[General] Verified and Updated Amazon DOP-C02 Exam Questions & Answers
142
【General】 Verified and Updated Amazon DOP-C02 Exam Questions & Answers
Posted at 2/20/2026 18:38:32      View:83 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New DOP-C02 dumps are available on Google Drive shared by ExamTorrent: https://drive.google.com/open?id=1uOUC0ddlkfXaWp3G2ZivxWX1nxKunO9A
God wants me to be a person who have strength, rather than a good-looking doll. When I chose the IT industry I have proven to God my strength. But God forced me to keep moving. Amazon DOP-C02 exam is a major challenge in my life, so I am desperately trying to learn. But it does not matter, because I purchased ExamTorrent's Amazon DOP-C02 Exam Training materials. With it, I can pass the Amazon DOP-C02 exam easily. Road is under our feet, only you can decide its direction. To choose ExamTorrent's Amazon DOP-C02 exam training materials, and it is equivalent to have a better future.
To help our customer know our DOP-C02 exam questions better, we have carried out many regulations which concern service most. You can ask what you want to know about our DOP-C02 study guide. Once you submit your questions, we will soon give you detailed explanations. Even you come across troubles during practice the DOP-C02 Learning Materials; we will also help you solve the problems. We are willing to deal with your problems. So just come to contact us.
DOP-C02 PDF - DOP-C02 Simulated TestWhatever may be the reason to leave your job, if you have made up your mind, there is no going back. By getting the Amazon DOP-C02 Certification, you can avoid thinking about negative things, instead, you can focus on the positive and bright side of taking this step and find a new skill set to improve your chances of getting your dream job.
Amazon AWS Certified DevOps Engineer - Professional Sample Questions (Q310-Q315):NEW QUESTION # 310
An application running on a set of Amazon EC2 instances in an Auto Scaling group requires a configuration file to operate. The instances are created and maintained with AWS CloudFormation. A DevOps engineer wants the instances to have the latest configuration file when launched and wants changes to the configuration file to be reflected on all the instances with a minimal delay when the CloudFormation template is updated.
Company policy requires that application configuration files be maintained along with AWS infrastructure configuration files m source control.
Which solution will accomplish this?
  • A. In the CloudFormaiion template add an AWS Config rule. Place the configuration file content in the rule's InputParameters property and set the Scope property to the EC2 Auto Scaling group. Add an AWS Systems Manager Resource Data Sync resource to the template to poll for updates to the configuration.
  • B. In the CloudFormation template add CloudFormation imt metadata. Place the configuration file content m the metadata. Configure the cfn-init script to run when the instance is launched and configure the cfn-hup script to poll for updates to the configuration.
  • C. In the CloudFormation template add an EC2 launch template resource. Place the configuration file content in the launch template. Configure the cfn-mit script to run when the instance is launched and configure the cfn-hup script to poll for updates to the configuration.
  • D. In the CloudFormation template add an EC2 launch template resource. Place the configuration file content in the launch template. Add an AWS Systems Manager Resource Data Sync resource to the template to poll for updates to the configuration.
Use the AWS::CloudFormation::Init type to include metadata on an Amazon EC2 instance for the cfn-init helper script. If your template calls the cfn-init script, the script looks for resource metadata rooted in the AWS::CloudFormation::Init metadata key. Reference:
https://docs.aws.amazon.com/AWSC ... -resource-init.html
NEW QUESTION # 311
A DevOps team manages an API running on-premises that serves as a backend for an Amazon API Gateway endpoint. Customers have been complaining about high response latencies, which the development team has verified using the API Gateway latency metrics in Amazon CloudWatch. To identify the cause, the team needs to collect relevant data without introducing additional latency.
Which actions should be taken to accomplish this? (Choose two.)
  • A. Enable AWS X-Ray tracing in API Gateway, modify the application to capture request segments, and upload those segments to X-Ray during each request.
  • B. Enable AWS X-Ray tracing in API Gateway, modify the application to capture request segments, and use the X-Ray daemon to upload segments to X-Ray.
  • C. Modify the on-premises application to send log information back to API Gateway with each request.
  • D. Install the CloudWatch agent server side and configure the agent to upload relevant logs to CloudWatch.
  • E. Modify the on-premises application to calculate and upload statistical data relevant to the API service requests to CloudWatch metrics.
https://docs.aws.amazon.com/Amaz ... ent-on-premise.html https://docs.aws.amazon.com/xray ... pi-sendingdata.html
NEW QUESTION # 312
A company has several AWS accounts. An Amazon Connect instance runs in each account. The company uses an Amazon EventBridge default event bus in each account for event handling.
A DevOps team needs to receive all the Amazon Connect events in a single DevOps account.
Which solution meets these requirements?
