Hardware
Pass Guaranteed 2026 Fortinet Reliable Practice NSE7_OTS-7.2 Test Engine
Posted at 2/20/2026 23:54:15
View129
Replies0
P.S. Free & New NSE7_OTS-7.2 dumps are available on Google Drive shared by DumpExam: https://drive.google.com/open?id=1mouhfskb9xQzDQ7_zD1JojlCM2xs7HtZ
It can be said that all the content of the NSE7_OTS-7.2 study materials are from the experts in the field of masterpieces, and these are understandable and easy to remember, so users do not have to spend a lot of time to remember and learn. It takes only a little practice on a daily basis to get the desired results. Especially in the face of some difficult problems, the user does not need to worry too much, just learn the NSE7_OTS-7.2 Study Materials provide questions and answers, you can simply pass the exam.
Fortinet NSE7_OTS-7.2 Certification is highly valued in the cybersecurity industry, as it demonstrates a thorough understanding of OT security and the ability to implement effective security measures to protect OT systems. Fortinet NSE 7 - OT Security 7.2 certification is particularly beneficial for professionals who work in industries such as manufacturing, energy, and transportation, where OT systems are critical to the operation of the organization. By earning the Fortinet NSE 7 - OT Security 7.2 certification, individuals can enhance their career prospects and demonstrate their commitment to excellence in OT security.
NSE7_OTS-7.2 Valid Braindumps Free - Test NSE7_OTS-7.2 EngineFortinet NSE7_OTS-7.2 training materials have won great success in the market. Tens of thousands of the candidates are learning on our NSE7_OTS-7.2 practice engine. First of all, our Fortinet NSE7_OTS-7.2 study dumps cover all related tests about computers. It will be easy for you to find your prepared learning material. If you are suspicious of our NSE7_OTS-7.2 Exam Questions, you can download the free demo from our official websites.
Fortinet NSE7_OTS-7.2 (Fortinet NSE 7 - OT Security 7.2) Certification Exam is a professional certification program designed for individuals who are seeking to validate their skills and expertise in the field of operational technology (OT) security. Fortinet NSE 7 - OT Security 7.2 certification is intended for network security professionals who want to enhance their knowledge and skills in securing OT environments and is an excellent opportunity for individuals to demonstrate their expertise to potential employers.
Fortinet NSE 7 - OT Security 7.2 Sample Questions (Q58-Q63):NEW QUESTION # 58
Refer to the exhibit
In the topology shown in the exhibit, both PLCs can communicate directly with each other, without going through the firewall.
Which statement about the topology is true?
- A. An administrator can create firewall policies in the switch to secure between PLCs.
- B. PLCs use IEEE802.1Q protocol to communicate each other.
- C. There is no micro-segmentation in this topology.
- D. This integration solution expands VLAN capabilities from Layer 2 to Layer 3.
NEW QUESTION # 59
Which statement is true about application control inspection?
- A. Security actions cannot be applied on the lowest level of the hierarchy.
- B. You can control security actions only on the parent-level application signature
- C. The industrial application control inspection process is unique among application categories.
- D. The parent signature takes precedence over the child application signature.
NEW QUESTION # 60
What are two benefits of a Nozomi integration with FortiNAC? (Choose two.)
- A. Direct VLAN assignment
- B. Adapter consolidation for multi-adapter hosts
- C. Importation and classification of hosts
- D. Enhanced point of connection details
The two benefits of a Nozomi integration with FortiNAC are enhanced point of connection details and importation and classification of hosts. Enhanced point of connection details allows for the identification and separation of traffic from multiple points of connection, such as Wi-Fi, wired, cellular, and VPN. Importation and classification of hosts allows for the automated importing and classification of host and device information into FortiNAC. This allows for better visibility and control of the network.
NEW QUESTION # 61
An OT network security audit concluded that the application sensor requires changes to ensure the correct security action is committed against the overrides filters.
