[General] PEGACPRSA22V1 Reliable Test Bootcamp & PEGACPRSA22V1 Certification Materials
98
General PEGACPRSA22V1 Reliable Test Bootcamp & PEGACPRSA22V1 Certification Materials
Posted at 2/20/2026 07:10:14      View101 | Replies0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of PassTorrent PEGACPRSA22V1 dumps from Cloud Storage: https://drive.google.com/open?id=1H3y3Tfb4aa7OECxw3wSStzIZQi2up9fn
Our PEGACPRSA22V1 exam materials are compiled by experts and approved by the professionals who are experienced. They are revised and updated according to the pass exam papers and the popular trend in the industry. The language of our PEGACPRSA22V1 exam torrent is simple to be understood and our PEGACPRSA22V1 test questions are suitable for any learners. Only 20-30 hours are needed for you to learn and prepare our PEGACPRSA22V1 Test Questions for the exam and you will save your time and energy. No matter you are the students or the in-service staff you are busy in your school learning, your jobs or other important things and can't spare much time to learn.
We are a team of certified professionals with lots of experience in editing PEGACPRSA22V1 exam questions. Every candidate should have more than 11 years' education experience in this filed of PEGACPRSA22V1 study guide. We have rather a large influence over quite a quantity of candidates. We are more than more popular by our high passing rate and high quality of our PEGACPRSA22V1 Study Guide. Our education team of professionals will give you the best of what you deserve. If you are headache about your PEGACPRSA22V1 certification exams, our PEGACPRSA22V1 training materials will be your best select.
PEGACPRSA22V1 Certification Materials - Valid Braindumps PEGACPRSA22V1 SheetIf you purchasing the PEGACPRSA22V1 study materials designed by many experts and professors from our company, we can promise that our online workers are going to serve you day and night during your learning period. If you have any questions about our study materials, you can send an email to us, and then the online workers from our company will help you solve your problem in the shortest time. So do not hesitate to buy our PEGACPRSA22V1 Study Materials.
Pegasystems Certified Pega Robotics System Architect 22 Sample Questions (Q46-Q51):NEW QUESTION # 46
As pan of the initial development of a robotic project, you are using targeted step creation lo interrogate a text input control. The system invokes the automation from a separate automation, and the value of the text input uses a value that is passed into the recorded automation.
In the Recording Steps list, move all of the options to the Ordered Recording Steps column and place them in the correct order.
(Correct Order):
* Hover your pointer over the control.
* Click the Gear icon.
* Set the Action to Set Text.
* In the Value list, select Create New.
* Set the Value source to Input parameter.
* In the Name field, enter the name of the input parameter.
* Click Submit to save the input parameter.
* Click Save to save the step.
Targeted Step Creation is a Pega Robot Studio feature used to record automation steps directly by interacting with an interrogated control (for example, typing into a textbox). When the automation being recorded needs to receive data from another automation, an input parameter is configured as the value source for the recorded step.
According to the Pega Robotics System Design and Implementation Guide, section "Recording Steps and Configuring Input Parameters":
"When recording a targeted step for an input control:
* Hover over the target control and select the Gear icon to open the recording configuration.
* Choose the appropriate action (for example, Set Text for text boxes).
* Create a new value reference and select Input parameter as the value source.
* Assign a name to the input parameter that will be passed from the calling automation.
* Submit and save the step to finalize the recording."
Detailed Step Reasoning:
* This initializes the control recognition in targeted step creation mode.
* Opens the step configuration dialog for the selected control.
* Defines the intended action for the control (entering text).
* Creates a new value definition to assign data to the control.
* Ensures that the value for the text input will come from an external automation that invokes this one.
* Defines the name of the input variable so that it can be referenced when calling this automation.
* Confirms and stores the parameter definition.
* Finalizes the recorded step in the automation sequence.
Final Ordered Steps:
Reference:Extracted and verified from Pega Robotics System Design and Implementation Guide, Recording Steps, Targeted Step Creation, and Input Parameter Configuration section (Pega Robotics 19.1 and later).
