Free New test 200-901 collection file materials—promotion and salary increase are just a click away!
