[Hardware] Exam AI-102 Questions & Test AI-102 Objectives Pdf
108
Hardware Exam AI-102 Questions & Test AI-102 Objectives Pdf
Posted at 2/21/2026 04:39:38      View124 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free & New AI-102 dumps are available on Google Drive shared by TopExamCollection: https://drive.google.com/open?id=13CfvFiN5JHO0Etk9aCxFLQ03V1ydV9ak
It follows its goal by giving a completely free demo of real Microsoft AI-102 exam questions. The free demo will enable users to assess the characteristics of the Microsoft AI-102 Exam product. TopExamCollection will provide you with free Microsoft AI-102 actual questions updates for 365 days after the purchase of our product.
Life is beset with all different obstacles that are not easily overcome. For instance, AI-102 exams may be insurmountable barriers for the majority of population. However, with the help of our exam test, exams are no longer problems for you. The reason why our AI-102 Training Materials outweigh other study prep can be attributed to three aspects, namely free renewal in one year, immediate download after payment and simulation for the software version.
Top Exam AI-102 Questions 100% Pass | High-quality Test AI-102 Objectives Pdf: Designing and Implementing a Microsoft Azure AI SolutionIn today's technological world, more and more students are taking the Designing and Implementing a Microsoft Azure AI Solution (AI-102) exam online. While this can be a convenient way to take a Designing and Implementing a Microsoft Azure AI Solution (AI-102) exam dumps, it can also be stressful. Luckily, TopExamCollection's best Microsoft AI-102 exam questions can help you prepare for your Microsoft AI-102 Certification Exam and reduce your stress. If you are preparing for the Designing and Implementing a Microsoft Azure AI Solution (AI-102) exam dumps our AI-102 Questions help you to get high scores in your Designing and Implementing a Microsoft Azure AI Solution (AI-102) exam.
Microsoft AI-102 exam is intended for professionals who work as AI engineers, data scientists, solution architects, or developers, and who have experience with Azure services such as Azure Machine Learning, Azure Cognitive Services, and Azure Bot Service. It is also suitable for individuals who are interested in pursuing a career in AI and want to validate their skills and knowledge through a recognized certification.
One of the key objectives of the Microsoft AI-102 Exam is to test candidates' ability to design and implement machine learning models using Azure Machine Learning. This includes understanding how to select appropriate algorithms, prepare data for training, and fine-tune models to achieve the best possible performance. Candidates will also be tested on their ability to deploy machine learning models as web services using Azure Kubernetes Service (AKS).
Microsoft Designing and Implementing a Microsoft Azure AI Solution Sample Questions (Q214-Q219):NEW QUESTION # 214
Select the answer that correctly completes the sentence.
NEW QUESTION # 215
You are developing an application to recognize employees' faces by using the Face Recognition API. Images of the faces will be accessible from a URI endpoint.
The application has the following code.
https://docs.microsoft.com/en-us ... use-persondirectory
NEW QUESTION # 216
You are creating an enrichment pipeline that will use Azure Cognitive Search. The knowledge store contains unstructured JSON data and scanned PDF documents that contain text.
Which projection type should you use for each data type? To answer, select the appropriate options in the answer area.
https://docs.microsoft.com/en-us ... projection-overview
Topic 2, Wide World Importers
Existing Environment
A company named Wide World Importers is developing an e-commerce platform.
You are working with a solutions architect to design and implement the features of the e-commerce platform. The platform will use microservices and a serverless environment built on Azure.
Wide World Importers has a customer base that includes English, Spanish, and Portuguese speakers.
Applications
Wide World Importers has an App Service plan that contains the web apps shown in the following table.
Azure Resources
You have the following resources:
An Azure Active Directory (Azure AD) tenant
The tenant supports internal authentication.
All employees belong to a group named AllUsers.
Senior managers belong to a group named LeadershipTeam.
An Azure Functions resource
A function app posts to Azure Event Grid when stock levels of a product change between OK, Low Stock, and Out of Stock. The function app uses the Azure Cosmos DB change feed.
An Azure Cosmos DB account
The account uses the Core (SQL) API.
The account stores data for the Product Management app and the Inventory Tracking app.
An Azure Storage account
The account contains blob containers for assets related to products.
The assets include images, videos, and PDFs.
An Azure Cognitive Services resource named wwics
A Video Indexer resource named wwivi
Requirements
Business Goals
Wide World Importers wants to leverage AI technologies to differentiate itself from its competitors.
