[General] 2026 High Hit-Rate Plat-Admn-201¨C100% Free New Braindumps Free | New Plat-Admn-2
101
¡¾General¡¿ 2026 High Hit-Rate Plat-Admn-201¨C100% Free New Braindumps Free | New Plat-Admn-2
Posted at 2/21/2026 04:38:10      View£º126 | Replies£º1        Print      Only Author   [Copy Link] 1#
We committed to providing you with the best possible Salesforce Certified Platform Administrator (Plat-Admn-201) practice test material to succeed in the Salesforce Plat-Admn-201 exam. With real Plat-Admn-201 exam questions in PDF, customizable Salesforce Plat-Admn-201 practice exams, free demos, and 24/7 support, you can be confident that you are getting the best possible Plat-Admn-201 Exam Material for the test. Buy today and start your journey to Salesforce Certified Platform Administrator (Plat-Admn-201) exam success with PrepAwayETE!
Our Plat-Admn-201 test braindumps can help you improve your abilities. Once you choose our learning materials, your dream that you have always been eager to get Plat-Admn-201 certification which can prove your abilities will realized. You will have more competitive advantages than others to find a job that is decent. We are convinced that our Plat-Admn-201 Exam Questions can help you gain the desired social status and thus embrace success. When you start learning, you will find a lot of small buttons, which are designed carefully. You can choose different ways of operation according to your learning habits to help you learn effectively.
New Plat-Admn-201 Dumps Free, New Plat-Admn-201 Test DurationNo one can beat us in terms of Salesforce Plat-Admn-201 exam prices. Download the Salesforce Plat-Admn-201 exam dumps after paying discounted prices and start this journey. You can study Plat-Admn-201 Exam Engine anytime and anyplace for the convenience our three versions of our Plat-Admn-201 study questions bring.
Salesforce Certified Platform Administrator Sample Questions (Q64-Q69):NEW QUESTION # 64
Service reps in a call center do not have assigned desks. They sit at any available desk and use the computer on that desk to access Salesforce. A Platform Administrator has been asked to streamline the login process so the reps do not have to authenticate each time they log in at a different computer. Which function should the administrator use to implement this request?
  • A. Trusted IP Ranges
  • B. Multi-factor Authentication
  • C. Custom Profile
  • D. Permission Set
In Salesforce, Trusted IP Ranges (configured under Network Access in Setup) define a set of IP addresses from which users can log in without being prompted for a verification code (identity confirmation). In a call center environment where reps use different machines but are all within the same corporate network (sharing a common external IP or range), adding those corporate IPs to the Trusted IP Ranges list "streamlines" the login process. This prevents the system from seeing each new machine as an "unrecognized device". Multi-factor Authentication (Option C) actually adds an extra step to the login process, which is the opposite of streamlining28. Profiles (Option A) and Permission Sets (Option D) can manage "Login IP Ranges" (which restrict access to specific IPs), but Trusted IP Ranges are the primary tool for bypassing identity verification within a known network.
NEW QUESTION # 65
Northern Trail Outfitters wants emails received from customers to generate cases automatically. How should a Platform Administrator ensure that the emails are sent to the correct queue?
  • A. Utilize a flow to identify the correct queue and assign the case.
  • B. Create an escalation rule to send cases to the correct queue.
  • C. Configure Email-to-Case so emails are delivered to the correct queue.
  • D. Use a custom email service to set the owner of the case upon creation.
The most efficient and standard way to automate case creation from inbound emails is by using Email-to-Case . When setting up Email-to-Case, the Platform Administrator configures "Routing Addresses" . For each routing address (e.g., support@company.com or billing@company.com), the administrator can specify a default owner or queue for the cases created via that specific address . This ensures that when a customer sends an email to the "Support" address, it is automatically routed to the Support Queue, and an email to the "Billing" address is routed to the Billing Queue . This configuration is handled directly within the Email-to-Case setup pages and does not require additional escalation rules (Option A) or complex custom flows (Option C) for the initial assignment . While a custom email service (Option B) is possible, it is a developer-centric approach that is generally unnecessary given the robust native capabilities of the standard Email-to-Case feature . This setup streamlines the intake process and ensures that customer issues are immediately visible to the correct service team34.
NEW QUESTION # 66
When Agentforce performs its grounding check, it examines source information, the topic instructions, and scope. Which additional information does the agent look for during its grounding check? 39
  • A. Prompt injection risks
  • B. Encrypted fields
  • C. Incompatible data types
  • D. The web for information verification
Grounding is the process by which an AI agent retrieves and uses specific, trusted data to ensure its responses are accurate and relevant41. During this process, Salesforce's Einstein Trust Layer performs several critical checks, including identifying Prompt Injection risks424242. Prompt injection refers to attempts by a user to "trick" the AI into ignoring its instructions or revealing sensitive data by entering malicious commands into the chat interface43. By checking for these risks during the grounding phase, the agent can ensure that the instructions it uses to generate a response remain secure and aligned with company policies44. While the agent respects field security, "Encrypted fields" (Option C) are handled at the data access layer rather than as part of the linguistic grounding check45. Standard Agentforce agents do not browse the open web for verification (Option D) as they are intended to remain grounded strictly in the company's verified internal data46.
