[General] 1z0-076 Updated Dumps, 1z0-076 Test Passing Score
110
【General】 1z0-076 Updated Dumps, 1z0-076 Test Passing Score
Posted at 2/21/2026 05:38:58      View:121 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of PDFDumps 1z0-076 dumps from Cloud Storage: https://drive.google.com/open?id=1XkUPNy4AIvYMIWw1k9sNHcheUaYntMnu
Our 1z0-076 learning questions are famous for that they are undeniable excellent products full of benefits, so our exam materials can spruce up our own company image. Besides, our 1z0-076 study quiz is priced reasonably, so we do not overcharge you at all. Not only the office staff can buy it, the students can also afford it. Meanwhile, our 1z0-076 Exam Materials are demonstrably high effective to help you get the essence of the knowledge which was convoluted. You will get more than you can imagine by our 1z0-076 learning guide.
We are not exaggerating that if you study with our 1z0-076 exam questions, then you will pass the exam for sure because this conclusion comes from previous statistics. The pass rate of our customers is high as 98% to 100% with our 1z0-076 Practice Engine. We believe you are also very willing to become one of them, then why still hesitate? Just come in and try our 1z0-076 study materials, and we can assure you that you will not regret your choice.
Pass Guaranteed Oracle - The Best 1z0-076 - Oracle Database 19c: Data Guard Administration Updated DumpsIf you feel difficult in choosing which version of our 1z0-076 reliable exam guide, if you want to be simple, PDF version may be suitable for you. PDF version is a normal file. Many candidates are used to printing out and then writing & reading of 1z0-076 reliable exam guide on paper. Yes, it is silent and clear. Also if you have some unclearly questions, you can ask or talk with others easily. Others may just think that it is normally practice material. Also you can print out many copies of Oracle 1z0-076 Reliable Exam Guide and share with others.
Oracle 1z0-076 Exam Syllabus Topics:
  • Backup and Recovery Considerations in an Oracle Data Guard Configuration: In this topic, Backup and recovery procedures in a Data Guard configuration are discussed, including RMAN backups, offloading to physical standby, and network-based recovery.
  • Patching and Upgrading Databases in a Data Guard Configuration: This section provides guidance on patching and upgrading databases in a Data Guard environment, along with performance optimization techniques and monitoring considerations.
  • Using Flashback Database in a Data Guard Configuration: This topic covers the configuration and advantages of using Flashback Database in a Data Guard setup, as well as the process of enabling fast-start failover for seamless role changes.
  • Performing Role Transitions: Here, the concept of database roles is explained, along with the steps for performing switchovers, failovers, and maintaining physical standby sessions during role transitions.
Topic 5
  • Monitoring a Data Guard Broker Configuration: The topic covers the use of Enterprise Manager and DGMGRL to monitor Data Guard configurations and explains the various data protection modes available.
Topic 6
  • Creating a Logical Standby Database: This topic guides users through the process of creating and managing a logical standby database, including SQL Apply filtering.
Topic 7
  • Enhanced Client Connectivity in a Data Guard Environment: This topic focuses on enhancing client connectivity in a Data Guard setup and implementing failover procedures for seamless client redirection. It also covers application continuity to ensure uninterrupted operations during role transitions.
Topic 8
  • Managing Oracle Net Services in a Data Guard Environment: The section focuses on Oracle Net Services and its role in Data Guard networking setup.
Topic 9
  • Oracle Data Guard Broker Basics: An overview of the Data Guard broker, its architecture, components, benefits, and configurations, is provided here. It serves as an introduction to the tool used for managing Data Guard configurations.
Topic 10
  • Creating a Data Guard Broker Configuration: This section delves into the practical aspects of creating and managing a Data Guard broker configuration, including command-line and Enterprise Manager approaches.
Topic 11
  • Managing Physical Standby Files After Structural Changes on the Primary Database: The topic covers managing structural changes in the primary database and their impact on physical standby files.
Topic 14
  • Using Oracle Active Data Guard: Supported Workloads in Read-Only Standby Databases: Here, the usage of physical standby databases for real-time queries is discussed.
Oracle Database 19c: Data Guard Administration Sample Questions (Q28-Q33):NEW QUESTION # 28
You notice that the SQL apply lag on your logical standby database has increased but the redo transport lag has not.
Which four could be reasons for the increase in SQL apply lag?
  • A. The standby redo log files are undersized on the primary database
  • B. An undersized undo tablespace on the logical standby
  • C. An increased number of bulk inserts on the primary
  • D. Many SQL apply operations do full table scans
  • E. An increased number of bulk updates on the primary
  • F. An undersized shared pool
Answer: B,D,E,F
The SQL apply lag on a logical standby database can be caused by several factors:
* A: An undersized undo tablespace can lead to delays in SQL apply operations as it may not be able to handle the volume of undo records generated by the SQL apply process.
* B: SQL apply operations that do full table scans can consume significant system resources, potentially leading to higher apply lag.
* C: An increased number of bulk updates on the primary database may generate a large volume of redo data, which can cause apply lag if the logical standby cannot apply the changes quickly enough.
* F: An undersized shared pool may affect the parsing and execution of SQL statements by SQL apply, which can contribute to the apply lag.
Option D is less likely to be a direct cause of SQL apply lag compared to bulk updates, as inserts generate new data rather than modifying existing data, which SQL apply can typically handle more efficiently.
Option E is incorrect because the size of the standby redo log files on the primary database impacts redo transport lag, not SQL apply lag.