  • A. Update the resource-based policy of the default event bus in each account to allow the DevOps account to replay events. Configure an EventBridge rule in the DevOps account that matches Amazon Connect events and has a target of the default event bus in the other accounts.
  • B. Update the resource-based policy of the default event bus in the DevOps account. Update the policy to allow events to be received from the accounts. Configure an EventBridge rule in each account that matches Amazon Connect events and has a target of the DevOps account's default event bus.
  • C. Update the resource-based policy of the default event bus in the DevOps account. Update the policy to allow events to be replayed by the accounts. Configure an EventBridge rule in each account that matches Amazon Connect events and has a target of the DevOps account's default event bus.
  • D. Update the resource-based policy of the default event bus in each account to allow the DevOps account to receive events. Configure an EventBridge rule in the DevOps account that matches Amazon Connect events and has a target of the default event bus in the other accounts.
To aggregate events from multiple accounts into a single account, thedefault event bus in the receiving (DevOps) accountmust have a resource-based policy allowing the source accounts to put events into it.
Then, an EventBridgerule in each source accountroutes Amazon Connect events to thedefault event bus in the DevOps account(cross-account event delivery).
Options A and B describe policies or rules incorrectly applying permissions or routing. Option D mentions replay permissions, which are unrelated to event routing.
EventBridge Cross-Account Event Delivery
Resource-Based Policies for Event Buses
NEW QUESTION # 313
A company deploys a web application on Amazon EC2 instances that are behind an Application Load Balancer (ALB). The company stores the application code in an AWS CodeCommit repository. When code is merged to the main branch, an AWS Lambda function invokes an AWS CodeBuild project. The CodeBuild project packages the code, stores the packaged code in AWS CodeArtifact, and invokes AWS Systems Manager Run Command to deploy the packaged code to the EC2 instances.
Previous deployments have resulted in defects, EC2 instances that are not running the latest version of the packaged code, and inconsistencies between instances.
Which combination of actions should a DevOps engineer take to implement a more reliable deployment solution? (Select TWO.)
  • A. Create an Amazon S3 bucket. Modify the CodeBuild project to store the packages in the S3 bucket instead of in CodeArtifact. Use deploy actions in CodeDeploy to deploy the artifact to the EC2 instances.
  • B. Create a pipeline in AWS CodePipeline that uses the CodeCommit repository as a source provider.
    Create separate pipeline stages that run a CodeBuild project to build and then test the application. In the pipeline, pass the CodeBuild project output artifact to an AWS CodeDeploy action.
  • C. Create an AWS CodeDeploy application and a deployment group to deploy the packaged code to the EC2 instances. Configure the ALB for the deployment group.
  • D. Create individual Lambda functions that use AWS CodeDeploy instead of Systems Manager to run build, test, and deploy actions.
  • E. Create a pipeline in AWS CodePipeline that uses the CodeCommit repository as a source provider.
    Configure pipeline stages that run the CodeBuild project in parallel to build and test the application. In the pipeline, pass the CodeBuild project output artifact to an AWS CodeDeploy action.
Answer: C,E
To implement a more reliable deployment solution, a DevOps engineer should take the following actions:
Create a pipeline in AWS CodePipeline that uses the CodeCommit repository as a source provider. Configure pipeline stages that run the CodeBuild project in parallel to build and test the application. In the pipeline, pass the CodeBuild project output artifact to an AWS CodeDeploy action. This action will improve the deployment reliability by automating the entire process from code commit to deployment, reducing human errors and inconsistencies. By running the build and test stages in parallel, the pipeline can also speed up the delivery time and provide faster feedback. By using CodeDeploy as the deployment action, the pipeline can leverage the features of CodeDeploy, such as traffic shifting, health checks, rollback, and deployment configuration123 Create an AWS CodeDeploy application and a deployment group to deploy the packaged code to the EC2 instances. Configure the ALB for the deployment group. This action will improve the deployment reliability by using CodeDeploy to orchestrate the deployment across multiple EC2 instances behind an ALB.
