First-grade Plat-Dev-301 Latest Dumps Ppt, Ensure to pass the Plat-Dev-301 Exam
Posted at 2/20/2026 20:56:36
Our Plat-Dev-301 training guide always promise the best to service the clients. We are committing in this field for many years and have a good command of the requirements of various candidates. Carefully testing and producing to match the certified quality standards of Plat-Dev-301 Exam Materials, we have made specific statistic researches on the Plat-Dev-301 practice materials. And our pass rate of the Plat-Dev-301 study engine is high as 98% to 100%.
Would you like to pass Salesforce Plat-Dev-301 test and to get Plat-Dev-301 certificate? TrainingDump can guarantee your success. When you are preparing for Plat-Dev-301 exam, it is necessary to learn test related knowledge. What's more important, you must choose the most effective exam materials that suit you. TrainingDump Salesforce Plat-Dev-301 Questions and answers are the best study method for you. The high quality exam dumps can produce a wonderful effect. If you fear that you cannot pass Plat-Dev-301 test, please click TrainingDump.com to know more details.
Plat-Dev-301 Latest Braindumps Ppt & Plat-Dev-301 Exam Dumps FreeOur Plat-Dev-301 study materials are constantly improving themselves. We keep updating them to be the latest and accurate. And we apply the latest technologies to let them applied to the electronic devices. If you have any good ideas, our Plat-Dev-301 Exam Questions are very happy to accept them. Plat-Dev-301 learning braindumps are looking forward to having more partners to join this family. We will progress together and become better ourselves.
Salesforce Certified Platform Developer II - Multiple Choice Sample Questions (Q116-Q121):NEW QUESTION # 116
Which statement is true regarding savepoints?
- A. Static variables are not reverted during a rollback.
- B. You can roll back to any savepoint variable created in any order.
- C. Reference to savepoints can cross trigger invocations.
- D. Savepoints are not limited by DML statement governor limits.
When rolling back to a savepoint, any DML operations that occurred after that savepoint are undone, but static variables are not reverted. Therefore, when a rollback occurs, the state of all static variables at the time of the rollback remains the same as it was just before the rollback.
NEW QUESTION # 117
A developer is responsible for formulating the deployment process for a Salesforce project. The project follows a source-driven development approach, and the developer wants to ensure efficient deployment and version control of the metadata changes.
Which tool or mechanism should be utilized for managing the source-driven deployment process?
- A. Metadata API
- B. Force.com IDE
- C. Salesforce CLI with Salesforce DX
- D. Change Sets
Salesforce CLI with Salesforce DX is the best tool for managing a source-driven deployment process. It facilitates version control, scriptable deployment, and rollback, and is optimized for collaboration and continuous integration.
NEW QUESTION # 118
Universal Containers implements a private sharing model for the Convention Attendee co custom object. As part of a new quality assurance effort, the company created an Event_Reviewer_c user lookup field on the object.
Management wants the event reviewer to automatically gain ReadWrite access to every record they are assigned to.
What is the best approach to ensure the assigned reviewer obtains Read/Write access to the record?
- A. Create a criteria-based sharing rule on the Convention Attendee custom object to share the records with a group of Event Reviewers.
- B. Create criteria-based sharing rules on the Convention Attendee custom object to share the records with the Event Reviewers,
- C. Create an after insert trigger on the Convention Attendee custom object, and use Apex Sharing Reasons and Apex Managed Sharing.
- D. Create a before insert trigger on the Convention Attendee custom object, and use Apex Sharing Reasons and Apex Managed Sharing.
Use Apex Managed Sharing with an after insert trigger. It allows dynamic record sharing based on user-defined criteria like the Event_Reviewer_c field.
NEW QUESTION # 119
A developer wrote an Apex class to make several callouts to an external system.
If the URLs used in these callouts will change often, which feature should the developer use to minimize changes needed to the Apex class?
- A. Connected Apps
- B. Session Id
- C. Named Credentials
- D. Remote Site Settings
The correct feature to use is C, Named Credentials. Named Credentials are a secure way of storing the endpoint and authentication details for callouts to external services. When URLs change frequently, using Named Credentials allows you to manage the endpoint URL in one place without changing the Apex code.
Named Credentials
NEW QUESTION # 120
A company recently deployed a Visualforce page with a custom controller that has a data grid of information about Opportunities in the org. Users report that they receive a "Maximum view state size limit" error message under certain conditions.
According to Visualforce best practice, which three actions should the developer take to reduce the view state?
Choose 3 answers
- A. Use filters and pagination to reduce the amount of data.
- B. Refine any SOQL queries to return only data relevant to the page.
- C. Use the private keyword in the controller for variables,
- D. Use the final keyword in the controller for variables that will not change.
- E. Use the transient keyword in the Apex controller for variables that do not maintain state.
Answer: A,B,E
NEW QUESTION # 121
We always try to find ways to accelerate our customers' professional ability and offer the best quality of Plat-Dev-301 dumps pdf among dumps vendors. So we decided to create the Plat-Dev-301 real dumps based on the requirement of the certification center and cover the most knowledge points of Plat-Dev-301 Practice Test. Our study guide will be your first choice as your exam preparation materials.
