[Hardware] 300-425 Free Dump Download & Reliable 300-425 Braindumps Ppt
127
【Hardware】 300-425 Free Dump Download & Reliable 300-425 Braindumps Ppt
Posted at 2/20/2026 11:39:01      View:72 | Replies:0        Print      Only Author   [Copy Link] 1#
What's more, part of that ActualCollection 300-425 dumps now are free: https://drive.google.com/open?id=1J-WOG1VtcrmdRKNx4E00bwLioFCphe52
ActualCollection offers affordable Designing Cisco Enterprise Wireless Networks exam preparation material. You don't have to go beyond your budget to buy Updated 300-425 Dumps. To make your 300-425 exam preparation material smooth, a bundle pack is also available that includes all the 3 formats of dumps questions. ActualCollection offers 365 days updates.
Cisco 300-425 exam covers a range of topics, including wireless site surveys, WLAN high availability, advanced location services, and wireless security. 300-425 exam also evaluates the candidates' ability to design and implement Cisco wireless infrastructure, including controllers, access points, and network management tools. Additionally, the exam includes questions on the integration of wireless networks with wired networks and other advanced technologies like IoT, SDN, and cloud-based solutions.
Cisco 300-425 certification exam is an important credential for network engineers and architects who want to advance their careers in the field of wireless network design. Achieving this certification demonstrates a high level of expertise in designing enterprise wireless networks using Cisco technologies. Additionally, it validates the ability to analyze business requirements, design solutions to meet those requirements, and implement and optimize wireless networks to ensure maximum performance and reliability.
What is the duration, questions, language, and format of the Cisco 300-425 Exam
  • Format: Multiple choices, multiple answers
  • Length of Examination: 90 minutes
  • Passing score:70%
  • Number of Questions: 150
Reliable 300-425 Braindumps Ppt - 300-425 Exam Lab QuestionsThese Cisco 300-425 exam practice questions will greatly help you to prepare well for the final 300-425 certification exam. Cisco 300-425 exam preparation and boost your confidence to pass the 300-425 Exam. All Cisco 300-425 exam practice test questions contain the real and updated Cisco 300-425 exam practice test questions.
Cisco Designing Cisco Enterprise Wireless Networks Sample Questions (Q182-Q187):NEW QUESTION # 182
A hospital wireless environment was designed with these characteristics:
* RF coverage
* better than -67 dBm in the 5 GHz spectrum
* RRM be used for DCA and TPC in the 2.4 GHz band
* RRM be used for DCA and TPC in the 5 GHz band
After deployment, why do many of the legacy 802.11b/g devices have difficulty maintaining connectivity?
  • A. Excessive co-channel interference in the 2.4 GHz band exists.
  • B. TPC drastically reduces Tx power in the 2.4 GHz band.
  • C. Excessive overlapping channels in the 2.4 GHz band exists.
  • D. TPC drastically increases Tx power in the 2.4 GHz band.
The Cisco Aironet 3800 Series APs support mGig, which allows for higher throughput over existing cabling. However, the maximum cable length that supports 5G operation is limited by the quality of the cable and signal attenuation. Category 5e cabling can support 5G operation up to a length of 130 meters, which is within the acceptable range for maintaining the required signal integrity for 5G speeds.
NEW QUESTION # 183
A network administrator of a global organization is collapsing all controllers to a single cluster located in central Europe. Which concern must be addressed?
  • A. Some channels may not be available consistently across the organization.
  • B. Different RF policies per office are not available in this configuration.
  • C. Syslog must be configured to the time-zone of the NMS platform.
  • D. Centralized controllers cannot uniformly authenticate global users.
Section: Wired and Wireless Infrastructure
NEW QUESTION # 184
An engineer must perform an assessment of a customer LAN for a future IEEE 802.11ac Wave 2 wireless deployment All access switches are Fast Ethernet-Capable only, and the wired infrastructure between existing APs and access switches is based on the CAT 6A standard. Which two actions provide maximum support of Cisco 3800 Series access points? (Choose two.)
  • A. Ensure that cable distances between access switches and APs are not longer than 100 meters.
  • B. Replace the existing wiring infrastructure with the CAT-7E wiring standard,
  • C. Replace the existing switches with gigabit switches with 10G uplinks.
  • D. Replace the existing switches with mGig switches.
  • E. Ensure that cable distances between access switches and APs are not longer than 55 meters.
NEW QUESTION # 185
A company has 10 access point licenses available on their backup Cisco WLC and their primary Cisco WLC is at full capacity, 5 access points are set to high failover priority and 7 access points are set to critical failover priority. During a failure, not all critical access points failed over to the backup Cisco WLC. Which configuration is the cause of this issue?
  • A. The high priority access point is oversubscribed.
  • B. network ap-priority is set to enable.
  • C. The critical priority access point count is oversubscribed.
  • D. network ap-priority is set to disable.
https://www.ciscolive.com/c/dam/ ... pdf/BRKCOL-2275.pdf
NEW QUESTION # 186
An engineer must perform a predictive design for a wireless network. The customer has devices that can tolerate at most 100 ms of delay when roaming. Which design criteria must be used?
  • A. voice
  • B. video
  • C. location
  • D. data
Devices that can tolerate at most 100 ms of delay when roaming are typically voice devices.
Voice applications are sensitive to delays, and ensuring a maximum of 100 ms delay is a common design criterion for a wireless network supporting voice services.
NEW QUESTION # 187
We have three packages of the 300-425 study materials: the PDF, Software and APP online and each one of them has its respect and different advantages. So you can choose as you like accoding to your study interest and hobbies. We strongly advise you to purchase all three packages of the 300-425 Exam Questions. And the prices of our 300-425 learning guide are quite favourable so that you absolutely can afford for them.
Reliable 300-425 Braindumps Ppt: https://www.actualcollection.com/300-425-exam-questions.html
2026 Latest ActualCollection 300-425 PDF Dumps and 300-425 Exam Engine Free Share: https://drive.google.com/open?id=1J-WOG1VtcrmdRKNx4E00bwLioFCphe52
