[General] Valid FCSS_SDW_AR-7.6 Test Simulator, FCSS_SDW_AR-7.6 New Soft Simulations
91
General Valid FCSS_SDW_AR-7.6 Test Simulator, FCSS_SDW_AR-7.6 New Soft Simulations
Posted at 2/20/2026 16:03:20      View135 | Replies0        Print      Only Author   [Copy Link] 1#
Are you very eager to pass the FCSS_SDW_AR-7.6 exam? Then you must want to see this amazing learning product right away! After you decide to purchase our FCSS_SDW_AR-7.6 guide questions, please pay immediately. If your page shows that the payment was successful, you will receive a link of our FCSS_SDW_AR-7.6 Exam Materials we sent to you within five to ten minutes. And the pass rate of FCSS_SDW_AR-7.6 study braindumps is high as 98% to 100%.
It follows its goal by giving a completely free demo of real Fortinet FCSS_SDW_AR-7.6 exam questions. The free demo will enable users to assess the characteristics of the Fortinet FCSS_SDW_AR-7.6 Exam product. ITPassLeader will provide you with free Fortinet FCSS_SDW_AR-7.6 actual questions updates for 365 days after the purchase of our product.
Fortinet FCSS_SDW_AR-7.6 New Soft Simulations & Pdf FCSS_SDW_AR-7.6 FreeITPassLeader always provides customer support for the convenience of desktop Fortinet FCSS_SDW_AR-7.6 practice test software users. The Fortinet FCSS_SDW_AR-7.6 certification provides both novices and experts with a fantastic opportunity to show off their knowledge of and proficiency in carrying out a particular task. You can benefit from a number of additional benefits after completing the Fortinet FCSS_SDW_AR-7.6 Certification Exam.
Fortinet FCSS_SDW_AR-7.6 Exam Syllabus Topics:
  • Centralized Management: This domain addresses FortiManager-based SD-WAN deployment, branch configuration implementation, and overlay orchestration using SD-WAN Manager.
  • SD-WAN Troubleshooting: This domain focuses on diagnosing SD-WAN rule behavior, routing issues, and ADVPN tunnel problems.
  • Advanced IPsec: This section covers hub-and-spoke topologies, ADVPN configuration, and scalable multihub and multiregion IPsec deployments.
  • Rules and Routing: This section focuses on configuring SD-WAN rules for traffic steering and routing policies for path selection and failover.
Topic 5
  • SD-WAN Basic Setup: This domain covers initial SD-WAN configuration, member and zone setup, and Performance SLA creation for link monitoring.
Fortinet FCSS - SD-WAN 7.6 Architect Sample Questions (Q93-Q98):NEW QUESTION # 93
Refer to the exhibit. For your ZTP deployment, you review the CSV file shown in exhibit and note that it is missing important information. Which two elements must you change before you can import it into FortiManager? (Choose two.)
  • A. You must define a name for each device
  • B. You must define a value for each device and each user-defined metadata variable.
  • C. You must define a value for each device and each metadata variable that defines an IP address.
  • D. You must associate a device blueprint with each device
NEW QUESTION # 94
An administrator configures SD-WAN rules for a DIA setup using the FortiGate GUI. The page to configure the source and destination part of the rule looks as shown in the exhibit. The GUI page shows no option to configure an application as the destination of the SD-WAN rule Why?
  • A. You cannot use applications as the destination when FortiGate is used for a DIA setup.
  • B. You must enable the feature on the CLI.
  • C. You must enable the feature first using the GUI menu System > Feature Visibility.
  • D. FortiGate allows the configuration of applications as the destination of SD-WAN rules only on the CLI.
NEW QUESTION # 95
Refer to the exhibit. The administrator configured the IPsec tunnel VPN1 on a FortiGate device with the parameters shown in exhibit.
Based on the configuration, which three conclusions can you draw about the characteristics and requirements of the VPN tunnel? (Choose three.)
  • A. The administrator must manually assign the tunnel interface IP address on the hub side
  • B. This configuration allows user-defined overlay IP addresses.
  • C. The remote end must support IKEv2.
  • D. The tunnel interface IP address on the spoke side is provided by the hub.
