最新1z0-1066-25考題 & 1z0-1066-25最新題庫
Posted at 2/20/2026 15:54:11
從Google Drive中免費下載最新的KaoGuTi 1z0-1066-25 PDF版考試題庫:https://drive.google.com/open?id=1IDkHsqd3-9Vyrop26ZPwpmnPmwemrRx1
你還在猶豫什麼,機不可失,失不再來。現在你就可以獲得Oracle的1z0-1066-25考題的完整本,只要你進KaoGuTi網站就能滿足你這個小小的欲望。你找到了最好的1z0-1066-25考試培訓資料,請你放心使用我們的考題及答案,你一定會通過的。
KaoGuTi是一家專業的,它專注于廣大考生最先進的Oracle的1z0-1066-25考試認證資料,有了KaoGuTi,Oracle的1z0-1066-25考試認證就不用擔心考不過,KaoGuTi提供的考題資料不僅品質過硬,而且服務優質,只要你選擇了KaoGuTi,KaoGuTi就能幫助你通過考試,並且讓你在短暫的時間裏達到高水準的效率,達到事半功倍的效果。
1z0-1066-25最新題庫,1z0-1066-25熱門證照還在為怎樣才能順利通過Oracle 1z0-1066-25 認證考試而苦惱嗎?還在苦苦等待Oracle 1z0-1066-25 認證考試的最新資料嗎?KaoGuTi研究出了最新的Oracle 1z0-1066-25 認證考試相關資料。想通過Oracle 1z0-1066-25 認證考試考試嗎?快將KaoGuTi的Oracle 1z0-1066-25認證考試的最新練習題及答案加入你的購物車吧!KaoGuTi已經在網站上為你免費提供部分Oracle 1z0-1066-25 認證考試的練習題和答案,你可以免費下載作為嘗試。相信你對我們的產品會很滿意的。利用它你可以很輕鬆地通過考試。我們承諾,如果你使用了KaoGuTi的最新的Oracle 1z0-1066-25 認證考試練習題和答案卻考試失敗,KaoGuTi將會全額退款給你。
最新的 Oracle Cloud 1z0-1066-25 免費考試真題 (Q96-Q101):問題 #96
Which two are valid settings when defining a replenishment planning cluster?
- A. Reserved safety stock percentage (optional)
- B. Sweep location (required)
- C. Location hierarchy (required)
- D. Source system (required)
答案:C,D
解題說明:
When setting up a replenishment planning cluster, the location hierarchy is necessary for structuring replenishment relationships, while specifying a reserved safety stock percentage is optional. The Source system setting is not required within the cluster definition context but is typically a part of the broader replenishment configuration ORACLE
問題 #97
Your client wants to exclude all of the inventory from the 'Reject' subinventory from only one of their supply plans. What action must be taken to meet this requirement?
- A. Manage Plans > Search and select supply plans > 'Organizations and Schedules' tab > 'Supply Schedules' > 'Subinventory Netting' > Deselect 'Reject' subinventory for each organization
- B. Manage Subinventories > Search and select subinventory > Deselect 'Nettable'
- C. Manage Subinventories > Choose a material status in which 'Nettable' is unchecked
- D. Manage Plans > Search and select supply plans > 'Organizations and Schedules' tab > 'Organizations' >
'Subinventory Netting' > Deselect 'Reject' subinventory for each organization - E. It is not possible to exclude one subinventory from a particular supply plan.
答案:D
問題 #98
Your customer has seasonal demand and wants to generate forecast for next six months. You ran a demand plan for first time using six months of shipments history but the forecast accuracy was low.
Identify two statements that are true in this scenario. (Choose two.)
- A. Running a demand plan with both shipments and seasonal shipments forecast profile is required to forecast seasonal demand.
- B. Running a demand plan with six months of booking history instead of six months of shipment history is required for seasonal demand.
- C. Running a demand plan with 18 to 36 months of shipments history is recommended.
- D. Running a demand plan with less than one year of history will impact seasonal analysis.
- E. Running a demand plan with both shipments and booking forecast profile is required to forecast seasonal demand.
