Free PDF Quiz HP - HPE6-A78 - Aruba Certified Network Security Associate Exam Fa
Posted at 2/20/2026 23:29:08
2026 Latest Lead1Pass HPE6-A78 PDF Dumps and HPE6-A78 Exam Engine Free Share: https://drive.google.com/open?id=1dYy2mMfH_pbz9Jd-Y1Tm0Fzyd_3Q07wT
These HPE6-A78 PDF Questions are being presented in practice test software and PDF dumps file formats. The HP HPE6-A78 desktop practice test software is easy to use and install on your desktop computers. Whereas the other HPE6-A78 web-based practice test software is concerned, this is a simple browser-based application that works with all operating systems. Both practice tests are customizable, simulate actual exam scenarios, and help you overcome mistakes.
HPE6-A78 certification exam covers a wide range of topics, including network security fundamentals, Aruba secure wireless and wired network design, and advanced security technologies such as VPN and firewall. HPE6-A78 exam also tests the candidate's knowledge of Aruba ClearPass, which is a network access control solution, and Aruba AirWave, which is a network management platform.
HP HPE6-A78 exam is a certification exam designed for networking professionals who are interested in validating their knowledge and skills in network security. HPE6-A78 Exam is specifically tailored for those who are looking to become Aruba Certified Network Security Associates. HPE6-A78 exam is designed to test the candidate's understanding of Aruba's security solutions and their ability to implement them effectively.
Quiz 2026 HPE6-A78: The Best Aruba Certified Network Security Associate Exam Braindumps TorrentOur technology and our staff are the most professional. What are the HPE6-A78 practice materials worthy of your choice, I hope you spend a little time to find out. First of all, after you make a decision, you can start using our HPE6-A78 Exam Questions soon. We will send you an email within five to ten minutes after your payment is successful. You can choose any version of HPE6-A78 study guide, as long as you find it appropriate.
HP HPE6-A78, also known as the Aruba Certified Network Security Associate (ACNSA) exam, is a certification test designed for IT professionals who want to demonstrate their knowledge and skills in network security. HPE6-A78 exam covers a range of topics related to Aruba's network security solutions, such as firewall policies, virtual private networks (VPNs), and access control. Passing the HPE6-A78 Exam is a great way to validate your expertise in network security and enhance your career prospects in the field.
HP Aruba Certified Network Security Associate Exam Sample Questions (Q10-Q15):NEW QUESTION # 10
You are managing an Aruba Mobility Controller (MC). What is a reason for adding a "Log Settings" definition in the ArubaOS Diagnostics > System > Log Settings page?
- A. Configuring a filter that you can apply to a defined Syslog server in order to filter events by subcategory
- B. Configuring the log facility and log format that the MC will use for forwarding logs to all Syslog servers
- C. Configuring the Syslog server settings for the server to which the MC forwards logs for a particular category and level
- D. Configuring the MC to generate logs for a particular event category and level, but only for a specific user or AP.
The primary reason for adding a "Log Settings" definition in the ArubaOS Diagnostics > System > Log Settings page is to configure the Syslog server settings for the server to which the Mobility Controller (MC) forwards logs for a particular category and level. This setting enables the MC to send detailed logs to a Syslog server for centralized logging and monitoring, which is essential for troubleshooting, security analysis, and compliance with various policies.
ArubaOS documentation on log management and Syslog configuration.
NEW QUESTION # 11
What is a guideline for managing local certificates on an ArubaOS-Switch?
- A. Generate the certificate signing request (CSR) with a program offline, then, install both the certificate and the private key on the switch in a single file.
- B. Install an Online Certificate Status Protocol (OCSP) certificate to simplify the process of enrolling and re-enrolling for certificate
- C. Before installing the local certificate, create a trust anchor (TA) profile with the root CA certificate for the certificate that you will install
- D. Create a self-signed certificate online on the switch because ArubaOS-Switches do not support CA-signed certificates.
When managing local certificates on an ArubaOS-Switch, a recommended guideline is to create a trust anchor (TA) profile with the root CA certificate before installing the local certificate. This step ensures that the switch can verify the authenticity of the certificate chain during SSL/TLS communications. The trust anchor profile establishes a basis of trust by containing the root CA certificate, which helps validate the authenticity of any subordinate certificates, including the local certificate installed on the switch. This process is essential for enhancing security on the network, as it ensures that encrypted communications involving the switch are based on a verified certificate hierarchy.
ArubaOS-Switch security configuration guides that detail the process of certificate management, including the creation of trust anchor profiles.
Security best practices and SSL/TLS implementation guidelines that emphasize the importance of establishing trusted certificate chains for secure communications.
NEW QUESTION # 12
What does the NIST model for digital forensics define?