  • E. The remote end can be a third-party IPsec device.
Answer: A,B,C
The administrator must manually assign the tunnel interface IP address on the hub side The setting "set exchange-interface-ip enable" means the tunnel interface IP address is exchanged, but the hub side IP must be set manually.
The command "set ike-version 2" explicitly configures IKE version 2 for this tunnel, so the remote device must support IKEv2.
The tunnel interface enables user control over IP addressing for the overlay network, allowing custom IP assignments.
NEW QUESTION # 96
(Refer to the exhibit.
You configure SD-WAN on a standalone FortiGate device.
You want to create an SD-WAN rule that steers traffic related to Facebook and LinkedIn through the less costly internet link.
What must you do to set Facebook and LinkedIn applications as destinations from the GUI? Choose one answer.)
  • A. You cannot configure applications as destinations of an SD-WAN rule on a standalone FortiGate device.
  • B. In the Internet service field, select Facebook and LinkedIn.
  • C. Enable the visibility of the applications field as destinations of the SD-WAN rule.
  • D. Install a license to allow applications as destinations of SD-WAN rules.
In FortiOS 7.6, SD-WAN rules can steer traffic based on Internet Services, which represent predefined application and service signatures maintained by FortiGuard. Common applications such as Facebook and LinkedIn are included in the Internet Service database.
According to the FCSS SD-WAN 7.6 curriculum, when configuring an SD-WAN rule from the GUI on a standalone FortiGate device, applications are selected as destinations using the Internet service field, not by enabling a separate application destination field. The exhibit highlights the Internet service option under the Destination section, which is the correct method to match traffic for specific applications.
Option A is incorrect because there is no GUI option to enable application visibility as destinations for SD-WAN rules. Application matching is already abstracted through Internet Services.
Option C is incorrect because standalone FortiGate devices fully support application-based steering using Internet Services in SD-WAN rules.
Option D is incorrect because no additional license is required to use Internet Services in SD-WAN rules. This functionality is included in FortiOS and relies on the built-in FortiGuard Internet Service database.
Therefore, to steer Facebook and LinkedIn traffic through a specific WAN link, you must select Facebook and LinkedIn in the Internet service field, which corresponds to option B.
NEW QUESTION # 97
You manage an SD-WAN topology. You will soon deploy 50 new branches.
Which three tasks can you do in advance to simplify this deployment? (Choose three.)
  • A. Create policy blueprint.
  • B. Create a ZTP template.
  • C. Define metadata variables value for each device.
  • D. Create model devices.
  • E. Update the DHCP server configuration.
Answer: A,B,D
When planning to deploy a large number of branches (e.g., 50), Fortinet recommends several preparatory steps to simplify and automate the rollout. Creating model devices allows you to predefine configurations and settings that can be cloned or adapted for each branch, saving time and minimizing manual errors. Preparing a Zero Touch Provisioning (ZTP) template enables automatic onboarding and provisioning of new FortiGates as soon as they come online, reducing manual intervention. Lastly, creating a policy blueprint allows for standardized policy deployment across all branches, ensuring consistent security and SD-WAN rule enforcement. This holistic approach streamlines the deployment process, allows for rapid scaling, and ensures that all devices are configured according to corporate policy from day one.
[FCSS_SDW_AR-7.4 1-0.docx Q8]
Fortinet SD-WAN 7.4 Reference Architecture, "ZTP and Model Device Strategies for Scalable Rollouts" FortiManager Admin Guide, "Policy Blueprints and Automation for Branch Deployment"
NEW QUESTION # 98
For some candidates who will attend the exam, they may have the concern that they cant pass the exam. FCSS_SDW_AR-7.6 study guide have the questions and answers for you to train, and we will be pass guaranteed and money back guaranteed, that is to say, if you cant pass the exam, we will refund your money, or if you have another exam to attend, we will replace other 2 valid exam dumps for free, and if the FCSS_SDW_AR-7.6 Exam Dumps updates, you can also get the free update for them. Choosing us, and you will benefit a lot.
FCSS_SDW_AR-7.6 New Soft Simulations: https://www.itpassleader.com/Fortinet/FCSS_SDW_AR-7.6-dumps-pass-exam.html
