PracticeMaterial will Help You in Passing the Salesforce PDII Certification Exam
Posted at 2/21/2026 02:28:16
View112
Replies0
P.S. Free 2026 Salesforce PDII dumps are available on Google Drive shared by PracticeMaterial: https://drive.google.com/open?id=1rmu4a3LtOhCcDzwaSyRFlWn_STxbrV_u
What are you waiting for? Unlock your potential and download PracticeMaterial actual PDII questions today! Start your journey to a bright future, and join the thousands of students who have already seen success by using Salesforce Dumps of PracticeMaterial, you too can achieve your goals and get the Salesforce PDII Certification of your dreams. Take the first step towards your future now and buy PDII exam dumps. You won't regret it!
The PDII certification exam evaluates the candidates ability to design and develop complex business logic, data models, and user interfaces using Salesforce. PDII exam is divided into multiple-choice questions and scenarios based questions, which require the candidate to apply their knowledge of Salesforce development to real-life scenarios. PDII exam is a challenging one, and it tests the candidates ability to develop solutions that are efficient, scalable, and maintainable.
Salesforce PDII, or Salesforce Certified Platform Developer II, is a certification exam that validates advanced knowledge and skills in Salesforce development. It is designed for experienced Salesforce professionals who have a deep understanding of the Salesforce platform and its capabilities, and who are able to design and develop complex business solutions using Apex, Visualforce, and the Salesforce Lightning Platform.
Salesforce PDII Certification Exam is a highly recognized certification for experienced Salesforce developers who specialize in building and deploying custom applications on the Salesforce platform. Platform Developer II certification is designed to test the candidate's technical knowledge and expertise in building scalable solutions that meet the business requirements of Salesforce clients. Salesforce PDII certification demonstrates the candidate's ability to design, develop, test, and deploy custom applications that are capable of integrating with various Salesforce technologies.
Pass Guaranteed Salesforce - PDII - Platform Developer II Latest Hot QuestionsIt is not hard to know that PDII torrent prep is compiled by hundreds of industry experts based on the syllabus and development trends of industries that contain all the key points that may be involved in the examination. Therefore, with PDII exam questions, you no longer need to purchase any other review materials, and you also dont need to spend a lot of money on tutoring classes. At the same time, PDII Test Guide will provide you with very flexible learning time in order to help you pass the exam.
Salesforce Platform Developer II Sample Questions (Q11-Q16):NEW QUESTION # 11
A developer has a Visual force page that automatically assign ownership of an Account to a queue save. The page appears to correctly assign ownership, but an assertion validating the correct ownership fails.
What can cause this problem?
- A. The test class does not retrieve the updated value- from the database.
- B. The test class does not use the seeAllData=true annotation,
- C. The test class does not use the Bulk API for loading test data.
- D. The test class does not implement the Queueabfe interface.
NEW QUESTION # 12
A business currently has a process to manually upload orders from its external Order Management System (OMS) into Salesforce.
This is a labor intensive process since accounts must be exported out of Salesforce to get the IDs. The upload file must be updated with the correct account IDs to relate the orders to the corresponding accounts.
Which two recommendations should make this process more efficient?
Choose 2 answers
- A. Use the upsert wizard in the Data Loader to import the data.
- B. Use the insert wizard in the Data Loader to import the data.
- C. Ensure the data in the file is sorted by the order ID.
- D. Identify unique fields on Order and Account and set them as External IDs.
Setting unique fields on related objects as External IDs allows for the creation of relationships during imports without needing Salesforce IDs. The upsert operation in Data Loader can then use these External IDs to relate records, which streamlines the process and avoids the need to export Salesforce IDs manually.
Data Loader Guide
NEW QUESTION # 13
MyOpportunities.js
JavaScript
import { LightningElement, api, wire } from 'lwc';
import getOpportunities from '@salesforce/apex/OpportunityController.findMyOpportunities'; export default class MyOpportunities extends LightningElement {
@api userId;
@wire(getOpportunities, {oppOwner: '$userId'})
opportunities;
OpportunityController.cls
Java
public with sharing class OpportunityController {
@AuraEnabled
public static List<Opportunity> findMyOpportunities(Id oppOwner) {
return [
SELECT Id, Name, StageName, Amount
FROM Opportunity
WHERE OwnerId = ppOwner
A developer is experiencing issues with a Lightning web component. The co12mponent must surface information about Opportunities owned by the currently logged-in user. When the component is rendered, the following message is displayed: "Error retrieving data". Which action must be completed in the Apex method to make it wireable?13
- A. Use the Continuation=true attribute in the Apex method.14
- B. Edit the code to use the without sharing keyword in the Apex class.15
- C. Use the Cacheable=true attribute in the Apex method.16
- D. Ensure the OWD for the Opportunity object is Public.17
To use the @wire service in a Lightning Web Component (LWC) to retrieve data from an Apex method, the Apex method must be marked as cacheable. In the provided OpportunityController class, the findMyOpportunities method is annotated with @AuraEnabled, but it lacks the mandatory cacheable=true property.
The @wire service is part of the Lightning Data Service (LDS) reactive framework. Salesforce requires wireable methods to be cacheable to improve performance and ensure that data can be stored in the client-side cache. Without (cacheable=true), the @wire decorator will fail to execute, resulting in the "Error retrieving data" message or a similar runtime failure.