References: Oracle Database High Availability Overview and Oracle Data Guard Concepts and Administration guide provide insights into the factors affecting SQL apply performance on logical standby databases.
NEW QUESTION # 29
You created two remote physical standby databases using SQL and RMAN.
The primary database is a four-instance RAC database and each physical standby database has two instances.
Roles-based services are used for client connectivity and have been defined in the Grid Infrastructure.
Consider these operational requirements:
* The ability to manage multiple standby databases with a single tool
* The simplification of switchovers, failovers, reinstatements, and conversions to and from snapshot standby databases
* The automation of failovers to a specified target standby database
Which TWO tools can be used to fulfill these requirements7
  • A. CRSCTL
  • B. Enterprise Manager Cloud Control
  • C. DGMGRL
  • D. SQL*Plus
  • E. RMAN
  • F. SRVCTL
  • G. GDCCTL
Enterprise Manager Cloud Control provides a graphical interface to manage multiple standby databases, simplify switchovers and failovers, and automate failover processes to a specified target standby database. It offers a comprehensive view and control over the Data Guard configuration, making complex operations more manageable.
DGMGRL is a command-line tool specifically designed for managing Data Guard configurations. It allows the administration of multiple standby databases, simplifies the execution of switchovers and failovers, reinstatements, and conversions to and from snapshot standby databases, and supports the automation of failover processes to a specified standby database.
Other options like RMAN, SQL*Plus, CRSCTL, SRVCTL, and GDCCTL do not provide the same level of integrated management functionality for Data Guard environments as Enterprise Manager Cloud Control and DGMGRL.
NEW QUESTION # 30
A Data Guard environment has this configuration and these attributes:
The primary database prima is in the local region.
A physical standby database physt1 is in the local region.
A physical standby database physt2 is in a remote region.
The primary ships redo to physt1.
physt1 ships redo to physt2.
physt1 and physt2 have Real-Time Query enabled.
A sequence has been created with this SQL statement in the primary database:
CREATE SEQUENCE a NOCACHE SESSION;
Which TWO statements are TRUE?
  • A. physt2 will no longer receive redo if physt1 becomes unavailable, unless LOG_ARCHIVE_DEST_n has the ALTERNATE attribute specified on the primary database.
  • B. The sequence is usable on physt2 if physt1 becomes unavailable, but only if an alternate redo destination has been configured on the primary database.
  • C. The sequence is usable on physt1 but not usable on physt2.
  • D. The sequence is usable on physt1 and physt2.
  • E. physt2 will no longer receive redo if physt1 becomes unavailable, unless LOG_ARCHIVE_DEST_n has the ALTERNATE attribute specified on physt1.
NEW QUESTION # 31
Examine the Data Guard configuration:
What happens if you issue "switchover to sheep;" at the DGMGRL prompt?
  • A. The switchover succeeds but Dogs needs to be reinstated.
  • B. The switchover succeeds and Dogs becomes the new failover target.
  • C. The switchover succeeds and Fast-Start Failover is suspended.
  • D. It results in an error indicating that a switchover is not allowed.
  • E. The switchover succeeds and Cats becomes the new failover target.
When issuing a "switchover to sheep;" command in a Data Guard configuration, the primary database (Dogs) transitions to a standby role, and the target standby database (Sheep) becomes the new primary database. Fast-Start Failover (FSFO) remains enabled, but its target changes according to the new roles of the databases. Since Cats is also a physical standby database, it does not become the failover target by default unless it is specified in the broker configuration. After the switchover, the original primary (Dogs) becomes the new standby database and thus the new failover target for FSFO.
Oracle Data Guard Broker documentation provides detailed procedures and explanations of switchover operations, including how FSFO targets are affected post-switchover. This behavior is consistent across different Oracle Database versions that support Data Guard and FSFO.
NEW QUESTION # 32
Which TWO are TRUE about offloading backups to a physical standby database in a Data Guard environment?
  • A. Backups of the standby control file taken while connected to the catalog where the database is registered, may be used to restore the control file on the primary database.
  • B. The standby database can not be registered in an RMAN catalog if the primary database has not been registered.
  • C. The standby database must be registered in an RMAN catalog before the primary database has been registered.
  • D. The standby database must be registered in an RMAN catalog after the primary database has been registered.
In a Data Guard environment, offloading backups to a physical standby database has certain requirements:
A: Once the primary database is registered in an RMAN catalog, the standby database can also be registered. This allows RMAN to manage backups coherently across both databases and leverage the standby database for backup purposes without interfering with the primary database's workload.
C: Backups of the standby control file taken while connected to the catalog where the database is registered can be used to restore the control file on the primary database. This ensures that backup metadata is consistent across the Data Guard configuration.
Options B and D are incorrect because there is no strict requirement for the order in which the primary and standby databases must be registered in an RMAN catalog. However, it is a common practice to register the primary database first.
NEW QUESTION # 33
Without practice, you cannot crack the 1z0-076 exam. PDFDumps facilitates you in this purpose with its desktop Oracle 1z0-076 practice exam software. It helps you get practical experience with the final 1z0-076 Exam. By practicing under real Oracle Database 19c: Data Guard Administration (1z0-076) exam situations again and again, you develop confidence and skills to attempt the 1z0-076 exam within its allocated time.
1z0-076 Test Passing Score: https://www.pdfdumps.com/1z0-076-valid-exam.html
P.S. Free & New 1z0-076 dumps are available on Google Drive shared by PDFDumps: https://drive.google.com/open?id=1XkUPNy4AIvYMIWw1k9sNHcheUaYntMnu