- A. how to define access control policies that will properly protect a company's most sensitive data and digital resources
- B. which types of architecture and security policies are best equipped to help companies establish a Zero Trust Network (ZTN)
- C. how to properly collect, examine, and analyze logs and other data, in order to use it as evidence in a security investigation
- D. which data encryption and authentication algorithms are suitable for enterprise networks in a world that is moving toward quantum computing
The National Institute of Standards and Technology (NIST) provides guidelines on digital forensics, which include methodologies for properly collecting, examining, and analyzing digital evidence. This framework helps ensure that digital evidence is handled in a manner that preserves its integrity and maintains its admissibility in legal proceedings:
Digital Forensics Process: This process involves steps to ensure that data collected from digital sources can be used reliably in investigations and court cases, addressing chain-of-custody issues, proper evidence handling, and detailed documentation of forensic procedures.
NEW QUESTION # 13
Which scenario requires the Aruba Mobility Controller to use a Server Certificate?
- A. Use RadSec for enforcing 802.1X authentication to ClearPass.
- B. Use RADIUS for enforcing 802.1X authentication to ClearPass.
- C. Obtain downloadable user roles (DURs) from ClearPass.
- D. Synchronize its clock with an NTP server that requires authentication.
A Server Certificate is required by Aruba Mobility Controller when using RadSec to secure RADIUS communication. RadSec provides a secure transport for RADIUS traffic through SSL/TLS which requires the use of a Server Certificate to establish the secure tunnel. In the other scenarios listed, a Server Certificate is not explicitly required for the operations mentioned.
NEW QUESTION # 14
A company has HPE Aruba Networking Mobility Controllers (MCs), HPE Aruba Networking campus APs, and AOS-CX switches. The company plans to use HPE Aruba Networking ClearPass Policy Manager (CPPM) to classify endpoints by type. The company is contemplating the use of ClearPass's TCP fingerprinting capabilities.
What is a consideration for using those capabilities?
- A. TCP fingerprinting of wireless endpoints requires a third-party Mobility Device Management (MDM) solution.
- B. You will need to mirror traffic to one of CPPM's span ports from a device such as a core routing switch.
- C. AOS-CX switches do not offer the support necessary for CPPM to use TCP fingerprinting on wired endpoints.
- D. ClearPass admins will need to provide the credentials of an API admin account to configure on HPE Aruba Networking devices.
HPE Aruba Networking ClearPass Policy Manager (CPPM) uses TCP fingerprinting as a passive profiling method to classify endpoints by analyzing TCP packet headers (e.g., TTL, window size) to identify the operating system (e.g., Windows, Linux). The company in this scenario has Mobility Controllers (MCs), campus APs, and AOS-CX switches, and wants to use CPPM's TCP fingerprinting capabilities for endpoint classification.
TCP Fingerprinting: This method requires CPPM to receive TCP traffic from endpoints. Since CPPM is not typically inline with network traffic, the traffic must be mirrored to CPPM for analysis. This is often done using a SPAN (Switched Port Analyzer) port or mirror port on a switch or controller.
Option A, "You will need to mirror traffic to one of CPPM's span ports from a device such as a core routing switch," is correct. For CPPM to perform TCP fingerprinting, it needs to see the TCP traffic from endpoints. This is typically achieved by mirroring traffic from a core routing switch (or another device like an MC) to a SPAN port on the CPPM server. For example, on an AOS-CX switch, you can configure a mirror session with the command mirror session 1 destination interface <CPPM-port> source vlan <vlan-id> to send traffic to CPPM. This is a key consideration for enabling TCP fingerprinting.
Option B, "ClearPass admins will need to provide the credentials of an API admin account to configure on HPE Aruba Networking devices," is incorrect. TCP fingerprinting does not require API credentials. It is a passive profiling method that analyzes mirrored traffic, and no API interaction is needed between CPPM and Aruba devices for this purpose.
Option C, "AOS-CX switches do not offer the support necessary for CPPM to use TCP fingerprinting on wired endpoints," is incorrect. AOS-CX switches support mirroring traffic to CPPM (e.g., using a mirror session), which enables CPPM to perform TCP fingerprinting on wired endpoints. The switch does not need to perform the fingerprinting itself; it only needs to send the traffic to CPPM.
Option D, "TCP fingerprinting of wireless endpoints requires a third-party Mobility Device Management (MDM) solution," is incorrect. TCP fingerprinting is a built-in capability of CPPM and does not require an MDM solution. For wireless endpoints, the MC can mirror client traffic to CPPM (e.g., using a datapath mirror), allowing CPPM to perform TCP fingerprinting.