Which change must the OT network administrator make?
- A. Set all application categories to apply default actions.
- B. Set the priority of the C.BO.NA.1 signature override to 1.
- C. Change the security action of the industrial category to monitor.
- D. Remove IEC.60870.5.104 Information.Transfer from the first filter override.
According to the Fortinet NSE 7 - OT Security 6.4 exam guide1, the application sensor settings allow you to configure the security action for each application category andnetwork protocol override. The security action determines how the FortiGate unit handles traffic that matches the application category or network protocol override. The security action can be one of the following:
Allow: The FortiGate unit allows the traffic without any further inspection.
Monitor: The FortiGate unit allows the traffic and logs it for monitoring purposes.
Block: The FortiGate unit blocks the traffic and logs it as an attack.
The priority of the network protocol override determines the order in which the FortiGate unit applies the security action to the traffic. The lower the priority number, the higher the priority. For example, a priority of 1 is higher than a priority of 10.
In the exhibit, the application sensor has the following settings:
The industrial category has a security action of allow, which means that the FortiGate unit will not inspect or log any traffic that belongs to this category.
The IEC.60870.5.104 Information.Transfer network protocol override has a security action of block, which means that the FortiGate unit will block and log any traffic that matches this protocol.
The IEC.60870.5.104 Control.Functions network protocol override has a security action of monitor, which means that the FortiGate unit will allow and log any traffic that matches this protocol.
The IEC.60870.5.104 Start/Stop network protocol override has a security action of allow, which means that the FortiGate unit will not inspect or log any traffic that matches this protocol.
The IEC.60870.5.104 Transfer.C.BO.NA.1 network protocol override has a security action of block, which means that the FortiGate unit will block and log any traffic that matches this protocol.
The problem with these settings is that the IEC.60870.5.104 Transfer.C.BO.NA.1 network protocol override has a lower priority than the IEC.60870.5.104 Information.Transfer network protocol override. This means that if the traffic matches both protocols, the FortiGate unit will apply the security action of the higher priority override, which is block. However, the IEC.60870.5.104 Transfer.C.BO.NA.1 protocol is used to transfer binary outputs, which are essential for controlling OT devices. Therefore, blocking this protocol could have negative consequences for the OT network.
To fix this issue, the OT network administrator must set the priority of the IEC.60870.5.104 Transfer.C.BO.NA.1 network protocol override to 1, which is higher than the priority of the IEC.60870.5.104 Information.Transfer network protocol override. This way, the FortiGate unit will apply the security action of the lower priority override, which is allow, to the traffic that matches both protocols. This will ensure that the FortiGate unit does not block the traffic that is used to transfer binary outputs, while still blocking the traffic that is used to transfer information.
1: NSE 7 Network Security Architect - Fortinet
NEW QUESTION # 62
Which three Fortinet products can you use for device identification in an OT industrial control system (ICS)? (Choose three.)
