100% Pass-Rate C-HRHPC-2505 Latest Braindumps - Win Your SAP Certificate with To
93
Posted at 2/20/2026 10:13:45      View:88 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of LatestCram C-HRHPC-2505 dumps from Cloud Storage: https://drive.google.com/open?id=13SYlVcpm_M97YOhP0ClOu1nvufsIGoK5
Our C-HRHPC-2505 real exam has three packages, which meets your different demands. They are PDF version, online test engine and windows software of the C-HRHPC-2505 learning guide. The contents are all identical. But the displays are totally different and you may choose the right one according to your interest and hobbies. Every version of our C-HRHPC-2505 Real Exam is worthy and affordable for you to purchase. Let us fight for our bright future. You are bound to win if you are persistent.
Nowadays the knowledge capabilities and mental labor are more valuable than the manual labor because knowledge can create more wealth than the mental labor. If you boost professional knowledge capabilities in some area you are bound to create a lot of values and can get a good job with high income. Passing the test of C-HRHPC-2505 Certification can help you achieve that, and our C-HRHPC-2505 training materials are the best study materials for you to prepare for the C-HRHPC-2505 test. Our C-HRHPC-2505 guide materials combine the key information to help the clients both solidify the foundation and advance with the times.
C-HRHPC-2505 guide torrent & C-HRHPC-2505 study guide & C-HRHPC-2505 actual examA lot of applicants have studied with SAP Certified Associate - Implementation Consultant - SAP SuccessFactors Employee Central Payroll (C-HRHPC-2505) practice material and passed the C-HRHPC-2505 exam on the first try with their hard work and consistency. The LatestCram assures the customers that they will pass the C-HRHPC-2505 Exam on the first try by studying from C-HRHPC-2505 exam material and if they fail to do it so they can claim their money back (terms and conditions apply). Buy It Now!
SAP C-HRHPC-2505 Exam Syllabus Topics:
  • Payroll Control Center Tools: This section of the exam measures the skills of payroll implementation consultants and covers the tools and utilities provided within the Payroll Control Center. It includes the use of diagnostic tools and monitors to ensure that payroll processes are running smoothly and errors are addressed proactively.
  • Provisioning Settings for Employee Central Payroll: This section of the exam measures the skills of integration analysts and covers the provisioning-level configurations required to enable Employee Central Payroll functionality. It includes system setup tasks that must be completed during the initial implementation to ensure the system is payroll-ready.
  • Declustered Payroll Results: This section of the exam measures the skills of payroll implementation consultants and covers the concept and use of declustered payroll results. It introduces how payroll data is stored and accessed more efficiently for reporting and auditing in SAP’s modern payroll architecture.
  • This section of the exam measures the skills of integration analysts and covers the technical and functional configuration for point-to-point integration between Employee Central and the payroll system. It ensures data consistency and proper communication between the two platforms.
Topic 5
  • Point-to-Point Integration (Employee Central, Employee Central Configuration)
Topic 6
  • Payroll Processing: This section of the exam measures the skills of payroll implementation consultants and covers the basic concepts and steps involved in executing payroll processes within Employee Central Payroll. It ensures that the candidate understands how payroll runs are initiated and how results are processed accurately using SAP tools.
Topic 7
  • Payroll Control Center Configuration: This section of the exam measures the skills of payroll implementation consultants and covers the full range of configuration tasks required to enable and customise the Payroll Control Center. It addresses setting up validation rules, alerts, checks, and user interfaces that help streamline payroll management.
SAP Certified Associate - Implementation Consultant - SAP SuccessFactors Employee Central Payroll Sample Questions (Q11-Q16):NEW QUESTION # 11
When you need to reset a previously initiated payroll process, which standard report should you use?
  • A. PYC_REGENERATE_REPORTS
  • B. PYC_GENERATE_PROVIDER
  • C. PYC_SUPPORT_CONS_CHECK_INST
  • D. PYC_RESET_PROC_INST
NEW QUESTION # 12
To which accounting components can the payroll document be posted? Note: There are 3 correct answers to this question.
  • A. General Ledger Accounting (FI-GL)
  • B. Travel Management (FI-TV)
  • C. Controlling (CO)
  • D. Bank Accounting (FI-BL)
  • E. Accounts Payable (FI-AP)
Answer: A,C,D
NEW QUESTION # 13
Which of the following statements apply to the results of the PYC_CONVERT_VR_TO_TSK PCC report for converting legacy validation rules into the new framework? Note: There are 3 correct answers to this question.
  • A. The legacy validation rules and the rules created in Manage Configuration application can be used in the same process
  • B. The legacy validation rules and the rules created in Manage Configuration application can be used only for the Team Monitoring processes
  • C. The legacy validation rules remain unchanged
  • D. The legacy validation rules and the rules created in Manage Configuration application can be used only in separate processes
  • E. Converting legacy validation rules creates a new set of validation rules with the same check logic in Manage Configuration
Answer: A,C,E
NEW QUESTION # 14
Why do you manually populate the key mapping table (HRSFEC_D_EEKEYMP) in SAP SuccessFactors Employee Central Payroll?
  • A. To create the mapping between employee and manager to support workflows
  • B. To avoid the creation of new employees in SAP SuccessFactors Employee Central Payroll, which contains employee data already
  • C. To populate PERNR IDs from SAP SuccessFactors Employee Central to SAP SuccessFactors Employee Central Payroll
  • D. To populate all employees' new SAP SuccessFactors Employee Central PERNR ID to SAP SuccessFactors Employee Central Payroll on employee rehire
NEW QUESTION # 15
Which of the following can you use to explore released APIs?
  • A. SAP Application Interface Framework
  • B. SAP Business Accelerator Hub
  • C. SAP Integration Suite
NEW QUESTION # 16
As for the structure of content, please believe that our team of experts has many years of experience in compiling and designing on the C-HRHPC-2505 exam questions. I can say that no persion can know the C-HRHPC-2505 study materials than them for they have been devoting themselves in this career for ten years. And they know every detail about the C-HRHPC-2505 learning guide. No matter how high your request is, our C-HRHPC-2505 learning quiz must satisfy you.
Learning C-HRHPC-2505 Mode: https://www.latestcram.com/C-HRHPC-2505-exam-cram-questions.html
P.S. Free 2026 SAP C-HRHPC-2505 dumps are available on Google Drive shared by LatestCram: https://drive.google.com/open?id=13SYlVcpm_M97YOhP0ClOu1nvufsIGoK5
