[General] Useful Amazon SAA-C03 Dumps - SAA-C03 Upgrade Dumps
106
【General】 Useful Amazon SAA-C03 Dumps - SAA-C03 Upgrade Dumps
Posted at 2/21/2026 10:14:21      View:121 | Replies:0        Print      Only Author   [Copy Link] 1#
P.S. Free & New SAA-C03 dumps are available on Google Drive shared by Pass4training: https://drive.google.com/open?id=117WIPwopvCxleayJL86IhvJOWTRMkBW7
Our AWS Certified Solutions Architect - Associate test torrent was designed by a lot of experts in different area. You will never worry about the quality and pass rate of our study materials, it has been helped thousands of candidates pass their exam successful and helped them find a good job. If you choose our SAA-C03 study torrent, we can promise that you will not miss any focus about your exam. There are three different versions to meet customers’ needs you can choose the version that is suitable for you to study. If you buy our AWS Certified Solutions Architect - Associate test torrent, you will have the opportunity to make good use of your scattered time to learn whether you are at home, in the company, at school, or at a metro station.
Amazon SAA-C03 exam is a certification exam that validates the technical expertise of individuals in designing and deploying scalable and fault-tolerant systems on AWS. SAA-C03 exam tests the candidate's knowledge of AWS services and their ability to design and deploy highly available, cost-effective, and scalable systems on AWS. Candidates who pass SAA-C03 exam will demonstrate their ability to design and deploy robust and scalable systems on AWS, which is highly valued by employers. To prepare for the exam, candidates should enroll in AWS training courses, read AWS documentation, and practice with AWS services.
Amazon SAA-C03 (Amazon AWS Certified Solutions Architect - Associate) Certification Exam is designed for IT professionals who want to establish their expertise in designing and deploying scalable, highly available, and fault-tolerant systems on Amazon Web Services (AWS) platform. SAA-C03 exam is intended for individuals who have experience working with AWS services and possess foundational knowledge of AWS cloud computing.
SAA-C03 Upgrade Dumps - Test SAA-C03 FreeOur SAA-C03 practice exams lower the likelihood of failing and are optimal for self-evaluation. You can access the web-based AWS Certified Solutions Architect - Associate (SAA-C03) practice exam online without having to install any software. All browsers and operating systems support our web-based SAA-C03 Practice Test. Every Windows computer supports our desktop Amazon SAA-C03 practice exam software, enabling you to prepare for the SAA-C03 test without an active internet connection. You can customize the time and types of these Amazon Questions.
Amazon AWS Certified Solutions Architect - Associate Sample Questions (Q702-Q707):NEW QUESTION # 702
A company has an on-premises MySQL database that handles transactional data. The company is migrating the database to the AWS Cloud. The migrated database must maintain compatibility with the company's applications that use the database. The migrated database also must scale automatically during periods of increased demand.
Which migration solution will meet these requirements?
  • A. Use AWS Database Migration Service (AWS DMS) to migrate the database to Amazon DynamoDB.Configure an Auto Scaling policy.
  • B. Migrate the database to Amazon Redshift by using the mysqldump utility. Turn on Auto Scaling for the Amazon Redshift cluster.
  • C. Use AWS Database Migration Service (AWS DMS) to migrate the database to Amazon Aurora. Turn on Aurora Auto Scaling.
  • D. Use native MySQL tools to migrate the database to Amazon RDS for MySQL. Configure elastic storage scaling.
To migrate a MySQL database to AWS with compatibility and scalability, Amazon Aurora is a suitable option. Aurora is compatible with MySQL and can scale automatically with Aurora Auto Scaling. AWS Database Migration Service (AWS DMS) can be used to migrate the database from on-premises to Aurora with minimal downtime.
What Is Amazon Aurora?
Using Amazon Aurora Auto Scaling with Aurora Replicas
What Is AWS Database Migration Service?
NEW QUESTION # 703
A company maintains a searchable repository of items on its website. The data is stored in an Amazon RDS for MySQL database table that contains more than 10 million rows The database has 2 TB of General Purpose SSD storage There are millions of updates against this data every day through the company's website The company has noticed that some insert operations are taking 10 seconds or longer The company has determined that the database storage performance is the problem Which solution addresses this performance issue?
  • A. Enable Multi-AZ RDS read replicas with MySQL native asynchronous replication.
  • B. Change the DB instance to a memory optimized instance class
  • C. Change the storage type to Provisioned IOPS SSD
  • D. Change the DB instance to a burstable performance instance class
https://aws.amazon.com/ebs/features/
"rovisioned IOPS volumes are backed by solid-state drives (SSDs) and are the highest performance EBS volumes designed for your critical, I/O intensive database applications. These volumes are ideal for both IOPS-intensive and throughput-intensive workloads that require extremely low latency."