NEW QUESTION # 67
Agentforce is escalating cases to the support team, but the support team complains they have no context and have to ask the customer to repeat everything. Which configuration issue is the most likely cause of this issue?
  • A. The support team members are missing the Agentforce User permission set.
  • B. The handoff is creating a new case instead of transferring the existing session.
  • C. The agent's instructions are preventing the history and context from being saved.
  • D. The support team's case page layout is missing the agent history component.
When an AI agent like Agentforce transfers a conversation to a human support representative, the goal is a "warm handoff" where the rep can see exactly what the customer and the AI discussed. If reps are complaining about a lack of context, the most common administrative cause is that the Conversation History component (or Agent History component) has not been added to the Case Lightning Record Page. Without this component on their page layout, the rep sees the newly assigned case but cannot see the transcript of the preceding chat session. To resolve this, the Platform Administrator should use the Lightning App Builder to add the relevant history component to the Case page used by the support team. Option D is less likely if escalation is working but context is missing. Option A would prevent users from using Agentforce features but wouldn't specifically hide the transcript of a finished AI interaction. Ensuring the UI includes the conversation history is critical for maintaining high customer satisfaction during handoffs.
NEW QUESTION # 68
A Platform Administrator deactivates an agent to add a new topic and action. What happens to any ongoing user conversations with the agent?
  • A. The agent window automatically closes to prevent new messages.
  • B. The agent will continue conversations using the deactivated agent until reactivated.
  • C. The agent will send a system error message as a response to any new messages.
  • D. The agent will pause the conversation and resume once reactivated.
In the Agentforce environment, deactivating an agent to make configuration changes (like adding a Topic or Action) does not immediately terminate existing sessions. To ensure a smooth user experience, Salesforce allows ongoing conversations to continue using the version of the agent that was active when the session started. The "deactivation" simply prevents new sessions from being initiated. Once the administrator reactivates the agent, new sessions will utilize the updated configuration, while current users finish their interactions without interruption or "system errors". The window does not automatically close, and the conversation is not "paused" in a way that requires the user to wait for reactivation
NEW QUESTION # 69
Additionally, students can take multiple Salesforce Plat-Admn-201 exam questions, helping them to check and improve their performance. Three formats are prepared in such a way that by using them, candidates will feel confident and crack the Salesforce Certified Platform Administrator (Plat-Admn-201) actual exam. These three formats suit different preparation styles of Plat-Admn-201 test takers.
New Plat-Admn-201 Dumps Free: https://www.prepawayete.com/Salesforce/Plat-Admn-201-practice-exam-dumps.html
Many candidates find the Salesforce Plat-Admn-201 exam preparation difficult, With the increasing marketization, the Plat-Admn-201 study guide experience marketing has been praised by the consumer market, Salesforce Plat-Admn-201 New Braindumps Free We can¡¯t deny that the pursuit of success can encourage us to make greater progress, For this, you don¡¯t have to worry as PrepAwayETE is here to help you in preparation for Plat-Admn-201 questions.
Many, such as the Ribbon, File tab, and Quick Access Toolbar, can Plat-Admn-201 also be found in Excel, PowerPoint, and Outlook, The successful ones were a lot more fun, for us, and for our customers.
Many candidates find the Salesforce Plat-Admn-201 Exam Preparation difficult, With the increasing marketization, the Plat-Admn-201 study guide experience marketing has been praised by the consumer market.
Salesforce Plat-Admn-201 Questions - Latest Preparation Material (2026)We can¡¯t deny that the pursuit of success can encourage us to make greater progress, For this, you don¡¯t have to worry as PrepAwayETE is here to help you in preparation for Plat-Admn-201 questions.
They are pdf, software and the most convenient one app.
Posted at 2/23/2026 01:40:11        Only Author  2#
Fast2test의 Huawei H19-308_V4.0덤프를 공부하면 100% Huawei H19-308_V4.0 시험패스를 보장해드립니다. 만약 Huawei H19-308_V4.0 덤프자료를 구매하여 공부한후 시험에 탈락할시 불합격성적표와 주문번호를 메일로 보내오시면 덤프비용을 바로 환불해드립니다. 저희 Fast2test Huawei H19-308_V4.0덤프로 자격증부자되세요.
