[General] Useful Exam Mule-Arch-201 Simulations | Mule-Arch-201 100% Free Valid Exam Simul
135
【General】 Useful Exam Mule-Arch-201 Simulations | Mule-Arch-201 100% Free Valid Exam Simul
Posted at 2/20/2026 17:32:46      View:86 | Replies:0        Print      Only Author   [Copy Link] 1#
Dumpkiller provide you with the most authoritative and the fullest Salesforce Mule-Arch-201 Exam Dumps, thus the hit rate is very high. All questions that may appear in the exam are included in our exam dumps. With the changes of exam outline, we also update our exam dumps at any time. Dumpkiller pdf real questions and answers can prevent you from wasting lots of time and efforts on preparing for the exam and can help you sail through you exam with ease and high efficiency. But even you fail the exam, we assure we will give you FULL REFUND. Opportunities always for those who are well prepared and we wish you not to miss the good opportunities.
Dumpkiller allows all visitors to try a free demo of Mule-Arch-201 pdf questions and practice tests to assess the quality of our Mule-Arch-201 study material. Your money is 100% secure as we will ensure that you crack the Salesforce Mule-Arch-201 test on the first attempt. You will also enjoy 24/7 efficient support from our customer support team before and after the purchase of Salesforce Mule-Arch-201 Exam Dumps. If you face any issues while using our Mule-Arch-201 PDF dumps or Mule-Arch-201 practice exam software (desktop and web-based), contact Dumpkiller customer service for guidance.
Mule-Arch-201 Valid Exam Simulator | Latest Mule-Arch-201 Test VoucherWhen you decide to pass Mule-Arch-201 exam, you must want to find a good study materials to help you prepare for your exam. If you decide to choice our products as your study tool, you will be easier to pass your exam and get the Mule-Arch-201 certification in the shortest time. So do not hesitate and buy our Mule-Arch-201 Test Torrent, an unexpected surprise is awaiting you, we believe you will prefer to our Mule-Arch-201 test questions than other study materials. In order to let you understand our Mule-Arch-201 exam prep in detail, we are going to introduce our products to you.
Salesforce Certified MuleSoft Platform Architect Sample Questions (Q149-Q154):NEW QUESTION # 149
A large organization with an experienced central IT department is getting started using MuleSoft. There is a project to connect a siloed back-end system to a new Customer Relationship Management (CRM) system. The Center for Enablement is coaching them to use API-led connectivity.
What action would support the creation of an application network using API-led connectivity?
  • A. Determine if the new CRM system supports the creation of custom: REST APIs, establishes 4 private network with CloudHub, and supports GAuth 2.0 authentication
  • B. Create a System API to unlock the data on the back-end system using a REST API
  • C. To expedite this project, central IT should extend the CRM system and back-end systems to connect to one another using built in integration interfaces
  • D. Invite the business analyst to create a business process model to specify the canonical data model between the two systems
For an organization starting with API-led connectivity to integrate a siloed back-end system with a new CRM, the following approach aligns with best practices and MuleSoft's Center for Enablement (C4E) guidance:
API-led Connectivity: This model organizes APIs into distinct layers (System, Process, and Experience) to improve reusability, modularity, and manageability.
System APIs are used to expose and unlock data from core systems (such as back-end applications or databases).
Process APIs orchestrate data across multiple systems and transform it as needed.
Experience APIs format the data specifically for consumption by applications or devices, such as the CRM in this case.
Step to Support Application Network:
Create a System API for the back-end system. This API should expose the necessary data to support integration with the CRM.
By creating a System API with a RESTful interface, data can be accessed in a standardized way, making it easier to integrate with other systems and supporting future scalability.
Why Option D is Correct:
Creating a System API aligns with the principle of API-led connectivity, ensuring that data is exposed in a reusable manner. This API can then be orchestrated by Process APIs as needed to meet CRM requirements and can easily be extended to other applications.
of Incorrect Options:
Option A (creating a business process model) does not directly enable connectivity or expose back-end data through APIs.
Option B is unnecessary at this stage; assessing CRM capabilities like OAuth 2.0 support is not directly related to creating the application network via System APIs.
Option C contradicts API-led best practices by suggesting a point-to-point integration, which API-led connectivity seeks to avoid due to its lack of flexibility and scalability.
Reference
Refer to MuleSoft's API-led Connectivity resources for a detailed framework on building scalable integration layers using System, Process, and Experience APIs.