NEW QUESTION # 704
A company has a VPC with multiple private subnets that host multiple applications. The applications must not be accessible to the internet. However, the applications need to access multiple AWS services. The applications must not use public IP addresses to access the AWS services.
  • A. Configure interface VPC endpoints for the required AWS services. Route traffic from the private subnets through the interface VPC endpoints.
  • B. Deploy internet gateways in each private subnet. Route traffic from the private subnets through the internet gateways.
  • C. Deploy a NAT gateway in each private subnet. Route traffic from the private subnets through the NAT gateways.
  • D. Set up an AWS Direct Connect connection between the private subnets. Route traffic from the private subnets through the Direct Connect connection.
AWS VPC endpoints (interface and gateway) allow private connectivity from VPC resources to AWS services without requiring public IP addresses or internet gateways. This ensures applications remain isolated in private subnets while securely accessing AWS services. NAT gateways (B) would allow internet access, which does not meet the security requirement. Internet gateways (C) directly expose traffic to the internet, which violates the isolation requirement. Direct Connect (D) connects on-premises environments to AWS but does not provide service access from private subnets. Therefore, option A - using interface VPC endpoints - is the correct solution.
* Amazon VPC User Guide - VPC endpoints (interface and gateway)
* AWS Well-Architected Framework - Security Pillar: Network isolation and private connectivity
NEW QUESTION # 705
[Design Secure Architectures]
A company is running a highly sensitive application on Amazon EC2 backed by an Amazon RDS database Compliance regulations mandate that all personally identifiable information (Pll) be encrypted at rest.
Which solution should a solutions architect recommend to meet this requirement with the LEAST amount of changes to the infrastructure?
  • A. Deploy AWS CloudHSM. generate encryption keys, and use the keys to encrypt database volumes.
  • B. Deploy AWS Certificate Manager to generate certificates Use the certificates to encrypt the database volume
  • C. Configure Amazon Elastic Block Store (Amazon EBS) encryption and Amazon RDS encryption with AWS Key Management Service (AWS KMS) keys to encrypt instance and database volumes.
  • D. Configure SSL encryption using AWS Key Management Service {AWS KMS) keys to encrypt database volumes.
EBS Encryption:
Default EBS Encryption: Can be enabled for new EBS volumes.
Use of AWS KMS: Specify AWS KMS keys to handle encryption and decryption of data transparently.
Amazon RDS Encryption:
RDS Encryption: Encrypts the underlying storage for RDS instances using AWS KMS.
Configuration: Enable encryption when creating the RDS instance or modify an existing instance to enable encryption.
Least Amount of Changes:
Both EBS and RDS support seamless encryption with AWS KMS, requiring minimal changes to the existing infrastructure.
Enables compliance with regulatory requirements without modifying the application.
Operational Efficiency: Using AWS KMS for both EBS and RDS ensures a consistent, managed approach to encryption, simplifying key management and enhancing security.
Amazon EBS Encryption
NEW QUESTION # 706
A company has a web server running on an Amazon EC2 instance in a public subnet with an Elastic IP address. The default security group is assigned to the EC2 instance. The default network ACL has been modified to block all traffic. A solutions architect needs to make the web server accessible from everywhere on port 443.
Which combination of steps will accomplish this task? (Choose two.)
  • A. Create a security group with a rule to allow TCP port 443 from source 0.0.0.0/0.
  • B. Update the network ACL to allow inbound TCP port 443 from source 0.0.0.0/0 and outbound TCP port 32768-65535 to destination 0.0.0.0/0.
  • C. Update the network ACL to allow inbound/outbound TCP port 443 from source 0.0.0.0/0 and to destination 0.0.0.0/0.
  • D. Create a security group with a rule to allow TCP port 443 to destination 0.0.0.0/0.
  • E. Update the network ACL to allow TCP port 443 from source 0.0.0.0/0.
Answer: A,E
The combination of steps that will accomplish the task of making the web server accessible from everywhere on port 443 is to create a security group with a rule to allow TCP port 443 from source 0.0.0.0/0 (A) and to update the network ACL to allow inbound TCP port 443 from source 0.0.0.0/0 (C). This will ensure that traffic to port 443 is allowed both at the security group level and at the network ACL level, which will make the web server accessible from everywhere on port 443.
NEW QUESTION # 707
There are three formats of Pass4training practice material. Anyone can try a free demo to assess the quality of our Amazon product before buying. The AWS Certified Solutions Architect - Associate (SAA-C03) PDF file of actual questions, web-based AWS Certified Solutions Architect - Associate practice exam, and desktop practice test are three formats of Pass4training. The SAA-C03 PDF Questions are printable which means you can do off-screen study.
SAA-C03 Upgrade Dumps: https://www.pass4training.com/SAA-C03-pass-exam-training.html
DOWNLOAD the newest Pass4training SAA-C03 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=117WIPwopvCxleayJL86IhvJOWTRMkBW7
