[General] Latest AZ-104 Exam Labs - Valid AZ-104 Learning Materials
140
【General】 Latest AZ-104 Exam Labs - Valid AZ-104 Learning Materials
Posted at 2/20/2026 04:52:51      View:81 | Replies:0        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of ValidVCE AZ-104 dumps for free: https://drive.google.com/open?id=1za3UJA1-DSZZVHXzYpnGLv6xbtRzygIb
ValidVCE has put emphasis on providing our AZ-104 exam questions with high quality products with high passing rate. Many exam candidates are uninformed about the fact that our AZ-104 preparation materials can help them with higher chance of getting success than others. It is all about efficiency and accuracy. And what is more charming than our AZ-104 Study Guide with a passing rate as 98% to 100%? The answer is no. Our AZ-104 practice quiz is unique in the market.
The pass rate of the AZ-104 exam braindumps is 98.75%, and pass guarantee and money back guarantee, if you indeed fail in the exam by using AZ-104 exam dumps of us , we will refund your money or if you need to attend other exam, we will replace other 2 valid exam dumps for free. Besides, the AZ-104 Exam Dumps contain both quality and certain quantity, it is good for you to practice and pass the exam successfully.
Valid AZ-104 Learning Materials & Official AZ-104 Practice TestIf you are prepared to take the AZ-104 exam with the help of excellent AZ-104 learning materials on our website, the choice is made brilliant. Our AZ-104 training materials are your excellent choices, especially helpful for those who want to pass the AZ-104 Exam without bountiful time and eager to get through it successfully. Besides that, our AZ-104 study questions have three versions: PDF version, Soft version and APP version, which can be interestinng and helpful for you to choose.
To take the AZ-104 exam, candidates should have a good understanding of Azure fundamentals, including virtualization, networking, and storage. They should also be familiar with Azure security and compliance, as well as Azure pricing and support. Candidates who are new to Azure may wish to consider taking an Azure Fundamentals course before attempting the AZ-104 Exam.
Microsoft Azure Administrator Sample Questions (Q378-Q383):NEW QUESTION # 378
You have an Azure subscription that contains the resources shown in the following table.
You need to configure a proximity placement group for VMSS1.
Which proximity placement groups should you use?
  • A. Proximity1 only
  • B. Proximity 1 and Proximity3 only
  • C. Proximity2 only
  • D. Proximity 1, Proximity2, and Proximity3
Placement Groups is a capability to achieve co-location of your Azure Infrastructure as a Service (IaaS) resources and low network latency among them, for improved application performance.
Azure proximity placement groups represent a new logical grouping capability for your Azure Virtual Machines, which in turn is used as a deployment constraint when selecting where to place your virtual machines. In fact, when you assign your virtual machines to a proximity placement group, the virtual machines are placed in the same data center, resulting in lower and deterministic latency for your applications.
The VMSS should share the same region, even it should be the same zone as proximity groups are located in the same data center. Accordingly, it should be proximity 2 only.
https://azure.microsoft.com/en-u ... ty-placement-groups
NEW QUESTION # 379
You have an Azure subscription that contains the virtual machines shown in the following table.
javascript:void(0)
You deploy a load balancer that has the following configurations:
* Name: LB1
* Type internal
* SKU: Standard
* Virtual network VNET1
You need to ensure that you can add VM1 and VM2 to the backend pool of LB1.
Solution: You create a Basic SKU public IP address, associate the address to the network interface of VM1, and then start VM1.
Does this meet the goal?
  • A. No
  • B. Yes
You can only attach virtual machines that are in the same location and on the same virtual network as the LB.
Virtual machines must have a standard SKU public IP or no public IP.
The LB needs to be a standard SKU to accept individual VMs outside an availability set or vmss. VMs do not need to have public IPs but if they do have them they have to be standard SKU. Vms can only be from a single network. When they don't have a public IP they are assigned an ephemeral IP.
Also, when adding them to a backend pool, it doesn't matter in which status are the VMs.
Note: Load balancer and the public IP address SKU must match when you use them with public IP addresses.
NEW QUESTION # 380
You have an on-premises network that contains a Hyper-V host named Host1. Host1 runs Windows Server
2016 and hosts 10 virtual machines that run Windows Server 2016.
You plan to replicate the virtual machines to Azure by using Azure Site Recovery.
You create a Recovery Services vault named ASR1 and a Hyper-V site named Site1.
You need to add Host1 to ASR1.
What should you do?
  • A. Download the installation file for the Azure Site Recovery Provider.
    Download the vault registration key.
    Install the Azure Site Recovery Provider on Host1 and register the server.
  • B. Download the installation file for the Azure Site Recovery Provider.
    Download the storage account key.
    Install the Azure Site Recovery Provider on each virtual machine and register the virtual machines.
  • C. Download the installation file for the Azure Site Recovery Provider.
  • D. Download the installation file for the Azure Site Recovery Provider.
Below are the steps you need to perform in this scenario. Refer the link mentioned in the reference section.
To set up the source environment, you create a Hyper-V site and add to that site the Hyper-V hosts containing VMs that you want to replicate. Then, you download and install the Azure Site Recovery Provider and the Azure Recovery Services agent on each host, and register the Hyper-V site in the vault.
Download the Vault registration key. You need this when you install the Provider. The key is valid for five days after you generate it.
Install the Azure Site Recovery Provider on Host1.
Install the downloaded setup file (AzureSiteRecoveryProvider.exe) on each Hyper-V host that you want to add to the Hyper-V site. Setup installs the Azure Site Recovery Provider and Recovery Services agent on each Hyper-V host.
Register the server
In Registration, after the server is registered in the vault, select Finish.
https://docs.microsoft.com/en-us ... er-v-azure-tutorial
NEW QUESTION # 381
You have an Azure subscription that contains a storage account named storage1. The subscription is linked to an Azure Active Directory (Azure AD) tenant named contoso.com that syncs to an on-premises Active Directory domain.
The domain contains the security principals shown in the following table.
In Azure AD, you create a user named User2.
The storage1 account contains a file share named share1 and has the following configurations.
Text Description automatically generated
https://docs.microsoft.com/en-us ... ssions?tabs=azure-p
NEW QUESTION # 382
You create a Recovery Services vault backup policy named Policy1 as shown in the following exhibit:
Box 1: 10 years
D18912E1457D5D1DDCBD40AB3BF70D5D
The yearly backup point occurs to 1 March and its retention period is 10 years.
Box 2: 36 months
The monthly backup point occurs on the 1st of every month and its retention period is 36 months.
NEW QUESTION # 383
We provide AZ-104 exam torrent which are of high quality and can boost high passing rate and hit rate. Our passing rate of AZ-104 training guide is 99% and thus you can reassure yourself to buy our product and enjoy the benefits brought by our AZ-104 exam materials. Our AZ-104 Learning Engine is efficient and can help you master the AZ-104 guide torrent in a short time and save your energy. The AZ-104 exam material we provide is compiled by experts and approved by the professionals who boost profound experiences.
Valid AZ-104 Learning Materials: https://www.validvce.com/AZ-104-exam-collection.html
DOWNLOAD the newest ValidVCE AZ-104 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1za3UJA1-DSZZVHXzYpnGLv6xbtRzygIb