NEW QUESTION # 150
Which component monitors APIs and endpoints at scheduled intervals, receives reports about whether tests pass or fail, and displays statistics about API and endpoint performance?
  • A. APT Functional Monitoring
  • B. Anypoint Monitoring dashboards
  • C. Anypoint Runtime Manager alerts
  • D. API Analytics
Understanding API Functional Monitoring:
API Functional Monitoring is a feature within MuleSoft's Anypoint Platform that enables users to monitor the health and performance of APIs and endpoints by running functional tests at scheduled intervals.
It checks whether APIs are functioning as expected by running test calls and then evaluating if the response meets the desired conditions. This is particularly useful for testing endpoint availability, checking for specific data in responses, and measuring API performance over time.
Component Features:
Scheduled Intervals: Functional monitoring allows configuring tests to run at regular intervals, such as every minute, hour, or day, depending on the monitoring requirements.
Reports on Test Pass/Fail Status: After each test run, API Functional Monitoring reports whether the API passed or failed the test conditions.
Performance Statistics: It displays metrics like average response time, success rate, and error rates, giving insights into API health and performance.
Evaluating the Options:
Option A (API Analytics): API Analytics provides insights on API usage and metrics but does not involve scheduled tests for pass/fail status or endpoint health checks.
Option B (Anypoint Monitoring Dashboards): These dashboards display API metrics but do not actively test API endpoints or provide pass/fail reporting on a scheduled basis.
Option C (Correct Answer): API Functional Monitoring fits the description, as it is designed to monitor API and endpoint health with scheduled test runs and display statistics about performance.
Option D (Anypoint Runtime Manager Alerts): Runtime Manager alerts notify users of issues with application status but do not actively test endpoints at scheduled intervals.
Conclusion:
Option C (API Functional Monitoring) is the correct answer because it provides the necessary tools to test API functionality, monitor endpoint health, and display performance statistics in real-time.
Refer to MuleSoft documentation on API Functional Monitoring for further guidance on setting up and configuring these tests in Anypoint Platform.
NEW QUESTION # 151
Which of the following sequence is correct?
  • A. API Client implementes logic to call an API >> API Consumer requests access to API >> API Implementation routes the request to >> API
  • B. API Client implementes logic to call an API >> API Consumer requests access to API >> API routes the request to >> API Implementation
  • C. API Consumer requests access to API >> API Client implementes logic to call an API >> API routes the request to >> API Implementation
  • D. API Consumer implementes logic to call an API >> API Client requests access to API >> API Implementation routes the request to >> API
Correct Answe r: API Consumer requests access to API >> API Client implementes logic to call an API >> API routes the request to >> API Implementation
>> API consumer does not implement any logic to invoke APIs. It is just a role. So, the option stating "API Consumer implementes logic to call an API" is INVALID.
>> API Implementation does not route any requests. It is a final piece of logic where functionality of target systems is exposed. So, the requests should be routed to the API implementation by some other entity. So, the options stating "API Implementation routes the request to >> API" is INVALID
>> The statements in one of the options are correct but sequence is wrong. The sequence is given as "API Client implementes logic to call an API >> API Consumer requests access to API >> API routes the request to >> API Implementation". Here, the statements in the options are VALID but sequence is WRONG.
>> Right option and sequence is the one where API consumer first requests access to API on Anypoint Exchange and obtains client credentials. API client then writes logic to call an API by using the access client credentials requested by API consumer and the requests will be routed to API implementation via the API which is managed by API Manager.
NEW QUESTION # 152
An auto manufacturer has a mature CI/CD practice and wants to automate packaging and deployment of any Mule applications to various deployment targets, including CloudHub workers/replicas, customer-hosted Mule runtimes, and Anypoint Runtime Fabric.
Which MuleSoft-provided tool or component facilitates automating the packaging and deployment of Mule applications to various deployment targets as part of the company's CI/CD practice?
  • A. Anypoint Platform REST APIs
  • B. Mule Maven plugin
  • D. Anypoint Platform CLI
For organizations with established CI/CD practices, the Mule Maven plugin is the recommended tool for automating packaging and deployment across multiple environments, including CloudHub, on-premise Mule runtimes, and Anypoint Runtime Fabric. Here's why:
Automation with Maven:
The Mule Maven plugin allows for CI/CD integration by supporting automated build and deployment processes. It is commonly used in CI/CD pipelines to handle application packaging and deployment directly through Maven commands, making it ideal for teams that want consistent deployment automation across different MuleSoft environments.
