High Pass Rate Oracle 1Z0-1042-25 Test Dumps Cram is the best for you - ValidExa
110
Posted at 2/20/2026 20:56:29      View87 | Replies0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest ValidExam 1Z0-1042-25 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1I9RCxvnRmQXJkMzTMR8jmafdL29TIqew
We provide a wide range of learning and preparation methodologies to the customers for the 1Z0-1042-25 complete training. After using the 1Z0-1042-25 products, success would surely be the fate of customer because, self-evaluation, highlight of the mistakes, time management and sample question answers in comprehensive manner, are all the tools which are combined to provide best possible results. We are also offering 100% money back guarantee to the customers in case they don't achieve passing scores in the Oracle 1Z0-1042-25 in the first attempt.
Oracle 1Z0-1042-25 Exam Syllabus Topics:
  • Testing, Monitoring, and Troubleshooting Integrations: This section assesses the abilities of Support Engineers and Integration Administrators in managing integration lifecycles. It includes activating and deactivating integrations, testing REST-triggered integrations, importing and exporting integrations, as well as monitoring and troubleshooting integration instances to ensure smooth operations.
  • Creating Scheduled Integrations: This domain measures the skills of Automation Engineers and Cloud Administrators in defining integration schedules and converting scheduled integrations to app-driven ones. It also includes using scheduled parameters to automate workflows efficiently.
  • Creating Orchestrated Integrations: This section tests the knowledge of Orchestration Developers and Business Process Analysts in managing orchestrated integrations within OIC. It includes using lookups, data mappers, and custom JavaScript libraries, configuring orchestration flow actions, implementing file handling options, and leveraging the fault-handling framework to manage errors effectively.
  • Using OIC Connections & Adapters: This section evaluates the expertise of Integration Developers and Solution Architects in creating and configuring OIC connections. It includes setting up trigger and invoke connections, understanding the role of the Connectivity Agent, and effectively using adapters to connect cloud and on-premises applications seamlessly.
Topic 5
  • Getting Started with OIC Integrations: This section of the exam measures the skills of Integration Specialists and Cloud Engineers in understanding the foundational components of Oracle Integration Cloud (OIC). It covers key integration concepts, how integrations work, and web services fundamentals such as WSDL, SOAP, REST, and JSON. The focus is on building a strong understanding of OICs integration capabilities.
2026 Oracle Realistic 1Z0-1042-25 Flexible Learning Mode Free PDF QuizWe are committed to providing our customers with the most up-to-date and accurate Oracle Cloud Infrastructure 2025 Application Integration Professional (1Z0-1042-25) preparation material. That's why we offer free demos and up to 1 year of free Oracle Dumps updates if the 1Z0-1042-25 certification exam content changes after purchasing our product. With these offers, our customers can be assured that they have the latest and most reliable prepare for your Oracle Cloud Infrastructure 2025 Application Integration Professional (1Z0-1042-25) preparation material.
Oracle Cloud Infrastructure 2025 Application Integration Professional Sample Questions (Q14-Q19):NEW QUESTION # 14
Which statement about Oracle Integration Cloud (OIC) is NOT valid?
  • A. When you open the mapper for a request or response message in an integration, the data structures are automatically populated with the information pulled from the source and target connections.
  • B. Using the connectivity agent, you can create hybrid integrations and exchange messages between applications in private or on-premises networks and OIC.
  • C. An application-driven integration can contain one or more trigger (source) connections for requests sent to OIC and one or more invoke (target) connections for requests sent from OIC.
  • D. OIC lookups are based on a static definition, meaning you create and populate them during design time, and cannot be changed by runtime activities.
OIC fundamentals:
Option A:True-lookups are static, design-time artifacts.
Option B:True-connectivity agents enable hybrid integrations.
Option D:True-the mapper auto-populates from connection schemas.
Option C:False-application-driven (app-driven) integrations typically have one trigger connection; multiple triggers require separate integrations or event patterns, making this invalid.
