[General] NSK300}ȥ`󥰡NSK300}ץ
90
General NSK300}ȥ`󥰡NSK300}ץ
Posted at 2/20/2026 07:55:21      View178 | Replies1        Print      Only Author   [Copy Link] 1#
P.S.GoShikenGoogle DriveǹФƤoϤ2026 Netskope NSK300ףhttps://drive.google.com/open?id=13VssXwQEKPkd1E0yrHWqg1WjZDPBz0vS
NetskopeNSK300ԇY˺ϸ񤹤뤿ˤηޤҡGoShikenṩ뷽һĤʤΤǤҡITTɤNetskopeNSK300եȤäƤȤʤԷ֤θߤ餫˸Ф뤳ȤǤޤNetskopeNSK300ԇYϳ˸¤Ƥޤ顢ʤһ¤YϤṩ뤿ˡҡϤُһgΟoϸ¥`ӥṩƤʤ˰Ĥޤ
Netskope NSK300 JԇYγ}죺
ȥԥå}
ȥԥå 1
  • Netskope ƥ 饦 ץåȥե`: Netskope Υ`ƥ㡢չ_xk֫ҪʙCܤص׵ĤǤޤ
ȥԥå 2
  • ƥ ݥꥷ`: Υȥԥåu 1 Ĥϡ饦 ꥽`ȥץꥱ`ˌ뤭Ἒƥ `ɤȹǤ
ȥԥå 3
  • 饦 ƥθ: ΥȥԥåǤϡ٥ ץ饯ƥץ饤Ҫ饦 ƥ{vĤˤĤhޤ
ȥԥå 4
  • 饦{ΗʳȌ: ӛ¤Ǥϡ{̽{ˡ󥷥ǥȌΤ˥饦ɭh Netskope ʹä뷽ˤĤhޤ
Netskope NSK300JԇYYХxGoShikenϳ˘I˜ʤؤƤޤ¤NSK300gHΥפζڵĤԇY}˾ͨƤ댟TҤơˤϤʤ֪R|Ĥ򜺤ȤǤޤޤNSK300ԇYƷ|^Ƥޤꡢ͘˸Ʒ|NSK300g̲Ĥṩ뤳Ȥˌ뤳Ȥǡ٤ƤΥƥĤgӛ˲Ƿʲ֤Ǥ뤳Ȥ^Ǥޤ
Netskope Certified Cloud Security Architect J NSK300 ԇY} (Q28-Q33):| # 28
You want customers to configure Real-time Protection policies. In which order should the policies be placed in this scenario?
  • A. RBI, CASB, Web, Threat
  • B. CASB, RBI, Threat, Web
  • C. Threat, RBI, CASB, Web
  • D. Threat, CASB, RBI, Web
⣺C
| # 29
You are deploying the Netskope Client in a multi-user VDI environment and need to determine the command to deploy the MSI.
Which three parameters are required in this scenario? (Choose three.)
  • A. mode=peruserconfig
  • B. host=
  • C. autoupdate=on
  • D. installmode=IDP
  • E. token=
⣺ABE
| # 30
You are deploying the Netskope Client to Windows devices. The following command line would be used to install the client MSI file:
In this scenario, what is <token> referring to in the command line?
  • A. a private token given to you by the SCCM administrator
  • B. the Netskope organization ID
  • C. a Netskope user identifier
  • D. the URL of the IdP used to authenticate the users
⣺B
h
In the context of deploying the Netskope Client to Windows devices, <token> in the command line refers to the Netskope organization ID. This is a unique identifier associated with your organization's account within the Netskope security cloud. It is used during the installation process to ensure that client devices are registered and managed under the correct organizational account, enabling appropriate security policies and configurations to be applied. Reference: The answer can be inferred from general knowledge about installing software clients and isn't directly available on Netskope's official resources.
| # 31
You are building an architecture plan to roll out Netskope for on-premises devices. You determine that tunnels are the best way to achieve this task due to a lack of support for explicit proxy in some instances and IPsec is the right type of tunnel to achieve the desired security and steering.
What are three valid elements that you must consider when using IPsec tunnels in this scenario? (Choose three.)
  • A. the impact of threat scanning performance
  • B. bandwidth considerations
  • C. Netskope Client behavior when on-premises
  • D. the categories to be blocked
  • E. cipher support on tunnel-initiating devices
⣺ABE
| # 32
Your client is an NG-SWG customer. They are going to use the Explicit Proxy over Tunnel (EPoT) steering method. They have a specific list of domains that they do not want to steer to the Netskope Cloud.
What would accomplish this task''
  • A. Create a real-time policy with a bypass action.
  • B. Define exception domains in the PAC file.
  • C. Define exceptions in the Netskope steering configuration
  • D. Use an SSL decryption policy.
⣺B
h
To accomplish the task of not steering specific domains to the Netskope Cloud while using the Explicit Proxy over Tunnel (EPoT) steering method, you woulddefine exception domains in the PAC file (A).This is because the PAC file is used to specify which domains should bypass the proxy and connect directly, thus allowing for granular control over the traffic that is steered to Netskope1.
The use of PAC files for steering exceptions is a standard practice in proxy configurations and is supported by Netskope's EPoT steering method as outlined in their documentation1.
| # 33
˽֪Ƥ褦ˡNetskope Certified Cloud Security ArchitectߤϸʤϡƷ|GoShikenNSK300оӳƤޤ ԇY˺ϸ񤷤98ѩ`ϤꡢˡρIȤNetskopeNSK300ƥȥȥȤʹäޤ NSK300ɼѧ̲Ĥߤϸʤ֤äƤ뤳Ȥg`ޤ ߤѥ`Ȥ٤ƤˡˤȤäƷdzҪǤ뤳Ȥ֪äƤ뤿ᡢ˥ѥ`ȤƤ뤿Ƥ򾡤Ƥޤ Fڡϸʤ99_ޤ ѧĩ`ȤNSK300ѧȥȤxkؤѧϡ
NSK300}ץ: https://www.goshiken.com/Netskope/NSK300-mondaishu.html
P.S. GoShikenGoogle DriveǹФƤoϤ¤NSK300ףhttps://drive.google.com/open?id=13VssXwQEKPkd1E0yrHWqg1WjZDPBz0vS
Posted at 3/11/2026 09:24:59        Only Author  2#
This article is truly exceptional, thank you for sharing it with us. Wishing you all the best of luck! Heres the free FCSS_EFW_AD-7.6 latest practice questions pdf material.
