[Hardware] D-MSS-DS-23TԇYD-MSS-DS-23Yʂ
115
Hardware D-MSS-DS-23TԇYD-MSS-DS-23Yʂ
Posted at 2/21/2026 03:09:17      View129 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. TopexamGoogle DriveǹФƤoϤ¤D-MSS-DS-23ףhttps://drive.google.com/open?id=16h1tr1IsAFwodWBu1-sMkhMuinZNHR0Y
PayPalϡHĤʥ饤ȡǤ갲ȫФʹäƤޤ ٤ƤYߤPayPal餷D-MSS-DS-23¤ԇY}ُǤ뤳ȤäƤޤ PayPalωӤ֤Ʒ|һȫԹǤ뤳ȤҪ󤷤ƤޤuƷȥ`ӥʤsΤȮʤϡPayPalωӤ֤ΥȤ֥åޤ PayPalD-MSS-DS-23¤ԇY}׷Ӥ˰֧BäơӤ֤I֤ΥȤȫǤ뤳Ȥ^Ǥޤ SWREGˤϡ֪ؔb˰ʤɤ׷˰ޤ
EMC D-MSS-DS-23 JԇYγ}죺
ȥԥå}
ȥԥå 1
  • Midrange Storage Solutions Best Practice: This section of the exam measures the skills of Dell Unity and PowerStore Midrange Storage Solutions professionals and covers best practice recommendations for system configuration and upgrades. It includes guidelines on hardware capacity, deployment models, clustering, and operating system upgrades. A key skill assessed is implementing effective backend connectivity solutions that enhance system performance.
ȥԥå 2
  • Dell Midrange Sizing Solutions: This section of the exam measures the skills of storage engineers and covers the use of tools like the Midrange Sizer for Unity to size solutions effectively. It includes design methods and deliverables associated with sizing storage solutions.
ȥԥå 3
  • Dell Midrange Storage Solutions Planning, Sizing, and Design: This section of the exam measures the skills of storage engineers and covers the planning, sizing, and design phases of a Midrange solution sales engagement. It emphasizes conducting site evaluations and remediation processes while considering performance parameters and environmental limits. A critical skill evaluated is accurately characterizing workloads to inform design decisions.
D-MSS-DS-23Yʂ䡢D-MSS-DS-23ѧEMCD-MSS-DS-23JԇYTopexamʌTҥ`बԷ֤֪RȘIνUYäƤɤɤоEMCJ^YҪ˜ΕۤΥȤˤҊޤTopexamƷⱣϤäơxkˤʤޤ
EMC Dell Midrange Storage Solutions Design 2023 J D-MSS-DS-23 ԇY} (Q53-Q58):| # 53
What can be done to provide best performance on Dell Unity iSCSI connections?
  • A. Configure LACP on all connections.
  • B. Utilize FSN on hosts.
  • C. Configure Jumbo frames end-to-end.
  • D. Configure Flow control on all ports.
⣺C
h
To provide the best performance on Dell Unity iSCSI connections, configuring Jumbo frames end-to-end is recommended. Jumbo frames allow for larger packet sizes than the standard 1500 bytes, typically up to 9000 bytes. This reduces the number of packets transmitted, decreases CPU utilization, and improves overall network efficiency. Here's how to configure Jumbo frames:
* Switch Configuration:Enable Jumbo frames on all network switches that will handle iSCSI traffic.
* Network Interface Configuration:Configure all network interfaces (NICs) on the storage system and the iSCSI hosts to support Jumbo frames.
* End-to-End Consistency:Ensure that Jumbo frames are configured consistently across the entire network path from the storage system to the hosts to avoid fragmentation and performance degradation.
* Dell Technologies Unity iSCSI Best Practices
* Dell Entry-Level and Mid-Range Storage Community
| # 54
Which describes cascade replication on the Dell Unity XT platform?
  • A. Asynchronous replication of a block resource from Sites A to B, then B to C, then C to D
  • B. Asynchronous replication of a file resource from Sites A to B, then B to C, then C to D
  • C. Synchronous replication of a file resource from Sites A to B, then B to C, then C to D
  • D. Synchronous replication of a block resource from Sites A to B, then B to C, then C to D
⣺A
h
Cascade replication on the Dell Unity XT platform describes the process where a block resource is replicated asynchronously from one site to another in a sequential manner. Here's how it works:
* Site A to Site B:The block resource is first replicated asynchronously from Site A to Site B.
* Site B to Site C:After the replication from A to B is complete, the resource is then replicated from Site B to Site C.
* Site C to Site D:Finally, the resource is replicated from Site C to Site D.
This cascade replication method allows for efficient data protection and disaster recovery across multiple sites.
* Dell Technologies Unity XT Replication Guide
| # 55
What is the maximum supported drive configuration in the base enclosure of the PowerStore
3200T?
  • A. 21 x NVMe SCMs 4 x NVMe NVRAM
  • B. 23xNVMe SCMs 2 x NVMe NVRAM
  • C. 23 x NVMe SSDs 2 x NVMe NVRAM
  • D. 21 x NVMe SSDs 2 x NVMe NVRAM
⣺C
h
The maximum supported drive configuration in the base enclosure of the PowerStore 3200T includes 23 NVMe SSDs and 2 NVMe NVRAM. This configuration provides high performance and low latency, suitable for demanding workloads.
| # 56
A solution architect is sizing a new Dell Unity XT array that requires hybrid dynamic pools. Which option must be selected in Midrange Sizer?
  • A. Application Oriented
  • B. Advanced Performance
  • C. System Designer
  • D. Quick Configuration
⣺D
h
When sizing a new Dell Unity XT array that requires hybrid dynamic pools, the "Quick Configuration" option must be selected in the Midrange Sizer. This option streamlines the configuration process, allowing for a balanced and efficient setup of hybrid pools. Here's why Quick Configuration is used:
* Simplifies Setupuick Configuration provides a straightforward approach to setting up the array, ensuring that the necessary parameters for hybrid dynamic pools are configured correctly without requiring in-depth manual input.
* Balanced Performance:The tool uses predefined settings and best practices to create a hybrid pool that balances performance and capacity, making it ideal for a variety of workloads.
* Dell Technologies Midrange Sizer Tool Documentation
| # 57
Which task does the Environment Collection Tool automate?
  • A. Generation of support matrix compliance reports
  • B. Collection of host configuration data
  • C. Migration Planning
  • D. Problem diagnosis and resolution
⣺A
| # 58
¤״B˱ĤˤäǰڤΤҡTopexamΥǥǤҡϳ˸¤ڵĤEMCD-MSS-DS-23ԇY_JƤޤ¤줿顢uƷʹäƤ뤪֪ͨ͘Ʊˤ¤⤵ޤ٤Ƥθ¥`ӥϱEMCD-MSS-DS-23եȤُ뤷һgǟoϤǤ
D-MSS-DS-23Yʂ: https://www.topexam.jp/D-MSS-DS-23_shiken.html
ʤߤˡTopexam D-MSS-DS-23һ򥯥饦ɥȥ``ɤǤޤhttps://drive.google.com/open?id=16h1tr1IsAFwodWBu1-sMkhMuinZNHR0Y
