[General] AP-219 Exam Book & AP-219 Latest Exam Pattern
103
【General】 AP-219 Exam Book & AP-219 Latest Exam Pattern
Posted at 2/20/2026 19:46:08      View:89 | Replies:0        Print      Only Author   [Copy Link] 1#
The AP-219 practice exam software is essential for your Salesforce Order Management Administrator Accredited Professional exam preparation as it gives you hands-on experience before the actual AP-219 certification exam. This kind of exam preparation ensures that a well-prepared and more confident candidate enters the examination arena. While using this Salesforce AP-219 Practice Exam software, you can easily customize your Salesforce Order Management Administrator Accredited Professional mock exam conditions such as exam duration, number of questions, and many more. These Salesforce AP-219 dumps bear the closest resemblance to the actual AP-219 dumps that will be asked of you in the exam.
Salesforce AP-219 Exam Syllabus Topics:
  • Deployment and Debugging: Deployment options, lifecycle management, building processes with pre-configured data, and understanding supporting objects and system runtime.
  • Data Model: Core objects (Order, Order Summary, Fulfillment Orders, Return Orders), B2C Commerce integrations, and tracing data flow including custom attributes.
  • Order Management Basics: Foundation of Order Management within Salesforce ecosystem, platform architecture, integration capabilities with third-party systems, and native Salesforce functionality.
  • Advanced Topics: Troubleshooting configuration issues, diagnosing system integration problems, and resolving deployment obstacles.
Topic 5
  • Process Automation and Integrations: Configuring end-to-end Order Management processes and external system integrations using declarative tools and clicks-based configuration.
AP-219 Latest Exam Pattern | AP-219 Reliable Exam GuideWith regard to the Internet, if you use our AP-219 study materials in a network environment, then you can use our products in a non-network environment. AP-219 learning guide guarantee that you can make full use of all your free time to learn, if you like. The reason why we emphasize this is that we know you have a lot of other things to do. Many users stated that they can only use fragmented time to learn. Experts at AP-219 practice prep also fully considered this point.
Salesforce Order Management Administrator Accredited Professional Sample Questions (Q94-Q99):NEW QUESTION # 94
An administrator is attempting to automatically create process exceptions for the Fulfillment Order object. When does the Create Process Exception flow get triggered?
  • A. On a daily basis using Schedule Jobs in Setup
  • B. A Process Exception Event is fired
  • C. A Fulfillment Order or Order Summary object are modified and any modification meets the error criteria
NEW QUESTION # 95
An Administrator has created a change set with two items, a new apex class and a new apex trigger. When attempting to deploy the change set, and error occurs? What could be the cause?
  • A. <br>
  • B. An Apex Trigger cannot be deployed via change set <br>
  • C. The new apex class and trigger have lowered the sent *** **** the ********* threshold
  • D. Different Metadata types cannot be deployed within a single change set <br>
  • E. Apex Classes require a header file when deployed <br>
Answer: E
NEW QUESTION # 96
Which two order management objects have their s set to hidden by default?
(choose 2)
  • A. Accounts
  • B. Order Delivery Method
  • C. Sales Location
  • D. Locations
  • E. Fulfillment orders
NEW QUESTION # 97
What two tools can an administrator use to debug an issue with an Apex trigger?
  • A. Log Inspector in the Developer Console
  • B. Error Logs in the Developer Console
  • C. Apex Logs in Setup
  • D. Debug Logs in Setup
The administrator can use two tools to debug an issue with an Apex trigger: Log Inspector in the Developer Console and Debug Logs in Setup. The Log Inspector is a tool that displays agraphical representation of a debug log, which is a record of database operations, system processes, and errors that occur when executing a transaction or running unit tests. The Log Inspector helps you analyze and troubleshoot your code by highlighting errors, checkpoints, and execution times. The Debug Logs page in Setup lets you monitor and retain debug logs for users, Apex classes, Apex triggers, and Lightning components. You can view, download, or delete debug logs from this page.
NEW QUESTION # 98
How can an administrator synchronize licenses from the production org when preparing a sandbox for development?
  • A. import a Change Set
  • B. Run the Match Production Licenses to Sandbox without a Refresh tool in Setup
  • C. Export a Change Set
  • D. Use a custom shell script
The best way for an administrator to synchronize licenses from the production org when preparing a sandbox for development is to run the Match Production Licenses to Sandbox without a Refresh tool in Setup. This tool allows administrators to match theirsandbox licenses with their production licenses without refreshing their sandbox. This way, the administrator can ensure that the sandbox has the same number and type of licenses as the production org, and avoid any license-related issues when developingor testing in the sandbox. Verified Reference:https://help.salesforce.com/s/ar ... nses.htm&type=5
NEW QUESTION # 99
Compared with the paper version, we have the advantage of instant access to download, and you will receive your download link and password for AP-219 training materials within ten minutes, so that you can start learning as early as possible. In addition, we have free demo for you to have a try for AP-219 Exam barindumps, so that you can know what the complete version is like. Online and offline service are available, and if you have any questions for AP-219 exam materials, you can contact us, and we will give you reply as quickly as we can.
AP-219 Latest Exam Pattern: https://www.dumpsking.com/AP-219-testking-dumps.html
