AWS-Solutions-Architect-Professional Reliable Dump & AWS-Solutions-Architect
Posted at 2/21/2026 08:54:56
View112
Replies0
DOWNLOAD the newest Fast2test AWS-Solutions-Architect-Professional PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1bnPSrpxLtcF14fQgakGMtjPz5E3ysoa2
In our software version of the AWS-Solutions-Architect-Professional exam dumps, the unique point is that you can take part in the practice test before the real AWS-Solutions-Architect-Professional exam. You never know what you can get till you try. It is universally acknowledged that mock examination is of great significance for those who are preparing for the exam since candidates can find deficiencies of their knowledge as well as their shortcomings in the practice test, so that they can enrich their knowledge before the Real AWS-Solutions-Architect-Professional Exam.
The AWS Certified Solutions Architect - Professional certification exam offered by Amazon is an advanced-level exam designed for professionals who are looking to enhance their skills and knowledge in the field of cloud computing. AWS-Solutions-Architect-Professional Exam is intended for individuals who have already gained basic knowledge of AWS services and are looking to take their expertise to the next level.
Amazon AWS-Solutions-Architect-Professional Training Questions, AWS-Solutions-Architect-Professional New QuestionsIn the PDF version, real AWS-Solutions-Architect-Professional exam questions are available. These Amazon AWS-Solutions-Architect-Professional real questions are printable and portable. You can take this PDF document anywhere and study for the AWS Certified Solutions Architect - Professional (AWS-Solutions-Architect-Professional) exam without time restrictions. Fast2test regularly make changes in the AWS-Solutions-Architect-Professional PDF format when required. AWS-Solutions-Architect-Professional questions in this format are relevant to the actual test.
Amazon AWS Certified Solutions Architect - Professional Sample Questions (Q325-Q330):NEW QUESTION # 325
A solutions architect is designing a web application on AWS that requires 99.99% availability. The application will consist of a three-tier architecture that supports 300.000 web requests each minute when experiencing peak traffic. The application will use Amazon Route 53 for DNS resolution. Amazon CloudFront as the content delivery network (CDN), an Elastic Load Balancer far load balancing. Amazon EC2 Auto Scaling groups to scale the application tier, and Amazon Aurora MySQL as the backend database.
The backend database load will average 90% reads and 10% writes. The company wants to build a cost-effective solution, but reliability is critical.
Which set of strategies should the solutions architect use?
- A. Build the application in a single AWS Region. Deploy the EC2 application layer to two Availability Zones using an Auto Scaling group with a minimum desired capacity sufficient to process 300.000 requests each minute. Use a Multi-AZ Amazon Aurora MySQL DB cluster with one Aurora Replica.
The Aurora Replica must have enough capacity to support 50% of the peak read and write queries. - B. Build the application in two AWS Regions Deploy the EC2 application layer to two Availability Zones using an Auto Scaling group with dynamic scaling based on the request metrics in each Region. In the second Region, deploy an Amazon Aurora MySQL cross-Region replica. Use Amazon Route 53 to distribute traffic between Regions and configure failover if a Region becomes unavailable.
- C. Build the application in a single AWS Region. Deploy the EC2 application layer to three Availably Zones using an Auto Scaling group with dynamic scaling based on request metrics. Use a Multi-AZ Amazon Aurora MySQL DB duster with two Aurora Replicas. Each Aurora Replica must have enough capacity to support 50% of the peak read queries.
- D. Build the application in a single AWS Region. Deploy the EC2 application layer to three Availability Zones using an Auto Scaling group with a minimum desired capacity sufficient to process 450.000 requests each minute. Use a Multi-AZ Amazon Aurora MySQL DB duster with two Aurora Replicas.
Each Aurora Replica must have enough capacity to support 100% of the peak read queries.
NEW QUESTION # 326
A company runs a serverless application in a single AWS Region. The application accesses external URLs and extracts metadata from those sites. The company uses an Amazon Simple Notification Service (Amazon SNS) topic to publish URLs to an Amazon Simple Queue Service (Amazon SQS) queue An AWS Lambda function uses the queue as an event source and processes the URLs from the queue Results are saved to an Amazon S3 bucket The company wants to process each URL other Regions to compare possible differences in site localization URLs must be published from the existing Region. Results must be written to the existing S3 bucket in the current Region.
