[General] New 2V0-32.24 Exam Practice & 2V0-32.24 Updated CBT
103
General New 2V0-32.24 Exam Practice & 2V0-32.24 Updated CBT
Posted at 2/20/2026 20:08:53      View149 | Replies1        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of PrepPDF 2V0-32.24 dumps from Cloud Storage: https://drive.google.com/open?id=1t7JeuL5nDO8DXfUZ5Qd_26u1izLKFdsO
Getting the VMware Cloud Operations 8.x Professional V2 (2V0-32.24) certification is the way to go if you're planning to get into VMware or want to start earning money quickly. Success in the VMware Cloud Operations 8.x Professional V2 (2V0-32.24) exam of this credential plays an essential role in the validation of your skills so that you can crack an interview or get a promotion in an VMware company. Many people are attempting the VMware 2V0-32.24 test nowadays because its importance is growing rapidly.
VMware 2V0-32.24 Exam Syllabus Topics:
  • Planning and Designing: This section of the exam measures the skills of Cloud Architects and covers the architectural models and sizing requirements for vRealize Operations and vRealize Log Insight. It evaluates the ability to choose between standalone, clustered, and high-availability setups, and to plan appropriately based on scenario-based requirements for capacity and deployment type, ensuring well-designed cloud solutions.
  • Architecture and Technologies: This section of the exam measures the skills of Cloud Architects and covers the core differences between VMware Cloud Management offerings, focusing on SaaS versus on-premises deployments. It introduces the capabilities of vRealize Suite Lifecycle Manager, vRealize Operations, and vRealize Log Insight, helping professionals understand the foundational technologies that support VMwares cloud ecosystem.
  • Performance-tuning, Optimization, and Upgrades: This section has no testable objectives and therefore is not directly assessed in the exam.
  • VMware Products and Solutions: This section of the exam measures the skills of Cloud Engineers and covers the components, integrations, and use cases for various VMware Cloud Management solutions. It includes tools like vRealize True Visibility Suite, Skyline, Federated Analytics, vRealize AI Cloud, and Log Insight Cloud. Candidates also explore deployment tools such as Remote Collectors and Cloud Proxies to understand their role in scalable cloud operations.
Free PDF Quiz VMware 2V0-32.24 Marvelous New Exam PracticeOur 2V0-32.24 exam torrent is finalized after being approved by industry experts and 2V0-32.24 Practice Materials are tested by professionals with a high pass rate as 99%. Besides, 2V0-32.24 Learning Guide helps establish your confidence and avoid wasting time. That is because our 2V0-32.24 Practice Test can serve as a conducive tool for you make up for those hot points you have ignored, you will have every needed 2V0-32.24 exam questions and answers in the actual exam to pass it.
VMware Cloud Operations 8.x Professional V2 Sample Questions (Q54-Q59):NEW QUESTION # 54
An administrator is setting up vSphere integration for syslog collection from ESXi hosts in vRealize Log Insight.
Which one is the correct permission required in vSphere?
  • A. Security profile and firewall.Configuration
  • B. Confiquration.AdvancedSettings.Host
  • C. Host.Network Configuration.Configuration
  • D. Host.Configuration.Change Settings
To configure vSphere integration for syslog collection from ESXi hosts in vRealize Log Insight, the administrator needs the Host.Configuration.Change Settings permission. This permission allows the user to modify the settings for the host, including configuring syslog settings, which are required for sending logs to vRealize Log Insight.
NEW QUESTION # 55
Which two types of pre-configured content are provided when deploying a content packs in vRealize Log Insight? (Choose two.)
  • A. Extracted fields
  • B. Reports
  • C. Dashboards
  • D. Recommendation
  • E. Custom scripts
When deploying a content pack in vRealize Log Insight, the following pre-configured content is typically provided:
Dashboards: Content packs often come with pre-configured dashboards that allow users to quickly visualize log data and gain insights based on predefined queries and metrics.
Reports: Content packs may also include pre-configured reports that summarize log data, helping users quickly generate and view key information from the logs.
NEW QUESTION # 56
An administrator has been tasked with deploying vRealize Operations (vROps).
The requirements are:
The deployment must consume a minimal amount of cluster compute resources The deployment must be resilient against a single vROps node failure Which option would meet the requirements?
  • A. Deploy vRealize Operations as a cluster and enable High Availability (HA)
  • B. Deploy vRealize Operations so that Continuous Availability (CA) can be enabled
  • C. Deploy two Remote Collector nodes and place them in a Collector Group
  • D. Deploy vRealize Operations as a cluster
To meet the requirement of consuming minimal cluster compute resources while also being resilient against a single node failure, deploying vRealize Operations as a cluster and enabling High Availability (HA) is the best option.
NEW QUESTION # 57
An administrator is deploying vRealize Log Insight and needs to choose the most performant disk format option.
Which option should the administrator choose?
  • A. Deploy vRealize Log Insight using the Thin Provision disk format.
  • B. Deploy vRealize Log Insight using Raw Disk Mapping.
  • C. Deploy vRealize Log Insight using the Thick Provision Lazy Zeroed disk format.
  • D. Deploy vRealize Log Insight using the Thick Provision Eager Zeroed disk format.
The most performant disk format for vRealize Log Insight is Thick Provision Eager Zeroed. This format provides better performance because the entire disk is allocated at the time of creation and is immediately zeroed out, which eliminates the overhead of allocating space during runtime and ensures faster read/write operations.
NEW QUESTION # 58
Forty days ago, an administrator provisioned a Virtual Machine (vm-01) in preparation for a new project. The project has now been delayed due to budgetary constraints. As part of the monthly service management checks, a second administrator executes the reclaim action on all idle virtual machines and vm-01 is listed.
The second administrator accidentally reclaims all idle virtual machines including vm-01.
What action can the administrator complete to prevent this scenario from happening again?
  • A. Increase the default value of the Exclude VM provisioned in the last x days setting.
  • B. Create a dynamic group with membership based on vSphere tags so that all new virtual machines are included and then exclude the entire group from reclaim analysis.
  • C. Create a new policy that disables the capacity reclamation on the policy and apply the policy to the parent object hosting new virtual machines.
  • D. Disable Capacity reclamation on the policy applied to new virtual machines.
To prevent virtual machines like vm-01 from being reclaimed too early, the administrator can increase the default value of the Exclude VM provisioned in the last x days setting. This ensures that newly provisioned VMs, like vm-01, will be excluded from the reclamation process for a longer period (e.g., 30, 60, or more days), preventing accidental reclamation of VMs that are still in use or under consideration for future projects.
This action directly addresses the issue of accidentally reclaiming recently provisioned virtual machines.
NEW QUESTION # 59
2V0-32.24 certification exam is a very import component VMware certification exam. But passing VMware certification 2V0-32.24 exam is not so simple. In order to give to relieve pressure and save time and effort for candidates who take a preparation for the 2V0-32.24 Certification Exam, PrepPDF specially produce a variety of training tools. So you can choose an appropriate quick training from PrepPDF to pass the exam.
2V0-32.24 Updated CBT: https://www.preppdf.com/VMware/2V0-32.24-prepaway-exam-dumps.html
Posted at 2/22/2026 11:20:28        Only Author  2#
No hesitation at all, this content gets my like. The content in Latest SDS exam camp is rich and free, available to aid you in your learning journey.