CodeDeploy can perform blue/green deployments or in-place deployments with traffic shifting, which can minimize downtime and reduce risks. CodeDeploy can also monitor the health of the instances during and after the deployment, and automatically roll back if any issues are detected. By configuring the ALB for the deployment group, CodeDeploy can register and deregister instances from the load balancer as needed, ensuring that only healthy instances receive traffic45 The other options are not correct because they do not improve the deployment reliability or follow best practices. Creating separate pipeline stages that run a CodeBuild project to build and then test the application is not a good option because it will increase the pipeline execution time and delay the feedback loop. Creating individual Lambda functions that use CodeDeploy instead of Systems Manager to run build, test, and deploy actions is not a valid option because it will add unnecessary complexity and cost to the solution. Lambda functions are not designed for long-running tasks such as building or deploying applications. Creating an Amazon S3 bucket and modifying the CodeBuild project to store the packages in the S3 bucket instead of in CodeArtifact is not a necessary option because it will not affect the deployment reliability. CodeArtifact is a secure, scalable, and cost-effective package management service that can store and share software packages for application development67
1: What is AWS CodePipeline? - AWS CodePipeline
2: Create a pipeline in AWS CodePipeline - AWS CodePipeline
3: Deploy an application with AWS CodeDeploy - AWS CodePipeline
4: What is AWS CodeDeploy? - AWS CodeDeploy
5: Configure an Application Load Balancer for your blue/green deployments - AWS CodeDeploy
6: What is AWS Lambda? - AWS Lambda
7: What is AWS CodeArtifact? - AWS CodeArtifact
NEW QUESTION # 314
An ecommerce company hosts a web application on Amazon EC2 instances that are in an Auto Scaling group.
The company deploys the application across multiple Availability Zones.
Application users are reporting intermittent performance issues with the application.
The company enables basic Amazon CloudWatch monitoring for the EC2 instances. The company identifies and implements a fix for the performance issues. After resolving the issues, the company wants to implement a monitoring solution that will quickly alert the company about future performance issues.
Which solution will meet this requirement?
  • A. Enable VPC Flow Logs. Use Amazon Data Firehose to stream flow logs to Amazon S3. Use Amazon Athena to analyze the logs and to send alerts to the company.
  • B. Enable detailed monitoring for the EC2 instances. Create custom CloudWatch metrics for application- specific performance indicators. Set up CloudWatch alarms based on the custom metrics. Use CloudWatch Logs Insights to analyze application logs for error patterns.
  • C. Use Amazon CloudFront to deliver the application. Use AWS CloudTrail to monitor API calls. Use AWS Trusted Advisor to generate recommendations to optimize performance. Use Amazon GuardDuty to detect potential performance issues.
  • D. Use AWS X-Ray to implement distributed tracing. Integrate X-Ray with Amazon CloudWatch RUM.
    Use Amazon EventBridge to trigger automatic scaling actions based on custom events.
The company needs fast, proactive alerts for future performance issues, beyond basic EC2 metrics. Option A provides a complete, AWS-native monitoring pattern aligned with best practices:
* Enable detailed monitoring on EC2 instances to increase metric resolution (from 5-minute to 1-minute intervals), improving the responsiveness of alarms.
* Define custom CloudWatch metrics for application-level indicators such as request latency, error rate, queue depth, or throughput. These metrics can be published from the application or sidecar agents.
* Create CloudWatch alarms on both infrastructure (CPU, network, disk) and custom application metrics with thresholds that reflect performance SLOs. Alarms can notify teams via SNS or incident management tools.
* Use CloudWatch Logs Insights to analyze logs for recurring error patterns, slow requests, or exceptions when alarms fire.
Option B focuses on tracing and frontend RUM; while useful, it is more complex and not necessary just to get quick alerts. Option C uses services (CloudTrail, GuardDuty, Trusted Advisor) that are not focused on real- time performance detection. Option D with VPC Flow Logs is network-level and would not detect general application performance issues.
Thus, Option A offers a direct, efficient way to detect and alert on performance degradations quickly.
NEW QUESTION # 315
As you all know that practicing with the wrong preparation material will waste your valuable money and many precious study hours. So you need to choose the most proper and verified preparation material with caution. Preparation material for the AWS Certified DevOps Engineer - Professional (DOP-C02) exam questions from ExamTorrent helps to break down the most difficult concepts into easy-to-understand examples. Also, you will find that all the included questions are based on the last and updated DOP-C02 Exam Dumps version. We are sure that using DOP-C02 Exam Questions preparation material will support you in passing the DOP-C02 exam with confidence.
DOP-C02 PDF: https://www.examtorrent.com/DOP-C02-valid-vce-dumps.html
Because this is a browser-based DOP-C02 practice test, there is no need for installation, Amazon DOP-C02 Test Dumps.zip You won't find anything difficult, and we want to help you succeed, which is why we offer a free demo, We have clear data collected from customers who chose our DOP-C02 actual tests, the passing rate is 98-100 percent, As long as you buy our DOP-C02 study guide, you will be benefited from it!
A more efficient way to add metadata, By Michael Sellers, Because this is a browser-based DOP-C02 Practice Test, there is no need for installation, You won't find anything DOP-C02 difficult, and we want to help you succeed, which is why we offer a free demo.
Quiz 2026 Amazon DOP-C02 Latest Test Dumps.zipWe have clear data collected from customers who chose our DOP-C02 actual tests, the passing rate is 98-100 percent, As long as you buy our DOP-C02 study guide, you will be benefited from it!
As long as you follow the pace of our DOP-C02 practice materials, you will certainly have unexpected results.