Option C is the correct fix: the developer must update the annotation to @AuraEnabled(cacheable=true).
Option A (Continuation) is only for long-running external callouts. Option B (without sharing) might affect visibility but isn't a requirement for the wire service itself. Option D (OWD) affects whether records are visible based on security, but the technical failure described is rooted in the component-to-Apex binding requirement. Once marked as cacheable, the LDS can properly manage the data lifecycle for the component.
NEW QUESTION # 14
A developer writes a Lightning web component that displays a dropdown list of all custom objects in the org from which a user will select. An Apex method prepares and returns data to the component.
What should the developer do to determine which objects to include in the response?
- A. Check the isCustom() value on the sObject describe result,
- B. Check the getobiectType [) value for 'Custom' or "Standard' on the sObject describe result.
- C. Import the list of all custom objects from @salesforce/schema.
- D. Use the getcustomobjects() method from the Schema class.
To determine which objects to include in the response, the developer should check the isCustom() value on the sObject describe result. This method returns a Boolean indicating whether the sObject is a custom object.References: Apex Developer Guide - Describing sObjects
NEW QUESTION # 15
A company has a custom object, Order_ c, that has a custom picklist field, Status__ c, with values of New/ 'In Progress/ or 'Fulfilled' and a lookup field, Contact__ c, to Contact.
Which SOQL query will return a unique list of all the Contact records that have no 'Fulfilled' Orders?
A)
B)
C)
D)
- A. option
- B. option
- C. option
- D. option
NEW QUESTION # 16
If you would like to use all kinds of electronic devices to prepare for the PDII exam, then I am glad to tell you that our online app version of our PDII study guide is definitely your perfect choice. With the online app version of our PDII Learning Materials, you can just feel free to practice the questions in our PDII training dumps no matter you are using your mobile phone, personal computer, or tablet PC.
PDII Test Questions Answers: https://www.practicematerial.com/PDII-exam-materials.html
- Salesforce PDII Exam Questions - Quick Tips To Pass [2026] 🧜 Search on ➠ [url]www.torrentvce.com 🠰 for ➽ PDII 🢪 to obtain exam materials for free download 🎽
DII Reliable Exam Registration[/url] - PDII Real Exam Answers 😌 PDII Reliable Exam Practice 🏐 New PDII Test Braindumps 🆔 Search on ➤ [url]www.pdfvce.com ⮘ for ➡ PDII ️⬅️ to obtain exam materials for free download ✊
DII Free Study Material[/url] - New PDII Test Braindumps 🥼 New PDII Test Braindumps 🥇 PDII Free Study Material 🏀 Open website { [url]www.testkingpass.com } and search for ➥ PDII 🡄 for free download 🎷Exam PDII Guide[/url]
- 100% Pass Quiz 2026 Salesforce PDII: Authoritative Platform Developer II Hot Questions 🐵 Enter ➽ [url]www.pdfvce.com 🢪 and search for PDII to download for free 🛃New PDII Exam Fee[/url]
- Pass Guaranteed Quiz Unparalleled Salesforce - PDII - Platform Developer II Hot Questions 🧣 Search for ➽ PDII 🢪 and obtain a free download on ⮆ [url]www.practicevce.com ⮄ 🎠
DII Exam Actual Tests[/url] - Pdfvce Salesforce PDII Web-Based Practice Test 👽 Enter ▷ [url]www.pdfvce.com ◁ and search for ✔ PDII ️✔️ to download for free 😝
DII Reliable Mock Test[/url] - PDII Reliable Exam Registration 🎊 Exam PDII Guide ⚒ Practice PDII Mock 👭 Search on ➥ [url]www.verifieddumps.com 🡄 for { PDII } to obtain exam materials for free download 💭Exam PDII Guide[/url]
- Pdfvce Salesforce PDII Web-Based Practice Test 🐜 Copy URL ✔ [url]www.pdfvce.com ️✔️ open and search for ➤ PDII ⮘ to download for free 🥾
DII Free Study Material[/url] - PDII Real Exam Answers 🐷 PDII Practice Online 🏟 PDII Reliable Mock Test ✡ Immediately open ▷ [url]www.troytecdumps.com ◁ and search for ⮆ PDII ⮄ to obtain a free download 🏂
DII Testing Center[/url] - Pass Guaranteed Quiz Unparalleled Salesforce - PDII - Platform Developer II Hot Questions 💐 Simply search for ▛ PDII ▟ for free download on ▛ [url]www.pdfvce.com ▟ 🧇Download PDII Pdf[/url]
- Pass Guaranteed Quiz Salesforce - PDII - Platform Developer II Authoritative Hot Questions 😀 Open website [url]www.validtorrent.com and search for ⮆ PDII ⮄ for free download 🌎Exam PDII Guide[/url]
- www.stes.tyc.edu.tw, digivator.id, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
2026 Latest PracticeMaterial PDII PDF Dumps and PDII Exam Engine Free Share: https://drive.google.com/open?id=1rmu4a3LtOhCcDzwaSyRFlWn_STxbrV_u