Which combination of changes will produce multi-Region deployment that meets these requirements? (Select TWO.)
- A. Subscribe the SNS topic in each Region to the SQS queue.
- B. Subscribe the SQS queue in each Region to the SNS topics in each Region.
- C. Deploy the SNS topic and the Lambda function to other Regions.
- D. Configure the SQS queue to publish URLs to SNS topics in each Region.
- E. Deploy the SOS queue with the Lambda function to other Regions.
NEW QUESTION # 327
How can multiple compute resources be used on the same pipeline in AWS Data Pipeline?
- A. You cannot use multiple compute resources on the same pipeline.
- B. You can use multiple compute resources on the same pipeline by defining multiple cluster objects in
your definition file and associating the cluster to use for each activity via its runsOn field. - C. You can use multiple compute resources on the same pipeline by defining multiple clusters for your
activity. - D. You can use multiple compute resources on the same pipeline by defining multiple cluster definition
files.
Multiple compute resources can be used on the same pipeline in AWS Data Pipeline by defining multiple
cluster objects in your definition file and associating the cluster to use for each activity via its runsOn field,
which allows pipelines to combine AWS and on-premise resources, or to use a mix of instance types for
their activities.
Reference: https://aws.amazon.com/datapipeline/faqs/
NEW QUESTION # 328
An Auto Scaling group is running at the desired capacity of 5 instances and receives a trigger from the Cloudwatch Alarm to increase the capacity by 1. The cool down period is 5 minutes. Cloudwatch sends another trigger after 2 minutes to decrease the desired capacity by 1.
What will be the count of instances at the end of 4 minutes?
The cool down period is the time difference between the end of one scaling activity (can be start or terminate) and the start of another one (can be start or terminate). During the cool down period, Auto Scaling does not allow the desired capacity of the Auto Scaling group to be changed by any other CloudWatch alarm. Thus, in this case the trigger from the second alarm will have no effect.
http://docs.aws.amazon.com/AutoS ... ts.html#healthcheck
NEW QUESTION # 329
A software development company has multiple engineers who are working remotely. The company is running Active Directory Domain Services (AD DS) on an Amazon EC2 instance. The company's security policy states that all internal, nonpublic services that are deployed in a VPC must be accessible through a VPN. Multi-factor authentication (MFA) must be used for access to a VPN.
What should a solutions architect do to meet these requirements?
- A. Create an AWS Site-to-Site VPN connection. Configure integration between a VPN and AD DS. Use an Amazon Workspaces client with MFA support enabled to establish a VPN connection.
- B. Create multiple AWS Site-to-Site VPN connections by using AWS VPN CloudHub. Configure integration between AWS VPN CloudHub and AD DS. Use AWS Copilot to establish a VPN connection.
- C. Create an Amazon WorkLink endpoint. Configure integration between Amazon WorkLink and AD DS. Enable MFA in Amazon WorkLink. Use AWS Client VPN to establish a VPN connection.
- D. Create an AWS Client VPN endpoint. Create an AD Connector directory for integration with AD DS.
Enable MFA for AD Connector. Use AWS Client VPN to establish a VPN connection.
NEW QUESTION # 330
This AWS-Solutions-Architect-Professional exam helps you put your career on the right track and you can achieve your career goals in the rapidly evolving field of technology. To gain all these personal and professional benefits you just need to pass the Prepare for your AWS-Solutions-Architect-Professional exam which is hard to pass. However, with proper Amazon AWS-Solutions-Architect-Professional Exam Preparation and planning you can achieve this task easily. For quick and complete AWS-Solutions-Architect-Professional exam preparation you can trust Fast2test Prepare for your AWS-Solutions-Architect-Professional Questions.