NEW QUESTION # 47
When interrogating an application in a Chrome or Edge browser without X-ray Vision enabled, Pega Robot Studio uses only three match rules to uniquely identify the control. Which three match rules does Pega Robot Studio use when interrogating Chrome or Edge? (Choose Three)
  • A. Web Control Children match rule
  • B. Control Children match rule
  • C. Native Control match rule
  • D. Attribute Value match rule
  • E. Element Path match rule
  • F. Property Value match rule
Answer: D,E,F
Comprehensive and Detailed Explanation From Pega Robotics System Exact Extract:
According to the Pega Robotics Interrogation and Matching Engine Documentation:
"When you interrogate controls in a web application using Chrome or Edge browsers without X-ray Vision, Pega Robot Studio utilizes a simplified set of match rules because these browsers do not expose a full DOM structure with automation identifiers." The documentation specifies:
"In non-X-ray Vision interrogation mode, the following three match rules are applied automatically to identify a control:
* Attribute Value Match Rule - Matches a control by its defined attribute (such as 'id', 'name', or 'class').
* Property Value Match Rule - Matches the control based on its property values exposed during interrogation (for example, 'InnerText' or 'TagName').
* Element Path Match Rule - Matches the control by its relative position in the DOM hierarchy." It also states:
"Without X-ray Vision, browser-specific identifiers and deep hierarchical context are not available; therefore, only the Attribute Value, Property Value, and Element Path rules are utilized for Chrome and Edge interrogation." References (Exact Extract Source):
* Pega Robotics Studio User Guide - Web Adapter and Match Rules Section
* Pega Academy - Robotics System Architect Course (Interrogation in Web Applications)
* Pega Robotics Help - Interrogation with and without X-ray Vision
Final Verified answer: B, C, F
NEW QUESTION # 48
You add a MessageDialog component to an automation. Based on the following image, which option shows the configuration settings that generates the message dialog?
  • A. Exhibit B
  • B. Exhibit C
  • C. Exhibit D
  • D. Exhibit A
NEW QUESTION # 49
To modify an object's default properties before use in a project, which setting must be updated?
  • A. Prefix Types
  • B. Naming Rules
  • C. Type Prefixes
  • D. Type Name
NEW QUESTION # 50
Pega Robotic Coding Standards suggest organization of project components. You have added the _GC_CRM project item to the CRMPrj.
Which three components are recommended to be placed in the _GC_CRM project item? (Choose three.)
  • A. ForLoop
  • B. messageDialog
  • C. dateTimeUtils
  • D. stringUtils
  • E. Switch
Answer: B,C,D
NEW QUESTION # 51
Our PEGACPRSA22V1 exam torrent has a high quality that you cant expect. I think our Certified Pega Robotics System Architect 22 prep torrent will help you save much time, and you will have more free time to do what you like to do. I can guarantee that you will have no regrets about using our PEGACPRSA22V1 Test Braindumps When the time for action arrives, stop thinking and go in, try our PEGACPRSA22V1 exam torrent, you will find our products will be a very good choice for you.
PEGACPRSA22V1 Certification Materials: https://www.passtorrent.com/PEGACPRSA22V1-latest-torrent.html
Our website is the single best training online tools to find your PEGACPRSA22V1 practice test and to study for your Certified Pega Robotics System Architect 22 real exam, Pegasystems PEGACPRSA22V1 Reliable Test Bootcamp In this competitive IT fields, it is essential to improve your ability in order to get better development, Our latest training materials about Pegasystems PEGACPRSA22V1 Certification Materials PEGACPRSA22V1 Certification Materials - Certified Pega Robotics System Architect 22 passleader review is developed by our professional team's constantly study of PEGACPRSA22V1 Certification Materials - Certified Pega Robotics System Architect 22 free dumps certification, Now let me acquaint you with features of out PEGACPRSA22V1 tesking vce.
Devising a workable plan involves a great deal Verified PEGACPRSA22V1 Answers of lucid thinking, collaboration, refinement, and documentation, Show or Hide the Layers Palette, Our website is the single best training online tools to find your PEGACPRSA22V1 Practice Test and to study for your Certified Pega Robotics System Architect 22 real exam.
Desktop Pegasystems PEGACPRSA22V1 Practice Exam SoftwareIn this competitive IT fields, it is essential PEGACPRSA22V1 Reliable Test Bootcamp to improve your ability in order to get better development, Our latest training materials about Pegasystems Certified Pega Robotics System Architect 22 passleader review is PEGACPRSA22V1 developed by our professional team's constantly study of Certified Pega Robotics System Architect 22 free dumps certification.
Now let me acquaint you with features of out PEGACPRSA22V1 tesking vce, Do not hesitate and act now.
P.S. Free 2026 Pegasystems PEGACPRSA22V1 dumps are available on Google Drive shared by PassTorrent: https://drive.google.com/open?id=1H3y3Tfb4aa7OECxw3wSStzIZQi2up9fn