Planned Changes
Wide World Importers plans to start the following projects:
A product creation project: Help employees create accessible and multilingual product entries, while expediting product entry creation.
A smart e-commerce project: Implement an Azure Cognitive Search solution to display products for customers to browse.
A shopping on-the-go project: Build a chatbot that can be integrated into smart speakers to support customers.
Business Requirements
Wide World Importers identifies the following business requirements for all the projects:
Provide a multilingual customer experience that supports English, Spanish, and Portuguese.
Whenever possible, scale based on transaction volumes to ensure consistent performance.
Minimize costs.
Governance and Security Requirements
Wide World Importers identifies the following governance and security requirements:
Data storage and processing must occur in datacenters located in the United States.
Azure Cognitive Services must be inaccessible directly from the internet.
Accessibility Requirements
Wide World Importers identifies the following accessibility requirements:
All images must have relevant alt text.
All videos must have transcripts that are associated to the video and included in product descriptions.
Product descriptions, transcripts, and all text must be available in English, Spanish, and Portuguese.
Product Creation Requirements
Wide World Importers identifies the following requirements for improving the Product Management app:
Minimize how long it takes for employees to create products and add assets.
Remove the need for manual translations.
Smart E-Commerce Requirements
Wide World Importers identifies the following requirements for the smart e-commerce project:
Ensure that the Cognitive Search solution meets a Service Level Agreement (SLA) of 99.9% availability for searches and index writes.
Provide users with the ability to search insight gained from the images, manuals, and videos associated with the products.
Support autocompletion and autosuggestion based on all product name variants.
Store all raw insight data that was generated, so the data can be processed later.
Update the stock level field in the product index immediately upon changes.
Update the product index hourly.
Shopping On-the-Go Requirements
Wide World Importers identifies the following requirements for the shopping on-the-go chatbot:
Answer common questions.
Support interactions in English, Spanish, and Portuguese.
Replace an existing FAQ process so that all Q&A is managed from a central location.
Provide all employees with the ability to edit Q&As. Only senior managers must be able to publish updates.
Support purchases by providing information about relevant products to customers. Product displays must include images and warnings when stock levels are low or out of stock.
Product JSON Sample
You have the following JSON sample for a product.
NEW QUESTION # 217
You develop a Conversational Azure AI Language Understanding model by using Language Studio.
During testing, users receive incorrect responses to requests that do NOT relate to the capabilities of the model.
You need to ensure that the model identifies spurious or irrelevant requests.
What should you do?
  • A. Enable active learning.
  • B. Add entities.
  • C. Add examples to the custom intents.
  • D. Add examples to the None intent
https://learn.microsoft.com/en-u ... ice/conversational- language-understanding/concepts/none-intent#adding-examples-to-the-none-intent The None intent is also treated like any other intent in your project. If there are utterances that you want predicted as None, consider adding similar examples to them in your training data. For example, if you would like to categorize utterances that are not important to your project as None, such as greetings, yes and no answers, responses to questions such as providing a number, then add those utterances to your intent.
You should also consider adding false positive examples to the None intent. For example, in a flight booking project it is likely that the utterance "I want to buy a book" could be confused with a Book Flight intent. Adding "I want to buy a book" or "I love reading books" as None training utterances helps alter the predictions of those types of utterances towards the None intent instead of Book Flight.
NEW QUESTION # 218
You are building a phone call handling solution that will use the Azure Al Speech service and a custom neural voice.
You need to create a custom speech model.
Which five actions should you perform in sequence from Speech Studio? To answer, move the appropriate actions from the list of actions to the answer area and arrange them in the correct order.
NEW QUESTION # 219
Our AI-102 practice tests have established impressive recognition throughout the industry, diversified modes of learning enables the AI-102 exam candidates to capture at the real exam scenario. Tremendous quality of our AI-102 products makes the admirable among the professionals. Our practice tests are on demand, attending the needs of AI-102 Exams more comprehensively and dynamically as well. Lift up your learning tendency with TopExamCollection practice tests training. Conceptual understanding matters the most for your success, technical excellence is certain with TopExamCollection training as our experts keep it on high priority.
Test AI-102 Objectives Pdf: https://www.topexamcollection.com/AI-102-vce-collection.html
2026 Latest TopExamCollection AI-102 PDF Dumps and AI-102 Exam Engine Free Share: https://drive.google.com/open?id=13CfvFiN5JHO0Etk9aCxFLQ03V1ydV9ak
