[General] Google - Professional-Cloud-Architect - Marvelous New Guide Google Certified Pro
111
General Google - Professional-Cloud-Architect - Marvelous New Guide Google Certified Pro
Posted at 2/20/2026 21:35:36      View120 | Replies0        Print      Only Author   [Copy Link] 1#
2026 Latest BraindumpStudy Professional-Cloud-Architect PDF Dumps and Professional-Cloud-Architect Exam Engine Free Share: https://drive.google.com/open?id=1GOvO5HPuEJaJssOPiLXQWSguJ6DwDDzV
As we all know, passing the exam just one time can save your money and time, our Professional-Cloud-Architect exam dumps will help you pass the exam just one time. Professional-Cloud-Architect exam materials are edited by professional experts, and they are quite familiar with the exam center, therefore quality can be guaranteed. In addition, Professional-Cloud-Architect exam materials cover most of knowledge points for the exam, and you can have a good command of the major knowledge points. We offer you free demo to have a try, and you can try before buying. Online and offline service are available, if you have any questions for Professional-Cloud-Architect Training Materials, you can consult us.
Google Professional-Cloud-Architect Certification is a highly respected and recognized certification in the cloud computing industry. Passing this certification exam validates the skills and knowledge of cloud architects who can design, develop, and manage solutions on the Google Cloud Platform. It is an excellent way for professionals to enhance their career prospects and demonstrate their commitment to learning and staying up-to-date with the latest cloud computing technologies.
Pass Guaranteed Updated Google - New Guide Professional-Cloud-Architect FilesThere are Google Certified Professional - Cloud Architect (GCP) (Professional-Cloud-Architect) exam questions provided in Google Certified Professional - Cloud Architect (GCP) (Professional-Cloud-Architect) PDF questions format which can be viewed on smartphones, laptops, and tablets. So, you can easily study and prepare for your Google Certified Professional - Cloud Architect (GCP) (Professional-Cloud-Architect) exam anywhere and anytime. You can also take a printout of these Google PDF Questions for off-screen study. To improve the Google Certified Professional - Cloud Architect (GCP) (Professional-Cloud-Architect) exam questions, BraindumpStudy always upgrades and updates its Professional-Cloud-Architect dumps PDF format and it also makes changes according to the syllabus of the Google Certified Professional - Cloud Architect (GCP) (Professional-Cloud-Architect) exam.
Google Certified Professional - Cloud Architect (GCP) Sample Questions (Q220-Q225):NEW QUESTION # 220
Your agricultural division is experimenting with fully autonomous vehicles. You want your architecture to promote strong security during vehicle operation.
Which two architectures should you consider? (Choose two.)
  • A. Enclose the vehicle's drive electronics in a Faraday cage to isolate chips.
  • B. Use a functional programming language to isolate code execution cycles.
  • C. Require IPv6 for connectivity to ensure a secure address space.
  • D. Use a trusted platform module (TPM) and verify firmware and binaries on boot.
  • E. Treat every micro service call between modules on the vehicle as untrusted.
  • F. Use multiple connectivity subsystems for redundancy.
Answer: D,E
NEW QUESTION # 221
Your company recently acquired a company that has infrastructure in Google Cloud. Each company has its own Google Cloud organization Each company is using a Shared Virtual Private Cloud (VPC) to provide network connectivity tor its applications Some of the subnets used by both companies overlap In order for both businesses to integrate, the applications need to have private network connectivity. These applications are not on overlapping subnets. You want to provide connectivity with minimal re-engineering. What should you do?
  • A. Set up VPC peering and peer each Shared VPC together
  • B. Set up a Cloud VPN gateway in each Shared VPC and peer Cloud VPNs
  • C. Configure SSH port forwarding on each application to provide connectivity between applications i the different Shared VPCs
  • D. Migrate the protects from the acquired company into your company's Google Cloud organization Re launch the instances in your companies Shared VPC
NEW QUESTION # 222
Your company has successfully migrated to the cloud and wants to analyze their data stream to optimize operations. They do not have any existing code for this analysis, so they are exploring all their options. These options include a mix of batch and stream processing, as they are running some hourly jobs and live- processing some data as it comes in.
Which technology should they use for this?
  • A. Google Container Engine with Bigtable
  • B. Google Cloud Dataflow
  • C. Google Cloud Dataproc
  • D. Google Compute Engine with Google BigQuery
Cloud Dataflow is a fully-managed service for transforming and enriching data in stream (real time) and batch (historical) modes with equal reliability and expressiveness -- no more complex workarounds or compromises needed.
Reference: https://cloud.google.com/dataflow/
NEW QUESTION # 223
A production database virtual machine on Google Compute Engine has an ext4-formatted persistent disk for data files. The database is about to run out of storage space.
How can you remediate the problem with the least amount of downtime?
  • A. In the Cloud Platform Console, increase the size of the persistent disk and use the resize2fs command in Linux.
  • B. Shut down the virtual machine, use the Cloud Platform Console to increase the persistent disk size, then restart the virtual machine
  • C. In the Cloud Platform Console, increase the size of the persistent disk and verify the new space is ready to use with the fdisk command in Linux
  • D. In the Cloud Platform Console, create a new persistent disk attached to the virtual machine, format and mount it, and configure the database service to move the files to the new disk
  • E. In the Cloud Platform Console, create a snapshot of the persistent disk restore the snapshot to a new larger disk, unmount the old disk, mount the new disk and restart the database service
On Linux instances, connect to your instance and manually resize your partitions and file systems to use the additional disk space that you added.
