Oracle 1z0-809 Latest Test Camp: Java SE 8 Programmer II - PrepAwayPDF Free Down
Posted at 2/20/2026 20:07:12
P.S. Free 2026 Oracle 1z0-809 dumps are available on Google Drive shared by PrepAwayPDF: https://drive.google.com/open?id=10_BEvEYnJdMNbm6dxW5nH6ONVHfjl9NC
Our 1z0-809 exam questions are valuable and useful and if you buy our 1z0-809 study materials will provide first-rate service to you to make you satisfied. We provide not only the free download and try out of the 1z0-809 Practice Guide but also the immediate download after your purchase successfully. To see whether our 1z0-809 training dumps are worthy to buy, you can have a try on our product right now.
The Oracle 1z0-809 exam consists of 85 multiple-choice and drag-and-drop questions, which you must complete within 150 minutes. 1z0-809 exam covers a range of topics, including Java Class Design, Generics and Collections, Lambda Built-in Functional Interfaces, Java Stream API, Java I/O Fundamentals, Java Concurrency, Building Database Applications with JDBC, and Localization. Passing the Oracle 1z0-809 Exam is a great way to demonstrate your advanced Java programming skills and enhance your career opportunities in the field of software development.
Real Oracle 1z0-809 Question - 1z0-809 Exam TopicOnce you get the Oracle 1z0-809 certificate, you can quickly quit your current job and then change a desirable job. The Oracle 1z0-809 certificate can prove that you are a competent person. So it is easy for you to pass the interview and get the job. The assistance of our 1z0-809 practice quiz will change your life a lot.
Oracle Java SE 8 Programmer II Sample Questions (Q93-Q98):NEW QUESTION # 93
Given the definition of the Country class:
public class country {
public enum Continent {ASIA, EUROPE}
String name;
Continent region;
public Country (String na, Continent reg) {
name = na, region = reg;
public String getName () {return name;}
public Continent getRegion () {return region;}
and the code fragment:
List<Country> couList = Arrays.asList (
new Country ("Japan", Country.Continent.ASIA),
new Country ("Italy", Country.Continent.EUROPE),
new Country ("Germany", Country.Continent.EUROPE));
Map<Country.Continent, List<String>> regionNames = couList.stream ()
.collect(Collectors.groupingBy (Country ::getRegion,
Collectors.mapping(Country::getName, Collectors.toList()))));
System.out.println(regionNames);
What is the output?
- A. {EUROPE = [Germany, Italy], ASIA = [Japan]}
- B. {EUROPE = [Italy, Germany], ASIA = [Japan]}
- C. {EUROPE = [Germany], EUROPE = [Italy], ASIA = [Japan]}
- D. {ASIA = [Japan], EUROPE = [Italy, Germany]}
NEW QUESTION # 94
Given:
public class Canvas implements Drawable {
public void draw () { }
public abstract class Board extends Canvas { }
public class Paper extends Canvas {
protected void draw (int color) { }
public class Frame extends Canvas implements Drawable {
public void resize () { }
public interface Drawable {
public abstract void draw ();
Which statement is true?
- A. Framedoes not compile.
- B. Paperdoes not compile.
- C. Drawabledoes not compile.
- D. Boarddoes not compile.
- E. All classes compile successfully.
Answer: E
NEW QUESTION # 95
Which two statements are true about localizing an application? (Choose two.)
- A. Support for new regional languages does not require recompilation of the code.
- B. Textual elements (messages and GUI labels) are hard-coded in the code.
- C. Resource bundle files include data and currency information.
- D. Language codes use lowercase letters and region codes use uppercase letters.
- E. Language and region-specific programs are created using localized data.
Explanation/Reference:
Reference: http://docs.oracle.com/javase/7/docs/technotes/guides/intl/
NEW QUESTION # 96
Given:
Which two interfaces can you use to create lambda expressions? (Choose two.)
Answer: C,E
NEW QUESTION # 97
Given the code fragment:
Which code fragment, when inserted at line 9, enables the code to print true?