C misrepresents OIC's app-driven pattern.
NEW QUESTION # 15
There are use cases in which you need to perform an advanced XSLT task that you cannot performin the Oracle Integration Cloud (OIC) data mapper. To perform the advanced mapping tasks, you decide to use an external XSLT mapper and then import the .xsl file back to your integration. What is NOT a valid consideration when handling this use case?
  • A. The exported archive must be imported into an Oracle Service Bus project in JDeveloper.
  • B. Once the advanced mapping is complete, you must import the entire integration that contains the updated .xsl files.
  • C. You must export the entire integration that contains one or more .xsl files.
  • D. The exported archive file can include a map file that is largely complete in content or a map file that is empty of content.
Advanced XSLT in OIC requires external tools. Let's analyze:
A:True-exported maps can be complete or empty templates.
B:False-not required; XSLT can be edited in any editor and reimported directly.
C:True-entire integration must be reimported with updated XSLT.
NEW QUESTION # 16
The Integrations flow element in Oracle Integration Cloud (OIC) processes provides you an option to easily integrate your process application with other applications and services.
Which three types can be added and managed from the Integrations flow element?
  • A. OIC invokable dynamic processes hosted within the same OIC environment
  • B. REST Connectors
  • C. OIC integrations hosted within the same OIC environment
  • D. OCI Functions deployed in the same OCI compartment hosting the OIC environment
  • E. Web Service Connectors
Answer: B,C,E
The three types that can be added and managed in OIC integrations are OIC integrations hosted within the environment, Web Service Connectors, and REST Connectors. OCI Functions are not directly managed from the integrations flow element.
NEW QUESTION # 17
You are creating integrations in Oracle Integration Cloud (OIC) using B2B trading partner agreements. Which identifier is implicitly used for all outbound agreements?
  • A. EDI Interchange Internal Sub ID
  • B. EDI Group ID Qualifier
  • C. Application Partner ID
  • D. EDI Interchange ID
In OIC B2B, outbound agreements use theEDI Interchange ID (B)as the implicit identifier. This ID, part of the EDI header, uniquely identifies the sender in transactions (e.g., X12 or EDIFACT standards).
Option A:Internal Sub ID is a secondary identifier, not implicit for all outbound flows.
Option C:Application Partner ID is specific to application-level config, not EDI.
Option D:Group ID Qualifier defines document grouping, not the primary outbound identifier.
The Interchange ID ensures consistency in B2B communication.
NEW QUESTION # 18
You can group one or more Oracle Integration Cloud (OIC) integrations into a single structure called a package.
Which statement is NOT true about OIC packages?
  • A. Packages cannot be locked to deny other users access to your integrations.
  • B. New packages can be created by clicking the Create button on the Packages page in the console.
  • C. Integrations do not need to be part of a package.
  • D. You can import packages directly from the Oracle Marketplace.
  • E. All packages must include at least one integration.
  • F. Packages enable you to easily import and export a group of integrations to and from OIC.
Packages in OIC cannot be locked to prevent other users from accessing the integrations. The other statements are true, including the ability to create, import, and manage integrations within packages.
NEW QUESTION # 19
One of the most important functions of our APP online vesion which is contained in our 1Z0-1042-25 preparation questions are that can support almost all electronic equipment, including the computer, mobile phone and so on. If you want to prepare for your exam by the computer, you can buy our 1Z0-1042-25 training quiz, because our products can work well by the computer. Of course, if you prefer to study by your mobile phone, our 1Z0-1042-25 study materials also can meet your demand.
1Z0-1042-25 Valid Test Camp: https://www.validexam.com/1Z0-1042-25-latest-dumps.html
2026 Latest ValidExam 1Z0-1042-25 PDF Dumps and 1Z0-1042-25 Exam Engine Free Share: https://drive.google.com/open?id=1I9RCxvnRmQXJkMzTMR8jmafdL29TIqew