- A. FortiAnalyzer
- B. FortiGate
- C. FortiManager
- D. FortiSIEM
- E. FortiNAC
Answer: B,D,E
NEW QUESTION # 63
NSE7_OTS-7.2 Valid Braindumps Free: https://www.dumpexam.com/NSE7_OTS-7.2-valid-torrent.html
- NSE7_OTS-7.2 Torrent 👄 Exam NSE7_OTS-7.2 Tests 🎩 New NSE7_OTS-7.2 Exam Sample 🕘 Simply search for [ NSE7_OTS-7.2 ] for free download on [ [url]www.examcollectionpass.com ] 🌳Exam NSE7_OTS-7.2 Tests[/url]
- NSE7_OTS-7.2 Reliable Practice Materials 🔄 New NSE7_OTS-7.2 Test Blueprint 🐥 NSE7_OTS-7.2 PDF Question 🔅 Download NSE7_OTS-7.2 for free by simply entering ⏩ [url]www.pdfvce.com ⏪ website 🙈NSE7_OTS-7.2 Reliable Practice Questions[/url]
- Quiz 2026 Fortinet NSE7_OTS-7.2: Perfect Practice Fortinet NSE 7 - OT Security 7.2 Test Engine ⭐ Simply search for ➤ NSE7_OTS-7.2 ⮘ for free download on ⇛ [url]www.practicevce.com ⇚ 📧NSE7_OTS-7.2 Reliable Practice Questions[/url]
- Reliable NSE7_OTS-7.2 Exam Review 🛩 NSE7_OTS-7.2 Dump Collection 🛹 NSE7_OTS-7.2 Actual Exam Dumps 🚎 Enter [url]www.pdfvce.com and search for ▶ NSE7_OTS-7.2 ◀ to download for free 🧈New NSE7_OTS-7.2 Exam Sample[/url]
- Pass Guaranteed Quiz 2026 Fortinet NSE7_OTS-7.2: Marvelous Practice Fortinet NSE 7 - OT Security 7.2 Test Engine 🧘 Open [url]www.pdfdumps.com and search for ✔ NSE7_OTS-7.2 ️✔️ to download exam materials for free 🏣NSE7_OTS-7.2 New Dumps Ppt[/url]
- NSE7_OTS-7.2 New Real Exam 🏚 New NSE7_OTS-7.2 Test Blueprint 💚 Test NSE7_OTS-7.2 Cram 💂 Search for ⏩ NSE7_OTS-7.2 ⏪ on [url]www.pdfvce.com immediately to obtain a free download 🦓New NSE7_OTS-7.2 Exam Sample[/url]
- NSE7_OTS-7.2 Free Practice 👑 NSE7_OTS-7.2 Valid Test Pass4sure 🔟 NSE7_OTS-7.2 New Real Exam 🦧 Go to website ✔ [url]www.pdfdumps.com ️✔️ open and search for NSE7_OTS-7.2 to download for free 🏕New NSE7_OTS-7.2 Exam Sample[/url]
- NSE7_OTS-7.2 Valid Test Pass4sure 🟢 NSE7_OTS-7.2 Torrent 🙁 NSE7_OTS-7.2 Free Practice 👵 Download NSE7_OTS-7.2 for free by simply entering ▷ [url]www.pdfvce.com ◁ website ☘NSE7_OTS-7.2 Valid Test Pass4sure[/url]
- Pass Guaranteed Quiz 2026 Fortinet NSE7_OTS-7.2: Marvelous Practice Fortinet NSE 7 - OT Security 7.2 Test Engine 🧡 Open ☀ [url]www.prepawayete.com ️☀️ and search for ☀ NSE7_OTS-7.2 ️☀️ to download exam materials for free 🌊New NSE7_OTS-7.2 Exam Sample[/url]
- Reliable NSE7_OTS-7.2 Exam Review 🐟 NSE7_OTS-7.2 Reliable Practice Materials 🚣 NSE7_OTS-7.2 Reliable Practice Questions 😳 Search for ▷ NSE7_OTS-7.2 ◁ and obtain a free download on ➥ [url]www.pdfvce.com 🡄 🧆New NSE7_OTS-7.2 Exam Sample[/url]
- Pass Guaranteed Quiz 2026 Fortinet NSE7_OTS-7.2: Marvelous Practice Fortinet NSE 7 - OT Security 7.2 Test Engine 🚂 Open website [url]www.testkingpass.com and search for ⇛ NSE7_OTS-7.2 ⇚ for free download 🚙Test NSE7_OTS-7.2 Cram[/url]
- myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, tutor1.gerta.pl, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, myportal.utt.edu.tt, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, asmtechnolabs.com, Disposable vapes
What's more, part of that DumpExam NSE7_OTS-7.2 dumps now are free: https://drive.google.com/open?id=1mouhfskb9xQzDQ7_zD1JojlCM2xs7HtZ