Extend the file system on the disk or the partition to use the added space. If you grew a partition on your disk, specify the partition. If your disk does not have a partition table, specify only the disk ID.
sudo resize2fs /dev/[DISK_ID][PARTITION_NUMBER]
where [DISK_ID] is the device name and [PARTITION_NUMBER] is the partition number for the device where you are resizing the file system.
Reference: https://cloud.google.com/compute/docs/disks/add-persistent-disk
NEW QUESTION # 224
Case Study: 6 - TerramEarth
Company Overview
TerramEarth manufactures heavy equipment for the mining and agricultural industries. About
80% of their business is from mining and 20% from agriculture. They currently have over 500 dealers and service centers in 100 countries. Their mission is to build products that make their customers more productive.
Solution Concept
There are 20 million TerramEarth vehicles in operation that collect 120 fields of data per second.
Data is stored locally on the vehicle and can be accessed for analysis when a vehicle is serviced.
The data is downloaded via a maintenance port. This same port can be used to adjust operational parameters, allowing the vehicles to be upgraded in the field with new computing modules.
Approximately 200,000 vehicles are connected to a cellular network, allowing TerramEarth to collect data directly. At a rate of 120 fields of data per second with 22 hours of operation per day, TerramEarth collects a total of about 9 TB/day from these connected vehicles.
Existing Technical Environment
TerramEarth's existing architecture is composed of Linux and Windows-based systems that reside in a single U.S. west coast based data center. These systems gzip CSV files from the field and upload via FTP, and place the data in their data warehouse. Because this process takes time, aggregated reports are based on data that is 3 weeks old.
With this data, TerramEarth has been able to preemptively stock replacement parts and reduce unplanned downtime of their vehicles by 60%. However, because the data is stale, some customers are without their vehicles for up to 4 weeks while they wait for replacement parts.
Business Requirements
Decrease unplanned vehicle downtime to less than 1 week.
* Support the dealer network with more data on how their customers use their equipment to better
* position new products and services
Have the ability to partner with different companies - especially with seed and fertilizer suppliers
* in the fast-growing agricultural business - to create compelling joint offerings for their customers.
Technical Requirements
Expand beyond a single datacenter to decrease latency to the American Midwest and east
* coast.
Create a backup strategy.
* Increase security of data transfer from equipment to the datacenter.
* Improve data in the data warehouse.
* Use customer and equipment data to anticipate customer needs.
* Application 1: Data ingest
A custom Python application reads uploaded datafiles from a single server, writes to the data warehouse.
Compute:
Windows Server 2008 R2
* - 16 CPUs
- 128 GB of RAM
- 10 TB local HDD storage
Application 2: Reporting
An off the shelf application that business analysts use to run a daily report to see what equipment needs repair. Only 2 analysts of a team of 10 (5 west coast, 5 east coast) can connect to the reporting application at a time.
Compute:
Off the shelf application. License tied to number of physical CPUs
* - Windows Server 2008 R2
- 16 CPUs
- 32 GB of RAM
- 500 GB HDD
Data warehouse:
A single PostgreSQL server
* - RedHat Linux
- 64 CPUs
- 128 GB of RAM
- 4x 6TB HDD in RAID 0
Executive Statement
Our competitive advantage has always been in the manufacturing process, with our ability to build better vehicles for lower cost than our competitors. However, new products with different approaches are constantly being developed, and I'm concerned that we lack the skills to undergo the next wave of transformations in our industry. My goals are to build our skills while addressing immediate market needs through incremental innovations.
For this question, refer to the TerramEarth case study. To be compliant with European GDPR regulation, TerramEarth is required to delete data generated from its European customers after a period of 36 months when it contains personal data. In the new architecture, this data will be stored in both Cloud Storage and BigQuery. What should you do?
  • A. Create a BigQuery table for the European data, and set the table retention period to 36 months.
    For Cloud Storage, use gsutil to create a SetStorageClass to NONE action when with an Age condition of 36 months.
  • B. Create a BigQuery time-partitioned table for the European data, and set the partition expiration period to 36 months. For Cloud Storage, use gsutil to enable lifecycle management using a DELETE action with an Age condition of 36 months.
  • C. Create a BigQuery time-partitioned table for the European data, and set the partition period to 36 months. For Cloud Storage, use gsutil to create a SetStorageClass to NONE action with an Age condition of 36 months.
  • D. Create a BigQuery table for the European data, and set the table retention period to 36 months.
NEW QUESTION # 225
We provide the update freely of Professional-Cloud-Architect exam questions within one year and 50% discount benefits if buyers want to extend service warranty after one year. The old client enjoys some certain discount when buying other exam materials. We update the Professional-Cloud-Architect guide torrent frequently and provide you the latest study materials which reflect the latest trend in the theory and the practice. So you can master the Google Certified Professional - Cloud Architect (GCP) test guide well and pass the exam successfully. While you enjoy the benefits we bring you can pass the exam. Dont be hesitated and buy our Professional-Cloud-Architect Guide Torrent immediately!
Exam Professional-Cloud-Architect Study Guide: https://www.braindumpstudy.com/Professional-Cloud-Architect_braindumps.html
What's more, part of that BraindumpStudy Professional-Cloud-Architect dumps now are free: https://drive.google.com/open?id=1GOvO5HPuEJaJssOPiLXQWSguJ6DwDDzV
