[Hardware] Free PDF Quiz Microsoft - Authoritative Verified MD-102 Answers
71
Hardware Free PDF Quiz Microsoft - Authoritative Verified MD-102 Answers
Posted at 2/21/2026 00:34:36      View297 | Replies2        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Microsoft MD-102 dumps are available on Google Drive shared by Prep4cram: https://drive.google.com/open?id=1Fj3UyiujBqI_GBqFEEfsRgpfTGsnu0pq
Don't be tied up in small things. Don't let your exam affect your regular work. Professionals do professionals. Only spend a little money on Microsoft MD-102 exam braindumps pdf, you will pass exam easily with only 24-36 hours preparation before the real test. Work is important, relax properly is important, Let our MD-102 Exam Braindumps pdf help you clear your exam easily so that you can achieve three things at one stroke. In fact time is money.
Microsoft MD-102 Exam Syllabus Topics:
  • Prepare infrastructure for devices: This topic focuses on adding devices to Microsoft Entra ID and enrolling devices to Microsoft Intune.
  • Protect devices: In this topic, aspiring administrators get knowledge about configuration of endpoint security and management of device updates by using Intune.
  • Manage applications: This section covers skills to manage application implementation, manage updates, and manage performance to support the performance of users to meet the needs of business organizations.
  • Manage and maintain devices: This section deals with managing, troubleshooting, and safeguarding various devices. It also covers methods to ensure that they meet organizational policies and security standards.
Valid MD-102 Exam Questions That Have Been Tried and TrueWe do admire our experts' familiarity and dedication with the industry all these years. By their help, you can qualify yourself with MD-102 guide materials. Our experts pass onto the exam candidate their know-how of coping with the exam by our MD-102 Exam Braindumps. Exam candidates are susceptible to the influence of ads, so our experts' know-how is impressive to pass the MD-102 exam instead of making financial reward solely.
Microsoft Endpoint Administrator Sample Questions (Q65-Q70):NEW QUESTION # 65
Hotspot Question
Your network contains an Active Directory domain. The domain contains computers that are managed by using Microsoft Endpoint Configuration Manager.
You plan to integrate Configuration Manager and Azure as part of a Desktop Analytics implementation.
You create a new organizational unit (OU) and place several test computers that run Windows 10 into the OU.
You need to collect diagnostic data from the test computers to Desktop Analytics.
- App usage and insights data
- Health monitoring data
- Deployment status data
The solution must minimize the data collected.
Which two Group Policy settings should you configure? To answer, select the appropriate settings in the answer area.
Box 1: Allow Telemetry
Use a Group Policy object to set your organization's telemetry level.
1. From the Group Policy Management Console, go to Computer Configuration > Administrative Templates > Windows Components > Data Collection and Preview Builds.
2. Double-click Allow Telemetry.
3. In the Options box, select Full, and then click OK.
Box 2: Limit Enhanced diagnostic data..
Microsoft recommends that you enable the Optional (limited) diagnostic data level with Desktop Analytics to maximize the benefits you get from it.
The Optional (Limited) setting in Configuration Manager is the same setting as Limit Enhanced diagnostic data to the minimum required by Windows Analytics policy available on devices running Windows 10, version 1709 and later.
https://docs.microsoft.com/en-us ... r/collector-client- configuration-windows-10-telemetry-requirements
https://docs.microsoft.com/en-us ... enable-data-sharing
NEW QUESTION # 66
Your company has a Remote Desktop Gateway (RD Gateway).
You have a server named Server1 that is accessible by using Remote Desktop Services (RDS) through the RD Gateway.
You need to configure a Remote Desktop connection to connect through the gateway.
Which setting should you configure?
  • A. Connect from anywhere
  • B. Server authentication
  • C. Local devices and resources
  • D. Connection settings
To connect to a remote server through the RD Gateway, you need to configure the Connect from anywhere setting in the Remote Desktop Connection client. This setting allows you to specify the domain name and port of the RD Gateway server, as well as the authentication method. The other settings are not related to the RD Gateway connection. References: Configure Remote Desktop Connection Settings for Remote Desktop Gateway
NEW QUESTION # 67
Hotspot Question
You have an Azure AD tenant named contoso.com that contains the devices shown in the following table.
The tenant contains the Azure AD groups shown in the following table.
You add an Autopilot deployment profile as shown in the following exhibit.
NEW QUESTION # 68
You have a Microsoft 365 E5 subscription that contains 500 macOS devices enrolled in Microsoft Intune.
You need to ensure that you can apply Microsoft Defender for Endpoint antivirus policies to the macOS devices. The solution must minimize administrative effort.
What should you do?
  • A. Install Defender for Endpoint on the macOS devices.
  • B. Onboard the macOS devices to the Microsoft Purview compliance portal.
  • C. From the Microsoft Intune admin center, create a configuration profile.
  • D. From the Microsoft Intune admin center, create a security baseline.
To apply Microsoft Defender for Endpoint antivirus policies to the macOS devices, you need to install Defender for Endpoint on the devices. You can use Intune to deploy a script that installs Defender for Endpoint on macOS devices. After installation, you can use Intune to create and assign antivirus policies to the devices.References:https://docs.microsoft.com/en-us ... osoft-defender-atp/
NEW QUESTION # 69
You have a Microsoft 365 E5 subscription and use Microsoft Intune. The subscription contains a Microsoft Entra tenant that syncs with an on-premises Active Directory Domain Services (AD DS) domain. The tenant has Windows Local Administrator Password Solution (Windows LAPS) enabled.
You have the Windows devices shown in the following table.
You have an Endpoint security policy that is configured as shown in the following table.
For each of the following statements, select Yes if the statement is true. Otherwise, select No. NOTE: Each correct selection is worth one point.
NEW QUESTION # 70
We provide our customers with the most reliable learning materials about MD-102 certification exam and the guarantee of pass. We assist you to prepare the key knowledge points of MD-102 actual test and obtain the up-to-dated exam answers. All MD-102 Test Questions offered by us are tested and selected by our senior experts in IT filed, which only need little time to focus on the practice and the preparation.
MD-102 Valid Braindumps: https://www.prep4cram.com/MD-102_exam-questions.html
What's more, part of that Prep4cram MD-102 dumps now are free: https://drive.google.com/open?id=1Fj3UyiujBqI_GBqFEEfsRgpfTGsnu0pq
Posted at 3/7/2026 06:11:50        Only Author  2#
This article has given me a lot of space for reflection, and Ive gained a lot. The New CC test syllabus questions are freeunlock your promotion and salary raise!
Posted at 4/20/2026 13:33:16        Only Author  3#
Your article is an absolute masterpiece, thank you for sharing! Boost your IT skills and enjoy free Test D-CIS-FN-01 name sharing. Wishing you success!