Supported Deployment Targets:
The Mule Maven plugin supports deployment to various targets, including CloudHub, Runtime Fabric, and on-premises servers, thus meeting the needs of environments with diverse deployment destinations.
Why Option B is Correct:
The Mule Maven plugin is specifically designed for CI/CD pipelines and integrates with Jenkins, GitLab, and other CI/CD tools to facilitate continuous deployment. It is the most efficient MuleSoft-provided tool for this purpose.
Option A (Anypoint Runtime Manager) provides deployment management but does not automate CI/CD processes.
Option C (Anypoint Platform CLI) can script deployments but lacks direct integration with CI/CD tools.
Option D (Anypoint Platform REST APIs) requires custom scripting for deployment, which can be more complex than using the Mule Maven plugin.
Reference
For more details, refer to MuleSoft documentation on using the Mule Maven plugin for CI/CD.
NEW QUESTION # 153
A RAML definition has been proposed for a new Promotions Process API, and has been published to Anypoint Exchange.
The Marketing Department, who will be an important consumer of the Promotions API, has important requirements and expectations that must be met.
What is the most effective way to use Anypoint Platform features to involve the Marketing Department in this early API design phase?
A) Ask the Marketing Department to interact with a mocking implementation of the API using the automatically generated API Console
B) Organize a design workshop with the DBAs of the Marketing Department in which the database schema of the Marketing IT systems is translated into RAML C) Use Anypoint Studio to Implement the API as a Mule application, then deploy that API implementation to CloudHub and ask the Marketing Department to interact with it D) Export an integration test suite from API designer and have the Marketing Department execute the tests In that suite to ensure they pass
  • A. Option B
  • B. Option D
  • C. Option A
  • D. Option C
Correct Answe r: Ask the Marketing Department to interact with a mocking implementation of the API using the automatically generated API Console.
As per MuleSoft's IT Operating Model:
>> API consumers need NOT wait until the full API implementation is ready.
>> NO technical test-suites needs to be shared with end users to interact with APIs.
>> Anypoint Platform offers a mocking capability on all the published API specifications to Anypoint Exchange which also will be rich in documentation covering all details of API functionalities and working nature.
>> No needs of arranging days of workshops with end users for feedback.
API consumers can use Anypoint Exchange features on the platform and interact with the API using its mocking feature. The feedback can be shared quickly on the same to incorporate any changes.
NEW QUESTION # 154
If you want to strive for a further improvement in the IT industry, it's right to choose our Dumpkiller. Dumpkiller's Mule-Arch-201 exam certification training materials is worked out by IT industry elite team through their own exploration and continuous practice. It has high accuracy and wide coverage. Owning Dumpkiller's Mule-Arch-201 Exam Certification training materials is equal to have the key to success.
Mule-Arch-201 Valid Exam Simulator: https://www.dumpkiller.com/Mule-Arch-201_braindumps.html
Salesforce Exam Mule-Arch-201 Simulations And you are able to apply for full refund or changing practice material freely with your flunked reports, Purchase Salesforce Mule-Arch-201 Exam Product with fully APP and available in your Dumpkiller Account.We Respect Privacy PolicyWe Respect Privacy Policy, Our Mule-Arch-201 valid pdf can stand the test of time and have been first-rank materials for ten years with tens of thousands of regular clients all over the world, The sooner you download and use Mule-Arch-201 guide torrent, the sooner you get the Mule-Arch-201 certificate.
The paper was prepared for presentation at a conference in mid  Sba The purpose Latest Mule-Arch-201 Test Voucher of the paper is to outline important issues facing small business owners and entrepreneurs and the policy issues the next administration will face.
Pass Guaranteed Quiz Salesforce - Mule-Arch-201 - Salesforce Certified MuleSoft Platform Architect –High-quality Exam SimulationsIn most cases, there are several ways to get to where you're Mule-Arch-201 going, And you are able to apply for full refund or changing practice material freely with your flunked reports.
Purchase Salesforce Mule-Arch-201 Exam Product with fully APP and available in your Dumpkiller Account.We Respect Privacy PolicyWe Respect Privacy Policy, Our Mule-Arch-201 valid pdf can stand the test of time and have New Mule-Arch-201 Test Online been first-rank materials for ten years with tens of thousands of regular clients all over the world.
The sooner you download and use Mule-Arch-201 guide torrent, the sooner you get the Mule-Arch-201 certificate, Dumpkiller provide a shot cut to pass the exam and get the certification.
