Reliable AWS-Certified-Developer-Associate Test Duration - AWS-Certified-Develop
77
Posted at 2/20/2026 22:54:32      View90 | Replies0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest ExamsReviews AWS-Certified-Developer-Associate PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1tDUO54_n9OQY2n5RMcyO7hdkwYvdulho
The quality of ExamsReviews product is very good and also have the fastest update rate. If you purchase the training materials we provide, you can pass Amazon Certification AWS-Certified-Developer-Associate Exam successfully.
No matter in the day or on the night, you can consult us the relevant information about our AWS-Certified-Developer-Associate preparation exam through the way of chatting online or sending emails. Im sure our 24-hour online service will not disappoint you as we offer our service 24/7 on our AWS-Certified-Developer-Associate Study Materials. And we will give you the most considerate suggestions on our AWS-Certified-Developer-Associate learning guide with all our sincere and warm heart.
Pass Guaranteed Quiz 2026 Amazon Unparalleled AWS-Certified-Developer-Associate: Reliable AWS Certified Developer Associate Exam (DVA-C02) Test DurationOur company hired the top experts in each qualification examination field to write the AWS-Certified-Developer-Associate prepare materials, so as to ensure that our products have a very high quality, so that users can rest assured that the use of our research materials. On the other hand, under the guidance of high quality AWS-Certified-Developer-Associate research materials, the rate of adoption of the AWS-Certified-Developer-Associate exam guide is up to 98% to 100%. Of course, it is necessary to qualify for a qualifying AWS-Certified-Developer-Associate exam, but more importantly, you will have more opportunities to get promoted in the workplace.
Amazon AWS Certified Developer Associate Exam (DVA-C02) Sample Questions (Q316-Q321):NEW QUESTION # 316
A Developer is writing an application that runs on Amazon EC2 instances in an Auto Scaling group. The application data is stored in an Amazon DynamoDB table and records are constantly updated by all instances. An instance sometimes retrieves old data. The Developer wants to correct this by making sure the reads are strongly consistent.
How can the Developer accomplish this?
  • A. Set ConsistentRead to true when calling Getltem.
  • B. Set Consistency to strong when calling UpdateTable.
  • C. Create a new DynamoDB Accelerator (DAX) table.
  • D. Use the GetShardIterator command.
https://docs.aws.amazon.com/amaz ... eadConsistency.html
NEW QUESTION # 317
You have multiple Amazon EC2 instances running in a cluster across multiple Availability Zones within the same region. What combination of the following should be used to ensure the highest network performance (packets per second), lowest latency, and lowest jitter? Choose 3 answers
  • A. Amazon VPC
  • B. Amazon HVM AMI
  • C. Amazon EC2 placement groups
  • D. Enhanced networking
  • E. Amazon PV AMI
  • F. Amazon Linux
Answer: A,B,D
NEW QUESTION # 318
In the basic monitoring package for EC2, Amazon CloudWatch provides the following metrics:
  • A. Operating system visible metrics such as memory utilization
  • B. Database visible metrics such as number of connections
  • C. Hypervisor visible metrics such as CPU utilization
  • D. Web server visible metrics such as number failed transaction requests
NEW QUESTION # 319
An advertising company has a dynamic website with heavy traffic. The company wants to migrate the website infrastructure to AWS to handle everything except website development.
Which solution BEST meets these requirements?
  • A. Use Amazon S3 to host the website. Use Amazon CloudFornt to deliver the content at scale.
  • B. Deploy the website code in an AWS Elastic Beanstalk environment. Use Auto Scaling to scale the numbers of instance
  • C. Use AWS VM Import to migrate a web server image to AWS Launch the image on a compute-optimized Amazon EC2 instanceLaunch.
  • D. Launch multiple Amazon Lighsall instance behind a load balancer. Set up the website on those instances.
NEW QUESTION # 320
A company is launching a poling application. The application will store the results of each pool an Amazon DynamoDB table. Management wants to remove pool data after a few data and store an archive of those records in Amazon S3.
Which approach would allow the application to archive each poll's data while keeping complexity to a MINIMUM?
  • A. Enable cross-Region replication on the S3 bucket to achieve the poll data.
  • B. Enable DynamoDB Streams on the table. Configure the steam as trigger for AWS Lambda. Save records to Amazon S3 when records on the stream are modified.
  • C. Enable Time to Live (TTL) on the DynamoDB table. Enable DynamoDB Streams on the table and store the records removed from the stream in Amazon S3.
  • D. Schedule an AWS Lambda function to periodically scan the DynamoDB table. Use the BatchWritten operation to delete the results of a scan Enable DynamoDB Stream on the table and store the records removed from the stream in Amazon S3.
NEW QUESTION # 321
Nowadays the knowledge capabilities and mental labor are more valuable than the manual labor because knowledge can create more wealth than the mental labor. If you boost professional knowledge capabilities in some area you are bound to create a lot of values and can get a good job with high income. Passing the test of AWS-Certified-Developer-Associate Certification can help you achieve that, and our AWS-Certified-Developer-Associate study materials are the best study materials for you to prepare for the test.
AWS-Certified-Developer-Associate Study Guides: https://www.examsreviews.com/AWS-Certified-Developer-Associate-pass4sure-exam-review.html
Amazon Reliable AWS-Certified-Developer-Associate Test Duration We can promise that you would like to welcome this opportunity to kill two birds with one stone, When you decide to choose our product, you have already found the shortcut to success in AWS-Certified-Developer-Associate exam certification, Amazon Reliable AWS-Certified-Developer-Associate Test Duration To obtain the certificate will help you to find a better job, Our AWS-Certified-Developer-Associate exam guide will help comprehensively improve your ability and storage of knowledge.
As you do this, you can preview the effect of the changes on the AWS-Certified-Developer-Associate image, Hobbies were last, so although she probably has some enjoyable activities, if she had to live without them she could.
Trustable Reliable AWS-Certified-Developer-Associate Test Duration, AWS-Certified-Developer-Associate Study GuidesWe can promise that you would like to welcome this opportunity to kill two birds with one stone, When you decide to choose our product, you have already found the shortcut to success in AWS-Certified-Developer-Associate Exam Certification.
To obtain the certificate will help you to find a better job, Our AWS-Certified-Developer-Associate exam guide will help comprehensively improve your ability and storage of knowledge, Our AWS-Certified-Developer-Associate exam braindumps will provide perfect service for everyone.
What's more, part of that ExamsReviews AWS-Certified-Developer-Associate dumps now are free: https://drive.google.com/open?id=1tDUO54_n9OQY2n5RMcyO7hdkwYvdulho