答案:B,C
問題 #99
Your buyers are very attentive in maintaining the approved supplier lists as needed. One of your planners regularly uses the portal to communicate with some of their key suppliers and has noticed that the publication process is taking a lot longer to complete because the business has grown. The planner is also complaining that the collaboration candidates' list is cluttered with items that are not yet required.
Which two steps should you take to address the planner's complaint?
- A. Activate the "Ignore for Supplier Collaboration" item attribute.
- B. Activate a Supply Chain Collaboration setting to ignore zero forecast combinations.
- C. Disable the decomposition and generate candidates' parameters in the Publish Order Forecast scheduled process.
- D. Activate a profile option called "Publish Order Forecast Using Sourcing Rules".
答案:C,D
解題說明:
To improve performance and reduce unnecessary items in the collaboration candidates list, you can activate settings to ignore zero forecast combinations, which prevents items with no forecast from appearing in the candidates list. Additionally, activating the "Ignore for Supplier Collaboration" attribute for specific items ensures that these are excluded from supplier collaboration processes, streamlining the list to relevant items only. These options help in managing supply collaboration settings efficiently and are verified in Oracle documentation on Supply Chain Collaboration and Publish Order Forecast processes
問題 #100
Planner 1 works in Europe and needs to see three measures in kilograms (the default UOM). Planner 2 is US- based and needs to see those same three measures in pounds. Both planners need to use five tables in their plan analyses on a regular basis. At the moment, all five tables are displayed in kilograms.
Which two options would most efficiently address this requirement?
- A. There is no efficient solution to this requirement.
- B. Duplicate all five tables, then format the three measures in the copied tables to be displayed in pounds.
- C. Open each table and format measures to duplicate the three measures and then format the duplicated measures to be displayed in pounds.
- D. Create duplicates of the three measures in Manage Planning Measures and change each new measure's UOM from kilograms to pounds, then duplicate the five tables but use the new measures.
- E. Planner 2 opens a table, formats each measure to be displayed in pounds. When Planner 1 opens the same table, they reformat back to be displayed in kilograms.
答案:C,D
解題說明:
The most efficient way to accommodate both planners' needs is to create duplicates of the required measures in pounds and then duplicate the tables to include the reformatted measures. This allows both planners to access tables in their preferred units without repetitive reformatting MY ORACLE SUPPORT
問題 #101
為什麼KaoGuTi Oracle的1z0-1066-25考試培訓資料與別的培訓資料相比,它更受廣大考生的歡迎呢,第一,這是共鳴的問題,我們必須真正瞭解考生的需求,而且要比任何網站都要全面到位。第二,專注,為了做好我們決定完成的事情,必須放棄所有不重要的機會。第三,人們的確會用表面來判斷一個東西的好壞,我們或許擁有最優秀最高品質的產品,但如果以粗製濫造的方式展示出來,自然會被列為粗製濫造的產品,如果以既有創意又很專業的方式呈現,那麼我們將得到最高的效果。KaoGuTi Oracle的1z0-1066-25考試培訓資料就是這樣成功的培訓資料,舍它其誰?
1z0-1066-25最新題庫: https://www.kaoguti.com/1z0-1066-25_exam-pdf.html
經過不斷的積累,我們的1z0-1066-25考試準備會越來越充足,KaoGuTi 是一个为考生们提供IT认证考试的考古題并能很好地帮助大家的网站,通過活用前輩們的經驗將歷年的考試資料編輯起來,製作出了最好的 Oracle 1z0-1066-25 考試題庫大綱,我們的 1z0-1066-25 認證考試最新題庫通過實踐檢驗了的,并且也在不斷升級我們的培訓資料,使你在第一時間得到最好和最新的資訊,通過了 Oracle 1z0-1066-25最新題庫 1z0-1066-25最新題庫 - Oracle Planning and Collaboration Cloud 2025 Implementation Professional 認證考試是有很多好處的,您是否有興趣在成功完成1z0-1066-25最新題庫認證考試後開始賺取高薪,KaoGuTi就是一個可以滿足很多參加Oracle 1z0-1066-25 認證考試的IT人士的需求的網站。
有兩名陌生面孔的散修幾乎在同壹時間登上了擂臺,卓秦風大步流星向前走去,經過不斷的積累,我們的1z0-1066-25考試準備會越來越充足,KaoGuTi 是一个为考生们提供IT认证考试的考古題并能很好地帮助大家的网站,通過活用前輩們的經驗將歷年的考試資料編輯起來,製作出了最好的 Oracle 1z0-1066-25 考試題庫大綱。
最新1z0-1066-25考題 | Oracle Planning and Collaboration Cloud 2025 Implementation Professional合法有效的通過利刃我們的 1z0-1066-25 認證考試最新題庫通過實踐檢驗了的,并且也在不斷升級我們的培訓資料,使你在第一時間得到最好和最新的資訊,通過了 Oracle Oracle Planning and Collaboration Cloud 2025 Implementation Professional 認證考試是有很多好處的,您是否有興趣在成功完成Oracle Cloud認證考試後開始賺取高薪?