The HPE Aruba Networking ClearPass Policy Manager 6.11 User Guide states:
"TCP fingerprinting requires ClearPass to receive TCP traffic from endpoints for analysis. A key consideration is that you must mirror traffic to one of ClearPass's SPAN ports from a device such as a core routing switch or Mobility Controller. For example, on an AOS-CX switch, configure a mirror session with mirror session 1 destination interface <CPPM-port> source vlan <vlan-id> to send traffic to ClearPass for TCP fingerprinting." (Page 248, TCP Fingerprinting Section) Additionally, the HPE Aruba Networking AOS-8 8.11 User Guide notes:
"For ClearPass to perform TCP fingerprinting on wireless endpoints, the Mobility Controller can mirror client traffic to ClearPass using a datapath mirror. For wired endpoints, an AOS-CX switch can mirror traffic to ClearPass's SPAN port, enabling TCP fingerprinting without requiring additional support on the switch itself." (Page 351, Device Profiling with CPPM Section)
HPE Aruba Networking ClearPass Policy Manager 6.11 User Guide, TCP Fingerprinting Section, Page 248.
HPE Aruba Networking AOS-8 8.11 User Guide, Device Profiling with CPPM Section, Page 351.
NEW QUESTION # 15
Exam HPE6-A78 Details: https://www.lead1pass.com/HP/HPE6-A78-practice-exam-dumps.html
- HPE6-A78 Reliable Test Review 🚕 HPE6-A78 Reliable Test Online 🛶 Technical HPE6-A78 Training 🤥 Search for “ HPE6-A78 ” and download exam materials for free through ➤ [url]www.prep4sures.top ⮘ 🗣HPE6-A78 Exam Cost[/url]
- HPE6-A78 Exam Cost 🐹 HPE6-A78 Test Dates ☝ Discount HPE6-A78 Code 📱 Easily obtain ▛ HPE6-A78 ▟ for free download through [ [url]www.pdfvce.com ] 🥔HPE6-A78 Accurate Answers[/url]
- HPE6-A78 Exam Lab Questions 🤲 HPE6-A78 Test Dates 📁 HPE6-A78 Exam Lab Questions 😏 Enter ▛ [url]www.dumpsmaterials.com ▟ and search for ➽ HPE6-A78 🢪 to download for free 🤫Valid HPE6-A78 Test Preparation[/url]
- Pass Guaranteed Quiz 2026 High Hit-Rate HP HPE6-A78: Aruba Certified Network Security Associate Exam Braindumps Torrent 🟠 Immediately open ⇛ [url]www.pdfvce.com ⇚ and search for ➽ HPE6-A78 🢪 to obtain a free download 🕠Valid HPE6-A78 Test Prep[/url]
- HPE6-A78 Study Torrent - HPE6-A78 Free Questions - HPE6-A78 Valid Pdf 🥛 Easily obtain ➤ HPE6-A78 ⮘ for free download through ✔ [url]www.examcollectionpass.com ️✔️ 🌻HPE6-A78 Exam Cost[/url]
- Valid HPE6-A78 Exam Pattern 🈺 Reliable HPE6-A78 Braindumps Sheet ⛅ HPE6-A78 Exam Cost 🔼 Search for ⏩ HPE6-A78 ⏪ and easily obtain a free download on ( [url]www.pdfvce.com ) 🦚Valid HPE6-A78 Test Preparation[/url]
- HPE6-A78 Test Dates 🆚 HPE6-A78 Reliable Test Review 🔫 HPE6-A78 Reliable Exam Camp 🕢 Easily obtain free download of ➠ HPE6-A78 🠰 by searching on 「 [url]www.verifieddumps.com 」 🚌HPE6-A78 Reliable Test Review[/url]
- Examcollection HPE6-A78 Vce 🃏 HPE6-A78 Exam Lab Questions 🌼 Examcollection HPE6-A78 Vce 💕 Download ▛ HPE6-A78 ▟ for free by simply entering ▛ [url]www.pdfvce.com ▟ website 😭Examcollection HPE6-A78 Vce[/url]
- HPE6-A78 Reliable Test Online 🐤 Valid HPE6-A78 Exam Pattern 🍜 Valid HPE6-A78 Test Preparation 😑 Immediately open 【 [url]www.prepawayexam.com 】 and search for ✔ HPE6-A78 ️✔️ to obtain a free download ⚫Reliable HPE6-A78 Braindumps Sheet[/url]
- HPE6-A78 Exam Resources - HPE6-A78 Actual Questions - HPE6-A78 Exam Guide 🍿 Copy URL ➤ [url]www.pdfvce.com ⮘ open and search for ➡ HPE6-A78 ️⬅️ to download for free 👄Valid HPE6-A78 Test Prep[/url]
- HPE6-A78 Exam Cost 🧽 Latest HPE6-A78 Guide Files ⬜ Valid HPE6-A78 Test Preparation 🧖 Easily obtain ▛ HPE6-A78 ▟ for free download through ⏩ [url]www.troytecdumps.com ⏪ 👟HPE6-A78 Reliable Test Review[/url]
- eastwest-lms.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, Disposable vapes
P.S. Free & New HPE6-A78 dumps are available on Google Drive shared by Lead1Pass: https://drive.google.com/open?id=1dYy2mMfH_pbz9Jd-Y1Tm0Fzyd_3Q07wT