Plat-Dev-301 Latest Braindumps Ppt: https://www.trainingdump.com/Salesforce/Plat-Dev-301-practice-exam-dumps.html
Our Plat-Dev-301 Latest Braindumps Ppt - Salesforce Certified Platform Developer II - Multiple Choice exam practice training will be updated nonsked according to the current tendency and situation of real texts, Among them, Salesforce Plat-Dev-301 certification test is the most important exam, It helps you to pass the Plat-Dev-301 test with excellent results, Now passing Plat-Dev-301 Salesforce Certified Platform Developer II - Multiple Choice is not Tough With APP Exams BrainDumps, Salesforce Plat-Dev-301 Latest Dumps Ppt Just remind you that we have engaged in the career for over ten years and we have became the leader in this field.
To help you get a whole overall before buying, Plat-Dev-301 Latest Dumps Ppt you can download the free demos as reference, No programming required, OurSalesforce Certified Platform Developer II - Multiple Choice exam practice training will be Plat-Dev-301 Latest Braindumps Ppt updated nonsked according to the current tendency and situation of real texts.
Salesforce Plat-Dev-301 Exam Study Material of TrainingDump in 3 FormatsAmong them, Salesforce Plat-Dev-301 Certification test is the most important exam, It helps you to pass the Plat-Dev-301 test with excellent results, Now passing Plat-Dev-301 Salesforce Certified Platform Developer II - Multiple Choice is not Tough With APP Exams BrainDumps.
Just remind you that we have engaged in Plat-Dev-301 the career for over ten years and we have became the leader in this field.
- Salesforce Plat-Dev-301 Latest Dumps Ppt - The Best Plat-Dev-301 Latest Braindumps Ppt and Professional Salesforce Certified Platform Developer II - Multiple Choice Exam Dumps Free 🍨 Search for ▛ Plat-Dev-301 ▟ and obtain a free download on { [url]www.testkingpass.com } 🥌Real Plat-Dev-301 Testing Environment[/url]
- Plat-Dev-301 Most Reliable Questions 🟤 Real Plat-Dev-301 Testing Environment 💏 Reliable Plat-Dev-301 Test Testking 💇 The page for free download of 【 Plat-Dev-301 】 on ▷ [url]www.pdfvce.com ◁ will open immediately 📱
lat-Dev-301 Reliable Test Online[/url] - Top Plat-Dev-301 Exam Dumps 🕤 Plat-Dev-301 Actual Tests 🕣 Plat-Dev-301 New Questions 🚮 Enter ➥ [url]www.examcollectionpass.com 🡄 and search for “ Plat-Dev-301 ” to download for free 🅱
lat-Dev-301 Latest Test Practice[/url] - Plat-Dev-301 Valid Test Topics 🥈 Plat-Dev-301 Reliable Exam Answers 🏜 Plat-Dev-301 Most Reliable Questions 🚑 Open website ➡ [url]www.pdfvce.com ️⬅️ and search for ⇛ Plat-Dev-301 ⇚ for free download 😜New Plat-Dev-301 Exam Book[/url]
- Valid Dumps Plat-Dev-301 Free 🖌 Plat-Dev-301 Valid Dumps Ppt ⚠ Reliable Plat-Dev-301 Test Testking 🖤 Search for 【 Plat-Dev-301 】 and download it for free on ☀ [url]www.exam4labs.com ️☀️ website 📂Valid Dumps Plat-Dev-301 Free[/url]
- Plat-Dev-301 Reliable Test Online 🧁 Valid Dumps Plat-Dev-301 Free ⬛ Plat-Dev-301 Reliable Exam Answers 🎫 Copy URL [ [url]www.pdfvce.com ] open and search for ➠ Plat-Dev-301 🠰 to download for free 🦁
lat-Dev-301 Valid Test Topics[/url] - Salesforce Plat-Dev-301 Latest Dumps Ppt - The Best Plat-Dev-301 Latest Braindumps Ppt and Professional Salesforce Certified Platform Developer II - Multiple Choice Exam Dumps Free 📨 The page for free download of ➤ Plat-Dev-301 ⮘ on ( [url]www.examcollectionpass.com ) will open immediately ⚖Real Plat-Dev-301 Torrent[/url]
- Important Features of Pdfvce Salesforce Plat-Dev-301 Exam Questions ✈ Search for ☀ Plat-Dev-301 ️☀️ and download it for free immediately on ➡ [url]www.pdfvce.com ️⬅️ 🏔Test Plat-Dev-301 Dumps Pdf[/url]
- Important Features of [url]www.prepawaypdf.com Salesforce Plat-Dev-301 Exam Questions 🚮 Easily obtain free download of ▛ Plat-Dev-301 ▟ by searching on ➤ www.prepawaypdf.com ⮘ 🕯
lat-Dev-301 Study Guide Pdf[/url] - Plat-Dev-301 Valid Dumps Ppt 🔊 Real Plat-Dev-301 Torrent 🍫 Free Plat-Dev-301 Study Material 💥 Search for ➤ Plat-Dev-301 ⮘ and obtain a free download on ☀ [url]www.pdfvce.com ️☀️ 🔅Free Plat-Dev-301 Study Material[/url]
- Plat-Dev-301 Valid Dumps Ppt 🥑 Plat-Dev-301 Reliable Exam Answers 🧘 Real Plat-Dev-301 Testing Environment 🐾 Open ➽ [url]www.vce4dumps.com 🢪 enter ▛ Plat-Dev-301 ▟ and obtain a free download 🤣Real Plat-Dev-301 Testing Environment[/url]
- apegoeperdas.com, www.anitawamble.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, dataclick.in, www.stes.tyc.edu.tw, Disposable vapes