- A. String str2 = sb1.toString ( );
- B. String str2 = "Duke";
- C. String str2 = str1;
- D. String str2 = new String (str1);
StringBuilder sb1 = new StringBuilder("Duke");
String str1 = sb1.toString();
String str2 = str1;
//String str2 = "Duke";
//String str2 = new String(str1);
System.out.println(str1 == str2);
NEW QUESTION # 98
You don't need to enroll yourself in expensive 1z0-809 exam training classes. With the Java SE 8 Programmer II (1z0-809) valid dumps, you can easily prepare well for the actual Oracle 1z0-809 Exam at home. Java SE 8 Programmer II (1z0-809) practice test software is compatible with windows and the web-based software will work on many operating systems.
Real 1z0-809 Question: https://www.prepawaypdf.com/Oracle/1z0-809-practice-exam-dumps.html
- 1z0-809 PDF VCE 🤸 Reliable 1z0-809 Exam Prep 🍴 1z0-809 PDF VCE 🎮 “ [url]www.testkingpass.com ” is best website to obtain { 1z0-809 } for free download 🎇Latest 1z0-809 Test Format[/url]
- 1z0-809 Latest Test Camp | Professional Oracle 1z0-809: Java SE 8 Programmer II 🕯 Simply search for ⮆ 1z0-809 ⮄ for free download on 《 [url]www.pdfvce.com 》 ☝1z0-809 Test Question[/url]
- Pass Guaranteed Quiz 2026 Authoritative Oracle 1z0-809 Latest Test Camp 🦚 Open website ➥ [url]www.practicevce.com 🡄 and search for ▷ 1z0-809 ◁ for free download 🥮1z0-809 Valid Exam Forum[/url]
- Reliable 1z0-809 Exam Sample 🦯 Instant 1z0-809 Discount 🖖 1z0-809 Practice Test Fee 🥽 Search for “ 1z0-809 ” on ⏩ [url]www.pdfvce.com ⏪ immediately to obtain a free download 🎫1z0-809 Valid Exam Forum[/url]
- 2026 Oracle Authoritative 1z0-809 Latest Test Camp 👒 Immediately open “ [url]www.pdfdumps.com ” and search for ➠ 1z0-809 🠰 to obtain a free download 🩳Reliable 1z0-809 Exam Sample[/url]
- Latest 1z0-809 Test Format 🙆 1z0-809 Latest Exam Fee ✳ 1z0-809 Test Question 🎻 Simply search for 「 1z0-809 」 for free download on ➠ [url]www.pdfvce.com 🠰 🥍1z0-809 Reliable Dump[/url]
- Pass Guaranteed Efficient Oracle - 1z0-809 Latest Test Camp 🐴 The page for free download of ☀ 1z0-809 ️☀️ on ⮆ [url]www.exam4labs.com ⮄ will open immediately 🤎1z0-809 Valid Exam Forum[/url]
- 2026 100% Free 1z0-809 –Efficient 100% Free Latest Test Camp | Real Java SE 8 Programmer II Question 💺 The page for free download of ⮆ 1z0-809 ⮄ on ⮆ [url]www.pdfvce.com ⮄ will open immediately 🏕1z0-809 Valid Braindumps Ppt[/url]
- Latest 1z0-809 Test Format 🦄 1z0-809 Study Guides 📅 1z0-809 Latest Exam Fee 😫 Copy URL 【 [url]www.examcollectionpass.com 】 open and search for ➽ 1z0-809 🢪 to download for free 💥1z0-809 PDF VCE[/url]
- Actual Oracle 1z0-809 Exam Dumps - Achieve Success In Exam 🦏 Go to website ( [url]www.pdfvce.com ) open and search for ( 1z0-809 ) to download for free 👯Latest 1z0-809 Test Format[/url]
- 1z0-809 Valid Exam Forum 🔷 1z0-809 Test Question 🅿 1z0-809 Actual Dumps 🤞 Search for ▛ 1z0-809 ▟ and easily obtain a free download on [ [url]www.prepawayexam.com ] 💑1z0-809 Valid Exam Forum[/url]
- programmercepat.com, thecodingtracker.com, 24hoursschool.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, lms.m1security.co.za, Disposable vapes
BONUS!!! Download part of PrepAwayPDF 1z0-809 dumps for free: https://drive.google.com/open?id=10_BEvEYnJdMNbm6dxW5nH6ONVHfjl9NC