- 1z0-1066-25 PDF題庫 🦳 1z0-1066-25信息資訊 📬 最新1z0-1066-25考證 🛢 在➥ [url]www.kaoguti.com 🡄網站上免費搜索▷ 1z0-1066-25 ◁題庫1z0-1066-25最新試題[/url]
- 高通過率的最新1z0-1066-25考題,高質量的考試指南幫助妳快速通過1z0-1066-25考試 👴 ⮆ [url]www.newdumpspdf.com ⮄是獲取▛ 1z0-1066-25 ▟免費下載的最佳網站1z0-1066-25考題套裝[/url]
- 1z0-1066-25考題套裝 💔 1z0-1066-25題庫分享 🧴 1z0-1066-25認證考試 🚢 進入《 [url]www.newdumpspdf.com 》搜尋⏩ 1z0-1066-25 ⏪免費下載1z0-1066-25最新試題[/url]
- 最新的1z0-1066-25認證考試考古題 🆕 進入▛ [url]www.newdumpspdf.com ▟搜尋[ 1z0-1066-25 ]免費下載1z0-1066-25最新試題[/url]
- 最新1z0-1066-25考證 🤿 1z0-1066-25考試資訊 🚞 1z0-1066-25題庫分享 📲 複製網址☀ [url]www.pdfexamdumps.com ️☀️打開並搜索「 1z0-1066-25 」免費下載1z0-1066-25考試資訊[/url]
- 最新1z0-1066-25考證 Ⓜ 1z0-1066-25考證 🏍 最新1z0-1066-25試題 🎁 ➽ [url]www.newdumpspdf.com 🢪網站搜索➡ 1z0-1066-25 ️⬅️並免費下載1z0-1066-25新版題庫上線[/url]
- 最新1z0-1066-25考題 |驚人通過率的考試材料| 1z0-1066-25最新題庫 📉 開啟⮆ tw.fast2test.com ⮄輸入⮆ 1z0-1066-25 ⮄並獲取免費下載1z0-1066-25考題套裝
- 1z0-1066-25考題寶典 🥺 1z0-1066-25 PDF題庫 🛹 1z0-1066-25 PDF題庫 🐎 立即在《 [url]www.newdumpspdf.com 》上搜尋【 1z0-1066-25 】並免費下載1z0-1066-25測試引擎[/url]
- 1z0-1066-25 PDF題庫 🙊 1z0-1066-25信息資訊 🧛 1z0-1066-25測試引擎 💓 在➠ tw.fast2test.com 🠰搜索最新的「 1z0-1066-25 」題庫1z0-1066-25考題寶典
- 準確的最新1z0-1066-25考題和資格考試中的領先提供者和免費PDF 1z0-1066-25:Oracle Planning and Collaboration Cloud 2025 Implementation Professional 👟 立即打開“ [url]www.newdumpspdf.com ”並搜索“ 1z0-1066-25 ”以獲取免費下載1z0-1066-25考題套裝[/url]
- 高通過率的最新1z0-1066-25考題,高質量的考試指南幫助妳快速通過1z0-1066-25考試 🚔 立即到「 [url]www.newdumpspdf.com 」上搜索《 1z0-1066-25 》以獲取免費下載1z0-1066-25考試證照綜述[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
