Cisco 300-425 Test Pdf, Customized 300-425 Lab Simulation
102
Posted at 2/21/2026 08:26:29      View:95 | Replies:0        Print      Only Author   [Copy Link] 1#
2026 Latest Itcertking 300-425 PDF Dumps and 300-425 Exam Engine Free Share: https://drive.google.com/open?id=1xtIqwNWWKEP0O2As6pe9iUWCX4B5hRF_
Our 300-425 exam guide are not only rich and varied in test questions, but also of high quality. A very high hit rate gives you a good chance of passing the final 300-425 exam. According to past statistics, 98 % - 99 % of the users who have used our 300-425 Study Materials can pass the exam successfully. So without doubt, you will be our nest passer as well as long as you buy our 300-425practice braindumps.
Certification in Cisco 300-425 provides many benefits to network engineers and architects. Designing Cisco Enterprise Wireless Networks certification validates their knowledge and skills in designing and deploying Cisco Enterprise Wireless Networks, which can help them advance their careers and increase their earning potential. Additionally, certification holders can demonstrate their ability to manage and troubleshoot wireless networks, which can help them gain the trust and respect of their peers and employers. Ultimately, certification in Cisco 300-425 is a valuable credential for anyone who works with wireless technologies and wants to demonstrate their expertise in this area.
Customized 300-425 Lab Simulation & Exam 300-425 ForumThe quality of our Cisco 300-425 training material is excellent. After all, we have undergone about ten years' development. Never has our practice test let customers down. Although we also face many challenges and troubles, our company get over them successfully. If you are determined to learn some useful skills, our Cisco 300-425 Real Dumps will be your good assistant. Then you will seize the good chance rather than others.
Cisco Designing Cisco Enterprise Wireless Networks Sample Questions (Q174-Q179):NEW QUESTION # 174
An engineer is designing a wireless network to support Cisco Hyperlocation. The customer indicated some How is the design adjusted?
  • A. Add more APs than indicated from the site survey spread across all areas.
  • B. Run the site survey using -57d Bm as a threshold.
  • C. Add an additional AP in the middle of the dense area.
  • D. Add additional APs to all the comers of the site.
Cisco Hyperlocation requires a dense deployment of access points for accurate location tracking.
Adding more APs than a standard site survey suggests can meet the granular location requirements needed for Hyperlocation services.
NEW QUESTION # 175
A warehouse has metal shelving that reflects RF signals. Which antenna strategy is best?
  • A. Low-gain directional antennas mounted on the aisles
  • B. APs installed randomly throughout the warehouse
  • C. High-gain Yagi antennas pointing across shelves
  • D. Ceiling-mounted omni-directional antennas only
NEW QUESTION # 176
An engineer must produce a passive survey report. The coverage heat map shows the entire site with all signal levels. To see only the desired coverage, which action must the engineer take?
  • A. Use the RSSI slider to set the heat map to the desired cutoff lter.
  • B. Use the RSSI calibration tool to configure the receiver sensitivity.
  • C. Change the color scheme to show the desired heat map.
  • D. Filter the results to show the desired APs only.
To focus the coverage heat map on the desired coverage, the engineer should use the RSSI slider to set the heat map to the desired cutoff filter. This action will adjust the display to show only the signal levels that meet or exceed the specified RSSI value, effectively filtering out weaker signals and highlighting areas with sufficient coverage. Reference: Designing Cisco Enterprise Wireless Networks (ENWLSD 300-425)
NEW QUESTION # 177
Refer to the exhibit. A WLC SSO pair is set up. Which failure scenario causes a split-brain scenario?
  • A. One distribution port on the active WLC is down.
  • B. VSL is down.
  • C. Two distribution ports on the active WLC are down.
  • D. RP is down.
NEW QUESTION # 178
Refer to the exhibit. An engineer determined that during a recent controller failure, some APs did not failover to their secondary controller based on the network design, which has sufficient licenses for all APs. The controllers are not in a mobility group but have A records for their hostnames in DNS. Which setting needs to be addressed?
  • A. The AP failover priority was not set high enough.
  • B. DNS hostnames are required to be FQDN.
  • C. The controllers must be in the same mobility group.
  • D. The secondary controller IP address is incorrect.
The question stated ENOUGH LICENSES, priority does not kick in.
NEW QUESTION # 179
The Designing Cisco Enterprise Wireless Networks (300-425) practice test software keeps track of each previous attempt and highlights the improvements with each attempt. The Designing Cisco Enterprise Wireless Networks (300-425) mock exam setup can be configured to a particular style and arrive at unique questions. Itcertking Cisco 300-425 practice exam software went through real-world testing with feedback from more than 90,000 global professionals before reaching its latest form. The Cisco 300-425 Exam Dumps are similar to real exam questions. Our Cisco 300-425 practice test software is suitable for computer users with a Windows operating system.
Customized 300-425 Lab Simulation: https://www.itcertking.com/300-425_exam.html
P.S. Free & New 300-425 dumps are available on Google Drive shared by Itcertking: https://drive.google.com/open?id=1xtIqwNWWKEP0O2As6pe9iUWCX4B5hRF_