AWS-Solutions-Architect-Professional Training Questions: https://www.fast2test.com/AWS-Solutions-Architect-Professional-premium-file.html
- Marvelous Amazon AWS-Solutions-Architect-Professional Reliable Dump Are Leading Materials - Verified AWS-Solutions-Architect-Professional: AWS Certified Solutions Architect - Professional 🧜 Copy URL ▷ [url]www.pdfdumps.com ◁ open and search for AWS-Solutions-Architect-Professional to download for free 🐌AWS-Solutions-Architect-Professional Exam Overviews[/url]
- AWS-Solutions-Architect-Professional Practice Guide 🤳 AWS-Solutions-Architect-Professional Trustworthy Exam Torrent 🈺 AWS-Solutions-Architect-Professional Valid Test Questions ⬆ Go to website ⮆ [url]www.pdfvce.com ⮄ open and search for AWS-Solutions-Architect-Professional to download for free ✈AWS-Solutions-Architect-Professional Trustworthy Exam Torrent[/url]
- 100% Pass 2026 Amazon AWS-Solutions-Architect-Professional: AWS Certified Solutions Architect - Professional Perfect Reliable Dump 👛 Search for ▷ AWS-Solutions-Architect-Professional ◁ and download it for free on [url]www.dumpsquestion.com website 🎥AWS-Solutions-Architect-Professional Test Collection[/url]
- Amazon's Exam Questions for AWS-Solutions-Architect-Professional Help You Achieve Success in Your First Attempt 🌉 The page for free download of AWS-Solutions-Architect-Professional on ⏩ [url]www.pdfvce.com ⏪ will open immediately 😙AWS-Solutions-Architect-Professional Trustworthy Exam Torrent[/url]
- AWS-Solutions-Architect-Professional Test Collection 🌅 Practice Test AWS-Solutions-Architect-Professional Pdf 🦼 Exam AWS-Solutions-Architect-Professional Online 🚻 The page for free download of ▶ AWS-Solutions-Architect-Professional ◀ on ➥ [url]www.troytecdumps.com 🡄 will open immediately 🧱AWS-Solutions-Architect-Professional Exam Overviews[/url]
- Amazon's Exam Questions for AWS-Solutions-Architect-Professional Help You Achieve Success in Your First Attempt 🙃 Search for ➽ AWS-Solutions-Architect-Professional 🢪 and download it for free immediately on ➥ [url]www.pdfvce.com 🡄 ⓂAWS-Solutions-Architect-Professional Exam Lab Questions[/url]
- 100% Pass 2026 Amazon AWS-Solutions-Architect-Professional: AWS Certified Solutions Architect - Professional Perfect Reliable Dump 🛷 Search for AWS-Solutions-Architect-Professional on ➠ [url]www.easy4engine.com 🠰 immediately to obtain a free download 🌆AWS-Solutions-Architect-Professional Lead2pass[/url]
- Newest AWS-Solutions-Architect-Professional Reliable Dump - How to Download for AWS-Solutions-Architect-Professional Training Questions Free of Charge ↩ The page for free download of ➠ AWS-Solutions-Architect-Professional 🠰 on { [url]www.pdfvce.com } will open immediately 🚾Reliable AWS-Solutions-Architect-Professional Test Braindumps[/url]
- Desktop Amazon AWS-Solutions-Architect-Professional Practice Exam Software 🤨 Search for AWS-Solutions-Architect-Professional and easily obtain a free download on ➥ [url]www.troytecdumps.com 🡄 👹AWS-Solutions-Architect-Professional Valid Exam Sample[/url]
- AWS-Solutions-Architect-Professional Reliable Dump - Free PDF Quiz AWS-Solutions-Architect-Professional - AWS Certified Solutions Architect - Professional CFirst-grade Training Questions 🔍 Search for ➠ AWS-Solutions-Architect-Professional 🠰 and download it for free immediately on ☀ [url]www.pdfvce.com ️☀️ 🧡New AWS-Solutions-Architect-Professional Braindumps Questions[/url]
- Marvelous Amazon AWS-Solutions-Architect-Professional Reliable Dump Are Leading Materials - Verified AWS-Solutions-Architect-Professional: AWS Certified Solutions Architect - Professional 🍰 ▛ [url]www.prepawayexam.com ▟ is best website to obtain ⮆ AWS-Solutions-Architect-Professional ⮄ for free download 🎂AWS-Solutions-Architect-Professional Current Exam Content[/url]
- www.stes.tyc.edu.tw, samerawad.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, academy.dfautomation.com, Disposable vapes
2026 Latest Fast2test AWS-Solutions-Architect-Professional PDF Dumps and AWS-Solutions-Architect-Professional Exam Engine Free Share: https://drive.google.com/open?id=1bnPSrpxLtcF14fQgakGMtjPz5E3ysoa2
